23.1.2020, 12:25
DEC VS3100 specifications
Код DESCRIPTION The VAXstation 3100 is Digital's powerful, low-cost VAXstation for high- performance graphics applications. The VAXstation 3100 is a full member of the standard-setting VAX family of computers that has sold over 200,000 systems since the introduction of the VAX 11/780. Based on the second generation of VAX chipset technology, the VAXstation 3100 redefines low-end VAX computing by delivering three times the performance of previous entry-level VAXstation workstations. The VAXstation 3100 provides an integrated computing environment that offers you a unique combination of desktop VAX computing, industry-standard personal productivity tools, and transparent access to distributed applications and resources. Through DECwindows, Digital's new windowing interface, the VAXstation 3100 enables both sophisticated and novice users to access all the power of the network through their desktop applications. And the VAXstation 3100 workstation is easy to buy, easy to install, and easy to use. Featuring a versatile packaging design, the VAXstation 3100 can be configured as a diskless network node, a standalone workstation, or a system that can simultaneously be a workstation and a server for up to seven other VAXstation 3100 workstations. The VAXstation 3100 can be configured for a broad range of needs, running applications that provide solutions from the factory floor to the executive offices. FEATURES o Entry-level VAXstation maintains full VAX family compatibility while adding new power and features. Over 6,000 software applications immediately available (VAX terminal applications, VWS/UIS, X Window System, and DECwindows) plus access to industry-standard MS-DOS applications. o Compact, three-piece desktop package minimizes desktop footprint. Innovative packaging delivers full configuration flexibility - from diskless workstations up to 1.2 gigabytes of storage. o High-performance system design uses CMOS-based Central Processor/Floating Point and a two-level cache. Features large, internal memory expansion (8-32 Mbytes), Ethernet connectivity, and high-performance I/O subsystem. o Choice of 32-bit operating systems - VMS or ULTRIX. o Supports the VWS/UIS or DECwindows user interface, allowing for a natural migration as the DECwindows application base expands. o Introduces Desktop-VMS Software, a full function VMS operating system environment that greatly simplifies installation and system management of standalone and clustered VAXstation 3100 workstations. Interactive question and answer dialogue through DECwindows makes system management and installation easy. o Optional MS-DOS software coprocessor runs unmodified PC applications at IBM PC/AT speed. Cut and paste from MS-DOS applications into DECwindows applications is easy. o Small Computer System Interface (SCSI) allows external expansion of industry- available SCSI peripherals. HIGH-PERFORMANCE DESKTOP SYSTEM The VAXstation 3100 delivers 2.6 to 4.2 times the CPU performance of previous entry-level VAXstations by offering the same CMOS central processing unit found in Digital's MicroVAX 3500/3600 systems and VAXstation 3200/3500 workstations. The minimum configuration contains 8 Mbytes of memory and is expandable to 32 Mbytes. Each VAXstation 3100 system contains a single plane of 1024 x 864 video resolution, with an 8-plane graphics coprocessor available as an option. Both 15-inch and 19-inch monochrome and color monitors are available. The VAXstation 3100 offers you a choice of Digital's powerful 32-bit operating systems: VMS or ULTRIX. VMS is Digital's general-purpose, virtual-memory operating system that runs on all VAX systems, from the desktop to the datacenter. ULTRIX is Digital's native-mode UNIX operating system as well as the first POSIX-compliant operating system in the industry. In both environments, the common VAX architecture enables you to easily integrate the VAXstation 3100 with Digital's other workstations, MicroVAX systems, larger VAX systems, and VAXclusters. The VAXstation 3100 environment is further enhanced by Desktop-VMS Software. Based on DECwindows and compact disc drive technology, Desktop-VMS Software brings a new level of simplicity to the previously complicated tasks of installing and managing standalone workstations or connected groups of workstations. As distributed computing reaches into new areas of your organization, you face new system management requirements. Desktop-VMS Software enables individuals with minimal system management experience to effectively manage their own systems or workgroups, so more experienced systems personnel can focus on higher-level system management tasks. Multiple networking protocols are supported by both VMS and ULTRIX, so you can choose between TCP/IP and DECnet/OSI. You can create workgroups by using either VAXcluster software (VMS) or NFS (ULTRIX). Your ability to operate between the environments is further enhanced by the VMS-ULTRIX Connection product set, which adds NFS Server functions and TCP/IP to the VMS environment. DECWINDOWS With DECwindows running on your VAXstation 3100, you can enjoy the same advanced user interface regardless of the underlying operating system. Digital's DECwindows is a high-performance, network-transparent windowing system. It is a superset of the industry-standard X Window System Digital has implemented for the ULTRIX, VMS, and MS-DOS operating systems. Through DECwindows you can view the output from any X application running on the network, just as any X-compliant VAXstation 3100 application can be displayed on other systems that conform to the X standard. DECwindows uses Digital's X User Interface (XUI), ensuring a consistent look and feel that is independent of hardware platform or operating system. Standard applications delivered with DECwindows include mail and VT320 emulation (with ReGIS capability) as well as a number of other personal productivity applications. Digital also offers layered products (available separately) for the DECwindows environment that support compound document processing, graphics, and decision support. Many popular third-party applications are also available on the DECwindows platform. Your investment in current VMS VAXstation applications is protected because the VAXstation 3100 separately supports the VAX Workstation Software User Interface System (VWS/UIS). And investment protection continues with ULTRIX VAXstations because current applications will run without modification. MS-DOS COMPATIBILITY The power and performance of the VAXstation 3100 are complemented by the wealth of personal productivity applications available through VAXpc for VMS Software, an MS-DOS software coprocessor under DECwindows. VAXpc enables the VAXstation 3100 to emulate the instruction set of the Intel 80286 microprocessor. As a result, VAXpc windows on your workstation look and act exactly like they do on a personal computer. VAXpc gives you the ability to cut and paste from any industry-standard PC application into the DECwindows environment. VERSATILE CONFIGURATIONS The VAXstation 3100 is available in two compact desktop packages - the Model 30 and the Model 40. Each system offers equal computing power, memory expansion, and display capabilities, but differs in the amount of internal storage capacity. The VAXstation 3100 Model 30 is a compact desktop system that can be configured in three ways: (1) a complete starter system with disk and load/backup device; (2) a satellite workstation either diskless or with paging/swapping disks; (3) a network workstation with disks to permit use as a connected yet independent system. The Model 30 system unit supports either three 3.5-inch half-height devices for a maximum of 208 Mbytes of internal disk storage and a 1.44-Mbyte PS/2-compatible floppy or a combination of one 3.5-inch half-height device and one 5.25-inch half-height device for a maximum of 104 Mbytes of internal disk storage with a TZ30 95-Mbyte streaming tape. The Model 40 features a slightly larger system enclosure (approximately two inches taller) and can accommodate three 3.5-inch half-height disks and two 5.25-inch half-height load devices. This results in a 312-Mbyte system that has both a TZ30 95-Mbyte streaming tape and an RRD40 Compact Disc Drive (providing 600 Mbytes of storage capacity) internal to the system box. This package, configured with 16 Mbytes of memory and dual SCSI channels enables the Model 40 to become a "Serverstation", functioning as a server for up to seven other diskless VAXstation 3100 workstations. At the same time, the Serverstation is also a fully-functional workstation for an individual user. The Serverstation capability greatly reduces the entry-level cost of the VAXstation 3100 Model 40 for a small workgroup. A special version of the VAXserver 3400 is available for larger workgroups. The Model 30 and Model 40 packages allow for external storage and load expansion such as 332-Mbyte full-height hard disks, 600-Mbyte compact disc drives, and TK50 95-Mbyte streaming tapes via the SCSI port. Both the Model 30 and Model 40 will use this external port to enable future expansion using a variety of third-party peripherals. SPECIFICATIONS Power Model 30 Model 40 Requirements Line voltage 120 V/240 V 120 V/240 V Voltage tolerance-RMS 88-132 V/176-264 V 88-132 V/176-264 V Frequency-single phase 60 Hz/50 Hz 60 Hz/50 Hz Frequency tolerance 47-63 Hz 47-63 Hz Max. running current 2.8 A/1.5 A 4.5 A/2.3A Max. power consumption 190 W 300 W Operating Temperature 10-40 C (50-104 F) Environment Relative humidity 20-80% noncondensing Max. operating altitude 2.4 km (8000 feet) System Model 30 Dimensions Height 10.33 cm (4.07 in) Width 46.38 cm (18.26 in) Depth 39.42 cm (15.52 in) Weight 11.4 kg (25 lb) Model 40 Height 14.99 cm (5.9 in) Width 46.38 cm (18.26 in) Depth 40 cm (15.75 in) Weight 20.5 kg (45 lb) Monitors VR290 19-inch color Height 47 cm (18.5 in) Width 50.8 cm (20 in) Depth 54.6 cm (21.5 in) Weight 36.4 kg (80 lb) Line Voltage 120 V/240 V Max. power consumption 150 W or VR260 19-inch monochrome Height 39.1 cm (15.4 in) Width 44.5 cm (17.5 in) Depth 39.6 cm (15.6 in) Weight 22.2 kg (49 lb) Line Voltage 120 V/240 V Max. power consumption 65 W or VR160 15-inch color Height 40.6 cm (16 in) Width 38.1 cm (15 in) Depth 45.7 cm (18 in) Weight 20 kg (44 lb) Line Voltage 120 V/240 V Max. power consumption 150 W or VR150 15-inch monochrome Height 38.1 cm (15 in) Width 38.1 cm (15 in) Depth 36.8 cm (14.5 in) Weight 18.2 kg (40 lb) Line Voltage 120 V/240 V Max. power consumption 70 W Orientation Landscape (horizontal) Resolution 1024 Horizontal x 864 Vertical DPI 78 pixels (dots) per inch (19-inch) 100 pixels (dots) per inch (15-inch) Refresh 60 Hz noninterlaced Ergonomics Tilt/swivel base (optional VS10X-AA on VR260), nonglare screen Controls Brightness, contrast, DeGauss (color) Keyboard Layout 105 sculptured keys, typewriter-style (QWERTY) main array; editing and numeric keypads, 20 special-fun. keys Profile 30.9 mm (1.2 in) from palm rest to home row Height 4 cm (1.6 in) Width 53.2 cm (21 in) Depth 17.8 cm (7.0 in) Cord length 1.8 m (6.0 ft) Weight 1.8 kg (approximately 4 lb) Mouse Output 200 pulses per inch (X and Y relative displacement) Programmable Function Buttons 3 ORDERING INFORMATION The VAXstation 3100 can be configured using one of two system configuration guides. Both methods are easy to use and are designed so that you can configure the best system to fit your needs. Packaged Systems ---------------- The Packaged System concept simplifies ordering by offering many different system designs in pre-packaged configurations. Systems may be ordered as diskless or disk-based, with a variety of load/backup devices. Depending on which part number is used, the system will also include either a 15- or 19-inch color or monochrome monitor, a regular or WPS keyboard, and VMS or ULTRIX software licensing. There are four different configurations of the VAXstation 3100 Model 30 available. Standard on all Model 30 packaged systems is: - 8 Mbytes of memory - Mouse - ThinWire/thick wire Ethernet port with a T-connector and two terminators (ThinWire) and an Ethernet loopback connector (thick wire) - 3 ft. Video Cable - 3 ft. Convenience Power Cord - English Language User Documentation Each Packaged System contains different amounts of mass storage, types of load/backup devices, and operating system media. The four pre-packaged Model 30 systems are: VAXstation 3100 Model 30 Standalone Workstation - Two 104-Mbyte Disk Drives (RZ23s) - 1.4-Mbyte IBM-Compatible Floppy Disk Drive (RX23) - 600-Mbyte Compact Disc Drive Expansion Box (RRD40) - SCSI port - Desktop-VMS and VMS Base License and Desktop-VMS Compact Disc, or ULTRIX Base License VAXstation 3100 Model 30 Networked Workstation - Two 104-Mbyte Disk Drives (RZ23s) - 1.4-Mbyte IBM-Compatible Floppy Disk Drive (RX23) - SCSI Port - VMS Base License or ULTRIX Base License - Note: Requires network, tape expansion box, or compact disc expansion box to load software VAXstation 3100 Model 30 Diskless Satellite Workstation - Desktop-VMS and VMS Base Licenses or ULTRIX Base License VAXstation 3100 Model 30 Satellite Workstation with disks for local disk paging and swapping - 52-Mbyte Disk Drive (RZ22) - 1.4-Mbyte IBM-Compatible Floppy Disk Drive (RX23) - SCSI Port - Desktop-VMS and VMS Base License or ULTRIX Base License The VAXstation 3100 Model 40 is also available as a Packaged System. Included with the Model 40 is: VAXstation 3100 Model 40 Server/Workstation - 16-Mbyte Memory - Three 104-Mbyte Disk Drives (RZ23s) - 95-Mbyte Streaming Tape Drive (TZ30) - 600-Mbyte Integral Compact Disc Drive (RRD40) - SCSI Port - Mouse - ThinWire/thick wire Ethernet port with a T-connector and two terminators (ThinWire) and an Ethernet loopback connector (thick wire) - 3 ft. Video Cable - 3 ft. Convenience Power Cord - English Language User Documentation - Desktop-VMS and VMS Base License and Desktop-VMS Compact Disc, or ULTRIX Base License Note: 120 V systems include English keyboard (LK201) and all required power cables. If a 240 V system is selected, appropriate keyboard and power cords must be ordered separately through the Custom Systems Menu. Selected country kits (see Step 14 of the Custom Systems Menu) are offered to simplify ordering 240 V systems; they include country specfic keyboard, power cords and local language user documentation (where available). Base Licenses for each operating system include: - Desktop-VMS (includes VMS with DECwindows, VAXcluster, DECnet VAX) - VMS (includes DECwindows, VAXcluster, DECnet VAX, VWS) - ULTRIX (includes DECwindows, NFS, TCP/IP, VAX C/ULTRIX, portable C compiler (pcc), PASCAL Compiliers, and Source Code Control System) -------------------------------------------------------------------------------- 1.1 Packaged Systems Model 30 Standalone Workstation Model 30 Networked Workstation -------------------------------------------------------------------------------- Desktop-VMS/VMS ULTRIX VMS ULTRIX -------------------------------------------------------------------------------- 15-inch Mono * 120 V PV014-BA PV014-JA 120 V w/WPS PV014-BE 240 V PV014-BB PV014-JB 19-inch Mono * 120 V PV014-BC PV014-JC PV012-BC PV012-JC 120 V w/WPS PV014-BF PV012-BF 240 V PV014-BD PV014-JD PV012-BD PV012-JD 15-inch Color 120 V PV014-BT PV014-JT PV012-BT PV012-JT 120 V w/WPS PV014-BG PV012-BG 240 V PV014-BU PV014-JU PV012-BU PV012-JU 240 V S.Hemi. PV014-BV PV014-JV PV012-BV PV012-JV 19-inch Color 120 V PV014-BW PV014-JW PV012-BW PV012-JW 120 V w/WPS PV014-BH PV012-BH 240 V PV014-BY PV014-JY PV012-BY PV012-JY 240 V S.Hemi. PV014-BZ PV014-JZ PV012-BZ PV012-JZ -------------------------------------------------------------------------------- Model 30 Diskless Satellite Model 30 Satellite w/disk -------------------------------------------------------------------------------- Desktop-VMS/VMS ULTRIX Desktop-VMS/VMS ULTRIX -------------------------------------------------------------------------------- 19-inch Mono * 120 V PV010-BC PV010-JC PV011-BC PV011-JC 120 V w/WPS PV010-BF PV011-BF 240 V PV010-BD PV010-JD PV011-BD PV011-JD 15-inch Color 120 V PV010-BT PV010-JT PV011-BT PV011-JT 120 V w/WPS PV010-BG PV011-BG 240 V PV010-BU PV010-JU PV011-BU PV011-JU 240 V S.Hemi. PV010-BV PV010-JV PV011-BV PV011-JV 19-inch Color 120 V PV010-BW PV010-JW PV011-BW PV011-JW 120 V w/WPS PV010-BH PV011-BH 240 V PV010-BY PV010-JY PV011-BY PV011-JY 240 V S.Hemi. PV010-BZ PV010-JZ PV011-BZ PV011-JZ -------------------------------------------------------------------------------- Model 40 Server/Workstation -------------------------------------------------------------------------------- Desktop-VMS/VMS Ultrix -------------------------------------------------------------------------------- 19-inch Mono * 120 V PV053-CC PV053-KC 120 V w/WPS PV053-CF 240 V PV053-CD PV053-KD 15-inch Color 120 V PV053-CT PV053-KT 120 V w/WPS PV053-CG 240 V PV053-CU PV053-KU 240 V S.Hemi. PV053-CV PV053-KV 19-inch Color 120 V PV053-CW PV053-KW 120 V w/WPS PV053-CH 240 V PV053-CY PV053-KY 240 V S.Hemi. PV053-CZ PV053-KZ -------------------------------------------------------------------------------- Note: * Single-plane monochrome system. CUSTOM SYSTEMS The Custom System concept allows you to configure a VAXstation 3100 Model 30 or Model 40 to suit your individual or company needs. The Model 30 base systems comes with a choice of 4 disk and load/backup device combinations and is available as either a single-plane or 8-plane system with either VMS or ULTRIX licenses and English language user documentation. Each base kernal also includes a 3 ft. video cable, a 3 ft. convenience power cord, mouse, ThinWire/thick wire Ethernet port, and an Ethernet kit. The type of monitor, keyboard, power cords, and additional mass storage or options must be ordered separetely. The Model 40 configurations start with a diskless base system that includes either VMS or ULTRIX license, English language user documentation, 3 ft. video cable, a 3 ft. convenience power cord, mouse, ThinWire/thick wire Ethernet port, and an Ethernet kit. Monitors, keyboards, power cords, mass storage, load/backup devices, and any options must be ordered separately. To order a VAXstation 3100 Model 30 or Model 40 Custom System, simply follow the following steps. - Choose the model-type base system from Step 1.2 - Choose a monitor from Step 2 - Choose the appropriate power cord (Step 3) and keyboard (Step 4) or choose a Country Kit from Step 13 - For a Model 40, choose mass storage from Step 5 - For any additional storage, options, or upgrades, see Steps 6-14 - Choose software media from Step 15 Note: The VAXstation 3100 has a universal power supply. Simply select the power cords (Step 3) that match your country requirements. Base Licenses for each operating system include: - VMS (includes DECwindows), VAXcluster, DECnet VAX, VWS - ULTRIX (includes DECwindows, NFS, TCP/IP, VAX C/ULTRIX, portable C compiler (pcc), PASCAL Compiliers, and Source Code Control System) -------------------------------------------------------------------------------- 1.2 Custom System Model 30 -------------------------------------------------------------------------------- System VMS VMS ULTRIX ULTRIX Storage 8 Mbytes 8 Mbytes 8 Mbytes 8 Mbytes Single-plane 8-plane Single-plane 8-plane -------------------------------------------------------------------------------- RZ23/TZ30 PV01A-BA PV01A-BB PV01A-JA PV01A-JB 2-RZ23 disks PV01A-BC PV01A-BD PV01A-JC PV01A-JD RZ23 PV01A-BE PV01A-BF PV01A-JE PV01A-JF RZ23/RX23 PV01A-BG PV01A-BH PV01A-JG PV01A-JH -------------------------------------------------------------------------------- Model 40 -------------------------------------------------------------------------------- System VMS VMS ULTRIX ULTRIX Storage 16 Mbytes 16 Mbytes 16 Mbytes 16 Mbytes Single-plane 8-plane Single-plane 8-plane -------------------------------------------------------------------------------- Diskless PV05A-CA PV05A-CB PV05A-KA PV05A-KB -------------------------------------------------------------------------------- 2.0 Monitors VR150-AA/A3 15-inch monochrome monitor VR260-AA/A3 19-inch monochrome monitor VR160-DA/D3/D4 15-inch color monitor VR290-DA/D3/D4 19-inch color monitor * Note: VRxxx-xA is 120-V and includes a power cord. VRxxx-x3/x4 is 240-V and does not include a power cord. VRxxx-x4 is southern hemisphere. Single-plane system use a monochrome monitor only. -------------------------------------------------------------------------------- 3.0 Power Cords BN19P-1K USA - 120 V BN19A-2E UK, Ireland - 240 V BN19C-2E Austria, Belgium, Finland, France, Germany, Holland, Norway, Portugal, Spain, Sweden - 220 V BN19E-2E Switzerland - 220 V BN19H-2E Australia/New Zealand - 240/230 V BN19K-2E Denmark - 220 V BN19M-2E Italy - 220 V BN19S-2E India, South Africa - 220 V BN19U-2E Israel - 240 V -------------------------------------------------------------------------------- 4.0 Keyboards LK201-RE/PE English LK201-LB/MB Flemish LK201-AC/FC French/Canadian LK201-RD/MD Danish LK201-NX/MF Suomi (Finnish) LK201-NG/PG German/Austrian & German LK201-NH/MH Dutch LK201-LI/MI Italian LK201-LK/MK French/Swiss LK201-LL/ML German/Swiss LK201-NM/MM Swedish LK201-RN/MN Norwegian LK201-LP/MP French/Parisian LK201-LS/MS Spanish LK201-LT/AT Hebrew LK201-LV/AV Portuguese * Note: - Country Kits which include keyboard, power cords, and in some cases local language user documentation can be selected from Step 14. - LK201-AC/Lx/Nx/Rx is a regular keyboard. LK201-AT/AV/Fx/Mx/Px is a WPS style keyboard. -------------------------------------------------------------------------------- 5.0 Internal Mass Storage - Model 40 Only RZ23-EG 104-Mbyte disk drive. Maximum of 3 per system. TZ30-EG 95-Mbyte streaming tape drive. Maximum of 1 per system. RRD40-EG 600-Mbyte Compact Disc Drive. Maximum of 1 per system. -------------------------------------------------------------------------------- 6.0 External Mass Storage RRD40-FA/F3 600-Mbyte Compact Disc Drive in expansion box. RRD40-FA = 120 V; RRD40-F3 = 240 V. TK50Z-GA/G3 95-Mbyte streaming tape drive in expansion box TK50Z-GA = 120 V; TK50Z-G3 = 240 V. RZ55-FA/F3 332-Mbyte disk drive in expansion box RZ55-FA = 120 V; RZ55-F3 = 240 V. * Note: - 240 V storage devices do not include a power cord. Order from Step 3. - Model 30 Diskless systems do not include a drive controller and therefore do not support external expansion boxes. - Maximum of 3 expansion disks per system. - Maximum of 1 tape device per system. -------------------------------------------------------------------------------- 7.0 Model 30 Integral Drive Upgrades VS42D-AA One 52-Mbyte disk drive (RZ22) and a 1.4-Mbyte IBM-compatible floppy disk drive (RX23) VS42D-BA One 104-Mbyte disk drive (RZ23)and a 95-Mbyte streaming tape drive (TZ30) VS42D-CA Two 104-Mbyte disk drives (RZ23) VS42D-DA One 104-Mbyte disk drive (RZ23) VS42D-EA One 104-Mbyte disk drive (RZ23) and a 1.4-Mbyte IBM-compatible floppy disk drive (RX23) * Note: - Model 30 upgrades for diskless systems only (PV010-xx systems). - Requires field service installation. - Maximum of three disk drives or one tape/floppy and one disk drive. -------------------------------------------------------------------------------- 8.0 Model 40 Integral Drive Upgrades RZ23-EF 104-Mbyte disk drive. Maximum of 3 per system. TZ30-EF 95-Mbyte streaming tape drive. Maximum of 1 per system. RRD40-EF 600-Mbyte Compact Disc drive. Maximum of 1 per system. * Note: Requires field service installation. -------------------------------------------------------------------------------- 9.0 Pointing Device (Optional) VSXXX-AB Tablet -------------------------------------------------------------------------------- 10.0 Expansion Box Cable BC56H-03 3-ft expansion box data cable required for connecting a TK50Z-FA/F3 (VAXstation 2000 tape expansion box) to a VAXstation 3100. * Note: A TK50Z-FA/F3 will require a field service installed ROM upgrade to work correctly with a VAXstation 3100. -------------------------------------------------------------------------------- 11.0 Video Cable BC18P-10 VAXstation 3100 10-ft monochrome video cable BC19S-10 VAXstation 3100 10-ft color video cable * Note: All VAXstation 3100 systems include a 3-ft video cable. This cable allows positioning the monitor remotely from the system. -------------------------------------------------------------------------------- 12.0 Graphics Upgrade VS40X-PA 8-plane graphics accelerator for single-plane systems. Allows 8-plane grayscale or color. Requires field service installation. Included in color systems. -------------------------------------------------------------------------------- 13.0 Country Kits PV01K-AB Belgium. Includes both Dutch and French user documentation. PV01K-AD Denmark. Includes local language hardware-only user doc. PV01K-AE England/Ireland. PV01K-AF Finland. PV01K-AG Germany. Includes local language hardware-only user doc. PV01K-AH Holland. Includes local language hardware-only user doc. PV01K-AI Italy. PV01K-AK Swiss/French. PV01K-AL Swiss/German. PV01K-AM Sweden. PV01K-AN Norway. PV01K-AP France. Includes local language hardware-only user doc. PV01K-AS Spain. Includes local language hardware-only user doc. PV01K-AT Israel. PV01K-AV Portugal. * Note: Country Kit includes keyboard and power cord. -------------------------------------------------------------------------------- 14.0 VAXstation 3100 User Documentation EK-VS310-IL VS3100 Model 40 Customer Information Kit - English EK-260AA-OM Managing Your VS3100 Model 30 Standalone - English EK-259AA-UG Using Your VS3100 Model 30 Satellite - English EK-265AA-OM VS3100 Model 30 Hardware Information - English EK-266AA-OM VS3100 Model 40 Hardware Information - English EK-265PA-OM VS3100 Model 30 Hardware Information - French EK-266PA-OM VS3100 Model 40 Hardware Information - French EK-265GA-OM VS3100 Model 30 Hardware Information - German EK-266GA-OM VS3100 Model 40 Hardware Information - German EK-265SA-OM VS3100 Model 30 Hardware Information - Spanish EK-266SA-OM VS3100 Model 40 Hardware Information - Spanish EK-265HA-OM VS3100 Model 30 Hardware Information - Dutch EK-266HA-OM VS3100 Model 40 Hardware Information - Dutch EK-265IA-OM VS3100 Model 30 Hardware Information - Italian EK-266IA-OM VS3100 Model 40 Hardware Information - Italian EK-265DA-OM VS3100 Model 30 Hardware Information - Danish EK-266DA-OM VS3100 Model 40 Hardware Information - Danish * Note: Appropriate English language user documentation is included with each packaged system and custom system kernal. Selected local language user documentation is included with each country kit. -------------------------------------------------------------------------------- 15.0 VAXstation 3100 Software Media QA-VVTAA-H8 ULTRIX-32 Single-User Kit and DECwindows Software on CD QA-VVTAA-H5 ULTRIX-32 Single-User Kit and DECwindows Software on TK50 QA-09SAB-H8 VMS Single-User Kit and DECwindows on Compact Disc Drive QA-09SAB-H5 VMS Single-User Kit and DECwindows on TK50 QA-VV8AA-H8 DESKTOP-VMS Single-User Kit and DECwindows on Compact Disc QA-A96AA-H5 VMS Workstation Software (VWS) on TK50 -------------------------------------------------------------------------------- -------------------- Живы будем - Не помрем !
| Текстовая версия | Сейчас: 12.11.2026, 1:26 |
