Исходники: Игра Ханойская башня |
4.9.2014, 8:59
Администратор Группа: Root Admin Сообщений: 6 282 Регистрация: 7.1.2006 Из: Красноярск Пользователь №: 1 |
Ханойская башня
Код 10 REM TOWERS 21-NOV-85 D.S.NUNN. 20 E$=CHR$(27) \ PRINT E$;"<";E$"(0";E$;")B";CHR$(15) 30 DIM A$(14),A(12),B(12),C(12) 40 PRINT E$;"[2J";E$;"[H" 50 PRINT E$;"[1;10H";E$;"#3TOWERS OF BABLE" 60 PRINT E$;"[2;10H";E$;"#4TOWERS OF BABLE" 70 GOSUB 1310 80 A$(1)="qqqqqqqqqqqqqqqqqqqqqqqq" 90 A$(2)=" qqqqqqqqqqqqqqqqqqqqqq " 100 A$(3)=" qqqqqqqqqqqqqqqqqqqq " 110 A$(4)=" qqqqqqqqqqqqqqqqqq " 120 A$(5)=" qqqqqqqqqqqqqqqq " 130 A$(6)=" qqqqqqqqqqqqqq " 140 A$(7)=" qqqqqqqqqqqq " 150 A$(8)=" qqqqqqqqqq " 160 A$(9)=" qqqqqqqq " 170 A$(10)=" qqqqqq " 180 A$(11)=" qqqq " 190 A$(12)=" qq " 200 A$(13)=" " 210 PRINT E$;"[5;5H";E$;"[0JHOW MANY LAYERS (3-12)"; 220 INPUT T 230 IF T>12 THEN 210 240 IF T<3 THEN 210 250 PRINT E$;"[2J" 260 FOR A=1 TO T 270 B$=STR$(20-A) 280 A(A)=A 290 PRINT E$;"[";B$;";1H";A$(A) 300 NEXT A 310 PRINT E$;"[21;5H";E$;"[0JMOVE"; 320 INPUT X$ 330 IF X$<"11" THEN 310 340 IF X$>"33" THEN 310 350 X=VAL(X$) 360 X1=INT(X/10) 370 X2=X-(X1*10) 380 IF X1>3 THEN 310 390 IF X1<1 THEN 310 400 IF X2>3 THEN 310 410 IF X2<1 THEN 310 420 ON X1 GOSUB 480,570,660 430 IF Z=1 THEN Z=0 \ GO TO 310 440 ON X2 GOSUB 750,850,950 450 M=M+1 \ PRINT E$;"[2;50HMOVES ";M 460 IF Z=2 THEN GO TO 1090 470 GO TO 310 480 FOR A=T TO 1 STEP -1 490 IF A(A)>0 THEN 520 500 NEXT A 510 PRINT CHR$(7); \ Z=1 \ RETURN 520 C=A(A) 530 B$=STR$(20-A) 540 PRINT E$;"[";B$;";1H";A$(13); 550 A(A)=0 560 RETURN 570 FOR A=T TO 1 STEP -1 580 IF B(A)>0 THEN 610 590 NEXT A 600 PRINT CHR$(7); \ Z=1 \ RETURN 610 C=B(A) 620 B$=STR$(20-A) 630 PRINT E$;"[";B$;";27H";A$(13); 640 B(A)=0 650 RETURN 660 FOR A=T TO 1 STEP -1 670 IF C(A)>0 THEN 700 680 NEXT A 690 PRINT CHR$(7); \ Z=1 \ RETURN 700 C=C(A) 710 B$=STR$(20-A) 720 PRINT E$;"[";B$;";54H";A$(13); 730 C(A)=0 740 RETURN 750 FOR B=1 TO T 760 IF A(B)=0 THEN 780 770 NEXT B 780 IF C>A(B-1) THEN 810 790 ON X1 GOSUB 750,850,950 800 RETURN 810 A(B)=C 820 B$=STR$(20-B) 830 PRINT E$;"[";B$;";1H";A$(C) 840 RETURN 850 FOR B=1 TO T 860 IF B(B)=0 THEN 880 870 NEXT B 880 IF C>B(B-1) THEN 910 890 ON X1 GOSUB 750,850,950 900 RETURN 910 B(B)=C 920 B$=STR$(20-B) 930 PRINT E$;"[";B$;";27H";A$(C) 940 RETURN 950 FOR B=1 TO T 960 IF C(B)=0 THEN 980 970 NEXT B 980 IF C>C(B-1) THEN 1010 990 ON X1 GOSUB 750,850,950 1000 RETURN 1010 C(B)=C 1020 B$=STR$(20-B) 1030 PRINT E$;"[";B$;";54H";A$(C) 1040 FOR F=1 TO T 1050 IF C(F)<>F THEN RETURN 1060 NEXT F 1070 Z=2 1080 RETURN 1090 FOR A=1 TO 5 \ PRINT CHR$(7); \ NEXT A 1100 PRINT E$;"[2J" 1110 PRINT E$;"[2;10H";E$;"#3CONGRATULATIONS" 1120 PRINT E$;"[3;10H";E$;"#4CONGRATULATIONS" 1130 PRINT E$;"[5;1HYOU MANAGED TO COMPLEATE THE TOWERS IN ONLY ";M;"MOVES" 1140 PRINT "THE BEST POSIBLE IS";2^T-1;"THIS PUTS YOU IN THE"; 1150 IF M-(2^T-1)=0 THEN PRINT " PERFECTIONEST CLASS" \ GO TO 1230 1160 IF M-(2^T-1)<5 THEN PRINT " EXPERT "; \ GO TO 1210 1170 IF M-(2^T-1)<20 THEN PRINT " AVERAGE "; \ GO TO 1210 1180 IF M-(2^T-1)<50 THEN PRINT " BEGINERS "; \ GO TO 1210 1190 IF M-(2^T-1)<100 THEN PRINT " DUMMIES "; \ GO TO 1210 1200 PRINT " NEAREST ASYLUM" \ GO TO 1220 1210 PRINT "CLASS" 1220 PRINT "YOU KNOW YOU COULD DO BETTER I RECOMEND THAT YOU TRY AGAIN" 1230 PRINT \ PRINT \ PRINT "WOULD YOU LIKE TO TRY AGAIN (Y\N) "; 1240 INPUT A$ 1250 IF A$="N" THEN 1520 1260 FOR A=1 TO 12 1270 A(A)=0 \ B(A)=0 \ C(A)=0 1280 NEXT A 1290 Z=0 \ M=0 1300 GO TO 40 1310 PRINT E$;"[5;5H WOULD YOU LIKE INSTRUCTIONS (Y/N) "; 1320 INPUT Q$ 1330 IF Q$="N" THEN RETURN 1340 PRINT E$;"[5;5H THE TOWERS OF BABLE ARE A SERIES OF DISKS DECREASING IN SIZE." 1350 PRINT " THE IDEA IS TO MOVE ALL OF THE DISKS FROM THE LEFT HAND SIDE" 1360 PRINT " TO THE RIGHT HAND SIDE. THERE ARE ONLY THREE PILES, AND YOU CAN" 1370 PRINT " NEVER PUT A LARGER DISK ON A SMALLER ONE." 1380 PRINT " I WILL KEEP TRACK OF HOW MANY MOVES IT TAKES YOU." 1390 PRINT 1400 PRINT " WHEN PROMPTED FOR THE 'MOVE' ENTER A TWO DIGIT NUMBER," 1410 PRINT " THE FIRST NUMBER IS THE IS WHERE YOU WANT THE DISK TO COME FROM," 1420 PRINT " AND THE SECOND IS WHERE IT WILL GO TO. I WILL NOT LET YOU PUT A" 1430 PRINT " LARGE DISK ON A SMALL ONE, I WILL JUST REPLACE IT WHERE IT CAME" 1440 PRINT " FROM. A MOVE OF '32' WILL PLACE THE TOP DISK FROM PILE THREE" 1450 PRINT " TO THE TOP DISK ON PILE TWO. WELL HAVE FUN AND DONT PULL ALL" 1460 PRINT " YOUR HAIR OUT." 1470 PRINT 1480 PRINT " I RECOMEND THAT BEGINERS TRY THREE TO FIVE DISKS TO START" 1490 PRINT " PUSH ENTER TO START"; 1500 INPUT Q$ 1510 RETURN 1520 PRINT CHR$(14); 1530 END -------------------- Живы будем - Не помрем !
Текстовая версия | Сейчас: 29.3.2024, 22:21 |
