30.12.2013, 11:32
Справочник по старым жестким дискам MFM RLL стандарта ST-506
_______________________________.rtf ( 415.58 килобайт )
Кол-во скачиваний: 3769-------------------- Живы будем - Не помрем !
10.9.2016, 17:22
NEC MFM D3142 42MB
Код Native| Translation ------+-----+-----+----- Form 3.5"/HH Cylinders 642| | | Capacity form/unform 44/ MB Heads 8| | | Seek time / track 25.0/ ms Sector/track 17| | | Controller MFM / ST506 Precompensation 128 Cache/Buffer KB Landing Zone 664 Data transfer rate 0.625 MB/S int Bytes/Sector 512 0.625 MB/S ext Recording method MFM operating | non-operating -------------+-------------- Supply voltage 5/12 V Temperature *C | Power: sleep W Humidity % | standby W Altitude km | idle W Shock g | seek W Rotation RPM read/write W Acoustic dBA spin-up W ECC Bit MTBF h 30000 Warranty Month Lift/Lock/Park NO Certificates ********************************************************************** L A Y O U T ********************************************************************** NEC MFM DISKS +---------------------------------------------------------+ | |XX | |XXJ2 | |XX | |XX | Terminator +-------+ |x J4 | Resistor | SW1 | | | ON/OFF Switch-------+ |XX | |XX | |XXJ1 | |XX | Drive Address-------+ |XX | Switch | SW2 | |XX | +-------+ |XX | |XX | | | |XXPower | |XXJ3 +---------------------------------------------------------+ ********************************************************************** J U M P E R S ********************************************************************** NEC MFM DISKS Jumper Settings =============== D512X, D5146 etc. ----------------- +-----------------+ | x . . . . . . . | ON | . x x x x x x x | OFF DS-1-2-3-4-------R-+ +-+-+-+ +------------- Radial Bit, Always set to OFF | +-------- Drive Select (set only one bit to ON) Terminator Res. +-----------------+ | x x x x x x x x |ON | . . . . . . . . |OFF Terminator ON, means active +-----------------+ D3126, D3142, D3146H, D51X6H etc. --------------------------------- SW2 +---------+ | x . . . | ON | . x x x | OFF DS-1-2-3-4-+ +-+-+-+ | +-------- Drive Select (set only one bit to ON) SW1 Terminator Res. +-----------------+ | . x x x x x x x |ON | x . . . . . . . |OFF Terminator ON, means active +-R---------------+ +------------------ Radial Bit, always set to OFF! Only the last drive on the cable must be terminated. J1 Connector for control signal interface J2 Connector for data signal interface J4 Frame Ground ********************************************************************** F E A T U R E S ********************************************************************** NEC MFM DISKS Installation Procedure ---------------------- Set the correct setup type and perform a low level format, in the most cases can the media defect list be entered in this step. If you cannot find a correct Setup Type (esp. for D3142) use either a lower cylinder count or special disk installation programms like DISK MANAGER from ONTRACK or SPEEDSTOR from STORAGE DIMENSIONS. Run under DOS FDISK and DOS FORMAT, the drive becomes bootable with the command: FORMAT C:/s. -------------------- Живы будем - Не помрем !
SuperMax Жесткие диски MFM RLL стандарта ST-506 30.12.2013, 11:32
SuperMax СМ5508 Производства Болгария
паспорт
3.9.2016, 22:02
SuperMax МС5401 производство СССР
Производство [b]Накопите... 3.9.2016, 22:03
SuperMax МС5406
Формуляр и схема
3.9.2016, 22:14![]() ![]() |
| Текстовая версия | Сейчас: 15.9.2026, 16:41 |
