> Оценка остаточного ресурса SSD
сообщение 23.8.2016, 11:40
Осенью 2014ого я поставил SSD PNY Prevail Elite SSD9SC240GEDA-PB 240 Гб
модель SSD2SC240G0LC726B104-297
на сервер базы данных (на котором крутится и этот форум в том числе)
Сейчас, те почти через 2 года я решил оценить остаточный ресурс данных SSD (они стоят у меня в программном зеркале MD )
Для начала я решил достать техподдержку PNY
ибо уж производитель должен знать как проверить их железку
Цитата
Good day, support!
I have 2 in the SSD of your production
Please help assess their residual resource
SMART printing an attachment
Dear Mr
Could you please explain what do you need to know from those SSD?
Sincerely.
Good day, tech-sup.
> Dear Mr
> Sincerely.
I use your SSD in the server database.
I want to evaluate the residual SSD resource for planning new purchases.
In an attachment listing S.M.A.R.T. these discs
Please help
Dear Mr
Im not sure to understand what do you need, could you please clarify.
Do you need to check if we have this SSD model on stock?
Sincerely.
Dear Mr
Thank you for clarifying the query.
The information regarding the maximum number of supported write cycles should be stored in the firmware, with no access for the S.M.A.R.T. ability.
I don't see how that technology would know how to compute the number of remaining write cycles before the SSD go to the read-only status. It would only read for how long the device has run, how many bytes have been read or written.
It is possible to get some data from S.M.A.R.T. reports such as those files you sent us. A big part of it is quite meaningless for the common mortal.
The other part is relevant, provided the viewing utility can clearly show it. Maybe you could use one such as CrystalDiskInfo? You will get for instance the number of total GBytes that have been written on a specific SSD. That number, divided by the capacity of the device, should provide the number of write cycles that have already been used.
Does this help?
сообщение 18.12.2023, 14:06
Сдохла и вторая SSD
вообще за это время я поменял уже несколько SSD и сформировал мнение об этом
Резюме:
- SSD хорошо, но бекапы лучше хранить на физических жестких дисках
- предсказать смерть SSD крайне сложно, SMART не показатель
- для длительного хранения информации без изменения SSD не годятся
Текстовая версия Сейчас: 6.7.2026, 6:44
