> Micro VAX 3100-80 3. Установка OpenVMS 7.3
сообщение 6.6.2015, 9:54
Берем дистрибутив OpenVMS 7.3 VAX
к примеру отсюда http://mirrors.pdp-11.ru/_vms/ftp.usa.hp.com/VAX/
нарезаем на CD и вставляем в привод VAXа
>>> sh conf
KA47-A V1.4-38D-V4.2
08-00-2B-3C-30-0B
40MB
DEVNBR    DEVNAM           INFO
     1         NVR    OK
     3          DZ    OK
     4       CACHE    OK
     5         MEM    OK
                      40MB = S0/1=8MB, S2/3=32MB, S4/5=0MB
     6         FPU    OK
     7          IT    OK
     8         SYS    OK
     9          NI    OK
    10        SCSI    OK
                      0-L0-ST15150 5-L0-MJ-5.16 5-L1-MJ-5.16 5-L2-MJ-5.16 5-L3-M
J-5.16 5-L4-MJ-5.16 6-INITR
    12        COMM    OK
                      DSW41/42 2 CHANNEL V4.52-b9
    14       ASYNC    OK
                      DHW41/2 V1.6
>>> sh dev
  VMS/VMB      ADDR      DEVTYPE    NUMBYTES     RM/FX    WP    DEVNAM      REV
  ESA0         08-00-2B-3C-30-0B
  DKA0         A/0/0     DISK         4.29GB      FX            ST15150     0023
  DKA500       A/5/0     RODISK     547.37MB      RM      WP    MJ-5.16     1.02
  DKA501       A/5/1     RODISK      ......       RM      WP    MJ-5.16     1.02
  DKA502       A/5/2     RODISK      ......       RM      WP    MJ-5.16     1.02
  DKA503       A/5/3     RODISK      ......       RM      WP    MJ-5.16     1.02
  DKA504       A/5/4     RODISK      ......       RM      WP    MJ-5.16     1.02
..HostID..    A/6       INITR
CD-ROM у нас крутой японский CD-CHANGER на 5 дисков ;-)
сразу видно в каком установлен диск дистрибутива
сообщение 6.6.2015, 21:24
Грузим систему
>>> boot dka0
-DKA0
%SYSBOOT-I-SYSBOOT Mapping the SYSDUMP.DMP on the System Disk
%SYSBOOT-I-SYSBOOT SYSDUMP.DMP on System Disk successfully mapped
%SYSBOOT-I-SYSBOOT Mapping PAGEFILE.SYS on the System Disk
%SYSBOOT-I-SYSBOOT SAVEDUMP parameter not set to protect the PAGEFILE.SYS
   OpenVMS (TM) VAX Version V7.3     Major version id = 1 Minor version id = 0
%DECnet-I-LOADED, network base image loaded, version = 05.0E.00
%DECnet-W-NOOPEN, could not open SYS$SYSROOT:[SYSEXE]NET$CONFIG.DAT
%WBM-I-WBMINFO Write Bitmap has successfully completed initialization.
$!  Copyright 2001 Compaq Computer Corporation.
%STDRV-I-STARTUP, OpenVMS startup begun at  5-JUN-2015 08:15:02.53
The OpenVMS VAX system is now executing the system startup procedure.
%SYSGEN-W-OPENIN, error opening SYS$COMMON:[SYSEXE]ZTDRIVER.EXE; as input
%SYSGEN-E-FNF, file not found
%RUN-S-PROC_ID, identification of created process is 00000204
%DCL-S-SPAWNED, process SYSTEM_1 spawned
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:31.18  %%%%%%%%%%%
Operator _AIKA$OPA0: has been enabled, username SYSTEM
%SET-I-NEWAUDSRV, identification of new audit server process is 0000020A
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:31.32  %%%%%%%%%%%
Operator status for operator _AIKA$OPA0:
CENTRAL, PRINTER, TAPES, DISKS, DEVICES, CARDS, NETWORK, CLUSTER, SECURITY,
LICENSE, OPER1, OPER2, OPER3, OPER4, OPER5, OPER6, OPER7, OPER8, OPER9, OPER10,
OPER11, OPER12
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:31.70  %%%%%%%%%%%
Logfile has been initialized by operator _AIKA$OPA0:
Logfile is AIKA::SYS$SYSROOT:[SYSMGR]OPERATOR.LOG;2
Operator status for operator AIKA::SYS$SYSROOT:[SYSMGR]OPERATOR.LOG;2
OPER11, OPER12
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:32.33  %%%%%%%%%%%
Message from user JOB_CONTROL on AIKA
%JBC-E-OPENERR, error opening SYS$COMMON:[SYSEXE]QMAN$MASTER.DAT;
-RMS-E-FNF, file not found
%LICENSE-F-EMTLDB, license database contains no license records
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:33.75  %%%%%%%%%%%
Message from user SYSTEM on AIKA
%SECSRV-E-NOPROXYDB, cannot find proxy database file NET$PROXY.DAT
%RMS-E-FNF, file not found
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:33.79  %%%%%%%%%%%
%SECSRV-I-CIACRECLUDB, security server created cluster intrusion database
Copyright 2000 Compaq Computer Corporation. All rights reserved.
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:33.80  %%%%%%%%%%%
%SECSRV-I-SERVERSTARTINGU, security server starting up
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:33.96  %%%%%%%%%%%
%SECSRV-I-CIASTARTINGUP, breakin detection and evasion processing now starting u
p
%NET$STARTUP-W-NONETCONFIG, this node has not been configured to run DECnet-Plus
for OpenVMS
        use SYS$MANAGER:NET$CONFIGURE.COM if you wish to configure DECnet
%NET$STARTUP-I-OPERSTATUS, DECnet-Plus for OpenVMS operational status is OFF
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:38.44  %%%%%%%%%%%
%LICENSE-E-NOAUTH, DEC VAX-VMS use is not authorized on this node
-LICENSE-F-NOLICENSE, no license is active for this software product
-LICENSE-I-SYSMGR, please see your system manager
Startup processing continuing...
%DECdtm-F-NODECnet, the TP_SERVER process was not started because either:
o  DECnet-Plus is not started or is not configured, or
o  The SYS$NODE_FULLNAME logical name is not defined
   This could be because when you installed DECnet-Plus and were prompted
   for the system's full name, you specified a local name instead of a
   DECdns or Domain name.
If you want to use DECdtm services, make sure that DECnet-Plus is started and
configured and that SYS$NODE_FULLNAME is defined, then use the following
command to start the TP_SERVER process:
    $ @SYS$STARTUP:DECDTM$STARTUP.COM
%STARTUP-I-AUDITCONTINUE, audit server initialization complete
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:15:40.98  %%%%%%%%%%%
Message from user AUDIT$SERVER on AIKA
Security alarm (SECURITY) and security audit (SECURITY) on AIKA, system id: 1777
Auditable event:          Audit server starting up
Event time:                5-JUN-2015 08:15:40.69
PID:                      00000203
Username:                 SYSTEM
The OpenVMS VAX system is now executing the site-specific startup commands.
%SET-I-INTSET, login interactive limit = 64, current interactive value = 0
  SYSTEM       job terminated at  5-JUN-2015 08:15:42.88
  Accounting information:
  Buffered I/O count:            1280         Peak working set size:    1760
  Direct I/O count:               568         Peak page file size:      5465
  Page faults:                   4501         Mounted volumes:             0
  Charged CPU time:           0 00:00:14.90   Elapsed time:     0 00:00:41.23
Welcome to OpenVMS (TM) VAX Operating System, Version V7.3
логонимся
Username: system
Password:
%LICENSE-I-NOLICENSE, no license is active for this software product
%LOGIN-S-LOGOPRCON, login allowed from OPA0:
    Last interactive login on Thursday,  4-JUN-2015 22:22
$ sh dev
Device                  Device           Error    Volume         Free  Trans Mnt
Name                   Status           Count     Label        Blocks Count Cnt
AIKA$DKA0:              Mounted              0  VMSSYS73       7809534   150   1
AIKA$DKA500:            Online wrtlck        0
Device                  Device           Error
Name                   Status           Count
FTA0:                   Offline              0
OPA0:                   Online               0
TTA1:                   Online               0
TTA2:                   Online               0
TTA3:                   Online               0
TXA0:                   Online               0
TXA1:                   Online               0
TXA2:                   Online               0
TXA3:                   Online               0
TXA4:                   Online               0
TXA5:                   Online               0
TXA6:                   Online               0
TXA7:                   Online               0
Device                  Device           Error
Name                   Status           Count
ESA0:                   Online               0
MPA0:                   Offline              0
PKA0:                   Online               0
Пришло время ввести лицензию на ОС
$ LICENSE REGISTER VAX-VMS -
_$ /ISSUER=DEC -
_$ /AUTHORIZATION=HOBBYIST-VA-KEY1234567890 -
_$ /PRODUCER=DEC -
_$ /UNITS=0 -
_$ /TERMINATION_DATE=NN-JUN-2016 -
_$ /ACTIVITY=CONSTANT=100 -
_$ /CHECKSUM=123456767890
а теперь шатдаун
$ shutdown
    SHUTDOWN -- Perform an Orderly System Shutdown
                on node AIKA
%SHUTDOWN-I-OPERATOR, this terminal is now an operator's console
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:28:39.04  %%%%%%%%%%%
OPER11, OPER12
%SHUTDOWN-I-DISLOGINS, interactive logins will now be disabled
%SET-I-INTSET, login interactive limit = 0, current interactive value = 1
%SHUTDOWN-I-STOPQUEUES, the queues on this node will now be stopped
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:28:40.01  %%%%%%%%%%%
SHUTDOWN message on AIKA from user SYSTEM at _AIKA$OPA0:   08:28:40
AIKA will shut down in 0 minutes; back up LATER.  Please log off node AIKA.
SHUTDOWN
%SHUTDOWN-I-STOPUSER, all user processes will now be stopped
1 terminal has been notified on AIKA.
%SHUTDOWN-I-STOPAUDIT, the security auditing subsystem will now be shut down
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:28:41.25  %%%%%%%%%%%
Auditable event:          Audit server shutting down
Event time:                5-JUN-2015 08:28:41.24
PID:                      0000020E
Username:                 SYSTEM
%SHUTDOWN-I-STOPSECSRV, the security server will now be shut down
%SHUTDOWN-I-REMOVE, all installed images will now be removed
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:28:42.51  %%%%%%%%%%%
%SECSRV-I-CIASHUTDOWN, breakin detection and evasion processing is shutting down
%SECSRV-I-PROXYSHUTDOWN, proxy processing is shutting down
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:28:43.09  %%%%%%%%%%%
%SECSRV-I-SERVERSHUTDOWN, security server shutting down
%SHUTDOWN-I-DISMOUNT, all volumes will now be dismounted
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:28:44.77  %%%%%%%%%%%
_AIKA$OPA0:, AIKA shutdown was requested by the operator.
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:28:44.82  %%%%%%%%%%%
Logfile was closed by operator _AIKA$OPA0:
Logfile was AIKA::SYS$SYSROOT:[SYSMGR]OPERATOR.LOG;2
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:28:44.87  %%%%%%%%%%%
Operator _AIKA$OPA0: has been disabled, username SYSTEM
    SYSTEM SHUTDOWN COMPLETE - use console to halt system
снова загрузка
>>> book t dka0
-DKA0
%STDRV-I-STARTUP, OpenVMS startup begun at  5-JUN-2015 08:30:03.11
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:30:31.78  %%%%%%%%%%%
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:30:31.91  %%%%%%%%%%%
OPER11, OPER12
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:30:32.25  %%%%%%%%%%%
Logfile is AIKA::SYS$SYSROOT:[SYSMGR]OPERATOR.LOG;3
Operator status for operator AIKA::SYS$SYSROOT:[SYSMGR]OPERATOR.LOG;3
OPER11, OPER12
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:30:32.85  %%%%%%%%%%%
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:30:32.86  %%%%%%%%%%%
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:30:34.19  %%%%%%%%%%%
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:30:34.24  %%%%%%%%%%%
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:30:34.42  %%%%%%%%%%%
%SECSRV-I-CIASTARTINGUP, breakin detection and evasion processing now starting up
%NET$STARTUP-W-NONETCONFIG, this node has not been configured to run DECnet-Plus for OpenVMS
%%%%%%%%%%%  OPCOM   5-JUN-2015 08:30:40.83  %%%%%%%%%%%
Event time:                5-JUN-2015 08:30:40.56
PID:                      00000203
Username:                 SYSTEM
  SYSTEM       job terminated at  5-JUN-2015 08:30:42.71
  Buffered I/O count:            1273         Peak working set size:    1746
  Page faults:                   4491         Mounted volumes:             0
  Charged CPU time:           0 00:00:14.74   Elapsed time:     0 00:00:40.47
Username: system
Password:
    Last interactive login on Friday,  5-JUN-2015 08:17
$ sh dev
AIKA$DKA0:              Mounted              0  VMSSYS73       7809498   149   1
Device                  Device           Error
Name                   Status           Count
FTA0:                   Offline              0
OPA0:                   Online               0
TTA1:                   Online               0
TTA2:                   Online               0
TTA3:                   Online               0
TXA0:                   Online               0
TXA1:                   Online               0
TXA2:                   Online               0
TXA3:                   Online               0
TXA4:                   Online               0
TXA5:                   Online               0
TXA6:                   Online               0
TXA7:                   Online               0
Device                  Device           Error
Name                   Status           Count
ESA0:                   Online               0
MPA0:                   Offline              0
PKA0:                   Online               0
Проверим лицензии
$ sh license
Active licenses on node AIKA:
------- Product ID --------    ---- Rating ----- -- Version --
Product            Producer    Units Avail Activ Version Release    Termination
VAX-VMS            DEC             0  0     100    0.0  (none)      30-JUN-2016
Начальная часть установки завершена
Текстовая версия Сейчас: 13.9.2026, 9:59
