> Запуск эмулятора Алексея Савельева, под NT/2k/2003/Vista
сообщение 29.1.2008, 23:52
Проблема запуска заключается в отсутствии expanded memory (EMS)
никакие танцы с EMM=RAM и прочие не помогает
Причина кроется в попытке винды использовать для этого BIOS машины
и если в машине много железок или BIOS это не поддерживает то получаем:
655360 bytes total conventional memory
655360 bytes available to MS-DOS
550624 largest executable program size
24117248 bytes total contiguous extended memory
0 bytes available contiguous extended memory
15580160 bytes available XMS memory
64Kb High Memory Area available
проблема неоднократно описана http://www.columbia.edu/~em36/wpdos/emsxp.html
A small percentage of Windows 2000-based and XP-based computers (including some popular Dell models, and models with advanced gaming-level graphics hardware) do not support Expanded (EMS) Memory even after you follow the procedures for enabling EMS described elsewhere on this site. On such machines, abbreviation-expander software like Smartype and PRD+ will not load and function correctly, and WPDOS 5.1 will have less memory to work with than it needs. With [i]some (probably not all) of these computers, you can enable EMS by making changes in the BIOS ("firmware") of your computer. The BIOS (Basic Input-Output System) settings are the hardware settings that control the way Windows works with your machine; the settings cannot be changed from inside Windows, but must be accessed, in the few seconds your system is first starting up, by pressing a key that opens up a special BIOS menu.[/i]
http://www.nfbr.org.uk/html/faq3.html#EMM
итд
Как же лечить ?
все просто !
есть EMS Magic :: LIM 4.0 Expanded Memory Emulator
Why Is It Needed?
In order to cut costs, newer motherboards feature a lot of integrated
devices. (LAN, RAID, SATA, etc.) The ROM for these devices is located in
the upper memory area (UMA), where the EMS page frame typically resides.
When EMM386 or the NTVDM EMM installs, it looks for a contiguous 64K block
of free space in the UMA for a page frame. If there is no room in the UMA
for a page frame, the EMM will not install and you have no EMS.
EMS Magic also tries to create a page frame in the UMA, but if there is no
space, it will create the page frame in conventional memory. This ensures
that all systems will have EMS support, at the expense of 64K conventional
memory.
EMS Magic also allows you to place the page frame manually. For example, if
you know you have space in the UMA for a page frame, but EMM386 or the NTVDM
EMM will not install, you can force EMS Magic to install with a page frame
at a set location in the UMA. (There must be RAM or unused UMBs at this
location.)
с ним картина меняется
D:\>mem
478032 largest executable program size
8388608 bytes total EMS memory
8388608 bytes free EMS memory
7176192 bytes available XMS memory
Сообщение отредактировал SuperMax - 23.11.2008, 18:41
сообщение 29.1.2008, 23:53
можно скачать
Прикрепленный файл  emsmagic10.exe ( 355.52 килобайт ) Кол-во скачиваний: 6764
Текстовая версия Сейчас: 4.10.2026, 7:29
