19.5.2015, 8:19
Редкие фото из сети
Серия топовых серверов 8200 / 8400 начала выпускаться в 1994(?) могут иметь достаточно солидную начинку даже по нынешним временам -------------------- Живы будем - Не помрем !
7.9.2015, 18:04
Код Part Description: DEC Part V Vendor Part Number: C Number: _______________________________________________________________________ AC Input Box, 208V 30A 3-Phase 30-33798-01 AC Input Box, 416V 16A 3-Phase 30-33798-02 Adapter, 25-way EIA-232 to 6-way MMJ H8575-A Baffle Assy 70-29331-01 Backplane Assy * Need to order the Enclosure 70-30430-01 Battery, Real Time Clock used on E2062-xx 21-32423-01 Bezel, Floppy *RX26 74-48827-01 Bezel Assy, Main 70-29360-01 Cable, External Serial Console 17-01364-01 Cable, SCSI, Y-Adapter (BN39A-0G) * New style, replaces 17-03822-01 (BN21W-0B) 17-04454-01 Cable, IOP Hose *DWLAB, only needed with rev B02 Motherboard 17-03085-01 Cable, Power 48V LSB *Black 17-03118-01 Cable, Power 48V LSB *RED 17-03118-02 Card Cage/Backplane Assy *XMI plug-in unit assy 70-25882-01 Catch, R-Latch 74-42872-01 Cable Assembly, Coaxial Control 4.5ft. *DWLAA 4.5 Hose Cable 17-03085-02 CD-ROM Drive, 5.25 in. 600MB RRD46-AA Converter, DC-DC 48V to 5V 120A *XMI plug-in unit assy 30-36009-01 Converter, DC-DC 48V to Multi O/P 136W *XMI plug-in unit assy 30-36010-01 CPU, Dual Turbolaser 437MHz (KN7CE-AB) E2062-DA CPU, Dual (EV5/350MHz)* Dual CPU Module E2061-DA CPU, TurboLaser Uni-Processor EV5 350 MHz E2061-CA CPU, Dual (EV5.6/625MHz) *KN7CF-AB E2065-DA CPU, Dual EV6, 525Mhz KN7CG-AB CPU, Dual EV6.7 700MHz *As an Upgrade 3X-KN7CH-AB CPU, TurboLaser Dual, 4MB Cache, KN7CC-AB *Alpha 300MHz CPU E2056-DA CPU, TurboLaser Single, 4MB Cache, KN7CC-AA *300MHz CPU E2056-CA CPU, TurboLaser Uni-Processor, 437MHz KN7CE-AA E2062-CA Drive Assy, SCSI 1GB, 3.5in. RZ26L-VA Drive Assy, SCSI 2.0GB, 3.5in. RZ28-VA Diskette Drive, 2.88MB 3.5in. RX26-AA Door, Rear *CPU Cabinet 70-28584-01 Door, Front *CPU Cabinet 70-31071-01 DWLPA, PCIA Daughter Board 54-23470-01 DWLPA, PCIA Mother Board 54-23468-01 Enclosure, SCSI StorageWorks Shelf BA658-AA Fan, 48VDC w/Servo Control 12-35173-01 Fan, DWLPB Expansion Box 12-23609-19 FDDI, Twisted Pair Daughter Board 54-22501-01 FDDI, SAS Multi-mode Fiber Daughter 54-23835-01 Foam, Front Cab 74-43948-01 Foam, Side Cab 74-43947-01 Future Bus Plug-in Unit, 48VDC BA653-AA Graphics Console, Windows NT Subsystem KFE72-AA Header Card Assy (CIXCD) 54-20225-01 Key, Console 74-43945-01 Local Disk Converter *LDC 54-20868-01 Memory, 8MB SIMM *Used on MS7CC-BA, MS7CC-CA and MS7CC-UA 54-21724-01 Memory, 32MB SIMM *Used on MS7CC-DA, MS7CC-EA and MS7CC-UB 54-21726-01 Memory, 64MB SIMM *Used on MS7AA-FA and MS7CC-FA 54-21718-01 Memory, 128MB Option MS7CC-BA Memory, 256MB Option MS7CC-CA Memory, 512MB Option MS7CC-DA Memory, 1GB Option MS7CC-EA Memory, 2GB Option MS7CC-FA Memory, 4GB Option *Qty 36 54-24723-01 MS7CC-GA Memory, Motherboard 1GB Turbo-Laser E2035-AA Module, PCI to Memory Channel controller Single Port *CCMAA-BA Linecard V1.5 54-23663-02 Module, Beeper 54-23491-01 Module, Cabinet Control Logic (CCL) 54-20300-01 Module, Clock (75MHz), 300MHz TurboLaser 54-21728-05 Module, Clock (87MHz), 350MHz TurboLaser 54-21728-06 Module, Clock, 437MHz *used with E2062-CA (KN7CE) or E2062-DA (KN7CE) or E2065-DA(KN7CF) 54-24776-01 Module, Clock/Arbitration (XMI Backplane) T2030-YA Module, DWLPB PCIS Daughter 54-23470-02 Module, DWLPB PCIA Main *w/Memory Channel 54-24721-01 Module, EISA 2-Line Sync Comm (DNSES-AA) 54-23279-01 Module, EISA Pronet 4/16 Token Ring Adapter (DW300) 29-29555-01 PD 12-412520-00 Module,PCI-EISA Standard I/O, Network B2110-AA Module, FDDI/PCI DAS Adapter (DEFPA-DA) 54-22499-01 Module, FDDI/PCI SAS Adapter (DEFPA-AA) 54-22499-02 Module, FDDI/PMC SAS Adapter (DEFPZ) 54-22501-01 Module, FDDI/PCI UTP Adapter (DEFPA-UA) 54-22499-03 Module, Future Bus Bridge (DWLAA) B2003-AA Module, I/O Port (KFTIA-AA) *ITIOP E2054-AA Module, I/O TurboLaser (KFTHA-AA) E2052-AA Module, Interface LASER to XMI *Lamb T2028-AA Module, Memory Motherboard E2035-AA Module, Memory Motherboard *2GB E2036-AA Module, Turbo Laser Terminator E2034-AA Module, XMI to CI Adapter (CIXCD) T2080-YA Module, XMI to NI Controller (DEMNA-M) T2020-00 Module, XMI to SCSI (KZMSA) T2029-AB NVRAM Daughter Board w/Prestoserve DJ-ML300-BA Operator Control Panel *CPU Cabinet 54-20306-01 PCI Plug in Unit (PIU) *1st for Sys Cab DWLPB-BA PCI Plug in Unit (PIU) *2nd for Sys Cab, mounts in DWLPB-BA DWLPB-BA PCI Plug in Unit (PIU) *1st in Exp. Cab DWLPB-BA PCI Plug in Unit (PIU) *2nd in Exp. Cab mounts in DWLPB-BA DWLPB-BA Power Supply, 120VAC 30A 30-33796-01 Power Supply, 240VAC 16A 30-33796-02 Solid State Disk Drive (SSD), 205MB EF52R-AF Tape Drive, 8GB DAT TLZ07-VA Tape Drive, 20GB SCSI Single Ended TZ87-VA Trim Kit, Bottom, 800mm H9C02-UC -------------------- Живы будем - Не помрем !
SuperMax AlphaServer 8200 19.5.2015, 8:19
SuperMax [size=3][size=4]Документация AlphaServer 8400/8200... 19.5.2015, 8:24
SuperMax Еще различные фото из сети
AlphaServer PCI DRAWER... 19.5.2015, 8:49
SuperMax в 1999-2000ом
Alpha 8200 была достаточно быстрой м... 20.5.2015, 8:15
-------------------------------------------------... 21.5.2015, 15:00
SuperMax Наименования модулей и их параметры
[b]Alpha
E20... 15.6.2015, 14:02
SuperMax Alpha SRM Console for Alpha Microprocessor Motherb... 18.10.2015, 21:45![]() ![]() |
| Текстовая версия | Сейчас: 20.11.2026, 16:34 |
