7.10.2006, 2:08
![]() Администратор ![]() ![]() ![]() ![]() ![]() Группа: Root Admin Сообщений: 6 381 Регистрация: 7.1.2006 Из: Красноярск Пользователь №: 1 |
E11.EXE is a beta test version of a full system emulator
for the PDP-11. It runs on any AT-class machine with an 80186 or better CPU, and requires around 350KB of free memory. It is intended to boot and run any PDP-11 operating system (it has been tested with RT-11 (all flavors), RSX-11M, RSTS/E, IAS, 2.9BSD UNIX, Fuzzball, and XXDP+; it seems to have some problems with VM under TSX+, and no attempt has been made to test DOS/BATCH, MUMPS, or any flavor of UNIX other than 2.9BSD; 2.11BSD will definitely not work due to its need for "cadillac" hardware). Emulated configuration: * PDP-11/34a CPU with selectable extensions * FP11A floating point processor * 248KB main memory * RL11/RL01-02 disk drives (up to 4) * RK611/RK06-07 disk drives (up to 8) * RX211/RX02 or RX11/RX01 8" floppy (using image files and/or 1.2MB floppies) * DL11 terminal ports; console and up to 15 others (VT100, and/or uses COM ports and/or LPT ports) * LP11 printer ports; up to 4 (same devices as DL11) * PC11 paper tape reader/punch (using files) * DELUA ethernet ports; up to 4 (using packet drivers) * KW11L line clock (50/60 Hz, settable) * display register (using special hardware) Скачать ERSATZ-11 PDP-11 SYSTEM SIMULATOR Сообщение отредактировал SuperMax - 11.10.2006, 20:30 -------------------- Живы будем - Не помрем !
SuperMax Ersatz-11 7.10.2006, 2:08
SuperMax Диски для эмуляторов
http://pdp-11.ru/mybk/pdp1... 7.10.2006, 2:10
SuperMax Мой рабочий комплект
скачать 7.10.2006, 2:24
Anonymous С Е11 приключилась не очень приятная история: при ... 28.6.2010, 21:53
SuperMax увы - у меня только антиквартиат ERSATZ-11 BETA VE... 16.7.2010, 14:55
Vamos Обновите пожалуйста ссылки на образы дисков. 21.8.2010, 1:50
SuperMax обновил - все скачивается 24.8.2010, 23:08![]() ![]() |
| Текстовая версия | Сейчас: 26.7.2026, 0:49 |
