20.10.2009, 15:38
Код .Mcall .Module .Module BCIRCL,Release=X02, Version=02, Comment=<BK0011 Circle Drawing> ; ; Copyright (c) 1986,1987 by ; C-11 Special Interest Group, Leningrad State University. ; All rights reserved. ; ; This software is furnished under a license and may be used and copied ; only in accordance with the terms of such license and with the ; inclusion of the above copyright notice. This software or any other ; copies thereof may not be provided or otherwise made available to any ; other person. No title to and ownership of the software is hereby ; transfered. ; ; The information in this software is subject to change without notice ; and should not be construed as a commitment by C-11 group. ; ; C-11 assumes no responsibility for the use or reliability of its ; software on equipment which is not submitted by C-11. ; .Include "BKHEAD" .Globl Point,Vector .Psect $CodOvr .SbTtl Circle Routine (Circle Drawing) ; ; This Routine draws the circle or circle arc with parameters specified. ; Routine Uses All the registers (R0..R5). ; Input parametres are in static memory area: ; ; $XC - X coordinate of arc center ; $YC - Y coordinate of arc center ; $RAD - circle or arc radius ; $BEG - Start angle ; $END - End angle ; $CX - X-Coordinate concise coeffitient ; $CY - Y-Coordinate concise coeffitient ; ;$BEG and $END - Integer number 0...77777 (Octal) ;0 -> 0 ;77777 -> 2*pi ; ;If number given less than <0, absolute value of parameter ;is angle, appropriate point of arc concatenated with arc center. ; ;$CX, $CY - 0..177777, If equal zero than no concise, else ; Real Coordinate X = X * $CX / 2 ** 16 ; Real Coordinate Y = Y * $CY / 2 ** 16 ; CIRCLE:: Clr $LB ; Clear LE and LB (Sign Flags) ClrB $LE Clr $INV Mov #BufOut,R0 ; Clear "BufOut" Buffer Mov #4,R1 10$: Clr (R0)+ Sob R1,10$ Mov $BEG,R1 ; Test initial angle Bpl 20$ Neg R1 ; Get absolute value IncB $LB ; and set flag 20$: Mov R1,-(SP) ; store initial angle Call Octet ; Compute octet and coordinate Mov R1,$$BEG ; Store initial coordinate Mov R5,R4 ; and octet No Mov $END,R1 ; Process ending point Bpl 30$ Neg R1 IncB $LE 30$: Mov R1,-(SP) ; Store End point Call Octet Mov R1,$$END ; Ending coordinate BisB #2,BufOut(R4) ; Mark begin Cmp R4,R5 ; End sector=Begin sector? Bne 40$ ; No... Cmp (SP)+,(SP)+ ; Compare End and Begin Coordinates Bgt 60$ ; End > Begin - normal direction Inc $INV ; Mark Inverse Direction Br 50$ 40$: Cmp (SP)+,(SP)+ ; Clear Stack 50$: Inc R4 ; Increase octet No Bic #^C7,R4 Cmp R4,R5 ; last octet? Beq 60$ ; Yes BisB #200,BufOut(R4) ; Set "Always write" Flag Br 50$ 60$: BisB #4,BufOut(R4) ; Set "Test the end" Flag .SbTtl Second part of Routine - Drawing proper ; ;Register are: ; R1- Relative X ; R2- Relative Y ; R5- Sector's Counter ; R0- D ; R3 and R4 are working ; Clr R1 ; X=0 Mov $RAD,R2 ; Y=R Mov R2,R0 Asl R0 Neg R0 Add #3,R0 ; D=3-2*R .SbTtl Main Loop of Drawing Algorithm 70$: Cmp R1,R2 Bgt 100$ ; If(X>Y) - Than Exit ; Else { Call DRAW8 ; Write eigth points of circle Tst R0 ; If D<0 Bge 80$ Mov R1,R3 ; Then D = D+4*X+6 Asl R3 Asl R3 Add #6,R3 Add R3,R0 Br 90$ 80$: Mov R1,R3 ; Else D = D+4*(X-Y)+10. Sub R2,R3 ;; X - Y Asl R3 Asl R3 Add #10.,R3 Add R3,R0 Dec R2 ; Y-- 90$: ;/* EndIf*/ Inc R1 ; X++ Br 70$ 100$: Return .SbTtl DRAW8 - Selective drawing of arc points ; ;Input: ;R1 - Relative X-coordinate of point ;R2 - Relative Y-coordinate of point ; ;This routine also uses $XC, $YC, $BEG, $END, $CX, $CY and Bufout Data ; DRAW8: Mov R0,-(SP) ;Save R0 Thru r2 Mov R1,-(SP) Mov R2,-(SP) Mov #7,R5 ;sektor No ; ;Sector's Loop ; 10$: Clr R4 ; Clear "Radius Drawing" flag Mov (SP),R2 ;Restore original Y Mov 2(SP),R1 ; and X Coordinates MovB BufOut(R5),R0 ;Test Flags for sector processing Beq 90$ ; == 0 --> skip this sector Bmi 30$ ; < 0 --> Draw All points Call @TTAB-2(R0) ; > 0 --> Check Cordinates Bcs 90$ ; Not draw this point 30$: Bit #2,R5 ; swap Coordinates ? Beq 40$ ; No... Mov R1,R3 Mov R2,R1 ; Swap(X,Y) Mov R3,R2 40$: Mov R5,-(SP) ; Store temporary Mov $CX,R3 ; X-Scaling Beq 50$ ; not used... Call CMul ; Used... 50$: Mov $CY,R3 ; Y-Scaling processing Beq 60$ Mov R1,-(SP) Mov R2,R1 Call CMul Mov R1,R2 Mov (SP)+,R1 60$: Mov (SP)+,R5 ; Restore Octet No MovB SIGS(R5),R0 ; Table of signs Bpl 70$ ; X-Sign Neg R1 ; is "-" 70$: AslB R0 ; Y-Sign Bpl 80$ ; "+" Neg R2 ; "-" 80$: Add $XC,R1 ; Get Absolute coordinates Add $YC,R2 ; .... Call Point ;Draw the point Tst R4 ;Radius Drawing? Beq 90$ ;No Mov $XC,R1 Mov $YC,R2 Call Vector ;Write Vector 90$: Dec R5 ;Goto the Next Octet Bpl 10$ Mov (SP)+,R2 ;All done, Restore registers and exit Mov (SP)+,R1 Mov (SP)+,R0 Return TTAB: .Word TBeg, TEnd, TAll ; ;Octet Signs Table ; SigS: .BYTE 100, 300, 300, 200; mask 200 - "-X" .BYTE 200, 0, 0, 100 ; mask 100 - "-Y" .Enabl LSB .SbTtl Points Testing ROutines TBEG: Mov $$BEG,R3 ; Bound Value Call TEST Bgt 20$ ; Not Draw Bne 10$ ; not at bound, Draw TstB $LB ; Initial Radius Drawing ? 15$: Beq 10$ ; No Inc R4 ; Yes, Mark... 10$: Tst (PC)+ 20$: SeC Return TEND: Mov $$END,R3 Call TEST BlT 20$ Bne 10$ TstB $LE Br 15$ TALL: Clr R0 Call TBEG Adc R0 Call TEND Adc R0 ;Now R0=0 Sub $INV,R0 Bgt 20$ Br 10$ TEST: Bit #1,R5 ; Sector Writting Direction Bne 30$ Cmp R1,R3 Return 30$: Cmp R3,R1 Return .Dsabl LSB .SbTtl Octet Computing Routine ; ; Input: ;R2 = Positive Angle value. ; Output: ;R5 = Octet No ;R1 = Initial coordinate of Octet @r5 ;R4 Not Changed. ;Uses MySin Routine ; Octet: Mov R1,R5 Bic #^C70000,R5 ;Octet No bits Bic R5,R1 ;R1 = internal octet angle Asr R5 ;111 000 000 000 00 Asr R5 ;111 000 000 000 0 Asr R5 ;111 000 000 000 Asr R5 ;111 000 000 00 Swab R5 ;111 Dec R5 Bic #^C7,R5 ;R5=Octet No Bit #1,R5 ;Internal Coordinate direction must be ;changed ? Bne 10$ ; No Neg R1 Add #7777,R1 10$: Call MySin ; R1=$RAD*Sin(R1/10000*Pi/4) Return .SbTtl Sine function approcsimation ; R1 = $RAD*Sin(R1/10000*Pi/4) where R1=0..7777 ; ; It's the simpliest realization - linear approcsimation used: ;R1=R1/10000*Sin(Pi/4) ; ;R4 and R5 are unchanged. ; SinPi4 = 132404 MySin: Mov R4,-(SP) Mov R5,R2 ;Save R4 and R5 Asl R1 Asl R1 Asl R1 Asl R1 ;Fix decimal point at the left of MSB Mov $Rad,R3 ;and Scale R1 Call CMul Mov #SinPi4,R3 ;Sin(Pi/4) Call CMul Mov R2,R5 ;Restore R5 Mov (SP)+,R4 ;and R4 Return .SbTtl CMul R1 to R3 Scaling procedure ; ;Computes R1=R1*R3/2**16 ; ;R0, R3, R4 and R5 are changed ; CMul: Mov R2,-(SP) Mov R1,R0 ;Multiplier Clr R1 Clr R2 Clr R5 10$: Ror R0 ;Shift out the following Bit (C == 0) Bcc 20$ Add R5,R1 ;Most significant part Add R3,R2 ;LSP Adc R1 20$: Asl R3 Rol R5 Tst R0 ;All Done? Bne 10$ ;No, Continue Mov (SP)+,R2 ;Restore R2 Return ;And Exit .Psect $Ram CrcBlk:: $XC: .BlkW ; X0 $YC: .BlkW ; Y0 $RAD: .BlkW ; radius $BEG: .BlkW ; Initial Main Coordinate $END: .BlkW ; Ending Main Coordinate $CX: .BlkW ; X-Scaling factor $CY: .BlkW ; Y-Scaling factor $$BEG: .BlkW ; $$END: .BlkW ; $INV: .BlkW ; $LB: .BlkB ; $LE: .BlkB ;Must be folow $LB BufOut: .BlkB 8. ;Circle definition table .Even .END -------------------- Живы будем - Не помрем !
SuperMax Исходники ПЗУ: Драйверный модуль БК-0011 20.10.2009, 15:38
SuperMax Архив 20.10.2009, 15:39![]() ![]() |
| Текстовая версия | Сейчас: 7.9.2026, 20:21 |
