> WEBDAV-клиенты, примеры работы с WEBDAV-сервером AZNET
сообщение 12.5.2020, 22:29
Консольный клиент DavUtils
Команды:
Usage: dav command [options] arguments...
Commands:
        list [-altdepcR] [-u <date>] <url>
        get [-pcRK] [-o <file>] [-u <date>] [-V <version>] <url>
        put [-pcR] [-k <key>] [-L <lock>] <url> <file...>
        mkdir [-pc] [-k <key>] [-L <lock>] <url> [file...]
        remove [-pc] [-L <lock>] <url> [file...]
        copy [-pcO] [-L <lock>] <url> <url>
        move [-pcO] [-L <lock>] <url> <url>
        rename [-pcO] [-L <lock>] <url> <name>
        export [-pc] [-o <file>] [-u <date>] <url>
        import [-pc] [-k <key>] [-L <lock>] <url> <file>
        get-property [-pcx] [-V <version>] [-n <uri>] <url> <property>
        set-property [-pcx] [-L <lock>] [-n <uri>] <url> <property> [value]
        remove-property [-pc] [-n <uri>] <url> <property>
        lock [-pc] [-T timeout] <url>
        unlock [-pc] [-L <lock>] <url>
        info [-pc] [-V <version>] <url>
        date [url]
Options:
        -k <key>    Key to use for encryption
        -p           Don't encrypt or decrypt files
        -c           Enable full encryption
        -R           Recursively do the operation for all children
        -K           Keep already present files
        -o <file>    Write output to file (use '-' for stdout)
        -u <date>    Get resources which are modified since the specified date
        -V <version> Download a specific version of a resource
        -a           show all files
        -l           print resources in long list format
        -t           print content type
        -d           order by last modified date
        -e           show extended flags
        -O           override resources
        -L <lock>    specificy lock token
        -T <sec>     timeout in seconds
        -n <uri>     specify namespace uri
        -x           xml property content
        -N           disable authentication prompt (all commands)
        -i           disable cert verification (all commands)
        -v           verbose output (all commands)
Advanced commands:
        versioncontrol list-versions checkout checkin uncheckout
Config commands:
        add-repository remove-repository list-repositories repository-url
        add-user remove-user edit-user list-users
        check-config
Instead of an url you can pass a repository name with an optional path:
        <repository>/path/
Примеры использования
получить каталог
dav list http://192.168.0.170/test/FORTR.DSK.F11
скачать файл
dav get http://192.168.0.164/test/10.td0
передать файл
dav put http://192.168.0.164/  10.td0
Скачать клиент
Ответов(1 - 4)
сообщение 13.5.2020, 14:52
Поддержка WEBDAV в Linux
Установка
# yum install davfs2
# mount -t davfs http://192.168.0.164/ /mnt/testdav/
# umount -t davfs  /mnt/testdav/
Данный клиент пока не поддерживается и может только читать файлы
на самом деле это странно тк используется таже библиотека Neon которая в NetBOX в FAR и где все летает.
сообщение 13.5.2020, 15:27
Поддержка WEBDAV в Windows
Монтирование
жмем ok
получаем:
сообщение 6.3.2021, 21:44
Настройка WEBDAV в FAR3
ALT+F1
Идем в NETBOX
ждем Shift+F4
создаем подключение по типу
можно указывать и DNS-имя и IP адрес нашего AZ-контроллера
далее сохраняем
и работаем
сообщение 15.9.2021, 1:43
Для подключения с телефона (Андроид)
ставим CX-проводник
создаем новое подключение
выбираем webdav
имя-пароль любые
готово:
Текстовая версия Сейчас: 18.9.2026, 18:06
