> Colors and formatting, ANSI/VT100 Control sequences
сообщение 31.12.2024, 0:36
# Bash tips: Colors and formatting (ANSI/VT100 Control sequences)
The **ANSI/VT100** terminals and terminal emulators are not just able to display black and white text ; they can display **colors** and formatted texts thanks to **escape sequences**. Those sequences are composed of the **Escape character** (often represented by "`^[`" or "` `") followed by some other characters: "` [`_FormatCode_`m`". In Bash, the ` ` character can be obtained with the following syntaxes: *
`\e`
`\033`
`\x1B`
_Examples:_
Code (Bash) Preview
echo -e "\e[31mHello World\e[0m"
Hello World
echo -e "\033[31mHello\e[0m World"
Hello World
_NOTE¹:_ The `-e` option of the `echo` command enable the parsing of the escape sequences. _NOTE²:_ The "`\e[0m`" sequence removes all attributes (formatting and colors). It can be a good idea to add it at the end of each colored text. wink.gif _NOTE³:_ The examples in this page are in **Bash** but the **ANSI/VT100** escape sequences can be used in every programming languages.
## Formatting
Here are the most commonly supported control sequences for formatting text. Their support depends on the used terminal ([see the compatibility list](https://misc.flogisoft.com/bash/tip_colors_and_formatting#terminals_compatibility "bash:tip_colors_and_formatting")).
### Set
Code Description Example Preview
1 Bold/Bright
echo -e "Normal \e[1mBold"
Normal Bold
2 Dim
echo -e "Normal \e[2mDim"
Normal Dim
4 Underlined
echo -e "Normal \e[4mUnderlined"
Normal Underlined
5 Blink 1)
echo -e "Normal \e[5mBlink"
Normal Blink
7 Reverse (invert the foreground and background colors)
echo -e "Normal \e[7minverted"
Normal inverted
8 Hidden (useful for passwords)
echo -e "Normal \e[8mHidden"
Normal Hidden
### Reset
0 Reset all attributes
echo -e "\e[0mNormal Text"
Normal Text
21 Reset bold/bright
echo -e "Normal \e[1mBold \e[21mNormal"
Normal Bold Normal
22 Reset dim
echo -e "Normal \e[2mDim \e[22mNormal"
Normal Dim Normal
24 Reset underlined
echo -e "Normal \e[4mUnderlined \e[24mNormal"
Normal Underlined Normal
25 Reset blink
echo -e "Normal \e[5mBlink \e[25mNormal"
Normal Blink Normal
27 Reset reverse
echo -e "Normal \e[7minverted \e[27mNormal"
Normal inverted Normal
28 Reset hidden
echo -e "Normal \e[8mHidden \e[28mNormal"
Normal Hidden Normal
## 8/16 Colors
The following colors works with most terminals and terminals emulators [2)](https://misc.flogisoft.com/bash/tip_colors_and_formatting#fn__2), [see the compatibility list](https://misc.flogisoft.com/bash/tip_colors_and_formatting#terminals_compatibility "bash:tip_colors_and_formatting") for more informations. _NOTE:_ The colors can vary depending of the terminal configuration.
### Foreground (text)
Code Color Example Preview
39 Default foreground color
echo -e "Default \e[39mDefault"
Default Default
30 Black
echo -e "Default \e[30mBlack"
Default Black
31 Red
echo -e "Default \e[31mRed"
Default Red
32 Green
echo -e "Default \e[32mGreen"
Default Green
33 Yellow
echo -e "Default \e[33mYellow"
Default Yellow
34 Blue
echo -e "Default \e[34mBlue"
Default Blue
35 Magenta
echo -e "Default \e[35mMagenta"
Default Magenta
36 Cyan
echo -e "Default \e[36mCyan"
Default Cyan
37 Light gray
echo -e "Default \e[37mLight gray"
Default Light gray
90 Dark gray
echo -e "Default \e[90mDark gray"
Default Dark gray
91 Light red
echo -e "Default \e[91mLight red"
Default Light red
92 Light green
echo -e "Default \e[92mLight green"
Default Light green
93 Light yellow
echo -e "Default \e[93mLight yellow"
Default Light yellow
94 Light blue
echo -e "Default \e[94mLight blue"
Default Light blue
95 Light magenta
echo -e "Default \e[95mLight magenta"
Default Light magenta
96 Light cyan
echo -e "Default \e[96mLight cyan"
Default Light cyan
97 White
echo -e "Default \e[97mWhite"
Default White
### Background
49 Default background color
echo -e "Default \e[49mDefault"
Default Default
40 Black
echo -e "Default \e[40mBlack"
Default Black
41 Red
echo -e "Default \e[41mRed"
Default Red
42 Green
echo -e "Default \e[42mGreen"
Default Green
43 Yellow
echo -e "Default \e[43mYellow"
Default Yellow
44 Blue
echo -e "Default \e[44mBlue"
Default Blue
45 Magenta
echo -e "Default \e[45mMagenta"
Default Magenta
46 Cyan
echo -e "Default \e[46mCyan"
Default Cyan
47 Light gray
echo -e "Default \e[47mLight gray"
Default Light gray
100 Dark gray
echo -e "Default \e[100mDark gray"
Default Dark gray
101 Light red
echo -e "Default \e[101mLight red"
Default Light red
102 Light green
echo -e "Default \e[102mLight green"
Default Light green
103 Light yellow
echo -e "Default \e[103mLight yellow"
104 Light blue
echo -e "Default \e[104mLight blue"
Default Light blue
105 Light magenta
echo -e "Default \e[105mLight magenta"
106 Light cyan
echo -e "Default \e[106mLight cyan"
Default Light cyan
107 White
echo -e "Default \e[107mWhite"
Default White
## 88/256 Colors
Some terminals ([see the compatibility list](https://misc.flogisoft.com/bash/tip_colors_and_formatting#terminals_compatibility "bash:tip_colors_and_formatting")) can support 88 or 256 colors. Here are the control sequences that permit you to use them. _NOTE¹_: The colors number `256` is only supported by **vte** (GNOME Terminal, XFCE4 Terminal, Nautilus Terminal, Terminator,…). _NOTE²_: The 88-colors terminals (like **rxvt**) does not have the same color map that the 256-colors terminals. For showing the 88-colors terminals color map, run the "[256-colors.sh](https://misc.flogisoft.com/bash/tip_colors_and_formatting#colors2 "bash:tip_colors_and_formatting")" script in a 88-colors terminal.
For using one of the 256 colors on the foreground (text color), the control sequence is "` [38;5;`_ColorNumber_`m`" where `ColorNumber` is one of the following colors: XTerm 256 color list (foreground)") _Examples:_
Code (Bash) Preview
echo -e "\e[38;5;82mHello \e[38;5;198mWorld"
Hello World
for i in {16..21} {21..16} ; do echo -en "\e[38;5;${i}m#\e[0m" ; done ; echo
Blue gradiant
### Background
For using one of the 256 colors on the background, the control sequence is "` [48;5;`_ColorNumber_`m`" where `ColorNumber` is one of the following colors: XTerm 256 color list (background)") _Examples:_
Code (Bash) Preview
echo -e "\e[40;38;5;82m Hello \e[30;48;5;82m World \e[0m"
Hello World
for i in {16..21} {21..16} ; do echo -en "\e[48;5;${i}m \e[0m" ; done ; echo
Blue gradiant
## Attributes combination
Terminals allow attribute combinations. The attributes must be separated by a semicolon ("`;`"). _Examples:_
Description Code (Bash) Preview
Bold + Underlined
echo -e "\e[1;4mBold and Underlined"
Bold and Underlined
Bold + Red forground + Green background
echo -e "\e[1;31;42m Yes it is awful \e[0m"
Yes it is awful
## Terminals compatibility
Terminal Formatting Colors Comment
Bold Dim Underlined Blink invert Hidden 8 16 88 256
[aTerm](http://www.afterstep.org/aterm.php "http://www.afterstep.org/aterm.php") ok - ok - ok - ok ~ - - Lighter background instead of blink.
[Eterm](http://www.eterm.org/ "http://www.eterm.org/") ~ - ok - ok - ok ~ - ok Lighter color instead of Bold. Lighter background instead of blink. Can overline a text with the "`^[``[6m`" sequence.
[GNOME Terminal](http://library.gnome.org/users/gnome-terminal/ "http://library.gnome.org/users/gnome-terminal/") ok ok ok ok ok ok ok ok - ok Strikeout with the "`^[``[9m`" sequence.
[Guake](http://guake.org/ "http://guake.org/") ok ok ok ok ok ok ok ok - ok Strikeout with the "`^[``[9m`" sequence.
[Konsole](http://konsole.kde.org/ "http://konsole.kde.org/") ok - ok ok ok - ok ok - ok
[Nautilus Terminal](https://github.com/flozz/nautilus-terminal "https://github.com/flozz/nautilus-terminal") ok ok ok ok ok ok ok ok - ok Strikeout with the "`^[``[9m`" sequence.
[rxvt](http://rxvt.sourceforge.net/ "http://rxvt.sourceforge.net/") ok - ok ~ ok - ok ok ok - If the background is not set to the default color, Blink make it lighter instead of blinking. Support of italic text with the "`^[``[3m`" sequence.
[Terminator](http://www.tenshu.net/terminator/ "http://www.tenshu.net/terminator/") ok ok ok - ok ok ok ok - ok Strikeout with the "`^[``[9m`" sequence.
[Tilda](http://tilda.sourceforge.net/tildaabout.php "http://tilda.sourceforge.net/tildaabout.php") ok - ok ok ok - ok ok - - Underline instead of Dim. Convert 256-colors in 16-colors.
[XFCE4 Terminal](http://www.xfce.org/projects/terminal "http://www.xfce.org/projects/terminal") ok ok ok ok ok ok ok ok - ok Strikeout with the "`^[``[9m`" sequence.
[XTerm](http://invisible-island.net/xterm/xterm.html "http://invisible-island.net/xterm/xterm.html") ok - ok ok ok ok ok ok - ok
xvt ok - ok - ok - - - - -
Linux TTY ok - - - ok - ok ~ - - Specials colors instead of Dim and Underlined. Lighter background instead of Blink, Bug with 88/256 colors.
[VTE Terminal](http://developer.gnome.org/vte/ "http://developer.gnome.org/vte/") [3)](https://misc.flogisoft.com/bash/tip_colors_and_formatting#fn__3) ok ok ok ok ok ok ok ok - ok Strikeout with the "`^[``[9m`" sequence.
_Notations used in the table:_ *
"`ok`": Supported by the terminal.
"`~`": Supported in a special way by the terminal.
"`-`": Not supported at all by the terminal.
## Demonstration programs ### Colors and formatting (16 colors)
Screenshot of the color_and_formatting.sh script The following shell script displays a lot of possible combination of the attributes (but not all, because it uses only one formatting attribute at a time).
[colors_and_formatting.sh](https://misc.flogisoft.com/_export/code/bash/tip_colors_and_formatting?codeblock=55 "Download Snippet")
#!/bin/bash
# This program is free software. It comes without any warranty, to
# the extent permitted by applicable law. You can redistribute it
# and/or modify it under the terms of the Do What The Fuck You Want
# To Public License, Version 2, as published by Sam Hocevar. See
# [http://sam.zoy.org/wtfpl/COPYING](http://sam.zoy.org/wtfpl/COPYING) for more details.
#Background
for clbg in {40..47} {100..107} 49 ; do
    #Foreground
    for clfg in {30..37} {90..97} 39 ; do
        #Formatting
        for attr in 0 1 2 4 5 7 ; do
            #Print the result
            echo -en "\e[${attr};${clbg};${clfg}m ^[${attr};${clbg};${clfg}m \e[0m"
        done
        echo #Newline
    done
done
exit 0
### 256 colors
Screenshot of the 256-colors.sh script The following script display the 256 colors available on some terminals and terminals emulators like **XTerm** and **GNOME Terminal**.
[256-colors.sh](https://misc.flogisoft.com/_export/code/bash/tip_colors_and_formatting?codeblock=56 "Download Snippet")
#!/bin/bash
for fgbg in 38 48 ; do # Foreground / Background
    for color in {0..255} ; do # Colors
        # Display the color
        printf "\e[${fgbg};5;%sm  %3s  \e[0m" $color $color
        # Display 6 colors per lines
        if [ $((($color + 1) % 6)) == 4 ] ; then
            echo # New line
        fi
    done
    echo # New line
done
exit 0
## Links
Текстовая версия Сейчас: 12.9.2026, 15:51
