![]() Администратор ![]() ![]() ![]() ![]() ![]() Группа: Root Admin Сообщений: 6 344 Регистрация: 7.1.2006 Из: Красноярск Пользователь №: 1 ![]() |
Программатор TL866A: полный список поддерживаемых микросхем
1. ICSP interface (6-pin interface of the programmer right side) is limited to the TL866A model. 2. Partly Microchip's MCU with More than 40pins require the use of the TL866A for ICSP interface programming . Most of Microchip's PICs MCU support programming on ICSP and 40PIN seat. 3. About ATMEGAxxxx and SYNCMOSЎЇs MCU SM89xxx SM59xxx TL866A support serial programming on ICSP and parallel programming on seat. TL886CS only support parallel programming on seat. 4. AT45DBxxxx can only be programmed using the ICSP interface (TL866A only). AT45DBxxxx 5. To all other chips. TL866A and TL866CS no diffrent. Both programmers work with genuine TL866 Adapters for devices up to 48 pins. ============================================================= Device Support List: ============================================================= BG25Q40A BG25Q800A BG25Q160A W25Q16DV W25Q32FV W25Q40CL W25Q64FV W25Q80DV W25Q128FV [ ACE ] 71 PCS ACE24C02A ACE24C02A @SOIC8 ACE24C02A @TSSOP8 ACE24C02B ACE24C02B @SOIC8 ACE24C02B @TSSOP8 ACE24C04A ACE24C04A @SOIC8 ACE24C04A @TSSOP8 ACE24C04B ACE24C04B @SOIC8 ACE24C04B @TSSOP8 ACE24C08A ACE24C08A @SOIC8 ACE24C08A @TSSOP8 ACE24C08B ACE24C08B @SOIC8 ACE24C08B @TSSOP8 ACE24C16A ACE24C16A @SOIC8 ACE24C16A @TSSOP8 ACE24C16B ACE24C16B @SOIC8 ACE24C16B @TSSOP8 ACE24C32 ACE24C32 @SOIC8 ACE24C32 @TSSOP8 ACE24C64 ACE24C64 @SOIC8 ACE24C64 @TSSOP8 ACE24C128 ACE24C128 @SOIC8 ACE24C128 @TSSOP8 ACE24C256 ACE24C256 @SOIC8 ACE24C256 @TSSOP8 ACE24C512 ACE24C512 @SOIC8 ACE24C512 @TSSOP8 ACE24C1024 ACE24C1024 @SOIC8 ACE24LC02 ACE24LC02 @SOIC8 ACE24LC02 @TSSOP8 ACE24LC04 ACE24LC04 @SOIC8 ACE24LC04 @TSSOP8 ACE24LC08 ACE24LC08 @SOIC8 ACE24LC08 @TSSOP8 ACE24LC16 ACE24LC16 @SOIC8 ACE24LC16 @TSSOP8 ACE93C46(x8) ACE93C46(x8) @SOIC8 ACE93C46(x8) @TSSOP8 ACE93C46(x16) ACE93C46(x16) @SOIC8 ACE93C46(x16) @TSSOP8 ACE93C56(x8) ACE93C56(x8) @SOIC8 ACE93C56(x8) @TSSOP8 ACE93C56(x16) ACE93C56(x16) @SOIC8 ACE93C56(x16) @TSSOP8 ACE93C66(x8) ACE93C66(x8) @SOIC8 ACE93C66(x8) @TSSOP8 ACE93C66(x16) ACE93C66(x16) @SOIC8 ACE93C66(x16) @TSSOP8 [ ACT ] 16 PCS 93LC46(x8) 93LC46(x8) @SOIC8 93LC46(x16) 93LC46(x16) @SOIC8 93LC56(x8) 93LC56(x8) @SOIC8 93LC56(x16) 93LC56(x16) @SOIC8 93LC66(x8) 93LC66(x8) @SOIC8 93LC66(x16) 93LC66(x16) @SOIC8 93LC86(x8) 93LC86(x8) @SOIC8 93LC86(x16) 93LC86(x16) @SOIC8 [ ACTRANS ] 9 PCS AC39LV010 @PLCC32 AC39LV010 @TSOP32 AC39LV020 @PLCC32 AC39LV020 @TSOP32 AC39LV040 @PLCC32 AC39LV040 @TSOP32 AC39LV080 @TSOP40 AC39LV512 @PLCC32 AC39LV512 @TSOP32 [ ADVANCE GROUP ] 51 PCS AF24BC01 AF24BC01 @SOIC8 AF24BC01 @TSOP8 AF24BC02 AF24BC02 @SOIC8 AF24BC02 @TSOP8 AF24BC04 AF24BC04 @SOIC8 AF24BC04 @TSOP8 AF24BC08 AF24BC08 @SOIC8 AF24BC08 @TSOP8 AF24BC16 AF24BC16 @SOIC8 AF24BC16 @TSOP8 AF24C32 AF24C32 @SOIC8 AF24C32 @TSOP8 AF24C64 AF24C64 @SOIC8 AF24C64 @TSOP8 AF24C128 AF24C128 @SOIC8 AF24C128 @TSOP8 AF24C256 AF24C256 @SOIC8 AF24C256 @TSOP8 AF93C46(x8) AF93C46(x8) @SOIC8 AF93C46(x8) @TSSOP8 AF93C46(x16) AF93C46(x16) @SOIC8 AF93C46(x16) @TSSOP8 AF93C56(x8) AF93C56(x8) @SOIC8 AF93C56(x8) @TSSOP8 AF93C56(x16) AF93C56(x16) @SOIC8 AF93C56(x16) @TSSOP8 AF93C66(x8) AF93C66(x8) @SOIC8 AF93C66(x8) @TSSOP8 AF93C66(x16) AF93C66(x16) @SOIC8 AF93C66(x16) @TSSOP8 AF93C86(x8) AF93C86(x8) @SOIC8 AF93C86(x8) @TSSOP8 AF93C86(x16) AF93C86(x16) @SOIC8 AF93C86(x16) @TSSOP8 [ AiT Semi ] 12 PCS A24C02 A24C02 @SOIC8 A24C02 @TSOP8 A24C04 A24C04 @SOIC8 A24C04 @TSOP8 A24C08 A24C08 @SOIC8 A24C08 @TSOP8 A24C16 A24C16 @SOIC8 A24C16 @TSOP8 [ ALI(Acer) ] 2 PCS M8720 M8720 @PLCC32 [ ALLIANCE ] 20 PCS AS29F002T AS29F002T @PLCC32 AS29F002T @TSOP32 AS29F002B AS29F002B @PLCC32 AS29F002B @TSOP32 AS29LV160T @TSOP48 AS29LV160B @TSOP48 AS29F200B @TSOP48 AS29F200B @PSOP44 AS29F200T @TSOP48 AS29F200T @PSOP44 AS29LV400B @TSOP48 AS29LV400B @PSOP44 AS29LV400T @TSOP48 AS29LV400T @PSOP44 AS29LV800B @TSOP48 AS29LV800B @PSOP44 AS29LV800T @TSOP48 AS29LV800T @PSOP44 [ AMD ] 249 PCS AM2716B @DIP24 AM2732B @DIP24 AM2764A @DIP28 AM2764A @PLCC32 AM27128A @DIP28 AM27128A @PLCC32 AM27256 @DIP28 AM27256 @PLCC32 AM27512 @DIP28 AM27512 @PLCC32 AM27C64 @DIP28 AM27C64 @PLCC32 AM27C010 @DIP32 AM27C010 @PLCC32 AM27C020 @DIP32 AM27C020 @PLCC32 AM27C040 @DIP32 AM27C040 @PLCC32 AM27C080 @DIP32 AM27C080 @PLCC32 AM27C128 @DIP28 AM27C128 @PLCC32 AM27C256 @DIP28 AM27C256 @PLCC32 AM27C512 @DIP28 AM27C512 @PLCC32 AM27C1024 @DIP40 AM27C2048 @DIP40 AM27C4096 @DIP40 AM27LV010 @DIP32 AM27LV010 @PLCC32 AM27LV010 @TSOP32 AM27LV020 @DIP32 AM27LV020 @PLCC32 AM27LV020 @TSOP32 AM27LV020B @DIP32 AM27LV020B @PLCC32 AM27LV020B @TSOP32 AM27LV040 @DIP32 AM27LV040 @PLCC32 AM27LV040 @TSOP32 AM27LV080 @DIP32 AM27LV080 @PLCC32 AM27LV080 @TSOP32 AM27H010 @DIP32 AM27H010 @PLCC32 AM27H010 @TSOP32 AM27H256 @DIP28 AM27H256 @PLCC32 AM27HB010 @DIP32 AM27HB010 @PLCC32 AM27HB010 @TSOP32 AM28C16A @DIP24 AM28C16A @PLCC32 AM28C17A @DIP28 AM28C17A @PLCC32 AM28C17A @SOIC28 AM28C64A @DIP28 AM28C64A @PLCC32 AM28C64A @SOIC28 AM28C64AE @DIP28 AM28C64AE @PLCC32 AM28C64AE @SOIC28 AM28C64B @DIP28 AM28C64B @PLCC32 AM28C64B @SOIC28 AM28C64BE @DIP28 AM28C64BE @PLCC32 AM28C64BE @SOIC28 AM28F256 AM28F256 @PLCC32 AM28F256 @TSOP32 AM28F512 AM28F512 @PLCC32 AM28F512 @TSOP32 AM28F010 AM28F010 @PLCC32 AM28F010 @TSOP32 AM28F020 AM28F020 @PLCC32 AM28F020 @TSOP32 AM29BL162CB @SOP56 AM29BL802CB @SOP56 AM29DL161DB @TSOP48 AM29DL161DT @TSOP48 AM29DL162DB @TSOP48 AM29DL162DT @TSOP48 AM29DL163DB @TSOP48 AM29DL163DT @TSOP48 AM29DL164DB @TSOP48 AM29DL164DT @TSOP48 AM29DL322DB @TSOP48 AM29DL322DT @TSOP48 AM29DL322GB @TSOP48 AM29DL322GT @TSOP48 AM29DL323DB @TSOP48 AM29DL323DT @TSOP48 AM29DL323GB @TSOP48 AM29DL323GT @TSOP48 AM29DL324DB @TSOP48 AM29DL324DT @TSOP48 AM29DL324GB @TSOP48 AM29DL324GT @TSOP48 AM29DL400BB @TSOP48 AM29DL400BB @SOP44 AM29DL400BT @TSOP48 AM29DL400BT @SOP44 AM29DL800BB @TSOP48 AM29DL800BB @SOP44 AM29DL800BT @TSOP48 AM29DL800BT @SOP44 AM29F002B @DIP32 AM29F002B @PLCC32 AM29F002B @TSOP32 AM29F002BB @DIP32 AM29F002BB @PLCC32 AM29F002BB @TSOP32 AM29F002BT @DIP32 AM29F002BT @PLCC32 AM29F002BT @TSOP32 AM29F002NB @DIP32 AM29F002NB @PLCC32 AM29F002NB @TSOP32 AM29F002NBB @DIP32 AM29F002NBB @PLCC32 AM29F002NBB @TSOP32 AM29F002NBT @DIP32 AM29F002NBT @PLCC32 AM29F002NBT @TSOP32 AM29F002NT @DIP32 AM29F002NT @PLCC32 AM29F002NT @TSOP32 AM29F002T @DIP32 AM29F002T @PLCC32 AM29F002T @TSOP32 AM29F010 @DIP32 AM29F010 @PLCC32 AM29F010 @TSOP32 AM29F010B @DIP32 AM29F010B @PLCC32 AM29F010B @TSOP32 AM29F016D @TSOP40 AM29F040 @DIP32 AM29F040 @PLCC32 AM29F040 @TSOP32 AM29F040B @DIP2 AM29F040B @PLCC32 AM29F040B @TSOP32 AM29F080 @TSOP40 AM29F080B @TSOP40 AM29F100AB @TSOP48 AM29F100AB @SOP44 AM29F100AT @TSOP48 AM29F100AT @SOP44 AM29F100B @TSOP48 AM29F100B @SOP44 AM29F100T @TSOP48 AM29F100T @SOP44 AM29F160DB @TSOP48 AM29F160DT @TSOP48 AM29F200AB @TSOP48 AM29F200AB @SOP44 AM29F200AT @TSOP48 AM29F200AT @SOP44 AM29F200BB @TSOP48 AM29F200BB @SOP44 AM29F200BT @TSOP48 AM29F200BT @SOP44 AM29F400AB @TSOP48 AM29F400AB @SOP44 AM29F400AT @TSOP48 AM29F400AT @SOP44 AM29F400BB @TSOP48 AM29F400BB @SOP44 AM29F400BT @TSOP48 AM29F400BT @SOP44 AM29F800AB @TSOP48 AM29F800AB @SOP44 AM29F800AT @TSOP48 AM29F800AT @SOP44 AM29F800B @TSOP48 AM29F800B @SOP44 AM29F800BB @TSOP48 AM29F800BB @SOP44 AM29F800BT @TSOP48 AM29F800BT @SOP44 AM29F800T @TSOP48 AM29F800T @SOP44 AM29LV001B @PLCC32 AM29LV001B @TSOP32 AM29LV001BB @PLCC32 AM29LV001BB @TSOP32 AM29LV001BT @PLCC32 AM29LV001BT @TSOP32 AM29LV001T @PLCC32 AM29LV001T @TSOP32 AM29LV002B @TSOP40 AM29LV002T @TSOP40 AM29LV004B @TSOP40 AM29LV004BB @TSOP40 AM29LV004BT @TSOP40 AM29LV004T @TSOP40 AM29LV008B @TSOP40 AM29LV008BB @TSOP40 AM29LV008BT @TSOP40 AM29LV008T @TSOP40 AM29LV010B @PLCC32 AM29LV010B @TSOP32 AM29LV017 @TSOP40 AM29LV020B @PLCC32 AM29LV020B @TSOP32 AM29LV033C @TSOP40 AM29LV033M @TSOP40 AM29LV040B @PLCC32 AM29LV040B @TSOP32 AM29LV081 @TSOP40 AM29LV160BB @TSOP48 AM29LV160BT @TSOP48 AM29LV160DB @TSOP48 AM29LV160DT @TSOP48 AM29LV200B @TSOP48 AM29LV200B @SOP44 AM29LV200BB @TSOP48 AM29LV200BB @SOP44 AM29LV200BT @TSOP48 AM29LV200BT @SOP44 AM29LV200T @SOP44 AM29LV200T @TSOP48 AM29LV320DB @TSOP48 AM29LV320DT @TSOP48 AM29LV320MB @TSOP48 AM29LV320MT @TSOP48 AM29LV400B @TSOP48 AM29LV400B @SOP44 AM29LV400BB @TSOP48 AM29LV400BB @SOP44 AM29LV400BT @TSOP48 AM29LV400BT @SOP44 AM29LV400T @TSOP48 AM29LV400T @SOP44 AM29LV641D @TSOP48 AM29LV800B @TSOP48 AM29LV800B @SOP44 AM29LV800BB @TSOP48 AM29LV800BB @SOP44 AM29LV800BT @TSOP48 AM29LV800BT @SOP44 AM29LV800T @TSOP48 AM29LV800T @SOP44 [ AMIC ] 204 PCS A25L05PT @DIP8 A25L05PT @SOP8 A25L05PT @TSOP8 A25L05PU @DIP8 A25L05PU @SOP8 A25L05PU @TSOP8 A25L10PT @DIP8 A25L10PT @SOP8 A25L10PT @TSOP8 A25L10PU @DIP8 A25L10PU @SOP8 A25L10PU @TSOP8 A25L20PT @DIP8 A25L20PT @SOP8 A25L20PT @TSOP8 A25L20PU @DIP8 A25L20PU @SOP8 A25L20PU @TSOP8 A25L40PT @DIP8 A25L40PT @SOP8 A25L40PT @SOP16 A25L40PU @DIP8 A25L40PU @SOP8 A25L40PU @SOP16 A25L80PT @DIP8 A25L80PT @SOP8 A25L80PT @SOP16 A25L80PU @DIP8 A25L80PU @SOP8 A25L80PU @SOP16 A25L16PT @DIP8 A25L16PT @SOP8 A25L16PT @SOP16 A25L16PU @DIP8 A25L16PU @SOP8 A25L16PU @SOP16 A25L512 @DIP8 A25L512 @SOP8 A25L512 @TSOP8 A25L010 @DIP8 A25L010 @SOP8 A25L010 @TSOP8 A25L020 @DIP8 A25L020 @SOP8 A25L020 @TSOP8 A25L040 @DIP8 A25L040 @SOP8 A25L040 @TSOP8 A25L080 @DIP8 A25L080 @SOP8 A25L080 @TSOP8 A25L016 @DIP8 A25L016 @SOP8 A25L016 @SOP16 A25L032 @DIP8 A25L032 @SOP8 A25L032 @SOP16 A25LQ16 @DIP8 A25LQ16 @SOP8 A25LQ16 @SOP16 A25LQ32A @DIP8 A25LQ32A @SOP8 A25LQ32A @SOP16 A27020 @DIP32 A27020 @TSOP32 A27020L @PLCC32 A276308 @DIP28 A276308 @SOP28 A276308L @PLCC32 A276308A @DIP28 A276308A @SOP28 A276308AL @PLCC32 A278308 @DIP28 A278308L @PLCC32 A278308A @DIP28 A278308AL @PLCC32 A29001T A29001T @PLCC32 A29001T @TSOP32 A29001U A29001U @PLCC32 A29001U @TSOP32 A290011T A290011T @PLCC32 A290011T @TSOP32 A290011U A290011U @PLCC32 A290011U @TSOP32 A29002T A29002T @PLCC32 A29002T @TSOP32 A29002U A29002U @PLCC32 A29002U @TSOP32 A290021T A290021T @PLCC32 A290021T @TSOP32 A290021U A290021U @PLCC32 A290021U @TSOP32 A29512 A29512 @PLCC32 A29512 @TSOP32 A29512A A29512A @PLCC32 A29512A @TSOP32 A29010 A29010 @PLCC32 A29010 @TSOP32 A29040 A29040 @PLCC32 A29040 @TSOP32 A29040A A29040A @PLCC32 A29040A @TSOP32 A29040B A29040B @PLCC32 A29040B @TSOP32 A29400TV @TSOP48 A29400TM @SOP44 A29400UV @TSOP48 A29400UM @SOP44 A29800TV @TSOP48 A29800TM @SOP44 A29800UV @TSOP48 A29800UM @SOP44 A29801TV @TSOP48 A29801TM @SOP44 A29801UV @TSOP48 A29801UM @SOP44 A29DL162TV @TSOP48 A29DL162UV @TSOP48 A29DL163TV @TSOP48 A29DL163UV @TSOP48 A29DL164TV @TSOP48 A29DL164UV @TSOP48 A29DL322TV @TSOP48 A29DL322UV @TSOP48 A29DL323TV @TSOP48 A29DL323UV @TSOP48 A29DL324TV @TSOP48 A29DL324UV @TSOP48 A29L040 @DIP32 A29L040 @PLCC32 A29L040 @TSOP32 A29L040A @DIP32 A29L040A @PLCC32 A29L040A @TSOP32 A29L004ATL @PLCC32 A29L004ATV @TSOP32 A29L004ATW @TSOP40 A29L004ATX @TSOP32 A29L004ATY @TSOP32 A29L004AUL @PLCC32 A29L004AUV @TSOP32 A29L004AUW @TSOP40 A29L004AUX @TSOP32 A29L004AUY @TSOP32 A29L004TL @PLCC32 A29L004TV @TSOP32 A29L004TW @TSOP40 A29L004TX @TSOP32 A29L004UL @PLCC32 A29L004UV @TSOP32 A29L004UW @TSOP40 A29L004UX @TSOP32 A29L008TV @TSOP40 A29L008UV @TSOP40 A29L008ATV @TSOP40 A29L008AUV @TSOP40 A29L400TV @TSOP48 A29L400TM @SOP44 A29L400UV @TSOP48 A29L400UM @SOP44 A29L400ATV @TSOP48 A29L400ATM @SOP44 A29L400AUM @SOP44 A29L400AUV @TSOP48 A29L800TV @TSOP48 A29L800TM @SOP44 A29L800UV @TSOP48 A29L800UM @SOP44 A29L800ATV @TSOP48 A29L800ATM @SOP44 A29L800AUV @TSOP48 A29L800AUM @SOP44 A29L160TV @TSOP48 A29L160UV @TSOP48 A29L160ATV @TSOP48 A29L160AUV @TSOP48 A29L320TV @TSOP48 A29L320UV @TSOP48 A29L320ATV @TSOP48 A29L320AUV @TSOP48 A29L640TV @TSOP48 A29L640UV @TSOP48 A49LF004TL @PLCC32 A49LF004TX @TSOP32 A49LF040TL @PLCC32 A49LF040TX @TSOP32 A49LF040ATL @PLCC32 A49LF040ATX @TSOP32 A49FL004TL @PLCC32 A49FL004TX @TSOP32 [ ANACHIP ] 60 PCS 27CX010 @DIP32 27CX010 @PLCC32 27CX256 @DIP28 27CX256 @PLCC32 93C46 93C46 @SOIC8 93C46A 93C46A @SOIC8 93C56A 93C56A @SOIC8 93C66A 93C66A @SOIC8 93CX46 93CX46 @SOIC8 93CX56 93CX56 @SOIC8 93CX66 93CX66 @SOIC8 AM24LC02 AM24LC02 @SOIC8 AM24LC02 @TSSOP8 AM24LC04 AM24LC04 @SOIC8 AM24LC04 @TSSOP8 AM24LC08 AM24LC08 @SOIC8 AM24LC08 @TSSOP8 AM24LC16 AM24LC16 @SOIC8 AM24LC16 @TSSOP8 AM24LC21 AM24LC21 @SOIC8 AM24LC21 @TSSOP8 AM24LC21B AM24LC21B @SOIC8 AM24LC21B @TSSOP8 AM93LC46(x8) AM93LC46(x8) @SOIC8 AM93LC46(x8) @TSOP8 AM93LC46(x16) AM93LC46(x16) @SOIC8 AM93LC46(x16) @TSOP8 AM93LC56(x8) AM93LC56(x8) @SOIC8 AM93LC56(x8) @TSOP8 AM93LC56(x16) AM93LC56(x16) @SOIC8 AM93LC56(x16) @TSOP8 AM93LC66(x8) AM93LC66(x8) @SOIC8 AM93LC66(x8) @TSOP8 AM93LC66(x16) AM93LC66(x16) @SOIC8 AM93LC66(x16) @TSOP8 AM93LC86(x8) AM93LC86(x8) @SOIC8 AM93LC86(x8) @TSOP8 AM93LC86(x16) AM93LC86(x16) @SOIC8 AM93LC86(x16) @TSOP8 [ APLUS FLASH ] 105 PCS AF24BC01 AF24BC01 @SOIC8 AF24BC01 @TSSOP8 AF24BC02 AF24BC02 @SOIC8 AF24BC02 @TSSOP8 AF24BC04 AF24BC04 @SOIC8 AF24BC04 @TSSOP8 AF24BC08 AF24BC08 @SOIC8 AF24BC08 @TSSOP8 AF24BC16 AF24BC16 @SOIC8 AF24BC16 @TSSOP8 AF24BC32 AF24BC32 @SOIC8 AF24BC32 @TSSOP8 AF24BC64 AF24BC64 @SOIC8 AF24BC64 @TSSOP8 AF24BC128 AF24BC128 @SOIC8 AF24BC128 @TSSOP8 AF24BC256 AF24BC256 @SOIC8 AF24BC256 @TSSOP8 AF24C32 AF24C32 @SOIC8 AF24C32 @TSSOP8 AF24C64 AF24C64 @SOIC8 AF24C64 @TSSOP8 AF24C128 AF24C128 @SOIC8 AF24C128 @TSSOP8 AF24C256 AF24C256 @SOIC8 AF24C256 @TSSOP8 AF25BC08 AF25BC08 @SOIC8 AF25BC08 @TSSOP8 AF25BC16 AF25BC16 @SOIC8 AF25BC16 @TSSOP8 AF25BC32 AF25BC32 @SOIC8 AF25BC32 @TSSOP8 AF25BC64 AF25BC64 @SOIC8 AF25BC64 @TSSOP8 AF25BC128 AF25BC128 @SOIC8 AF25BC128 @TSSOP8 AF25BC256 AF25BC256 @SOIC8 AF25BC256 @TSSOP8 AF93BC46(x8) AF93BC46(x8) @SOIC8 AF93BC46(x8) @TSOP8 AF93BC46(x16) AF93BC46(x16) @SOIC8 AF93BC46(x16) @TSOP8 AF93BC56(x8) AF93BC56(x8) @SOIC8 AF93BC56(x8) @TSOP8 AF93BC56(x16) AF93BC56(x16) @SOIC8 AF93BC56(x16) @TSOP8 AF93BC66(x8) AF93BC66(x8) @SOIC8 AF93BC66(x8) @TSOP8 AF93BC66(x16) AF93BC66(x16) @SOIC8 AF93BC66(x16) @TSOP8 AF93BC86(x8) AF93BC86(x8) @SOIC8 AF93BC86(x8) @TSOP8 AF93BC86(x16) AF93BC86(x16) @SOIC8 AF93BC86(x16) @TSOP8 AF93C46(x8) AF93C46(x8) @SOIC8 AF93C46(x8) @TSOP8 AF93C46(x16) AF93C46(x16) @SOIC8 AF93C46(x16) @TSOP8 AF93C56(x8) AF93C56(x8) @SOIC8 AF93C56(x8) @TSOP8 AF93C56(x16) AF93C56(x16) @SOIC8 AF93C56(x16) @TSOP8 AF93C66(x8) AF93C66(x8) @SOIC8 AF93C66(x8) @TSOP8 AF93C66(x16) AF93C66(x16) @SOIC8 AF93C66(x16) @TSOP8 AF93C86(x8) AF93C86(x8) @SOIC8 AF93C86(x8) @TSOP8 AF93C86(x16) AF93C86(x16) @SOIC8 AF93C86(x16) @TSOP8 [ ARTSCHIP ] 42 PCS 24AA02 24AA02 @SOIC8 24AA02 @TSSOP8 24LC01A 24LC01A @SOIC8 24LC01A @TSSOP8 24LC01B 24LC01B @SOIC8 24LC01B @TSSOP8 24LC02A 24LC02A @SOIC8 24LC02A @TSSOP8 24LC02B 24LC02B @SOIC8 24LC02B @TSSOP8 24LC04A 24LC04A @SOIC8 24LC04A @TSSOP8 24LC04B 24LC04B @SOIC8 24LC04B @TSSOP8 24LC08A 24LC08A @SOIC8 24LC08A @TSSOP8 24LC08B 24LC08B @SOIC8 24LC08B @TSSOP8 24LC16A 24LC16A @SOIC8 24LC16A @TSSOP8 24LC32 24LC32 @SOIC8 24LC32 @TSSOP8 24LC64 24LC64 @SOIC8 24LC64 @TSSOP8 24LC128 24LC128 @SOIC8 24LC128 @TSSOP8 24LC256 24LC256 @SOIC8 24LC256 @TSSOP8 [ ASAHI KASEI(AKM) ] 44 PCS AK93C45 AK93C45F @SOP8 AK93C45AV @TSSOP8 AK93C45AF @SOP8 AK93C45BH @MSOP8 AK93C45BL @SON8 AK93C45CT @TMSOP8 AK93C45CL @SON8 AK93C45CU @USON8 AK93C46 AK93C46F @SOP8 AK93C46M AK93C46MF @SOP8 AK93C55 AK93C55F @SOP8 AK93C55AV @TSSOP8 AK93C55AF @SOP8 AK93C55BH @MSOP8 AK93C55BL @SON8 AK93C55CT @TMSOP8 AK93C55CL @SON8 AK93C55CU @USON8 AK93C56 AK93C56F @SOP8 AK93C65 AK93C65F @SOP8 AK93C65AV @TSSOP8 AK93C65AF @SOP8 AK93C65BH @MSOP8 AK93C65BL @SON8 AK93C65CT @TMSOP8 AK93C65CL @SON8 AK93C65CU @USON8 AK93C66 AK93C66F @SOP8 AK93C75 AK93C75F @SOP8 AK93C75AV @TSSOP8 AK93C75AF @SOP8 AK93C75BH @MSOP8 AK93C85AM @SSOP8 AK93C85AF @SOP8 AK93C95AF @SOP8 AK93C10AF @SOP8 [ ASD ] 12 PCS AE29F1008 @DIP32 AE29F1008 @PLCC32 AE29F1008 @TSOP32 AE29F2008 @DIP32 AE29F2008 @PLCC32 AE29F2008 @TSOP32 AE29F4008 @DIP32 AE29F4008 @PLCC32 AE29F4008 @TSOP32 AE49F2008 @DIP32 AE49F2008 @PLCC32 AE49F2008 @TSOP32 [ ASI ] 20 PCS AX24C02 AX24C02 @SOIC8 AX24C04 AX24C04 @SOIC8 AX24C08 AX24C08 @SOIC8 AX24C16 AX24C16 @SOIC8 SMJ27C010A @DIP32 SMJ27C010A @PLCC32 SMJ27C010A @TSOP32 SMJ27C040 @DIP32 SMJ27C040 @PLCC32 SMJ27C040 @TSOP32 SMJ27C128 @DIP28 SMJ27C128 @PLCC32 SMJ27C256 @DIP28 SMJ27C256 @PLCC32 SMJ27C512 @DIP28 SMJ27C512 @PLCC32 [ ATC ] 60 PCS ATC24C02 ATC24C02 @SOIC8 ATC24C02 @TSSOP8 ATC24C04 ATC24C04 @SOIC8 ATC24C04 @TSSOP8 ATC24C08 ATC24C08 @SOIC8 ATC24C08 @TSSOP8 ATC24C16 ATC24C16 @SOIC8 ATC24C16 @TSSOP8 ATC24LC02 ATC24LC02 @SOIC8 ATC24LC02 @TSSOP8 ATC24LC04 ATC24LC04 @SOIC8 ATC24LC04 @TSSOP8 ATC24LC08 ATC24LC08 @SOIC8 ATC24LC08 @TSSOP8 ATC24LC16 ATC24LC16 @SOIC8 ATC24LC16 @TSSOP8 ATC93C46(x8) ATC93C46(x8) @SOIC8 ATC93C46(x16) ATC93C46(x16) @SOIC8 ATC93C46R(x8) @SOIC8 ATC93C46R(x16) @SOIC8 ATC93C56(x8) ATC93C56(x8) @SOIC8 ATC93C56(x16) ATC93C56(x16) @SOIC8 ATC93C56R(x8) @SOIC8 ATC93C56R(x16) @SOIC8 ATC93C66(x8) ATC93C66(x8) @SOIC8 ATC93C66(x16) ATC93C66(x16) @SOIC8 ATC93C66R(x8) @SOIC8 ATC93C66R(x16) @SOIC8 ATC93LC46(x8) ATC93LC46(x8) @SOIC8 ATC93LC46(x16) ATC93LC46(x16) @SOIC8 ATC93LC46R(x8) @SOIC8 ATC93LC46R(x16) @SOIC8 ATC93LC56(x8) ATC93LC56(x8) @SOIC8 ATC93LC56(x16) ATC93LC56(x16) @SOIC8 ATC93LC56R(x8) @SOIC8 ATC93LC56R(x16) @SOIC8 ATC93LC66(x8) ATC93LC66(x8) @SOIC8 ATC93LC66(x16) ATC93LC66(x16) @SOIC8 ATC93LC66R(x8) @SOIC8 ATC93LC66R(x16) @SOIC8 [ ATMEL ] 1183 PCS AT24C01 AT24C01 @MSOP8 AT24C01 @SOIC8 AT24C01 @TSSOP8 AT24C01A AT24C01A @MAP8 AT24C01A @SOIC8 AT24C01A @TSSOP8 AT24C01B AT24C01B @MAP8 AT24C01B @SOIC8 AT24C01B @TSSOP8 AT24C02 AT24C02 @SOIC8 AT24C02 @TSSOP8 AT24C02A AT24C02A @SOIC8 AT24C02A @TSSOP8 AT24C02B AT24C02B @MAP8 AT24C02B @SOIC8 AT24C02B @TSSOP8 AT24C02C AT24C02C @SOIC8 AT24C02C @TSSOP8 AT24C04 AT24C04 @MAP8 AT24C04 @SOIC8 AT24C04 @TSSOP8 AT24C04A AT24C04A @MAP8 AT24C04A @SOIC8 AT24C04A @TSSOP8 AT24C04B AT24C04B @MAP8 AT24C04B @SOIC8 AT24C04B @TSSOP8 AT24C08 AT24C08 @MAP8 AT24C08 @SOIC8 AT24C08 @TSSOP8 AT24C08A AT24C08A @MAP8 AT24C08A @SOIC8 AT24C08A @TSSOP8 AT24C08B AT24C08B @MAP8 AT24C08B @SOIC8 AT24C08B @TSSOP8 AT24C16 AT24C16 @SOIC8 AT24C16 @TSSOP8 AT24C16A AT24C16A @MAP8 AT24C16A @SOIC8 AT24C16A @TSSOP8 AT24C16B AT24C16B @MAP8 AT24C16B @SOIC8 AT24C16B @TSSOP8 AT24C21 AT24C21 @SOIC8 AT24C32 AT24C32 @SOIC8 AT24C32 @TSSOP8 AT24C32A AT24C32A @MAP8 AT24C32A @SOIC8 AT24C32A @TSSOP8 AT24C32C AT24C32C @MAP8 AT24C32C @SOIC8 AT24C32C @TSSOP8 AT24C32D AT24C32D @SOIC8 AT24C32D @TSSOP8 AT24C64 AT24C64 @SOIC8 AT24C64 @TSSOP8 AT24C64A AT24C64A @MAP8 AT24C64A @SOIC8 AT24C64A @TSSOP8 AT24C64B AT24C64B @SOIC8 AT24C64B @TSSOP8 AT24C64C AT24C64C @MAP8 AT24C64C @SOIC8 AT24C64C @TSSOP8 AT24C64D AT24C64D @SOIC8 AT24C64D @TSSOP8 AT24C128 AT24C128 @MAP8 AT24C128 @SOIC8 AT24C128 @TSSOP8 AT24C128 (3.3V) AT24C128 (3.3V) @MAP8 AT24C128 (3.3V) @SOIC8 AT24C128 (3.3V) @TSSOP8 AT24C128B AT24C128B @MAP8 AT24C128B @SOIC8 AT24C128B @TSSOP8 AT24C256 AT24C256 @MAP8 AT24C256 @SOIC8 AT24C256 @TSSOP8 AT24C256 (3.3V) AT24C256 (3.3V) @MAP8 AT24C256 (3.3V) @SOIC8 AT24C256 (3.3V) @TSSOP8 AT24C256B AT24C256B @MAP8 AT24C256B @SOIC8 AT24C256B @TSSOP8 AT24C512 AT24C512 @MAP8 AT24C512 @SOIC8 AT24C512 @TSSOP8 AT24C512 (3.3V) AT24C512 (3.3V) @MAP8 AT24C512 (3.3V) @SOIC8 AT24C512 (3.3V) @TSSOP8 AT24C512B AT24C512B @MAP8 AT24C512B @SOIC8 AT24C512B @TSSOP8 AT24C512C AT24C512C @TSSOP8 AT24C512C @SOIC8 AT24C1024 AT24C1024 @SOIC8 AT24C1024B AT24C1024B @SOIC8 AT24HC02B AT24HC02B @SOIC8 AT24HC02B @TSSOP8 AT24RF08A @SOIC8 AT24RF08B @SOIC8 AT24RF08C @SOIC8 AT25010 AT25010 @SOIC8 AT25010-1.8 AT25010-1.8 @SOIC8 AT25010A AT25010A @SOIC8 AT25010A @TSSOP8 AT25020 AT25020 @SOIC8 AT25020-1.8 AT25020-1.8 @SOIC8 AT25020A AT25020A @SOIC8 AT25020A @TSSOP8 AT25040 AT25040 @SOIC8 AT25040-1.8 AT25040-1.8 @SOIC8 AT25040A AT25040A @SOIC8 AT25040A @TSSOP8 AT25080 AT25080 @SOIC8 AT25080-1.8 AT25080-1.8 @SOIC8 AT25080A AT25080A @SOIC8 AT25080A @TSSOP8 AT25080B AT25080B @SOIC8 AT25080B @TSSOP8 AT25160 AT25160 @SOIC8 AT25160-1.8 AT25160-1.8 @SOIC8 AT25160A AT25160A @SOIC8 AT25160B AT25160B @MAP8 AT25160B @SOIC8 AT25160B @TSSOP8 AT25320 AT25320 @SOIC8 AT25320-1.8 AT25320-1.8 @SOIC8 AT25320A AT25320A @SOIC8 AT25320B AT25320B @MAP8 AT25320B @SOIC8 AT25320B @TSSOP8 AT25640 AT25640 @SOIC8 AT25640-1.8 AT25640-1.8 @SOIC8 AT25640A AT25640A @SOIC8 AT25640B AT25640B @SOIC8 AT25640B @TSSOP8 AT25128 AT25128 @SOIC8 AT25128-1.8 AT25128-1.8 @SOIC8 AT25128A AT25128A @SOIC8 AT25128B AT25128B @SOIC8 AT25128B @TSSOP8 AT25256 AT25256 @SOIC8 AT25256-1.8 AT25256-1.8 @SOIC8 AT25256A AT25256A @SOIC8 AT25256B AT25256B @SOIC8 AT25256B @TSSOP8 AT25512 AT25512 @SOIC8 AT25512 @TSSOP8 AT25512-1.8 AT25512-1.8 @SOIC8 AT25512-1.8 @TSSOP8 AT25DF021 AT25DF021 @SOIC8 AT25DF021 @UDFN8 AT25DF041 AT25DF041 @SOIC8 AT25DF041 @UDFN8 AT25DF041A AT25DF041A @SOIC8 AT25DF041A @UDFN8 AT25DF081 AT25DF081 @SOIC8 AT25DF081 @UDFN8 AT25DF081A AT25DF081A @SOIC8 AT25DF081A @UDFN8 AT25DF161 AT25DF161 @SOIC8 AT25DF161 @UDFN8 AT25DF321 AT25DF321 @SOIC8 AT25DF321A AT25DF321A @SOIC8 AT25DF321A @UDFN8 AT25F512 AT25F512 @SOIC8 AT25F512 @VQFPN8 AT25F512A AT25F512A @SOIC8 AT25F512A @VQFPN8 AT25F1024 AT25F1024 @SOIC8 AT25F1024 @VQFPN8 AT25F1024A AT25F1024A @SOIC8 AT25F1024A @VQFPN8 AT25F2048 AT25F2048 @SOIC8 AT25F2048 @VQFPN8 AT25F2048A AT25F2048A @SOIC8 AT25F2048A @VQFPN8 AT25F4096 AT25F4096 @SOIC8 AT25F4096 @VQFPN8 AT25F4096A AT25F4096A @SOIC8 AT25F4096A @VQFPN8 AT25HP256 AT25HP256 @SOIC8 AT25HP256-1.8 AT25HP256-1.8 @SOIC8 AT25HP512 AT25HP512 @SOIC8 AT25HP512-1.8 AT25HP512-1.8 @SOIC8 AT26DF081 @SOIC8 AT26DF081 @UDFN8 AT26DF081A @SOIC8 AT26DF081A @UDFN8 AT26DF161 @SOIC8 AT26DF161 @UDFN8 AT26DF161A @SOIC8 AT26DF161A @UDFN8 AT26DF321 AT26DF321 @SOIC8 AT26DF321 @SOIC16 AT26DF321A AT26DF321A @SOIC8 AT26DF321A @SOIC16 AT26F004 AT26F004 @MLF8 AT26F004 @SOIC8 AT2732A @DIP24 AT27256 @DIP28 AT27256 @PLCC32 AT27C010 @DIP32 AT27C010 @PLCC32 AT27C010 @TSOP32 AT27C010L @DIP32 AT27C010L @PLCC32 AT27C010L @TSOP32 AT27C020 @DIP32 AT27C020 @PLCC32 AT27C020 @TSOP32 AT27C040 @DIP32 AT27C040 @PLCC32 AT27C040 @TSOP32 AT27C080 @DIP32 AT27C080 @PLCC32 AT27C080 @TSOP32 AT27C128 @DIP28 AT27C128 @PLCC32 AT27C256 @DIP28 AT27C256 @PLCC32 AT27C256R @DIP28 AT27C256R @PLCC32 AT27C256R @SOIC28 AT27C512 @DIP28 AT27C512 @PLCC32 AT27C512R @DIP28 AT27C512R @PLCC32 AT27C512R @SOIC28 AT27C1024 @DIP40 AT27C1024L @DIP40 AT27C2048 @DIP40 AT27C4096 @DIP40 AT27HC256 AT27HC256 @PLCC32 AT27HC256L AT27HC256L @PLCC32 AT27HC256R AT27HC256R @PLCC32 AT27HC256RL AT27HC256RL @PLCC32 AT27HC1024 @DIP40 AT27BV010 AT27BV010 @PLCC32 AT27BV010 @TSOP32 AT27BV010 @VSOP32 AT27BV020 AT27BV020 @PLCC32 AT27BV020 @TSOP32 AT27BV020 @VSOP32 AT27BV040 AT27BV040 @PLCC32 AT27BV040 @TSOP32 AT27BV040 @VSOP32 AT27BV256 AT27BV256 @PLCC32 AT27BV256 @SOIC28 AT27BV512 AT27BV512 @PLCC32 AT27BV512 @SOIC28 AT27BV1024 @DIP40 AT27BV2048 @DIP40 AT27BV4096 @DIP40 AT27LV010 AT27LV010 @PLCC32 AT27LV010 @TSOP32 AT27LV010 @VSOP32 AT27LV010A AT27LV010A @PLCC32 AT27LV010A @TSOP32 AT27LV010A @VSOP32 AT27LV020 AT27LV020 @PLCC32 AT27LV020 @TSOP32 AT27LV020 @VSOP32 AT27LV020A AT27LV020A @PLCC32 AT27LV020A @TSOP32 AT27LV020A @VSOP32 AT27LV040 AT27LV040 @PLCC32 AT27LV040 @TSOP32 AT27LV040 @VSOP32 AT27LV040A AT27LV040A @PLCC32 AT27LV040A @TSOP32 AT27LV040A @VSOP32 AT27LV256A AT27LV256A @PLCC32 AT27LV256A @SOIC28 AT27LV256R AT27LV256R @PLCC32 AT27LV256R @SOIC28 AT27LV512A AT27LV512A @PLCC32 AT27LV512A @SOIC28 AT27LV512R AT27LV512R @PLCC32 AT27LV512R @SOIC28 AT27LV1024 @DIP40 AT27LV2048 @DIP40 AT27LV4096 @DIP40 AT28BV64 AT28BV64 @PLCC32 AT28BV64 @SOIC28 AT28BV64B AT28BV64B @PLCC32 AT28BV64B @SOIC28 AT28BV256 AT28BV256 @PLCC32 AT28C010 AT28C010 @PLCC32 AT28C010 @TSOP32 AT28C010E AT28C010E @PLCC32 AT28C010E @TSOP32 AT28C04 @DIP24 AT28C04 @PLCC32 AT28C04 @SOIC24 AT28C04E @DIP24 AT28C04E @PLCC32 AT28C04E @SOIC24 AT28C04F @DIP24 AT28C04F @PLCC32 AT28C04F @SOIC24 AT28C040 AT28C040 @PLCC32 AT28C040 @TSOP32 AT28C040E AT28C040E @PLCC32 AT28C040E @TSOP32 AT28C16 @DIP24 AT28C16 @PLCC32 AT28C16 @SOIC24 AT28C16E @DIP24 AT28C16E @PLCC32 AT28C16E @SOIC24 AT28C16F @DIP24 AT28C16F @PLCC32 AT28C16F @SOIC24 AT28C17 AT28C17 @PLCC32 AT28C17 @SOIC28 AT28C17E AT28C17E @PLCC32 AT28C17E @SOIC28 AT28C17F AT28C17F @PLCC32 AT28C17F @SOIC28 AT28C256 AT28C256 @PLCC32 AT28C256 @SOIC28 AT28C256E AT28C256E @PLCC32 AT28C256E @SOIC28 AT28C256F AT28C256F @PLCC32 AT28C256F @SOIC28 AT28C64 AT28C64 @PLCC32 AT28C64 @SOIC28 AT28C64B AT28C64B @PLCC32 AT28C64B @SOIC28 AT28C64E AT28C64E @PLCC32 AT28C64E @SOIC28 AT28C64F AT28C64F @PLCC32 AT28C64F @SOIC28 AT28HC04 AT28HC04 @PLCC32 AT28HC16 AT28HC16L AT28HC256 AT28HC256 @PLCC32 AT28HC256E AT28HC256E @PLCC32 AT28HC256F AT28HC256F @PLCC32 AT28HC256L AT28HC256L @PLCC32 AT28HC64 AT28HC64 @PLCC32 AT28HC64 @SOIC28 AT28HC64B AT28HC64B @PLCC32 AT28HC64B @SOIC28 AT28HC64BF AT28HC64BF @PLCC32 AT28HC64BF @SOIC28 AT28HC64L AT28HC64L @PLCC32 AT28HC64L @SOIC28 AT28LV64 AT28LV64 @PLCC32 AT28LV64 @SOIC28 AT28LV64B AT28LV64B @PLCC32 AT28LV64B @SOIC28 AT28LV256 AT28LV256 @PLCC32 AT28LV010 AT28LV010 @PLCC32 AT28LV010 @TSOP32 AT28MC010 AT28MC010 @PLCC32 AT28MC010 @TSOP32 AT28MC020 AT28MC020 @PLCC32 AT28MC020 @TSOP32 AT28MC040 AT28MC040 @PLCC32 AT28MC040 @TSOP32 AT28PC64 AT28PC64 @PLCC32 AT28PC64 @SOIC28 AT28PC64E AT28PC64E @PLCC32 AT28PC64E @SOIC28 AT29BV010A AT29BV010A @PLCC32 AT29BV010A @TSOP32 AT29BV020 AT29BV020 @PLCC32 AT29BV020 @TSOP32 AT29BV040 AT29BV040 @PLCC32 AT29BV040 @TSOP32 AT29BV040A AT29BV040A @PLCC32 AT29BV040A @TSOP32 AT29C256 @DIP28 AT29C257 AT29C257 @PLCC32 AT29C512 AT29C512 @PLCC32 AT29C512 @TSOP32 AT29C010A AT29C010A @PLCC32 AT29C010A @TSOP32 AT29C020 AT29C020 @PLCC32 AT29C020 @TSOP32 AT29C040 AT29C040 @PLCC32 AT29C040 @TSOP32 AT29C040A AT29C040A @PLCC32 AT29C040A @TSOP32 AT29LV256 @DIP28 AT29LV512 AT29LV512 @PLCC32 AT29LV512 @TSOP32 AT29LV010A AT29LV010A @PLCC32 AT29LV010A @TSOP32 AT29LV020 AT29LV020 @PLCC32 AT29LV020 @TSOP32 AT29LV040 AT29LV040 @PLCC32 AT29LV040 @TSOP32 AT29LV040A AT29LV040A @PLCC32 AT29LV040A @TSOP32 AT45DB011B @ICSP AT45DB021B @ICSP AT45DB041B @ICSP AT45DB081B @ICSP AT45DB161B @ICSP AT45DB011D[Page264] @ICSP AT45DB011D[Page256] @ICSP AT45DB021D[Page264] @ICSP AT45DB021D[Page256] @ICSP AT45DB041D[Page264] @ICSP AT45DB041D[Page256] @ICSP AT45DB081D[Page264] @ICSP AT45DB081D[Page256] @ICSP AT45DB161D[Page528] @ICSP AT45DB161D[Page512] @ICSP AT49BV001 AT49BV001 @PLCC32 AT49BV001 @TSOP32 AT49BV001 @VSOP32 AT49BV001A AT49BV001A @PLCC32 AT49BV001A @TSOP32 AT49BV001A @VSOP32 AT49BV001AN AT49BV001AN @PLCC32 AT49BV001AN @TSOP32 AT49BV001AN @VSOP32 AT49BV001ANT AT49BV001ANT @PLCC32 AT49BV001ANT @TSOP32 AT49BV001ANT @VSOP32 AT49BV001AT AT49BV001AT @PLCC32 AT49BV001AT @TSOP32 AT49BV001AT @VSOP32 AT49BV001N AT49BV001N @PLCC32 AT49BV001N @TSOP32 AT49BV001N @VSOP32 AT49BV001NT AT49BV001NT @PLCC32 AT49BV001NT @TSOP32 AT49BV001NT @VSOP32 AT49BV001T AT49BV001T @PLCC32 AT49BV001T @TSOP32 AT49BV001T @VSOP32 AT49BV002 AT49BV002 @PLCC32 AT49BV002 @TSOP32 AT49BV002 @VSOP32 AT49BV002A AT49BV002A @PLCC32 AT49BV002A @TSOP32 AT49BV002A @VSOP32 AT49BV002AN AT49BV002AN @PLCC32 AT49BV002AN @TSOP32 AT49BV002AN @VSOP32 AT49BV002ANT AT49BV002ANT @PLCC32 AT49BV002ANT @TSOP32 AT49BV002ANT @VSOP32 AT49BV002AT AT49BV002AT @PLCC32 AT49BV002AT @TSOP32 AT49BV002AT @VSOP32 AT49BV002N AT49BV002N @PLCC32 AT49BV002N @TSOP32 AT49BV002N @VSOP32 AT49BV002NT AT49BV002NT @PLCC32 AT49BV002NT @TSOP32 AT49BV002NT @VSOP32 AT49BV002T AT49BV002T @PLCC32 AT49BV002T @TSOP32 AT49BV002T @VSOP32 AT49BV004 @TSOP40 AT49BV004T @TSOP40 AT49BV008A @TSOP40 AT49BV008AT @TSOP40 AT49BV010 AT49BV010 @PLCC32 AT49BV010 @TSOP32 AT49BV010 @VSOP32 AT49BV020 AT49BV020 @PLCC32 AT49BV020 @TSOP32 AT49BV020 @VSOP32 AT49BV040 AT49BV040 @PLCC32 AT49BV040 @TSOP32 AT49BV040 @VSOP32 AT49BV040A AT49BV040A @PLCC32 AT49BV040A @TSOP32 AT49BV040A @VSOP32 AT49BV040B AT49BV040B @PLCC32 AT49BV040B @TSOP32 AT49BV040B @VSOP32 AT49BV040T AT49BV040T @PLCC32 AT49BV040T @TSOP32 AT49BV040T @VSOP32 AT49BV080 @TSOP40 AT49BV080T @TSOP40 AT49BV1024A @VSOP40 AT49BV160 @TSOP48 AT49BV160T @TSOP48 AT49BV161 @TSOP48 AT49BV161T @TSOP48 AT49BV1604 @TSOP48 AT49BV1604T @TSOP48 AT49BV1614 @TSOP48 AT49BV1614T @TSOP48 AT49BV162A @TSOP48 AT49BV162AT @TSOP48 AT49BV163A @TSOP48 AT49BV163AT @TSOP48 AT49BV2048A @TSOP48 AT49BV320 @TSOP48 AT49BV320T @TSOP48 AT49BV320D @TSOP48 AT49BV321 @TSOP48 AT49BV321T @TSOP48 AT49BV322 @TSOP48 AT49BV322T @TSOP48 AT49BV3218 @TSOP48 AT49BV3218T @TSOP48 AT49BV4096A @TSOP48 AT49BV4096AT @TSOP48 AT49BV512 AT49BV512 @PLCC32 AT49BV512 @TSOP32 AT49BV512 @VSOP32 AT49BV6416 @TSOP48 AT49BV6416T @TSOP48 AT49BV8011 @TSOP48 AT49BV8011T @TSOP48 AT49BV802A @TSOP48 AT49BV802AT @TSOP48 AT49BV8192A @TSOP48 AT49BV8192AT @TSOP48 AT49F001 AT49F001 @PLCC32 AT49F001 @TSOP32 AT49F001 @VSOP32 AT49F001A AT49F001A @PLCC32 AT49F001A @TSOP32 AT49F001A @VSOP32 AT49F001AN AT49F001AN @PLCC32 AT49F001AN @TSOP32 AT49F001AN @VSOP32 AT49F001ANT AT49F001ANT @PLCC32 AT49F001ANT @TSOP32 AT49F001ANT @VSOP32 AT49F001AT AT49F001AT @PLCC32 AT49F001AT @TSOP32 AT49F001AT @VSOP32 AT49F001N AT49F001N @PLCC32 AT49F001N @TSOP32 AT49F001N @VSOP32 AT49F001NT AT49F001NT @PLCC32 AT49F001NT @TSOP32 AT49F001NT @VSOP32 AT49F001T AT49F001T @PLCC32 AT49F001T @TSOP32 AT49F001T @VSOP32 AT49F002 AT49F002 @PLCC32 AT49F002 @TSOP32 AT49F002 @VSOP32 AT49F002A AT49F002A @PLCC32 AT49F002A @TSOP32 AT49F002A @VSOP32 AT49F002AN AT49F002AN @PLCC32 AT49F002AN @TSOP32 AT49F002AN @VSOP32 AT49F002ANT AT49F002ANT @PLCC32 AT49F002ANT @TSOP32 AT49F002ANT @VSOP32 AT49F002AT AT49F002AT @PLCC32 AT49F002AT @TSOP32 AT49F002AT @VSOP32 AT49F002N AT49F002N @PLCC32 AT49F002N @TSOP32 AT49F002N @VSOP32 AT49F002NT AT49F002NT @PLCC32 AT49F002NT @TSOP32 AT49F002NT @VSOP32 AT49F002T AT49F002T @PLCC32 AT49F002T @TSOP32 AT49F002T @VSOP32 AT49F004 @TSOP40 AT49F004T @TSOP40 AT49F008 @TSOP40 AT49F008A @TSOP40 AT49F008AT @TSOP40 AT49F010 AT49F010 @PLCC32 AT49F010 @TSOP32 AT49F020 AT49F020 @PLCC32 AT49F020 @TSOP32 AT49F040 AT49F040 @PLCC32 AT49F040 @TSOP32 AT49F040A AT49F040A @PLCC32 AT49F040A @TSOP32 AT49F040T AT49F040T @PLCC32 AT49F040T @TSOP32 AT49F080 @TSOP40 AT49F080T @TSOP40 AT49F1024 @VSOP40 AT49F1024A @VSOP40 AT49F1604 @TSOP48 AT49F1604T @TSOP48 AT49F1614 @TSOP48 AT49F1614T @TSOP48 AT49F2048 @TSOP48 AT49F2048A @TSOP48 AT49F4096 @TSOP48 AT49F4096A @TSOP48 AT49F4096AT @TSOP48 AT49F512 AT49F512 @PLCC32 AT49F512 @TSOP32 AT49F512 @VSOP32 AT49F8011 @TSOP48 AT49F8011T @TSOP48 AT49F8192 @TSOP48 AT49F8192A @TSOP48 AT49F8192AT @TSOP48 AT49F8192T @TSOP48 AT49HBV010 AT49HBV010 @PLCC32 AT49HBV010 @TSOP32 AT49HBV010 @VSOP32 AT49HF010 @DIP32 AT49HF010 @PLCC32 AT49HF010 @TSOP32 AT49HLV010 AT49HLV010 @PLCC32 AT49HLV010 @TSOP32 AT49HLV010 @VSOP32 AT49LH002 @PLCC32 AT49LH002 @TSOP40 AT49LH004 @PLCC32 AT49LH004 @TSOP40 AT49LL020 @PLCC32 AT49LL020 @TSOP40 AT49LL040 @PLCC32 AT49LL040 @TSOP40 AT49LL080 @PLCC32 AT49LL080 @TSOP40 AT49LV001 AT49LV001 @PLCC32 AT49LV001 @TSOP32 AT49LV001 @VSOP32 AT49LV001N AT49LV001N @PLCC32 AT49LV001N @TSOP32 AT49LV001N @VSOP32 AT49LV001NT AT49LV001NT @PLCC32 AT49LV001NT @TSOP32 AT49LV001NT @VSOP32 AT49LV001T AT49LV001T @PLCC32 AT49LV001T @TSOP32 AT49LV001T @VSOP32 AT49LV002 AT49LV002 @PLCC32 AT49LV002 @TSOP32 AT49LV002 @VSOP32 AT49LV002N AT49LV002N @PLCC32 AT49LV002N @TSOP32 AT49LV002N @VSOP32 AT49LV002NT AT49LV002NT @PLCC32 AT49LV002NT @TSOP32 AT49LV002NT @VSOP32 AT49LV002T AT49LV002T @PLCC32 AT49LV002T @TSOP32 AT49LV002T @VSOP32 AT49LV008A @TSOP40 AT49LV008AT @TSOP40 AT49LV010 AT49LV010 @PLCC32 AT49LV010 @TSOP32 AT49LV010 @VSOP32 AT49LV020 AT49LV020 @PLCC32 AT49LV020 @TSOP32 AT49LV020 @VSOP32 AT49LV040 AT49LV040 @PLCC32 AT49LV040 @TSOP32 AT49LV040 @VSOP32 AT49LV040T AT49LV040T @PLCC32 AT49LV040T @TSOP32 AT49LV040T @VSOP32 AT49LV080 @TSOP40 AT49LV080T @TSOP40 AT49LV1024 @VSOP40 AT49LV1024A @VSOP40 AT49LV160 @TSOP48 AT49lV160T @TSOP48 AT49LV161 @TSOP48 AT49LV161T @TSOP48 AT49LV1614 @TSOP48 AT49LV1614T @TSOP48 AT49LV2048 @TSOP48 AT49LV2048A @TSOP48 AT49LV320 @TSOP48 AT49LV320T @TSOP48 AT49LV320D @TSOP48 AT49LV321 @TSOP48 AT49LV321T @TSOP48 AT49LV3218 @TSOP48 AT49LV3218T @TSOP48 AT49LV4096 @TSOP48 AT49LV4096A @TSOP48 AT49LV4096AT @TSOP48 AT49LV512 AT49LV512 @PLCC32 AT49LV512 @TSOP32 AT49LV512 @VSOP32 AT49LV8011 @TSOP48 AT49LV8011T @TSOP48 AT49LV8192 @TSOP48 AT49LV8192A @TSOP48 AT49LV8192AT @TSOP48 AT49LV8192T @TSOP48 AT49LW040 @PLCC32 AT49LW040 @TSOP40 AT49LW080 @PLCC32 AT49LW080 @TSOP40 AT89C1051 AT89C1051 @SOIC20 AT89C1051U AT89C1051U @SOIC20 AT89C2051 AT89C2051 @SOIC20 AT89C2051x2 AT89C2051x2 @SOIC20 AT89C4051 AT89C4051 @SOIC20 AT89C51 AT89C51 @PLCC44 AT89C52 AT89C52 @PLCC44 AT89C55 AT89C55 @PLCC44 AT89C55WD AT89C55WD @PLCC44 AT89C51RC AT89C51RC @PLCC44 AT89LS51 AT89LS51 @PLCC44 AT89LS52 AT89LS52 @PLCC44 AT89LS53 AT89LS53 @PLCC44 AT89LS8252 AT89LS8252 @PLCC44 AT89LS8253 AT89LS8253 @PLCC44 AT89LV51 AT89LV51 @PLCC44 AT89LV52 AT89LV52 @PLCC44 AT89LV55 AT89LV55 @PLCC44 AT89S51 AT89S51 @PLCC44 AT89S52 AT89S52 @PLCC44 AT89S53 AT89S53 @PLCC44 AT89S8252 AT89S8252 @PLCC44 AT89S8253 AT89S8253 @PLCC44 AT90S1200 AT90S1200 @SOIC20 AT90S1200 @SSOP20 AT90S2313 AT90S2313 @SOIC20 AT90S2333 AT90S4414 AT90S4433 AT90S4434 AT90S8515 AT90S8535 AT90SLS2313 AT90SLS2313 @SOIC20 AT90SLS2333 AT90SLS4414 AT90SLS4433 AT90SLS4434 AT90SLS8515 AT90SLS8535 AT93C46(x8) AT93C46(x8) @SOIC8 AT93C46(x8) @TSOP8 AT93C46(x16) AT93C46(x16) @SOIC8 AT93C46(x16) @TSOP8 AT93C46A AT93C46A @SOIC8 AT93C46A @TSOP8 AT93C46C AT93C46C @SOIC8 AT93C46C @TSOP8 AT93C46D(x8) AT93C46D(x8) @SOIC8 AT93C46D(x8) @TSOP8 AT93C46D(x16) AT93C46D(x16) @SOIC8 AT93C46D(x16) @TSOP8 AT93C46E AT93C46E @SOIC8 AT93C46E @TSOP8 AT93C46R(x8) AT93C46R(x8) @SOIC8 AT93C46R(x8) @TSOP8 AT93C46R(x16) AT93C46R(x16) @SOIC8 AT93C46R(x16) @TSOP8 AT93C56(x8) AT93C56(x8) @SOIC8 AT93C56(x16) AT93C56(x16) @SOIC8 AT93C56A(x8) AT93C56A(x8) @SOIC8 AT93C56A(x8) @TSOP8 AT93C56A(x16) AT93C56A(x16) @SOIC8 AT93C56A(x16) @TSOP8 AT93C57(x8) AT93C57(x8) @SOIC8 AT93C57(x8) @TSOP8 AT93C57(x16) AT93C57(x16) @SOIC8 AT93C57(x16) @TSOP8 AT93C66(x8) AT93C66(x8) @SOIC8 AT93C66(x8) @TSOP8 AT93C66(x16) AT93C66(x16) @SOIC8 AT93C66(x16) @TSOP8 AT93C66A(x8) AT93C66A(x8) @SOIC8 AT93C66A(x8) @TSOP8 AT93C66A(x16) AT93C66A(x16) @SOIC8 AT93C66A(x16) @TSOP8 AT93C86(x8) AT93C86(x8) @SOIC8 AT93C86(x8) @TSOP8 AT93C86(x16) AT93C86(x16) @SOIC8 AT93C86(x16) @TSOP8 AT93C86A(x8) AT93C86A(x8) @SOIC8 AT93C86A(x8) @TSOP8 AT93C86A(x16) AT93C86A(x16) @SOIC8 AT93C86A(x16) @TSOP8 ATF16V8B ATMEGA8 ATMEGA8L ATMEGA8A ATMEGA16 ATMEGA16L ATMEGA16A ATMEGA32 ATMEGA32L ATMEGA32A ATMEGA48 ATMEGA48V ATMEGA48A ATMEGA48PA ATMEGA64 @TQFP64 ATMEGA64A @TQFP64 ATMEGA64L @TQFP64 ATMEGA88 ATMEGA88V ATMEGA88A ATMEGA88PA ATMEGA128 @TQFP64 ATMEGA128A @TQFP64 ATMEGA128L @TQFP64 ATMEGA162 ATMEGA162V ATMEGA164A ATMEGA164PA ATMEGA165A @TQFP64 ATMEGA165P @TQFP64 ATMEGA165PA @TQFP64 ATMEGA165PV @TQFP64 ATMEGA168 ATMEGA168A ATMEGA168PA ATMEGA168V ATMEGA169A @TQFP64 ATMEGA169P @TQFP64 ATMEGA169PA @TQFP64 ATMEGA169PV @TQFP64 ATMEGA324A ATMEGA324PA ATMEGA325A @TQFP64 ATMEGA325PA @TQFP64 ATMEGA328 ATMEGA328P ATMEGA329A @TQFP64 ATMEGA329PA @TQFP64 ATMEGA644A ATMEGA644PA ATMEGA645A @TQFP64 ATMEGA645P @TQFP64 ATMEGA649A @TQFP64 ATMEGA649P @TQFP64 ATMEGA1284 ATMEGA1284P ATMEGA8515 ATMEGA8515L ATMEGA8535 ATMEGA8535L ATTINY11 ATTINY11 @SOIC8 ATTINY11L ATTINY11L @SOIC8 ATTINY12 ATTINY12 @SOIC8 ATTINY12V ATTINY12V @SOIC8 ATTINY12L ATTINY12L @SOIC8 ATTINY13 ATTINY13 @SOIC8 ATTINY13V ATTINY13V @SOIC8 ATTINY13A ATTINY13A @SOIC8 ATTINY15 ATTINY15 @SOIC8 ATTINY15L ATTINY15L @SOIC8 ATTINY24 ATTINY24 @SOIC14 ATTINY24A ATTINY24A @SOIC14 ATTINY24V ATTINY24V @SOIC14 ATTINY25 ATTINY25 @SOIC8 ATTINY25V ATTINY25V @SOIC8 ATTINY26 ATTINY26 @SOIC20 ATTINY26 @SSOP20 ATTINY26L ATTINY26L @SOIC20 ATTINY26L @SSOP20 ATTINY28L ATTINY28V ATTINY44 ATTINY44 @SOIC14 ATTINY44A ATTINY44A @SOIC14 ATTINY44V ATTINY44V @SOIC14 ATTINY45 ATTINY45 @SOIC8 ATTINY45V ATTINY45V @SOIC8 ATTINY84 ATTINY84 @SOIC14 ATTINY84A ATTINY84A @SOIC14 ATTINY84V ATTINY84V @SOIC14 ATTINY85 ATTINY85 @SOIC8 ATTINY85V ATTINY85V @SOIC8 ATTINY2313 ATTINY2313 @SOIC20 ATTINY2313V ATTINY2313V @SOIC20 ATTINY2313A ATTINY2313A @SOIC20 ATTINY4313 ATTINY4313 @SOIC20 [ BELLING ] 24 PCS BL24C02 BL24C02 @SOIC8 BL24C02 @TSSOP8 BL24C04 BL24C04 @SOIC8 BL24C04 @TSSOP8 BL24C08 BL24C08 @SOIC8 BL24C08 @TSSOP8 BL24C16 BL24C16 @SOIC8 BL24C16 @TSSOP8 BL24C32 BL24C32 @SOIC8 BL24C32 @TSSOP8 BL24C64 BL24C64 @SOIC8 BL24C64 @TSSOP8 BL24C128 BL24C128 @SOIC8 BL24C128 @TSSOP8 BL24C256 BL24C256 @SOIC8 BL24C256 @TSSOP8 [ BJX ] 12 PCS BJX24LC02 BJX24LC02 @SOIC8 BJX24LC02 @TSSOP8 BJX24LC04 BJX24LC04 @SOIC8 BJX24LC04 @TSSOP8 BJX24LC08 BJX24LC08 @SOIC8 BJX24LC08 @TSSOP8 BJX24LC16 BJX24LC16 @SOIC8 BJX24LC16 @TSSOP8 [ BMT ] 2 PCS BM29LV160B @TSOP48 BM29LV160T @TSOP48 [ BOOKLY MICRO ] 12 PCS 24C02 24C02 @SOIC8 24C02 @TSSOP8 24C04 24C04 @SOIC8 24C04 @TSSOP8 24C08 24C08 @SOIC8 24C08 @TSSOP8 24C16 24C16 @SOIC8 24C16 @TSSOP8 [ BRIGHT ] 6 PCS BM29F400B @TSOP48 BM29F400B @SOP44 BM29F400T @TSOP48 BM29F400T @SOP44 BM29LV160B @TSOP48 BM29LV160T @TSOP48 [ CATALYST(CSI) ] 394 PCS CAT24AA01 @SOIC8 CAT24AA02 @SOIC8 CAT24AA04 @SOIC8 CAT24AA08 @SOIC8 CAT24AA16 @SOIC8 CAT24AC128 CAT24AC128 @SOIC8 CAT24C00 CAT24C00 @SOIC8 CAT24C00 @TSSOP8 CAT24C01 CAT24C01 @SOIC8 CAT24C01 @TSSOP8 CAT24C01B CAT24C01B @MSOP8 CAT24C01B @SOIC8 CAT24C01B @TSSOP8 CAT24C02 CAT24C02 @SOIC8 CAT24C02 @TSSOP8 CAT24C03 CAT24C03 @SOIC8 CAT24C03 @TSSOP8 CAT24C04 CAT24C04 @SOIC8 CAT24C04 @TSSOP8 CAT24C05 CAT24C05 @SOIC8 CAT24C05 @TSSOP8 CAT24C08 CAT24C08 @SOIC8 CAT24C08 @TSSOP8 CAT24C09 CAT24C09 @SOIC8 CAT24C09 @TSSOP8 CAT24C16 CAT24C16 @SOIC8 CAT24C16 @TSSOP8 CAT24C21 CAT24C21 @SOIC8 CAT24C21 @TSSOP8 CAT24C32 CAT24C32 @SOIC8 CAT24C32 @TSSOP8 CAT24C64 CAT24C64 @SOIC8 CAT24C64 @TSSOP8 CAT24C128 CAT24C128 @SOIC8 CAT24C128 @TSSOP8 CAT24C256 CAT24C256 @SOIC8 CAT24C256 @TSSOP8 CAT24FC01 CAT24FC01 @SOIC8 CAT24FC01 @TSSOP8 CAT24FC02 CAT24FC02 @SOIC8 CAT24FC02 @TSSOP8 CAT24FC16 CAT24FC16 @SOIC8 CAT24FC16 @TSSOP8 CAT24FC17 CAT24FC17 @SOIC8 CAT24FC17 @TSSOP8 CAT24FC32 CAT24FC32 @SOIC8 CAT24FC32 @TSSOP8 CAT24FC64 CAT24FC64 @SOIC8 CAT24FC64 @TSSOP8 CAT24FC65 CAT24FC65 @SOIC8 CAT24FC65 @TSSOP8 CAT24FC128 CAT24FC128 @SOIC8 CAT24FC128 @TSSOP8 CAT24FC256 CAT24FC256 @SOIC8 CAT24FC256 @TSSOP8 CAT24LC02 CAT24LC02 @SOIC8 CAT24LC04 CAT24LC04 @SOIC8 CAT24LC08 CAT24LC08 @SOIC8 CAT24LC16 CAT24LC16 @SOIC8 CAT24WC01 CAT24WC01 @SOIC8 CAT24WC01 @TSSOP8 CAT24WC02 CAT24WC02 @SOIC8 CAT24WC02 @TSSOP8 CAT24WC03 CAT24WC03 @SOIC8 CAT24WC03 @TSSOP8 CAT24WC04 CAT24WC04 @SOIC8 CAT24WC04 @TSSOP8 CAT24WC05 CAT24WC05 @SOIC8 CAT24WC05 @TSSOP8 CAT24WC08 CAT24WC08 @SOIC8 CAT24WC08 @TSSOP8 CAT24WC09 CAT24WC09 @SOIC8 CAT24WC09 @TSSOP8 CAT24WC16 CAT24WC16 @SOIC8 CAT24WC16 @TSSOP8 CAT24WC17 CAT24WC17 @SOIC8 CAT24WC17 @TSSOP8 CAT24WC32 CAT24WC32 @SOIC8 CAT24WC32 @TSSOP8 CAT24WC33 CAT24WC33 @SOIC8 CAT24WC33 @TSSOP8 CAT24WC64 CAT24WC64 @SOIC8 CAT24WC64 @TSSOP8 CAT24WC65 CAT24WC65 @SOIC8 CAT24WC66 CAT24WC66 @SOIC8 CAT24WC128 CAT24WC128 @SOIC8 CAT24WC128 @TSSOP8 CAT24WC129 CAT24WC129 @SOIC8 CAT24WC256 CAT24WC256 @SOIC8 CAT24WC256 @TSSOP8 CAT25010 CAT25010 @SOIC8 CAT25010 @TSSOP8 CAT25020 CAT25020 @SOIC8 CAT25020 @TSSOP8 CAT25040 CAT25040 @SOIC8 CAT25040 @TSSOP8 CAT25080 CAT25080 @SOIC8 CAT25080 @TSSOP8 CAT25160 CAT25160 @SOIC8 CAT25160 @TSSOP8 CAT25320 CAT25320 @SOIC8 CAT25320 @TSSOP8 CAT25640 CAT25640 @SOIC8 CAT25640 @TSSOP8 CAT25128 CAT25128 @SOIC8 CAT25128 @TSSOP8 CAT25256 CAT25256 @SOIC8 CAT25256 @TSSOP8 CAT25C01 CAT25C01 @SOIC8 CAT25C01 @TSSOP8 CAT25C02 CAT25C02 @SOIC8 CAT25C02 @TSSOP8 CAT25C03 CAT25C03 @SOIC8 CAT25C03 @TSSOP8 CAT25C04 CAT25C04 @SOIC8 CAT25C04 @TSSOP8 CAT25C05 CAT25C05 @SOIC8 CAT25C05 @TSSOP8 CAT25C08 CAT25C08 @SOIC8 CAT25C08 @TSSOP8 CAT25C09 CAT25C09 @SOIC8 CAT25C09 @TSSOP8 CAT25C16 CAT25C16 @SOIC8 CAT25C16 @TSSOP8 CAT25C17 CAT25C17 @SOIC8 CAT25C17 @TSSOP8 CAT25C32 CAT25C32 @SOIC8 CAT25C32 @TSSOP8 CAT25C33 CAT25C33 @SOIC8 CAT25C33 @TSSOP8 CAT25C64 CAT25C64 @SOIC8 CAT25C64 @TSSOP8 CAT25C65 CAT25C65 @SOIC8 CAT25C65 @TSSOP8 CAT25C128 CAT25C128 @SOIC8 CAT25C128 @TSSOP8 CAT25C256 CAT25C256 @SOIC8 CAT25C256 @TSSOP8 CAT27010 @DIP32 CAT27010 @PLCC32 CAT27010 @TSOP32 CAT2764A @DIP28 CAT2764A @PLCC32 CAT27128A @DIP28 CAT27128A @PLCC32 CAT27256 @DIP28 CAT27256 @PLCC32 CAT27512 @DIP28 CAT27512 @PLCC32 CAT27C16 @DIP24 CAT27C210 @DIP40 CAT27HC256 @DIP28 CAT27HC256 @PLCC32 CAT27HC256I @DIP28 CAT27HC256I @PLCC32 CAT28C16A CAT28C16A @PLCC32 CAT28C16A @SOIC24 CAT28C16AI CAT28C16AI @PLCC32 CAT28C16AI @SOIC24 CAT28C17A CAT28C17A @PLCC32 CAT28C17A @SOIC28 CAT28C256 CAT28C256 @PLCC32 CAT28C256 @SOIC28 CAT28C257 CAT28C257 @PLCC32 CAT28C257 @SOIC28 CAT28C64A CAT28C64A @PLCC32 CAT28C64A @SOIC28 CAT28C64B CAT28C64B @PLCC32 CAT28C64B @SOIC28 CAT28C65 CAT28C65 @PLCC32 CAT28C65 @SOIC28 CAT28C512 @DIP32 CAT28C512 @PLCC32 CAT28C512 @TSOP32 CAT28C010 @DIP32 CAT28C010 @PLCC32 CAT28C010 @TSOP32 CAT28C020 @DIP32 CAT28C020 @PLCC32 CAT28C020 @TSOP32 CAT28C040 @DIP32 CAT28C040 @PLCC32 CAT28C040 @TSOP32 CAT28LV64 CAT28LV64 @PLCC32 CAT28LV64 @SOIC28 CAT28LV65 CAT28LV65 @PLCC32 CAT28LV65 @SOIC28 CAT28LV256 CAT28LV256 @PLCC32 CAT28LV256 @SOIC28 CAT28F001P-B CAT28F001P-T CAT28F001N-B @PLCC32 CAT28F001N-T @PLCC32 CAT28F001T-B @TSOP32 CAT28F001T-T @TSOP32 CAT28F002T-B @TSOP40 CAT28F002T-T @TSOP40 CAT28F256 CAT28F256 @PLCC32 CAT28F256 @TSOP32 CAT28F512 CAT28F512 @PLCC32 CAT28F512 @TSOP32 CAT28F010 CAT28F010 @PLCC32 CAT28F010 @TSOP32 CAT28F020 CAT28F020 @PLCC32 CAT28F020 @TSOP32 CAT35C102(x8) CAT35C102(x8)(S) @SOIC8 CAT35C102(x8)(K) @SOIC8 CAT35C102(x16) CAT35C102(x16)(S) @SOIC8 CAT35C102(x16)(K) @SOIC8 CAT35C104(x8) CAT35C104(x8)(S) @SOIC8 CAT35C104(x8)(K) @SOIC8 CAT35C104(x16) CAT35C104(x16)(S) @SOIC8 CAT35C104(x16)(K) @SOIC8 CAT93C46(x8) CAT93C46(x8)(J) @SOIC8 CAT93C46(x8)(K) @SOIC8 CAT93C46(x8)(S) @SOIC8 CAT93C46(x8)(U) @TSOP8 CAT93C46(x16) CAT93C46(x16)(J) @SOIC8 CAT93C46(x16)(K) @SOIC8 CAT93C46(x16)(S) @SOIC8 CAT93C46(x16)(U) @TSOP8 CAT93C46A CAT93C46A(J) @SOIC8 CAT93C46A(K) @SOIC8 CAT93C46A(S) @SOIC8 CAT93C46R(x8) CAT93C46R(x8)(W) @SOIC8 CAT93C46R(x8)(V) @SOIC8 CAT93C46R(x8)(X) @SOIC8 CAT93C46R(x8)(Y) @TSOP8 CAT93C46R(x16) CAT93C46R(x16)(W) @SOIC8 CAT93C46R(x16)(V) @SOIC8 CAT93C46R(x16)(X) @SOIC8 CAT93C46R(x16)(Y) @TSOP8 CAT93C56(x8) CAT93C56(x8)(J) @SOIC8 CAT93C56(x8)(K) @SOIC8 CAT93C56(x8)(S) @SOIC8 CAT93C56(x8)(U) @TSOP8 CAT93C56(x16) CAT93C56(x16)(J) @SOIC8 CAT93C56(x16)(K) @SOIC8 CAT93C56(x16)(S) @SOIC8 CAT93C56(x16)(U) @TSOP8 CAT93C56A CAT93C56A(J) @SOIC8 CAT93C56A(K) @SOIC8 CAT93C56A(S) @SOIC8 CAT93C57(x8) CAT93C57(x8)(J) @SOIC8 CAT93C57(x8)(K) @SOIC8 CAT93C57(x8)(S) @SOIC8 CAT93C57(x8)(U) @TSOP8 CAT93C57(x16) CAT93C57(x16)(J) @SOIC8 CAT93C57(x16)(K) @SOIC8 CAT93C57(x16)(S) @SOIC8 CAT93C57(x16)(U) @TSOP8 CAT93C66(x8) CAT93C66(x8)(J) @SOIC8 CAT93C66(x8)(K) @SOIC8 CAT93C66(x8)(S) @SOIC8 CAT93C66(x8)(U) @TSOP8 CAT93C66(x16) CAT93C66(x16)(J) @SOIC8 CAT93C66(x16)(K) @SOIC8 CAT93C66(x16)(S) @SOIC8 CAT93C66(x16)(U) @TSOP8 CAT93C66A CAT93C66A(J) @SOIC8 CAT93C66A(K) @SOIC8 CAT93C66A(S) @SOIC8 CAT93C86(x8) CAT93C86(x8)(J) @SOIC8 CAT93C86(x8)(K) @SOIC8 CAT93C86(x8)(S) @SOIC8 CAT93C86(x8)(U) @TSOP8 CAT93C86(x16) CAT93C86(x16)(J) @SOIC8 CAT93C86(x16)(K) @SOIC8 CAT93C86(x16)(S) @SOIC8 CAT93C86(x16)(U) @TSOP8 CAT93C86A CAT93C86A(J) @SOIC8 CAT93C86A(K) @SOIC8 CAT93C86A(S) @SOIC8 CAT93H46(x8) CAT93H46(x8)(J) @SOIC8 CAT93H46(x8)(S) @SOIC8 CAT93H46(x8)(U) @TSOP8 CAT93H46(x16) CAT93H46(x16)(J) @SOIC8 CAT93H46(x16)(S) @SOIC8 CAT93H46(x16)(U) @TSOP8 CAT93HC46(x8) CAT93HC46(x8)(J) @SOIC8 CAT93HC46(x8)(S) @SOIC8 CAT93HC46(x8)(U) @TSOP8 CAT93HC46(x16) CAT93HC46(x16)(J) @SOIC8 CAT93HC46(x16)(S) @SOIC8 CAT93HC46(x16)(U) @TSOP8 [ CBC MICRO ] 12 PCS MC24LC02 MC24LC02 @SOIC8 MC24LC02 @TSSOP8 MC24LC04 MC24LC04 @SOIC8 MC24LC04 @TSSOP8 MC24LC08 MC24LC08 @SOIC8 MC24LC08 @TSSOP8 MC24LC16 MC24LC16 @SOIC8 MC24LC16 @TSSOP8 [ CFEON ] 134 PCS EN25F05 EN25F05 @SOP8 EN25F05 @VDFN8 EN25F10 EN25F10 @SOP8 EN25F10 @VDFN8 EN25F20 EN25F20 @SOP8 EN25F20 @VDFN8 EN25F40 EN25F40 @SOP8 EN25F40 @VDFN8 EN25F80 EN25F80 @SOP8 EN25F80 @VDFN8 EN25F16 EN25F16 @SOP8 EN25F16 @VDFN8 EN25F16 @SOP16 EN25F32 EN25F32 @SOP8 EN25F32 @VDFN8 EN25F32 @SOP16 EN25Q40 EN25Q40 @SOP8 EN25Q40 @VDFN8 EN25Q80A EN25Q80A @SOP8 EN25Q80A @VDFN8 EN25Q16A EN25Q16A @SOP8 EN25Q16A @VDFN8 EN25Q32A EN25Q32A @SOP8 EN25Q32A @VDFN8 EN25Q32A @SOP16 EN25Q32B EN25Q32B @SOP8 EN25Q32B @VDFN8 EN25Q32B @SOP16 EN25Q64 EN25Q64 @SOP8 EN25Q64 @VDFN8 EN25Q64 @SOP16 EN25QH16 EN25QH16 @SOP8 EN25QH16 @VDFN8 EN25QH32 EN25QH32 @SOP8 EN25QH32 @VDFN8 EN25QH32 @SOP16 EN25T80 EN25T80 @SOP8 EN25T80 @VDFN8 EN25T16 EN25T16 @SOP8 EN25T16 @VDFN8 EN29F002AB @DIP32 EN29F002AB @PLCC32 EN29F002AB @TSOP32 EN29F002ANT @DIP32 EN29F002ANT @PLCC32 EN29F002ANT @TSOP32 EN29F002ANB @DIP32 EN29F002ANB @PLCC32 EN29F002ANB @TSOP32 EN29F002AT @DIP32 EN29F002AT @PLCC32 EN29F002AT @TSOP32 EN29F002B @DIP32 EN29F002B @PLCC32 EN29F002B @TSOP32 EN29F002NT @DIP32 EN29F002NT @PLCC32 EN29F002NT @TSOP32 EN29F002NB @DIP32 EN29F002NB @PLCC32 EN29F002NB @TSOP32 EN29F002T @DIP32 EN29F002T @PLCC32 EN29F002T @TSOP32 EN29F512 @DIP32 EN29F512 @PLCC32 EN29F512 @TSOP32 EN29F512 @VSOP32 EN29F010 @DIP32 EN29F010 @PLCC32 EN29F010 @TSOP32 EN29F010 @VSOP32 EN29F040 @DIP32 EN29F040 @PLCC32 EN29F040 @TSOP32 EN29F040A @DIP32 EN29F040A @PLCC32 EN29F040A @TSOP32 EN29F800B @TSOP48 EN29F800T @TSOP48 EN29LV010 @PLCC32 EN29LV010 @TSOP32 EN29LV040 @PLCC32 EN29LV040 @TSOP32 EN29LV040A @DIP32 EN29LV040A @PLCC32 EN29LV040A @TSOP32 EN29LV400T @TSOP48 EN29LV400B @TSOP48 EN29LV400AT @TSOP48 EN29LV400AB @TSOP48 EN29LV800T @TSOP48 EN29LV800B @TSOP48 EN29LV800AT @TSOP48 EN29LV800AB @TSOP48 EN29LV800BT @TSOP48 EN29LV800BB @TSOP48 EN29LV160T @TSOP48 EN29LV160B @TSOP48 EN29LV160AT @TSOP48 EN29LV160AB @TSOP48 EN29LV160JT @TSOP48 EN29LV160JB @TSOP48 EN29LV320T @TSOP48 EN29LV320B @TSOP48 EN29LV640B @TSOP48 EN29LV640H @TSOP48 EN29LV640L @TSOP48 EN29LV640T @TSOP48 EN29LV641H @TSOP48 EN29LV641L @TSOP48 EN29LV641U @TSOP48 EN39LV010 @PLCC32 EN39LV010 @TSOP32 EN39SL800 @TSOP48 EN39SL160H @TSOP48 EN39SL160L @TSOP48 [ CHINGIS ] 99 PCS PM25LD256C PM25LD256C @SOP8 PM25LD256C @WSON8 PM25LD256C @TSSOP8 PM25LD512 PM25LD512 @SOP8 PM25LD512 @WSON8 PM25LD512 @TSSOP8 PM25LD512C PM25LD512C @SOP8 PM25LD512C @WSON8 PM25LD512C @TSSOP8 PM25LD010 PM25LD010 @SOP8 PM25LD010 @WSON8 PM25LD010 @TSSOP8 PM25LD010C PM25LD010C @SOP8 PM25LD010C @WSON8 PM25LD010C @TSSOP8 PM25LD020 PM25LD020 @SOP8 PM25LD020 @WSON8 PM25LD020 @TSSOP8 PM25LD020C PM25LD020C @SOP8 PM25LD020C @WSON8 PM25LD020C @TSSOP8 PM25LD040 PM25LD040 @SOP8 PM25LD040 @WSON8 PM25LD040 @TSSOP8 PM25LD040C PM25LD040C @SOP8 PM25LD040C @WSON8 PM25LD040C @TSSOP8 PM25LV512 PM25LV512 @SOP8 PM25LV512 @WSON8 PM25LV512A PM25LV512A @SOP8 PM25LV512A @WSON8 PM25LV010 PM25LV010 @SOP8 PM25LV010 @WSON8 PM25LV010A PM25LV010A @SOP8 PM25LV010A @WSON8 PM25LV020 PM25LV020 @SOP8 PM25LV020 @WSON8 PM25LV040 PM25LV040 @SOP8 PM25LV040 @WSON8 PM25LV080B PM25LV080B @SOP8 PM25LV080B @WSON8 PM25LV016B PM25LV016B @SOP8 PM25LV016B @WSON8 PM25WD020 PM25WD020 @SOP8 PM25WD020 @WSON8 PM25WD040 PM25WD040 @SOP8 PM25WD040 @WSON8 PM29F002T @DIP32 PM29F002T @PLCC32 PM29F002B @DIP32 PM29F002B @PLCC32 PM29F004T @DIP32 PM29F004T @PLCC32 PM29F004B @DIP32 PM29F004B @PLCC32 PM39F010 @DIP32 PM39F010 @PLCC32 PM39F010 @TSOP32 PM39F020 @DIP32 PM39F020 @PLCC32 PM39F020 @TSOP32 PM39F040 @DIP32 PM39F040 @PLCC32 PM39F040 @TSOP32 PM39LV512 @PLCC32 PM39LV512 @TSOP32 PM39LV010 @PLCC32 PM39LV010 @TSOP32 PM39LV020 @PLCC32 PM39LV020 @TSOP32 PM39LV040 @PLCC32 PM39LV040 @TSOP32 PM49FL002T @PLCC32 PM49FL002T @TSOP32 PM49FL004T @PLCC32 PM49FL004T @TSOP32 PM49FL008T @PLCC32 PM49FL008T @TSOP32 PM49LP002T @PLCC32 PM49LP002T @TSOP32 [ CHIPSWINNER ] 56 PCS CW24C02 CW24C02 @DFN8 CW24C02 @SOIC8 CW24C02 @TSSOP8 CW24C02B CW24C02B @DFN8 CW24C02B @SOIC8 CW24C02B @TSSOP8 CW24C02C CW24C02C @DFN8 CW24C02C @SOIC8 CW24C02C @TSSOP8 CW24C04 CW24C04 @DFN8 CW24C04 @SOIC8 CW24C04 @TSSOP8 CW24C04A CW24C04A @DFN8 CW24C04A @SOIC8 CW24C04A @TSSOP8 CW24C08 CW24C08 @DFN8 CW24C08 @SOIC8 CW24C08 @TSSOP8 CW24C08B CW24C08B @DFN8 CW24C08B @SOIC8 CW24C08B @TSSOP8 CW24C08C CW24C08C @DFN8 CW24C08C @SOIC8 CW24C08C @TSSOP8 CW24C16 CW24C16 @DFN8 CW24C16 @SOIC8 CW24C16 @TSSOP8 CW24C16A CW24C16A @DFN8 CW24C16A @SOIC8 CW24C16A @TSSOP8 CW24C32 CW24C32 @DFN8 CW24C32 @SOIC8 CW24C32 @TSSOP8 CW24C64 CW24C64 @DFN8 CW24C64 @SOIC8 CW24C64 @TSSOP8 CW24C128 CW24C128 @DFN8 CW24C128 @SOIC8 CW24C128 @SOIC8 CW24C256 CW24C256 @DFN8 CW24C256 @SOIC8 CW24C256 @TSSOP8 [ CORERIVER ] 36 PCS CR24C01 CR24C01 @DFN8 CR24C01 @SOIC8 CR24C01 @TSSOP8 CR24C02 CR24C02 @DFN8 CR24C02 @SOIC8 CR24C02 @TSSOP8 CR24C04 CR24C04 @DFN8 CR24C04 @SOIC8 CR24C04 @TSSOP8 CR24C08 CR24C08 @DFN8 CR24C08 @SOIC8 CR24C08 @TSSOP8 CR24C16 CR24C16 @DFN8 CR24C16 @SOIC8 CR24C16 @TSSOP8 CR24C32 CR24C32 @DFN8 CR24C32 @SOIC8 CR24C32 @TSSOP8 CR24C64 CR24C64 @DFN8 CR24C64 @SOIC8 CR24C64 @TSSOP8 CR24C128 CR24C128 @DFN8 CR24C128 @SOIC8 CR24C128 @SOIC8 CR24C256 CR24C256 @DFN8 CR24C256 @SOIC8 CR24C256 @TSSOP8 [ CYPRESS ] 22 PCS CY27C010 @DIP32 CY27C010 @PLCC32 CY27C010 @TSOP32 CY27C020 @DIP32 CY27C020 @PLCC32 CY27C020 @TSOP32 CY27C040 @DIP32 CY27C040 @PLCC32 CY27C040 @TSOP32 CY27C128 @DIP28 CY27C128 @PLCC32 CY27C256 @DIP28 CY27C256 @PLCC32 CY27C512 @DIP28 CY27C512 @PLCC32 CY27H010 @DIP32 CY27H010 @PLCC32 CY27H010 @TSOP32 CY27H256 @DIP28 CY27H256 @PLCC32 CY27H512 @DIP28 CY27H512 @PLCC32 [ DALLAS ] 19 PCS DS1220 (RW) DS1220 (TEST) DS1225 (RW) DS1225 (TEST) DS1230AB (RW) DS1230AB (TEST) DS1230W (RW) DS1230W (TEST) DS1230Y (RW) DS1230Y (TEST) DS1245AB DS1245W DS1245Y DS1249AB DS1249W DS1249Y DS1250AB DS1250W DS1250Y [ DENSE-PAC ] 6 PCS DPV27C101 @DIP32 DPV27C101 @PLCC32 DPV27C256 @DIP28 DPV27C256 @PLCC32 DPV27C512 @DIP28 DPV27C512 @PLCC32 [ DEUTRON ] 10 PCS AC25LV512 AC25LV512 @SOP8 AC25LV010 AC25LV010 @SOP8 P439LV010 @PLCC32 P439LV010 @TSOP32 P439LV040 @PLCC32 P439LV040 @TSOP32 P439LV080 @TSOP40 P439LV800 @TSOP48 [ E-CMOS ] 52 PCS EC24C01 EC24C01 @DFN8 EC24C01 @SOIC8 EC24C01 @TSSOP8 EC24C02 EC24C02 @DFN8 EC24C02 @SOIC8 EC24C02 @TSSOP8 EC24C02A EC24C02A @DFN8 EC24C02A @SOIC8 EC24C02A @TSSOP8 EC24C04 EC24C04 @DFN8 EC24C04 @SOIC8 EC24C04 @TSSOP8 EC24C04A EC24C04A @DFN8 EC24C04A @SOIC8 EC24C04A @TSSOP8 EC24C08 EC24C08 @DFN8 EC24C08 @SOIC8 EC24C08 @TSSOP8 EC24C08A EC24C08A @DFN8 EC24C08A @SOIC8 EC24C08A @TSSOP8 EC24C16 EC24C16 @DFN8 EC24C16 @SOIC8 EC24C16 @TSSOP8 EC24C16A EC24C16A @DFN8 EC24C16A @SOIC8 EC24C16A @TSSOP8 EC24C32 EC24C32 @DFN8 EC24C32 @SOIC8 EC24C32 @TSSOP8 EC24C64 EC24C64 @DFN8 EC24C64 @SOIC8 EC24C64 @TSSOP8 EC24C128 EC24C128 @DFN8 EC24C128 @SOIC8 EC24C128 @TSSOP8 EC24C256 EC24C256 @DFN8 EC24C256 @SOIC8 EC24C256 @TSSOP8 [ EFST ] 18 PCS EM25LV512 EM25LV512 @SOP8 EM25LV010 EM25LV010 @SOP8 F49B002UA F49B002UA @PLCC32 F49L004BA @PLCC32 F49L004BA @TSOP40 F49L004UA @PLCC32 F49L004UA @TSOP40 F49L040A @PLCC32 F49L040A @TSOP32 F49L400BA @TSOP48 F49L400UA @TSOP48 F49L800BA @TSOP48 F49L800UA @TSOP48 F49L160BA @TSOP48 F49L160UA @TSOP48 [ EMTC ] 12 PCS EM24C02 EM24C02 @SOIC8 EM24C02 TSSOP8 EM24C04 EM24C04 @SOIC8 EM24C04 @TSSOP8 EM24C08 EM24C08 @SOIC8 EM24C08 @TSSOP8 EM24C16 EM24C16 @SOIC8 EM24C16 @TSSOP8 [ EON ] 233 PCS EN25B05 EN25B05 @SOP8 EN25B05 @VDFN8 EN25B05T EN25B05T @SOP8 EN25B05T @VDFN8 EN25B10 EN25B10 @SOP8 EN25B10 @VDFN8 EN25B10T EN25B10T @SOP8 EN25B10T @VDFN8 EN25B20 EN25B20 @SOP8 EN25B20 @VDFN8 EN25B20T EN25B20T @SOP8 EN25B20T @VDFN8 EN25B40 EN25B40 @SOP8 EN25B40 @VDFN8 EN25B40T EN25B40T @SOP8 EN25B40T @VDFN8 EN25B80 EN25B80 @SOP8 EN25B80 @VDFN8 EN25B80T EN25B80T @SOP8 EN25B80T @VDFN8 EN25B16 EN25B16 @SOP8 EN25B16 @VDFN8 EN25B16 @SOP16 EN25B16T EN25B16T @SOP8 EN25B16T @VDFN8 EN25B16T @SOP16 EN25B32 EN25B32 @SOP8 EN25B32 @VDFN8 EN25B32 @SOP16 EN25B32T EN25B32T @SOP8 EN25B32T @VDFN8 EN25B32T @SOP16 EN25B64 @SOP8 EN25B64 @SOP16 EN25B64T @SOP8 EN25B64T @SOP16 EN25F05 EN25F05 @SOP8 EN25F05 @VDFN8 EN25F10 EN25F10 @SOP8 EN25F10 @VDFN8 EN25F20 EN25F20 @SOP8 EN25F20 @VDFN8 EN25F40 EN25F40 @SOP8 EN25F40 @VDFN8 EN25F80 EN25F80 @SOP8 EN25F80 @VDFN8 EN25F16 EN25F16 @SOP8 EN25F16 @VDFN8 EN25F16 @SOP16 EN25F32 EN25F32 @SOP8 EN25F32 @VDFN8 EN25F32 @SOP16 EN25F64 EN25F64 @SOP8 EN25F64 @VDFN8 EN25F64 @SOP16 EN25LF05 EN25LF05 @SOP8 EN25LF05 @VDFN8 EN25LF10 EN25LF10 @SOP8 EN25LF10 @VDFN8 EN25LF20 EN25LF20 @SOP8 EN25LF20 @VDFN8 EN25LF40 EN25LF40 @SOP8 EN25LF40 @VDFN8 EN25P05 EN25P05 @SOP8 EN25P05 @VDFN8 EN25P10 EN25P10 @SOP8 EN25P10 @VDFN8 EN25P20 EN25P20 @SOP8 EN25P20 @VDFN8 EN25P40 EN25P40 @SOP8 EN25P40 @VDFN8 EN25P80 EN25P80 @SOP8 EN25P80 @VDFN8 EN25P16 EN25P16 @SOP8 EN25P16 @VDFN8 EN25P32 EN25P32 @SOP8 EN25P32 @SOP16 EN25P64 @SOP8 EN25P64 @SOP16 EN25Q40 EN25Q40 @SOP8 EN25Q40 @VDFN8 EN25Q80A EN25Q80A @SOP8 EN25Q80A @VDFN8 EN25Q16A EN25Q16A @SOP8 EN25Q16A @VDFN8 EN25Q32A EN25Q32A @SOP8 EN25Q32A @VDFN8 EN25Q32A @SOP16 EN25Q32B EN25Q32B @SOP8 EN25Q32B @VDFN8 EN25Q32B @SOP16 EN25Q64 EN25Q64 @SOP8 EN25Q64 @VDFN8 EN25Q64 @SOP16 EN25QH16 EN25QH16 @SOP8 EN25QH16 @VDFN8 EN25QH32 EN25QH32 @SOP8 EN25QH32 @VDFN8 EN25QH32 @SOP16 EN25T80 EN25T80 @SOP8 EN25T80 @VDFN8 EN25T16 EN25T16 @SOP8 EN25T16 @VDFN8 EN27C010 @DIP32 EN27C010 @PLCC32 EN27C010 @TSOP32 EN27C512 @DIP28 EN27C512 @PLCC32 EN29F002AB @DIP32 EN29F002AB @PLCC32 EN29F002AB @TSOP32 EN29F002ANT @DIP32 EN29F002ANT @PLCC32 EN29F002ANT @TSOP32 EN29F002ANB @DIP32 EN29F002ANB @PLCC32 EN29F002ANB @TSOP32 EN29F002AT @DIP32 EN29F002AT @PLCC32 EN29F002AT @TSOP32 EN29F002B @DIP32 EN29F002B @PLCC32 EN29F002B @TSOP32 EN29F002NT @DIP32 EN29F002NT @PLCC32 EN29F002NT @TSOP32 EN29F002NB @DIP32 EN29F002NB @PLCC32 EN29F002NB @TSOP32 EN29F002T @DIP32 EN29F002T @PLCC32 EN29F002T @TSOP32 EN29F512 @DIP32 EN29F512 @PLCC32 EN29F512 @TSOP32 EN29F512 @VSOP32 EN29F010 @DIP32 EN29F010 @PLCC32 EN29F010 @TSOP32 EN29F010 @VSOP32 EN29F040 @DIP32 EN29F040 @PLCC32 EN29F040 @TSOP32 EN29F040A @DIP32 EN29F040A @PLCC32 EN29F040A @TSOP32 EN29F800B @TSOP48 EN29F800T @TSOP48 EN29LV010 @PLCC32 EN29LV010 @TSOP32 EN29LV020 @PLCC32 EN29LV020 @TSOP32 EN29LV040 @PLCC32 EN29LV040 @TSOP32 EN29LV040A @DIP32 EN29LV040A @PLCC32 EN29LV040A @TSOP32 EN29LV400B @TSOP48 EN29LV400T @TSOP48 EN29LV400AB @TSOP48 EN29LV400AT @TSOP48 EN29LV800B @TSOP48 EN29LV800T @TSOP48 EN29LV800AB @TSOP48 EN29LV800AT @TSOP48 EN29LV800BB @TSOP48 EN29LV800BT @TSOP48 EN29LV160B @TSOP48 EN29LV160T @TSOP48 EN29LV160AB @TSOP48 EN29LV160AT @TSOP48 EN29LV160BB @TSOP48 EN29LV160BT @TSOP48 EN29LV160JB @TSOP48 EN29LV160JT @TSOP48 EN29LV320T @TSOP48 EN29LV320B @TSOP48 EN29LV320AT @TSOP48 EN29LV320AB @TSOP48 EN29LV640B @TSOP48 EN29LV640H @TSOP48 EN29LV640L @TSOP48 EN29LV640T @TSOP48 EN29LV641H @TSOP48 EN29LV641L @TSOP48 EN29LV641U @TSOP48 EN29PL320 @TSOP48 EN29PL640 @TSOP48 EN39LV010 @PLCC32 EN39LV010 @TSOP32 [ EOREX ] 32 PCS EM24LC02 EM24LC02 @SOIC8 EM93LC46(x8) EM93LC46(x8) @SOIC8 EM93LC46(x8) @TSOP8 EM93LC46(x16) EM93LC46(x16) @SOIC8 EM93LC46(x16) @TSOP8 EM93LC56(x8) EM93LC56(x8) @SOIC8 EM93LC56(x8) @TSOP8 EM93LC56(x16) EM93LC56(x16) @SOIC8 EM93LC56(x16) @TSOP8 EM93LC57(x8) EM93LC57(x8) @SOIC8 EM93LC57(x8) @TSOP8 EM93LC57(x16) EM93LC57(x16) @SOIC8 EM93LC57(x16) @TSOP8 EM93LC66(x8) EM93LC66(x8) @SOIC8 EM93LC66(x8) @TSOP8 EM93LC66(x16) EM93LC66(x16) @SOIC8 EM93LC66(x16) @TSOP8 EM93LC86(x8) EM93LC86(x8) @SOIC8 EM93LC86(x8) @TSOP8 EM93LC86(x16) EM93LC86(x16) @SOIC8 EM93LC86(x16) @TSOP8 [ ESMT ] 36 PCS EM25LV512 EM25LV512 @SOP8 EM25LV010 EM25LV010 @SOP8 F25L004A F25L004A @SOP8 F25L008A F25L008A @SOP8 F25L016A F25L016A @SOP8 F25L04UA F25L04UA @SOP8 F25L04P F25L04P @SOP8 F25S04P F25S04P @SOP8 F25L08P F25L08P @SOP8 F25L16P F25L16P @SOP8 F25L32P F25L32P @SOP8 F25L32Q F25L32Q @SOP8 F49L004U @PLCC32 F49L004U @TSOP40 F49L004B @PLCC32 F49L004B @TSOP40 F49L040A @PLCC32 F49L040A @TSOP32 F49L400UA @TSOP48 F49L400BA @TSOP48 F49L800UA @TSOP48 F49L800BA @TSOP48 F49L160UA @TSOP48 F49L160BA @TSOP48 [ ESTEK ] 12 PCS 24C02 24C02 @SOIC8 24C02 @TSSOP8 24C04 24C04 @SOIC8 24C04 @TSSOP8 24C08 24C08 @SOIC8 24C08 @TSSOP8 24C16 24C16 @SOIC8 24C16 @TSSOP8 [ EXCELSEMI ] 42 PCS ES25P10 @SOIC8 ES25P20 @SOIC8 ES25P40 @SOIC8 ES25P80 @SOIC8 ES25P16 @SOIC8 ES25P32 @SOIC8 ES25M40A ES25M40A @SOIC8 ES25M40A @WSON8 ES25M40A @SOP16 ES25M80A ES25M80A @SOIC8 ES25M80A @WSON8 ES25M80A @SOP16 ES25M16A ES25M16A @SOIC8 ES25M16A @WSON8 ES25M16A @SOP16 ES29LV400DB @TSOP48 ES29LV400DT @TSOP48 ES29LV400EB @TSOP48 ES29LV400ET @TSOP48 ES29LV400FB @TSOP48 ES29LV400FT @TSOP48 ES29LV800DB @TSOP48 ES29LV800DT @TSOP48 ES29LV800EB @TSOP48 ES29LV800ET @TSOP48 ES29LV800FB @TSOP48 ES29LV800FT @TSOP48 ES29LV160DB @TSOP48 ES29LV160DT @TSOP48 ES29LV160EB @TSOP48 ES29LV160ET @TSOP48 ES29LV160FB @TSOP48 ES29LV160FT @TSOP48 ES29LV320DB @TSOP48 ES29LV320DT @TSOP48 ES29LV320EB @TSOP48 ES29LV320ET @TSOP48 ES29LV320FB @TSOP48 ES29LV320FT @TSOP48 [ EXEL ] 62 PCS XL2804A XL2816A XL93CS56 XL93CS56 @SOIC8 XL93CS56 @TSSOP8 XL93CS66 XL93CS66 @SOIC8 XL93CS66 @TSSOP8 XL93LC46 XL93LC46 @SOIC8 XL93LC46A XL93LC46A @SOIC8 XL93LC56 XL93LC56 @SOIC8 XL93LC56A XL93LC56A @SOIC8 XL93LC66A XL93LC66A @SOIC8 XLE2865A XLE28C16A XLE28C16A @PLCC32 XLE28C16B XLE28C16B @PLCC32 XLE28C16B @SIOC24 XLE28C64A XLE28C64A @PLCC32 XLE28C64B XLE28C64B @PLCC32 XLE28C64B @SOIC28 XLE28C256 XLE28C256 @PLCC32 XLS2865A XLS2865A @PLCC32 XLS28C16A XLS28C16A @PLCC32 XLS28C16B XLS28C16B @PLCC32 XLS28C16B @SIOC24 XLS28C64A XLS28C64A @PLCC32 XLS28C64B XLS28C64B @PLCC32 XLS28C64B @SOIC28 XLS28C256 XLS28C256 @PLCC32 XLS93C46 XLS93C46 @SOIC8 XLS93C56 XLS93C56 @SOIC8 XLS93C66 XLS93C66 @SOIC8 XLS93CS46 XLS93CS46 @SOIC8 XLS93CS46 @TSSOP8 XLS93LC06 XLS93LC06 @SOIC8 XLS93LC46 XLS93LC46 @SOIC8 XLS93LC56 XLS93LC56 @SOIC8 XLS93LC66 XLS93LC66 @SOIC8 [ FAIRCHILD ] 302 PCS FM24C02 FM24C02 @SOIC8 FM24C02 @TSSOP8 FM24C03 FM24C03 @SOIC8 FM24C03 @TSSOP8 FM24C04 FM24C04 @SOIC8 FM24C04 @TSSOP8 FM24C05 FM24C05 @SOIC8 FM24C05 @TSSOP8 FM24C08 FM24C08 @SOIC8 FM24C08 @TSSOP8 FM24C09 FM24C09 @SOIC8 FM24C09 @TSSOP8 FM24C16 FM24C16 @SOIC8 FM24C16 @TSSOP8 FM24C17 FM24C17 @SOIC8 FM24C17 @TSSOP8 FM24C32 FM24C32 @SOIC8 FM24C32 @TSSOP8 FM24C64 FM24C64 @SOIC8 FM24C64 @TSSOP8 FM24C128 FM24C128 @SOIC8 FM24C128 @TSSOP8 FM24C256 FM24C256 @SOIC8 FM24C256 @TSSOP8 FM27C010 @DIP32 FM27C010 @PLCC32 FM27C010 @TSOP32 FM27C040 @DIP32 FM27C040 @PLCC32 FM27C040 @TSOP32 FM27C256 @DIP28 FM27C256 @PLCC32 FM27C512 @DIP28 FM27C512 @PLCC32 FM93C46 FM93C46 @SOIC8 FM93C46 @TSOP8 FM93C46A(x8) FM93C46A(x8) @SOIC8 FM93C46A(x8) @TSOP8 FM93C46A(x16) FM93C46A(x16) @SOIC8 FM93C46A(x16) @TSOP8 FM93C56 FM93C56 @SOIC8 FM93C56 @TSOP8 FM93C56A(x8) FM93C56A(x8) @SOIC8 FM93C56A(x8) @TSOP8 FM93C56A(x16) FM93C56A(x16) @SOIC8 FM93C56A(x16) @TSOP8 FM93C66 FM93C66 @SOIC8 FM93C66 @TSOP8 FM93C66A(x8) FM93C66A(x8) @SOIC8 FM93C66A(x8) @TSOP8 FM93C66A(x16) FM93C66A(x16) @SOIC8 FM93C66A(x16) @TSOP8 FM93C76 FM93C76 @SOIC8 FM93C76 @TSOP8 FM93C76A(x8) FM93C76A(x8) @SOIC8 FM93C76A(x8) @TSOP8 FM93C76A(x16) FM93C76A(x16) @SOIC8 FM93C76A(x16) @TSOP8 FM93C86 FM93C86 @SOIC8 FM93C86 @TSOP8 FM93C86A(x8) FM93C86A(x8) @SOIC8 FM93C86A(x8) @TSOP8 FM93C86A(x16) FM93C86A(x16) @SOIC8 FM93C86A(x16) @TSOP8 FM93CS06 FM93CS06 @SOIC8 FM93CS06 @TSOP8 FM93CS46 FM93CS46 @SOIC8 FM93CS46 @TSOP8 FM93CS56 FM93CS56 @SOIC8 FM93CS56 @TSOP8 FM93CS66 FM93CS66 @SOIC8 FM93CS66 @TSOP8 FM93S46 FM93S46 @SOIC8 FM93S46 @TSOP8 FM93S56 FM93S56 @SOIC8 FM93S56 @TSOP8 FM93S66 FM93S66 @SOIC8 FM93S66 @TSOP8 NM24C02 NM24C02 @SOIC8 NM24C02 @TSSOP8 NM24C02L NM24C02L @SOIC8 NM24C02L @TSSOP8 NM24C03 NM24C03 @SOIC8 NM24C03 @TSSOP8 NM24C04 NM24C04 @SOIC8 NM24C04 @TSSOP8 NM24C05 NM24C05 @SOIC8 NM24C05 @TSSOP8 NM24C08 NM24C08 @SOIC8 NM24C08 @TSSOP8 NM24C09 NM24C09 @SOIC8 NM24C09 @TSSOP8 NM24C16 NM24C16 @SOIC8 NM24C16 @TSSOP8 NM24C17 NM24C17 @SOIC8 NM24C17 @TSSOP8 NM24C65 NM24C65 @SOIC8 NM24C65 @TSSOP8 NM27C010 @DIP32 NM27C010 @PLCC32 NM27C010 @TSOP32 NM27C020 @DIP32 NM27C020 @PLCC32 NM27C020 @TSOP32 NM27C040 @DIP32 NM27C040 @PLCC32 NM27C040 @TSOP32 NM27C64Q @DIP28 NM27C64Q @PLCC32 NM27C128 @DIP28 NM27C128 @PLCC32 NM27C210 @DIP40 NM27C240 @DIP40 NM27C256 @DIP28 NM27C256 @PLCC32 NM27C512 @DIP28 NM27C512 @PLCC32 NM27LC010 @DIP32 NM27LC010 @PLCC32 NM27LC010 @TSOP32 NM27LC64 @DIP28 NM27LC64 @PLCC32 NM27LC256 @DIP28 NM27LC256 @PLCC32 NM27LC512 @DIP28 NM27LC512 @PLCC32 NM27LV010 NM27LV010 @PLCC32 NM27LV010 @TSOP32 NM27LV020 @DIP32 NM27LV020 @PLCC32 NM27LV020 @TSOP32 NM27LV040 @DIP32 NM27LV040 @PLCC32 NM27LV040 @TSOP32 NM27LV210 @DIP40 NM27LV512 @DIP28 NM27LV512 @PLCC32 NM27P010 NM27P010 @PLCC32 NM27P010 @TSOP32 NM27P020 @DIP32 NM27P020 @PLCC32 NM27P020 @TSOP32 NM27P040 @DIP32 NM27P040 @PLCC32 NM27P040 @TSOP32 NM27P210 @DIP40 NM27P512 @DIP28 NM27P512 @PLCC32 NM93C46 NM93C46 @SOIC8 NM93C46 @TSOP8 NM93C46A(x8) NM93C46A(x8) @SOIC8 NM93C46A(x8) @TSOP8 NM93C46A(x16) NM93C46A(x16) @SOIC8 NM93C46A(x16) @TSOP8 NM93C56 NM93C56 @SOIC8 NM93C56 @TSOP8 NM93C56A(x8) NM93C56A(x8) @SOIC8 NM93C56A(x8) @TSOP8 NM93C56A(x16) NM93C56A(x16) @SOIC8 NM93C56A(x16) @TSOP8 NM93C66 NM93C66 @SOIC8 NM93C66 @TSOP8 NM93C66A(x8) NM93C66A(x8) @SOIC8 NM93C66A(x8) @TSOP8 NM93C66A(x16) NM93C66A(x16) @SOIC8 NM93C66A(x16) @TSOP8 NM93C76 NM93C76 @SOIC8 NM93C76 @TSOP8 NM93C76A(x8) NM93C76A(x8) @SOIC8 NM93C76A(x8) @TSOP8 NM93C76A(x16) NM93C76A(x16) @SOIC8 NM93C76A(x16) @TSOP8 NM93C86 NM93C86 @SOIC8 NM93C86 @TSOP8 NM93C86A(x8) NM93C86A(x8) @SOIC8 NM93C86A(x8) @TSOP8 NM93C86A(x16) NM93C86A(x16) @SOIC8 NM93C86A(x16) @TSOP8 NM93CS06 NM93CS06 @SOIC8 NM93CS06 @TSOP8 NM93CS46 NM93CS46 @SOIC8 NM93CS46 @TSOP8 NM93CS56 NM93CS56 @SOIC8 NM93CS56 @TSOP8 NM93CS66 NM93CS66 @SOIC8 NM93CS66 @TSOP8 NMC2732 @DIP24 NMC27C010 @DIP32 NMC27C010 @PLCC32 NMC27C010 @TSOP32 NMC27C16 @DIP24 NMC27C16B @DIP24 NMC27C16Q @DIP24 NMC27C32B @DIP24 NMC27C64Q @DIP28 NMC27C64Q @PLCC32 NMC27C128B @DIP28 NMC27C128B @PLCC32 NMC27C128C @DIP28 NMC27C128C @PLCC32 NMC27C256B @DIP28 NMC27C256B @PLCC32 NMC27C256Q @DIP28 NMC27C256Q @PLCC32 NMC27C512A @DIP28 NMC27C512A @PLCC32 NMC27C512Q @DIP28 NMC27C512Q @PLCC32 NMC27C1024 @DIP40 NMC87C257Q @DIP28 NMC87C257Q @PLCC32 NMC87C257V @DIP28 NMC87C257V @PLCC32 NMC93C46 NMC93C46 @SOIC8 NMC93C46 @TSOP8 NMC93C46A NMC93C46A @SOIC8 NMC93C46A @TSOP8 NMC93C56 NMC93C56 @SOIC8 NMC93C56 @TSOP8 NMC93C66 NMC93C66 @SOIC8 NMC93C66 @TSOP8 NMC93CS06 NMC93CS06 @SOIC8 NMC93CS06 @TSOP8 NMC93CS46 NMC93CS46 @SOIC8 NMC93CS46 @TSOP8 NMC93CS56 NMC93CS56 @SOIC8 NMC93CS56 @TSOP8 NMC93CS66 NMC93CS66 @SOIC8 NMC93CS66 @TSOP8 [ FIDELIX ] 20 PCS FM25Q08A FM25Q08A @SOP8 FM25Q08A @WSON8 FM25Q08A @SOP16 FM25Q16A FM25Q16A @SOP8 FM25Q16A @WSON8 FM25Q16A @SOP16 FM25Q16B FM25Q16B @SOP8 FM25Q16B @WSON8 FM25Q16B @SOP16 FM25Q32A FM25Q32A @SOP8 FM25Q32A @WSON8 FM25Q32A @SOP16 FM25Q64A FM25Q64A @SOP8 FM25Q64A @WSON8 FM25Q64A @SOP16 [ FIRST-RANK ] 24 PCS T24C02 T24C02 @SOIC8 T24C02 @TSSOP8 T24C02A T24C02A @SOIC8 T24C02A @TSSOP8 T24C04 T24C04 @SOIC8 T24C04 @TSSOP8 T24C04A T24C04A @SOIC8 T24C04A @TSSOP8 T24C08 T24C08 @SOIC8 T24C08 @TSSOP8 T24C08A T24C08A @SOIC8 T24C08A @TSSOP8 T24C16 T24C16 @SOIC8 T24C16 @TSSOP8 T24C16A T24C16A @SOIC8 T24C16A @TSSOP8 [ FMD ] 96 PCS FT24C02 FT24C02 @SOIC8 FT24C02 @TSSOP8 FT24C02A FT24C02A @SOIC8 FT24C02A @TSSOP8 FT24C04 FT24C04 @SOIC8 FT24C04 @TSSOP8 FT24C04A FT24C04A @SOIC8 FT24C04A @TSSOP8 FT24C08 FT24C08 @SOIC8 FT24C08 @TSSOP8 FT24C08A FT24C08A @SOIC8 FT24C08A @TSSOP8 FT24C16 FT24C16 @SOIC8 FT24C16 @TSSOP8 FT24C16A FT24C16A @SOIC8 FT24C16A @TSSOP8 FT24C32 FT24C32 @SOIC8 FT24C32 @TSSOP8 FT24C32A FT24C32A @SOIC8 FT24C32A @TSSOP8 FT24C64 FT24C64 @SOIC8 FT24C64 @TSSOP8 FT24C64A FT24C64A @SOIC8 FT24C64A @TSSOP8 FT24C128 FT24C128 @SOIC8 FT24C128 @TSSOP8 FT24C128A FT24C128A @SOIC8 FT24C128A @TSSOP8 FT24C256 FT24C256 @SOIC8 FT24C256 @TSSOP8 FT24C256A FT24C256A @SOIC8 FT24C256A @TSSOP8 FT93C46(x8) FT93C46(x8) @SOIC8 FT93C46(x8) @TSOP8 FT93C46(x16) FT93C46(x16) @SOIC8 FT93C46(x16) @TSOP8 FT93C46A(x8) FT93C46A(x8) @SOIC8 FT93C46A(x8) @TSOP8 FT93C46A(x16) FT93C46A(x16) @SOIC8 FT93C46A(x16) @TSOP8 FT93C56(x8) FT93C56(x8) @SOIC8 FT93C56(x8) @TSOP8 FT93C56(x16) FT93C56(x16) @SOIC8 FT93C56(x16) @TSOP8 FT93C56A(x8) FT93C56A(x8) @SOIC8 FT93C56A(x8) @TSOP8 FT93C56A(x16) FT93C56A(x16) @SOIC8 FT93C56A(x16) @TSOP8 FT93C66(x8) FT93C66(x8) @SOIC8 FT93C66(x8) @TSOP8 FT93C66(x16) FT93C66(x16) @SOIC8 FT93C66(x16) @TSOP8 FT93C66A(x8) FT93C66A(x8) @SOIC8 FT93C66A(x8) @TSOP8 FT93C66A(x16) FT93C66A(x16) @SOIC8 FT93C66A(x16) @TSOP8 FT93C86(x8) FT93C86(x8) @SOIC8 FT93C86(x8) @TSOP8 FT93C86(x16) FT93C86(x16) @SOIC8 FT93C86(x16) @TSOP8 FT93C86A(x8) FT93C86A(x8) @SOIC8 FT93C86A(x8) @TSOP8 FT93C86A(x16) FT93C86A(x16) @SOIC8 FT93C86A(x16) @TSOP8 [ FORCE TECH. ] 54 PCS FT24C01 FT24C01 @SOIC8 FT24C01 @TSSOP8 FT24C01A FT24C01A @SOIC8 FT24C01A @TSSOP8 FT24C02 FT24C02 @SOIC8 FT24C02 @TSSOP8 FT24C02A FT24C02A @SOIC8 FT24C02A @TSSOP8 FT24C04 FT24C04 @SOIC8 FT24C04 @TSSOP8 FT24C04A FT24C04A @SOIC8 FT24C04A @TSSOP8 FT24C08 FT24C08 @SOIC8 FT24C08 @TSSOP8 FT24C08A FT24C08A @SOIC8 FT24C08A @TSSOP8 FT24C16 FT24C16 @SOIC8 FT24C16 @TSSOP8 FT24C16A FT24C16A @SOIC8 FT24C16A @TSSOP8 FT24C32 FT24C32 @SOIC8 FT24C32 @TSSOP8 FT24C32A FT24C32A @SOIC8 FT24C32A @TSSOP8 FT24C64 FT24C64 @SOIC8 FT24C64 @TSSOP8 FT24C64A FT24C64A @SOIC8 FT24C64A @TSSOP8 FT24C128 FT24C128 @SOIC8 FT24C128 @TSSOP8 FT24C128A FT24C128A @SOIC8 FT24C128A @TSSOP8 FT24C256 FT24C256 @SOIC8 FT24C256 @TSSOP8 FT24C256A FT24C256A @SOIC8 FT24C256A @TSSOP8 [ FORWARD ] 14 PCS 24LC01 24LC01 @SOIC8 24LC02 24LC02 @SOIC8 24LC04 24LC04 @SOIC8 24LC08 24LC08 @SOIC8 24LC16 24LC16 @SOIC8 24LC32 24LC32 @SOIC8 24LC64 24LC64 @SOIC8 [ FUDAN ] 42 PCS FM24C02A FM24C02A @SOIC8 FM24C02A @TSSOP8 FM24C02B FM24C02B @SOIC8 FM24C02B @TSSOP8 FM24C04A FM24C04A @SOIC8 FM24C04A @TSSOP8 FM24C04B FM24C04B @SOIC8 FM24C04B @TSSOP8 FM24C08A FM24C08A @SOIC8 FM24C08A @TSSOP8 FM24C08B FM24C08B @SOIC8 FM24C08B @TSSOP8 FM24C16A FM24C16A @SOIC8 FM24C16A @TSSOP8 FM24C16B FM24C16B @SOIC8 FM24C16B @TSSOP8 FM24C32A FM24C32A @SOIC8 FM24C32A @TSSOP8 FM24C32B FM24C32B @SOIC8 FM24C32B @TSSOP8 FM24C64A FM24C64A @SOIC8 FM24C64A @TSSOP8 FM24C128A FM24C128A @SOIC8 FM24C128A @TSSOP8 FM24C256 FM24C256 @SOIC8 FM24C256 @TSSOP8 FM24C256A FM24C256A @SOIC8 FM24C256A @TSSOP8 [ FUJITSU ] 231 PCS MBM2716 @DIP24 MBM27128 @DIP28 MBM27128 @PLCC32 MBM27256 @DIP28 MBM27256 @PLCC32 MBM2732 @DIP24 MBM2732A @DIP24 MBM2764 @DIP28 MBM2764 @PLCC32 MBM27C1001 MBM27C1001 @PLCC32 MBM27C1001 @SO32 MBM27C1001 @TSOP32 MBM27C1024 @DIP40 MBM27C128P @DIP28 MBM27C128P @PLCC32 MBM27C2001 MBM27C2001 @PLCC32 MBM27C2001 @TSOP32 MBM27C2048 @DIP40 MBM27C256A @DIP28 MBM27C256A @PLCC32 MBM27C32 @DIP24 MBM27C32A @DIP24 MBM27C4001 MBM27C4001 @PLCC32 MBM27C4001 @TSOP32 MBM27C4096 @DIP40 MBM27C512 @DIP28 MBM27C512 @PLCC32 MBM27C64 @DIP28 MBM27C64 @PLCC32 MBM28F010 MBM28F010 @SOIC32 MBM28F010 @PLCC32 MBM28F010 @TSOP32 MBM29DL161BD @TSOP48 MBM29DL161BE @TSOP48 MBM29DL161TD @TSOP48 MBM29DL161TE @TSOP48 MBM29DL162BD @TSOP48 MBM29DL162BE @TSOP48 MBM29DL162TD @TSOP48 MBM29DL162TE @TSOP48 MBM29DL163BD @TSOP48 MBM29DL163BE @TSOP48 MBM29DL163TD @TSOP48 MBM29DL163TE @TSOP48 MBM29DL164BD @TSOP48 MBM29DL164BE @TSOP48 MBM29DL164TD @TSOP48 MBM29DL164TE @TSOP48 MBM29DL321BD @TSOP48 MBM29DL321BE @TSOP48 MBM29DL321TD @TSOP48 MBM29DL321TE @TSOP48 MBM29DL322BD @TSOP48 MBM29DL322BE @TSOP48 MBM29DL322TD @TSOP48 MBM29DL322TE @TSOP48 MBM29DL323BD @TSOP48 MBM29DL323BE @TSOP48 MBM29DL323BF @TSOP48 MBM29DL323TD @TSOP48 MBM29DL323TE @TSOP48 MBM29DL323TF @TSOP48 MBM29DL324BD @TSOP48 MBM29DL324BE @TSOP48 MBM29DL324TD @TSOP48 MBM29DL324TE @TSOP48 MBM29DL32BF @TSOP48 MBM29DL32TF @TSOP48 MBM29DL34BF @TSOP48 MBM29DL34TF @TSOP48 MBM29DL400BB @TSOP48 MBM29DL400BB @SOP44 MBM29DL400BC @TSOP48 MBM29DL400BC @SOP44 MBM29DL400BT @TSOP48 MBM29DL400BT @SOP44 MBM29DL400TC @TSOP48 MBM29DL400TC @SOP44 MBM29DL800B @TSOP48 MBM29DL800B @SOP44 MBM29DL800BA @TSOP48 MBM29DL800BA @SOP44 MBM29DL800BB @TSOP48 MBM29DL800BB @SOP44 MBM29DL800BT @TSOP48 MBM29DL800BT @SOP44 MBM29DL800T @TSOP48 MBM29DL800T @SOP44 MBM29DL800TA @TSOP48 MBM29DL800TA @SOP44 MBM29DL640E @TSOP48 MBM29DL640D @TSOP48 MBM29F002B MBM29F002B @PLCC32 MBM29F002B @TSOP32 MBM29F002T MBM29F002T @PLCC32 MBM29F002T @TSOP32 MBM29F002SB @TSOP40 MBM29F002ST @TSOP40 MBM29F033C @TSOP40 MBM29F040 MBM29F040 @PLCC32 MBM29F040 @TSOP32 MBM29F040A @PLCC32 MBM29F040A @TSOP32 MBM29F040C @PLCC32 MBM29F040C @TSOP32 MBM29F160TE @TSOP48 MBM29F160BE @TSOP48 MBM29F200AB @TSOP48 MBM29F200AB @SOP44 MBM29F200AT @TSOP48 MBM29F200AT @SOP44 MBM29F200B @TSOP48 MBM29F200B @SOP44 MBM29F200BC @TSOP48 MBM29F200BC @SOP44 MBM29F200T @TSOP48 MBM29F200T @SOP44 MBM29F200TC @TSOP48 MBM29F200TC @SOP44 MBM29F400AB @TSOP48 MBM29F400AB @SOP44 MBM29F400AT @TSOP48 MBM29F400AT @SOP44 MBM29F400B @TSOP48 MBM29F400B @SOP44 MBM29F400BC @TSOP48 MBM29F400BC @SOP44 MBM29F400T @TSOP48 MBM29F400T @SOP44 MBM29F400TC @TSOP48 MBM29F400TC @SOP44 MBM29F800B @TSOP48 MBM29F800B @SOP44 MBM29F800BA @TSOP48 MBM29F800BA @SOP44 MBM29F800BB @TSOP48 MBM29F800BB @SOP44 MBM29F800BT @TSOP48 MBM29F800BT @SOP44 MBM29F800T @TSOP48 MBM29F800T @SOP44 MBM29F800TA @TSOP48 MBM29F800TA @SOP44 MBM29LV001B @PLCC32 MBM29LV001B @TSOP32 MBM29LV001BB @PLCC32 MBM29LV001BB @TSOP32 MBM29LV001BC @PLCC32 MBM29LV001BC @TSOP32 MBM29LV001BT @PLCC32 MBM29LV001BT @TSOP32 MBM29LV001T @PLCC32 MBM29LV001T @TSOP32 MBM29LV001TC @PLCC32 MBM29LV001TC @TSOP32 MBM29LV002B @TSOP40 MBM29LV002BC @TSOP40 MBM29LV002T @TSOP40 MBM29LV002TC @TSOP40 MBM29LV004B @TSOP40 MBM29LV004BB @TSOP40 MBM29LV004BC @TSOP40 MBM29LV004BT @TSOP40 MBM29LV004T @TSOP40 MBM29LV004TC @TSOP40 MBM29LV008B @TSOP40 MBM29LV008BA @TSOP40 MBM29LV008BB @TSOP40 MBM29LV008BT @TSOP40 MBM29LV008T @TSOP40 MBM29LV008TA @TSOP40 MBM29LV016T @TSOP40 MBM29LV016B @TSOP40 MBM29LV017 @TSOP40 MBM29LV017B @TSOP40 MBM29LV017E @TSOP40 MBM29LV160B @TSOP48 MBM29LV160BE @TSOP48 MBM29LV160BM @TSOP48 MBM29LV160T @TSOP48 MBM29LV160TE @TSOP48 MBM29LV160TM @TSOP48 MBM29LV200B @TSOP48 MBM29LV200B @SOP44 MBM29LV200BB @TSOP48 MBM29LV200BB @SOP44 MBM29LV200BC @TSOP48 MBM29LV200BC @SOP44 MBM29LV200BT @TSOP48 MBM29LV200BT @SOP44 MBM29LV200T @TSOP48 MBM29LV200T @SOP44 MBM29LV200TC @TSOP48 MBM29LV200TC @SOP44 MBM29LV320T @TSOP48 MBM29LV320B @TSOP48 MBM29LV400B @TSOP48 MBM29LV400B @SOP44 MBM29LV400BB @TSOP48 MBM29LV400BB @SOP44 MBM29LV400BC @TSOP48 MBM29LV400BC @SOP44 MBM29LV400BT @TSOP48 MBM29LV400BT @SOP44 MBM29LV400T @TSOP48 MBM29LV400T @SOP44 MBM29LV400TC @TSOP48 MBM29LV400TC @SOP44 MBM29LV650UE @TSOP48 MBM29LV651UE @TSOP48 MBM29LV800B @TSOP48 MBM29LV800B @SOP44 MBM29LV800BA @TSOP48 MBM29LV800BA @SOP44 MBM29LV800BB @TSOP48 MBM29LV800BB @SOP44 MBM29LV800BE @TSOP48 MBM29LV800BE @SOP44 MBM29LV800T @TSOP48 MBM29LV800T @SOP44 MBM29LV800TA @TSOP48 MBM29LV800TA @SOP44 MBM29LV800TE @TSOP48 MBM29LV800TE @SOP44 [ GATELEVEL ] 12 PCS GM24LC02B GM24LC02B @SOIC8 GM24LC02B @TSSOP8 GM24LC04B GM24LC04B @SOIC8 GM24LC04B @TSSOP8 GM24LC08B GM24LC08B @SOIC8 GM24LC08B @TSSOP8 GM24LC16B GM24LC16B @SOIC8 GM24LC16B @TSSOP8 [ GIANTEC ] 129 PCS GT24C01 GT24C01 @MSOP8 GT24C01 @SOIC8 GT24C01 @TSSOP8 GT24C02 GT24C02 @MSOP8 GT24C02 @SOIC8 GT24C02 @TSSOP8 GT24C04 GT24C04 @MSOP8 GT24C04 @SOIC8 GT24C04 @TSSOP8 GT24C08 GT24C08 @MSOP8 GT24C08 @SOIC8 GT24C08 @TSSOP8 GT24C16 GT24C16 @MSOP8 GT24C16 @SOIC8 GT24C16 @TSSOP8 GT24C32 GT24C32 @MSOP8 GT24C32 @SOIC8 GT24C32 @TSSOP8 GT24C32A GT24C32A @MSOP8 GT24C32A @SOIC8 GT24C32A @TSSOP8 GT24C64 GT24C64 @MSOP8 GT24C64 @SOIC8 GT24C64 @TSSOP8 GT24C128 GT24C128 @MSOP8 GT24C128 @SOIC8 GT24C128 @TSSOP8 GT24C128A GT24C128A @MSOP8 GT24C128A @SOIC8 GT24C128A @TSSOP8 GT24C256 GT24C256 @MSOP8 GT24C256 @SOIC8 GT24C256 @TSSOP8 GT24C512 GT24C512 @MAP8 GT24C512 @SOIC8 GT24C512 @TSSOP8 GT25C01 GT25C01 @SOIC8 GT25C01 @TSSOP8 GT25C02 GT25C02 @SOIC8 GT25C02 @TSSOP8 GT25C04 GT25C04 @SOIC8 GT25C04 @TSSOP8 GT25C08 GT25C08 @SOIC8 GT25C08 @TSSOP8 GT25C16 GT25C16 @SOIC8 GT25C16 @TSSOP8 GT25C32 GT25C32 @SOIC8 GT25C32 @TSSOP8 GT25C32A GT25C32A @SOIC8 GT25C32A @TSSOP8 GT25C64 GT25C64 @SOIC8 GT25C64 @TSSOP8 GT25C128 GT25C128 @SOIC8 GT25C128 @TSSOP8 GT25C128A GT25C128A @SOIC8 GT25C128A @TSSOP8 GT25C256 GT25C256 @SOIC8 GT25C256 @TSSOP8 GT93C46(x8) GT93C46(x8) @SOIC8 GT93C46(x8) @TSOP8 GT93C46(x16) GT93C46(x16) @SOIC8 GT93C46(x16) @TSOP8 GT93C46A(x8) GT93C46A(x8) @SOIC8 GT93C46A(x8) @TSOP8 GT93C46A(x16) GT93C46A(x16) @SOIC8 GT93C46A(x16) @TSOP8 GT93C56(x8) GT93C56(x8) @SOIC8 GT93C56(x8) @TSOP8 GT93C56(x16) GT93C56(x16) @SOIC8 GT93C56(x16) @TSOP8 GT93C56A(x8) GT93C56A(x8) @SOIC8 GT93C56A(x8) @TSOP8 GT93C56A(x16) GT93C56A(x16) @SOIC8 GT93C56A(x16) @TSOP8 GT93C66(x8) GT93C66(x8) @SOIC8 GT93C66(x8) @TSOP8 GT93C66(x16) GT93C66(x16) @SOIC8 GT93C66(x16) @TSOP8 GT93C66A(x8) GT93C66A(x8) @SOIC8 GT93C66A(x8) @TSOP8 GT93C66A(x16) GT93C66A(x16) @SOIC8 GT93C66A(x16) @TSOP8 GT93C76(x8) GT93C76(x8) @SOIC8 GT93C76(x8) @TSOP8 GT93C76(x16) GT93C76(x16) @SOIC8 GT93C76(x16) @TSOP8 GT93C86(x8) GT93C86(x8) @SOIC8 GT93C86(x8) @TSOP8 GT93C86(x16) GT93C86(x16) @SOIC8 GT93C86(x16) @TSOP8 [ GIGADEVICE ] 50 PCS GD25D40 GD25D40 @SOP8 GD25D80 GD25D80 @SOP8 GD25F40 GD25F40 @SOP8 GD25F80 GD25F80 @SOP8 GD25Q512 GD25Q512 @SOP8 GD25Q512 @TSSOP8 GD25Q512 @USON8 GD25Q10 GD25Q10 @SOP8 GD25Q10 @TSSOP8 GD25Q10 @USON8 GD25Q20 GD25Q20 @SOP8 GD25Q20 @TSSOP8 GD25Q20 @USON8 GD25Q40 GD25Q40 @SOP8 GD25Q40 @TSSOP8 GD25Q40 @USON8 GD25Q80 GD25Q80 @SOP8 GD25Q80B GD25Q80B @SOP8 GD25Q16 GD25Q16 @SOP8 GD25Q16B GD25Q16B @SOP8 GD25Q16B @TSSOP8 GD25Q16B @USON8 GD25Q32 GD25Q32 @SOP8 GD25Q32B GD25Q32B @SOP8 GD25Q32B @TSSOP8 GD25Q32B @USON8 GD25Q64 GD25Q64 @SOP8 GD25Q64 @USON8 GD25Q64 @SOP16 GD25Q64B GD25Q64B @SOP8 GD25Q64B @USON8 GD25Q64B @SOP16 GD25T80 GD25T80 @SOP8 [ GREEN-ENGINE ] 9 PCS GE24C01 GE24C01 @SOIC8 GE24C01 @TSSOP8 GE24C02 GE24C02 @SOIC8 GE24C02 @TSSOP8 GE24C04 GE24C04 @SOIC8 GE24C04 @TSSOP8 [ GREENWICH ] 4 PCS GR2764 @DIP28 GR27128 @DIP28 GR27256 @DIP28 GR27512 @DIP28 [ GTM ] 57 PCS GP24BC01 GP24BC01 @SOIC8 GP24BC01 @TSSOP8 GP24BC02 GP24BC02 @SOIC8 GP24BC02 @TSSOP8 GP24BC04 GP24BC04 @SOIC8 GP24BC04 @TSSOP8 GP24BC08 GP24BC08 @SOIC8 GP24BC08 @TSSOP8 GP24BC16 GP24BC16 @SOIC8 GP24BC16 @TSSOP8 GSC24BC01 GSC24BC01 @SOIC8 GSC24BC01 @TSSOP8 GSC24BC02 GSC24BC02 @SOIC8 GSC24BC02 @TSSOP8 GSC24BC04 GSC24BC04 @SOIC8 GSC24BC04 @TSSOP8 GSC24BC08 GSC24BC08 @SOIC8 GSC24BC08 @TSSOP8 GSC24BC16 GSC24BC16 @SOIC8 GSC24BC16 @TSSOP8 GSC93BC46(x8) GSC93BC46(x8) @SOIC8 GSC93BC46(x8) @TSOP8 GSC93BC46(x16) GSC93BC46(x16) @SOIC8 GSC93BC46(x16) @TSOP8 GSC93BC46A(x16) GSC93BC46A(x16) @SOIC8 GSC93BC46A(x16) @TSOP8 GSC93BC56(x8) GSC93BC56(x8) @SOIC8 GSC93BC56(x8) @TSOP8 GSC93BC56(x16) GSC93BC56(x16) @SOIC8 GSC93BC56(x16) @TSOP8 GSC93BC56A(x16) GSC93BC56A(x16) @SOIC8 GSC93BC56A(x16) @TSOP8 GSC93BC66(x8) GSC93BC66(x8) @SOIC8 GSC93BC66(x8) @TSOP8 GSC93BC66(x16) GSC93BC66(x16) @SOIC8 GSC93BC66(x16) @TSOP8 GSC93BC66A(x16) GSC93BC66A(x16) @SOIC8 GSC93BC66A(x16) @TSOP8 [ HITACHI ] 56 PCS HN27128AG @DIP28 HN27128AP @DIP28 HN27256G @DIP28 HN27256P @DIP28 HN27512G @DIP28 HN27512G @SOP28 HN27512P @DIP28 HN27512P @SOP28 HN27C101AG @DIP32 HN27C101AP @DIP32 HN27C101AFP @SOP32 HN27C101ATT @TSOP32 HN27C101G @DIP32 HN27C101P @DIP32 HN27C1024 @DIP40 HN27C256AG @DIP28 HN27C256AFP @SOP28 HN27C256AP @DIP28 HN27C256G @DIP28 HN27C256HG @DIP28 HN27C256HP @DIP28 HN27C256HFP @SOP28 HN27C4001G @DIP32 HN27C4001TT @TSOP32 HN27C4096 @DIP40 HN27C4096G @DIP40 HN27C4096H @DIP40 HN27C512G @DIP28 HN27C64G @DIP28 HN27C64FP @SOP28 HN28F101CP @PLCC32 HN28F101P @DIP32 HN28F101FP @SOP32 HN28F101T @TSOP32 HN58V24256 @SOIC8 HN58V24256 @TSSOP8 HN58V24512 @SOIC8 HN58V24512 @TSSOP8 HN58X2402 @SOIC8 HN58X2402 @TSSOP8 HN58X2404 @SOIC8 HN58X2404 @TSSOP8 HN58X2408 @SOIC8 HN58X2408 @TSSOP8 HN58X2416 @SOIC8 HN58X2416 @TSSOP8 HN58X2432 @SOIC8 HN58X2432 @TSSOP8 HN58X2464 @SOIC8 HN58X2464 @TSSOP8 HN58X24128 @SOIC8 HN58X24128 @TSSOP8 HN58X24256 @SOIC8 HN58X24256 @TSSOP8 HN58X24512 @SOIC8 HN58X24512 @TSSOP8 [ HOLTEK ] 120 PCS HT24C01 HT24C01 @SOIC8 HT24C02 HT24C02 @SOIC8 HT24C04 HT24C04 @SOIC8 HT24C08 HT24C08 @SOIC8 HT24C16 HT24C16 @SOIC8 HT24LC02 HT24LC02 @SOIC8 HT24LC02 @TSSOP8 HT24LC04 HT24LC04 @SOIC8 HT24LC04 @TSSOP8 HT24LC08 HT24LC08 @SOIC8 HT24LC08 @TSSOP8 HT24LC16 HT24LC16 @SOIC8 HT24LC16 @TSSOP8 HT24LC32 HT24LC32 @SOIC8 HT24LC32 @TSSOP8 HT24LC64 HT24LC64 @SOIC8 HT24LC64 @TSSOP8 HT24LC128 HT24LC128 @SOIC8 HT24LC128 @TSSOP8 HT24LC256 HT24LC256 @SOIC8 HT24LC256 @TSSOP8 HT27C010 HT27C010 @SOP32 HT27C010 @PLCC32 HT27C020 HT27C020 @SOP32 HT27C020 @PLCC32 HT27C040 HT27C040 @SOP32 HT27C040 @PLCC32 HT27C4096 @DIP40 HT27C512 HT27C512 @SOP28 HT27C512 @PLCC32 HT27LC010 HT27LC010 @SOP32 HT27LC010 @PLCC32 HT27LC010 @TSOP32 HT27LC020 HT27LC020 @SOP32 HT27LC020 @PLCC32 HT27LC020 @TSOP32 HT27LC040 HT27LC040 @SOP32 HT27LC040 @PLCC32 HT27LC040 @TSOP32 HT27LC4096 @DIP40 HT27LC512 HT27LC512 @SOP28 HT27LC512 @PLCC32 HT93C46(x16) HT93C46(x16) @SOIC8 HT93C46(x16) @TSOP8 HT93C56(x16) HT93C56(x16) @SOIC8 HT93C56(x16) @TSOP8 HT93C66(x16) HT93C66(x16) @SOIC8 HT93C66(x16) @TSOP8 HT93LC46A(x8) HT93LC46A(x8) @SOIC8 HT93LC46A(x8) @TSOP8 HT93LC46A(x16) HT93LC46A(x16) @SOIC8 HT93LC46A(x16) @TSOP8 HT93LC46B(x8) HT93LC46B(x8) @SOIC8 HT93LC46B(x8) @TSOP8 HT93LC46B(x16) HT93LC46B(x16) @SOIC8 HT93LC46B(x16) @TSOP8 HT93LC56A(x8) HT93LC56A(x8) @SOIC8 HT93LC56A(x8) @TSOP8 HT93LC56A(x16) HT93LC56A(x16) @SOIC8 HT93LC56A(x16) @TSOP8 HT93LC56B(x8) HT93LC56B(x8) @SOIC8 HT93LC56B(x8) @TSOP8 HT93LC56B(x16) HT93LC56B(x16) @SOIC8 HT93LC56B(x16) @TSOP8 HT93LC66A(x8) HT93LC66A(x8) @SOIC8 HT93LC66A(x8) @TSOP8 HT93LC66A(x16) HT93LC66A(x16) @SOIC8 HT93LC66A(x16) @TSOP8 HT93LC66B(x8) HT93LC66B(x8) @SOIC8 HT93LC66B(x8) @TSOP8 HT93LC66B(x16) HT93LC66B(x16) @SOIC8 HT93LC66B(x16) @TSOP8 HT93LC76(x8) HT93LC76(x8) @SOIC8 HT93LC76(x8) @TSOP8 HT93LC76(x16) HT93LC76(x16) @SOIC8 HT93LC76(x16) @TSOP8 HT93LC86(x8) HT93LC86(x8) @SOIC8 HT93LC86(x8) @TSOP8 HT93LC86(x16) HT93LC86(x16) @SOIC8 HT93LC86(x16) @TSOP8 [ HOPEFIND ] 21 PCS HM24LC01 HM24LC01 @SOIC8 HM24LC01 @TSSOP8 HM24LC02 HM24LC02 @SOIC8 HM24LC02 @TSSOP8 HM24LC04 HM24LC04 @SOIC8 HM24LC04 @TSSOP8 HM24LC08 HM24LC08 @SOIC8 HM24LC08 @TSSOP8 HM24LC16 HM24LC16 @SOIC8 HM24LC16 @TSSOP8 HM24LC32 HM24LC32 @SOIC8 HM24LC32 @TSSOP8 HM24LC64 HM24LC64 @SOIC8 HM24LC64 @TSSOP8 [ HUAHONG ] 18 PCS K24C02 K24C02 @SOIC8 K24C02 @TSSOP8 K24C04 K24C04 @SOIC8 K24C04 @TSSOP8 K24C08 K24C08 @SOIC8 K24C08 @TSSOP8 K24C16 K24C16 @SOIC8 K24C16 @TSSOP8 K24C32 K24C32 @SOIC8 K24C32 @TSSOP8 K24C64 K24C64 @SOIC8 K24C64 @TSSOP8 [ HUAJIE ] 36 PCS K24C02 K24C02 @SOIC8 K24C02 @TSSOP8 K24C04 K24C04 @SOIC8 K24C04 @TSSOP8 K24C08 K24C08 @SOIC8 K24C08 @TSSOP8 K24C16 K24C16 @SOIC8 K24C16 @TSSOP8 K24C32 K24C32 @SOIC8 K24C32 @TSSOP8 K24C64 K24C64 @SOIC8 K24C64 @TSSOP8 K93C46(x8) K93C46(x8) @SOIC8 K93C46(x8) @TSOP8 K93C46(x16) K93C46(x16) @SOIC8 K93C46(x16) @TSOP8 K93C56(x8) K93C56(x8) @SOIC8 K93C56(x8) @TSOP8 K93C56(x16) K93C56(x16) @SOIC8 K93C56(x16) @TSOP8 K93C66(x8) K93C66(x8) @SOIC8 K93C66(x8) @TSOP8 K93C66(x16) K93C66(x16) @SOIC8 K93C66(x16) @TSOP8 [ HYNIX ] 65 PCS HY27C64 @DIP28 HY29DL162B @TSOP48 HY29DL162T @TSOP48 HY29DL163B @TSOP48 HY29DL163T @TSOP48 HY29F002T HY29F002T @PLCC32 HY29F002T @TSOP32 HY29F040 HY29F040 @PLCC32 HY29F040 @TSOP32 HY29F040A HY29F040A @PLCC32 HY29F040A @TSOP32 HY29F040T HY29F040T @PLCC32 HY29F040T @TSOP32 HY29F080 @TSOP40 HY29F200B @TSOP48 HY29F200B @SOP44 HY29F200T @TSOP48 HY29F200T @SOP44 HY29F400AB @TSOP48 HY29F400AB @SOP44 HY29F400AT @TSOP48 HY29F400AT @SOP44 HY29F400B @TSOP48 HY29F400B @SOP44 HY29F400T @TSOP48 HY29F400T @SOP44 HY29F800AB @TSOP48 HY29F800AB @SOP44 HY29F800AT @TSOP48 HY29F800AT @SOP44 HY29F800B @TSOP48 HY29F800B @SOP44 HY29F800T @TSOP48 HY29F800T @SOP44 HY29LV400T @TSOP48 HY29LV400T @SOP44 HY29LV400B @TSOP48 HY29LV400B @SOP44 HY29LV800T @TSOP48 HY29LV800T @SOP44 HY29LV800B @TSOP48 HY29LV800B @SOP44 HY29LV160T @TSOP48 HY29LV160B @TSOP48 HY29LV320T @TSOP48 HY29LV320B @TSOP48 HY93C46 HY93C46 @SOIC8 HY93C46 @TSOP8 HY93C56 HY93C56 @SOIC8 HY93C56 @TSOP8 HY93C66 HY93C66 @SOIC8 HY93C66 @TSOP8 HY93C76 HY93C76 @SOIC8 HY93C76 @TSOP8 HY93C86 HY93C86 @SOIC8 HY93C86 @TSOP8 [ HYUNDAI ] 65 PCS HY27C64 @DIP28 HY29DL162B @TSOP48 HY29DL162T @TSOP48 HY29DL163B @TSOP48 HY29DL163T @TSOP48 HY29F002T HY29F002T @PLCC32 HY29F002T @TSOP32 HY29F040 HY29F040 @PLCC32 HY29F040 @TSOP32 HY29F040A HY29F040A @PLCC32 HY29F040A @TSOP32 HY29F040T HY29F040T @PLCC32 HY29F040T @TSOP32 HY29F080 @TSOP40 HY29F200B @TSOP48 HY29F200B @SOP44 HY29F200T @TSOP48 HY29F200T @SOP44 HY29F400AB @TSOP48 HY29F400AB @SOP44 HY29F400AT @TSOP48 HY29F400AT @SOP44 HY29F400B @TSOP48 HY29F400B @SOP44 HY29F400T @TSOP48 HY29F400T @SOP44 HY29F800AB @TSOP48 HY29F800AB @SOP44 HY29F800AT @TSOP48 HY29F800AT @SOP44 HY29F800B @TSOP48 HY29F800B @SOP44 HY29F800T @TSOP48 HY29F800T @SOP44 HY29LV400T @TSOP48 HY29LV400T @SOP44 HY29LV400B @TSOP48 HY29LV400B @SOP44 HY29LV800T @TSOP48 HY29LV800T @SOP44 HY29LV800B @TSOP48 HY29LV800B @SOP44 HY29LV160T @TSOP48 HY29LV160B @TSOP48 HY29LV320T @TSOP48 HY29LV320B @TSOP48 HY93C46 HY93C46 @SOIC8 HY93C46 @TSOP8 HY93C56 HY93C56 @SOIC8 HY93C56 @TSOP8 HY93C66 HY93C66 @SOIC8 HY93C66 @TSOP8 HY93C76 HY93C76 @SOIC8 HY93C76 @TSOP8 HY93C86 HY93C86 @SOIC8 HY93C86 @TSOP8 [ ICE ] 20 PCS ICE25P05 ICE25P05 @SOP8 ICE27C010 ICE27C010 @PLCC32 ICE27C010 @TSOP32 ICE27C020 ICE27C020 @PLCC32 ICE27C020 @TSOP32 ICE27C512 @DIP28 ICE27C512 @SO28 ICE27C512 @PLCC32 ICE27LC010 ICE27LC010 @PLCC32 ICE27LC010 @TSOP32 ICE27LC020 ICE27LC020 @PLCC32 ICE27LC020 @TSOP32 ICE27LC512 @DIP28 ICE27LC512 @SOP28 ICE27LC512 @PLCC32 [ ICMIC ] 48 PCS X24C01 X24C01 @MSOP8 X24C01 @SOIC8 X24C01A X24C01A @MSOP8 X24C01A @SOIC8 X24C02 X24C02 @SOIC8 X24C02 @MSOP8 X24C04 X24C04 @SOIC8 X24C04 @MSOP8 X24C08 X24C08 @SOIC8 X24C08 @MSOP8 X24C16 X24C16 @SOIC8 X24C16 @MSOP8 X25020 X25020 @SOIC8 X25021 X25021 @SOIC8 X25040 X25040 @SOIC8 X25041 X25041 @SOIC8 X25080 X25080 @SOIC8 X25128 X25128 @SOIC8 X25160 X25160 @SOIC8 X25170 X25170 @SOIC8 X25320 X25320 @SOIC8 X25330 X25330 @SOIC8 X25640 X25640 @SOIC8 X25642 X25642 @SOIC8 X25650 X25650 @SOIC8 27CX010 @DIP32 27CX010 @PLCC32 27CX256 @DIP28 27CX256 @PLCC32 [ ICT ] 18 PCS 27CX010 @DIP32 27CX010 @PLCC32 27CX256 @DIP28 27CX256 @PLCC32 93C46 93C46 @SOIC8 93C46A 93C46A @SOIC8 93C56A 93C56A @SOIC8 93C66A 93C66A @SOIC8 93CX46 93CX46 @SOIC8 93CX56 93CX56 @SOIC8 93CX66 93CX66 @SOIC8 [ IKSEMICON ] 8 PCS IK24LC02B IK24LC02B @SOIC8 IK24LC04B IK24LC04B @SOIC8 IK24LC08B IK24LC08B @SOIC8 IK24LC16B IK24LC16B @SOIC8 [ IMT ] 24 PCS IM29F001B IM29F001B @PLCC32 IM29F001B @TSOP32 IM29F001B @VSOP32 IM29F001T IM29F001T @PLCC32 IM29F001T @TSOP32 IM29F001T @VSOP32 IM29F002B IM29F002B @PLCC32 IM29F002B @TSOP32 IM29F002B @VSOP32 IM29F002T IM29F002T @PLCC32 IM29F002T @TSOP32 IM29F002T @VSOP32 IM29LV004B IM29LV004B @PLCC32 IM29LV004B @TSOP32 IM29LV004B @VSOP32 IM29LV004T IM29LV004T @PLCC32 IM29LV004T @TSOP32 IM29LV004T @VSOP32 [ INTEGRAL ] 60 PCS IN24AA02A IN24AA02A @SOIC8 IN24AA02B IN24AA02B @SOIC8 IN24LC02B IN24LC02B @SOIC8 IN24LC04B IN24LC04B @SOIC8 IN24LC08B IN24LC08B @SOIC8 IN24LC16B IN24LC16B @SOIC8 IN25AA020 IN25AA020 @SOIC8 IN25AA040 IN25AA040 @SOIC8 IN25AA080 IN25AA080 @SOIC8 IN25AA160 IN25AA160 @SOIC8 IN93AA46A IN93AA46A @SOIC8 IN93AA46B IN93AA46B @SOIC8 IN93AA46C(x8) IN93AA46C(x8) @SOIC8 IN93AA46C(x16) IN93AA46C(x16) @SOIC8 IN93AA56A IN93AA56A @SOIC8 IN93AA56B IN93AA56B @SOIC8 IN93AA56C(x8) IN93AA56C(x8) @SOIC8 IN93AA56C(x16) IN93AA56C(x16) @SOIC8 IN93AA66A IN93AA66A @SOIC8 IN93AA66B IN93AA66B @SOIC8 IN93AA66C(x8) IN93AA66C(x8) @SOIC8 IN93AA66C(x16) IN93AA66C(x16) @SOIC8 IN93AA86A IN93AA86A @SOIC8 IN93AA86B IN93AA86B @SOIC8 IN93AA86C(x8) IN93AA86C(x8) @SOIC8 IN93AA86C(x16) IN93AA86C(x16) @SOIC8 IN93LC46A IN93LC46A @SOIC8 IN93LC46B IN93LC46B @SOIC8 IN93LC46C(x8) IN93LC46C(x8) @SOIC8 IN93LC46C(x16) IN93LC46C(x16) @SOIC8 [ INTEL ] 220 PCS M2716 @DIP24 2732A @DIP24 2764A @DIP28 2764A @PLCC32 27128A @DIP28 27128A @PLCC32 M27256 @DIP28 M27256 @PLCC32 D27256 @DIP28 D27256 @PLCC32 P27256 @DIP28 P27256 @PLCC32 27512 @DIP28 27512 @PLCC32 27C010 @DIP32 27C010 @PLCC32 27C010A @DIP32 27C010A @PLCC32 27C020 @DIP32 27C020 @PLCC32 27C040 @DIP32 27C040 @PLCC32 27C128 @DIP28 27C128 @PLCC32 27C210 @DIP40 27C220 @DIP40 27C240 @DIP40 27C256 @DIP28 27C256 @PLCC32 27C512 @DIP28 27C512 @PLCC32 87C257 @DIP28 87C257 @PLCC32 87C51 87C51 @PLCC44 87C51FA 87C51FA @PLCC44 87C51FB 87C51FB @PLCC44 87C51FC 87C51FC @PLCC44 87C52 87C52 @PLCC44 87C54 87C54 @PLCC44 87C58 87C58 @PLCC44 AB28F200BX-T @SOP44 AB28F200BX-B @SOP44 AB28F400BX-T @SOP44 AB28F400BX-B @SOP44 E28F001BX-T @TSOP32 E28F001BX-B @TSOP32 E28F002BVT @TSOP40 E28F002BVB @TSOP40 E28F002BET @TSOP40 E28F002BEB @TSOP40 E28F002BXT @TSOP40 E28F002BXB @TSOP40 E28F004BVT @TSOP40 E28F004BVB @TSOP40 E28F004BET @TSOP40 E28F004BEB @TSOP40 E28F004BLT @TSOP40 E28F004BLB @TSOP40 E28F004BXT @TSOP40 E28F004BXB @TSOP40 E28F004B5T @TSOP40 E28F004B5B @TSOP40 E28F004S3 @TSOP40 E28F004S5 @TSOP40 E28F004SC @TSOP40 E28F008BVT @TSOP40 E28F008BVB @TSOP40 E28F008BET @TSOP40 E28F008BEB @TSOP40 E28F008S3 @TSOP40 E28F008S5 @TSOP40 E28F008SA @TSOP40 E28F008SC @TSOP40 E28F016S3 @TSOP40 E28F016S5 @TSOP40 E28F016SC @TSOP40 E28F010 @TSOP32 E28F020 @TSOP32 E28F200B5T @TSOP48 E28F200B5B @TSOP48 E28F200CVT @TSOP48 E28F200CVB @TSOP48 E28F256A @TSOP32 E28F400B5T @TSOP48 E28F400B5B @TSOP48 E28F400CVT @TSOP48 E28F400CVB @TSOP48 E28F512 @TSOP32 E28F800B5T @TSOP48 E28F800B5B @TSOP48 E28F800CVT @TSOP48 E28F800CVB @TSOP48 E82802AB @TSOP40 E82802AC @TSOP40 JS28F800B3T @TSOP48 JS28F800B3B @TSOP48 JS28F800C3T @TSOP48 JS28F800C3B @TSOP48 JS28F160B3T @TSOP48 JS28F160B3B @TSOP48 JS28F160C3T @TSOP48 JS28F160C3B @TSOP48 JS28F320B3T @TSOP48 JS28F320B3B @TSOP48 JS28F320C3T @TSOP48 JS28F320C3B @TSOP48 P28F001BX-T @DIP32 P28F001BX-B @DIP32 P28F256A @DIP32 P28F512 @DIP32 P28F010 @DIP32 P28F020 @DIP32 PA28F200B5T @SOP44 PA28F200B5B @SOP44 PA28F200BVT @SOP44 PA28F200BVB @SOP44 PA28F400B5T @SOP44 PA28F400B5B @SOP44 PA28F400BVT @SOP44 PA28F400BVB @SOP44 PA28F800B5T @SOP44 PA28F800B5B @SOP44 QB25F016S33B QB25F160S33B @SOP16 QB25F320S33B @SOP16 QB25F640S33B @SOP16 QH25F016S33B QH25F160S33B @SOP16 QH25F320S33B @SOP16 QH25F640S33B @SOP16 N28F001BX-T @PLCC32 N28F001BX-B @PLCC32 N28F256A @PLCC32 N28F512 @PLCC32 N28F010 @PLCC32 N28F020 @PLCC32 N82802AB @PLCC32 N82802AC @PLCC32 TB28F200B5T @SOP44 TB28F200B5B @SOP44 TB28F200BVT @SOP44 TB28F200BVB @SOP44 TB28F400B5T @SOP44 TB28F400B5B @SOP44 TB28F400BVT @SOP44 TB28F400BVB @SOP44 TB28F800B5T @SOP44 TB28F800B5B @SOP44 TE28F002BVT @TSOP40 TE28F002BVB @TSOP40 TE28F002BET @TSOP40 TE28F002BEB @TSOP40 TE28F002BXT @TSOP40 TE28F002BXB @TSOP40 TE28F004BVT @TSOP40 TE28F004BVB @TSOP40 TE28F004BET @TSOP40 TE28F004BEB @TSOP40 TE28F004BXT @TSOP40 TE28F004BXB @TSOP40 TE28F004S3 @TSOP40 TE28F004S5 @TSOP40 TE28F004SC @TSOP40 TE28F008BVT @TSOP40 TE28F008BVB @TSOP40 TE28F008BET @TSOP40 TE28F008BEB @TSOP40 TE28F008B3T @TSOP40 TE28F008B3B @TSOP40 TE28F008C3T @TSOP40 TE28F008C3B @TSOP40 TE28F008S3 @TSOP40 TE28F008S5 @TSOP40 TE28F008SC @TSOP40 TE28F016B3T @TSOP40 TE28F016B3B @TSOP40 TE28F016C3T @TSOP40 TE28F016C3B @TSOP40 TE28F016S3 @TSOP40 TE28F016S5 @TSOP40 TE28F016SC @TSOP40 TE28F200B5T @TSOP48 TE28F200B5B @TSOP48 TE28F200CVT @TSOP48 TE28F200CVB @TSOP48 TE28F400B3T @TSOP48 TE28F400B3B @TSOP48 TE28F400B5T @TSOP48 TE28F400B5B @TSOP48 TE28F400CVT @TSOP48 TE28F400CVB @TSOP48 TE28F400CET @TSOP48 TE28F400CEB @TSOP48 TE28F800B3T @TSOP48 TE28F800B3B @TSOP48 TE28F800B5T @TSOP48 TE28F800B5B @TSOP48 TE28F800CVT @TSOP48 TE28F800CVB @TSOP48 TE28F800C3T @TSOP48 TE28F800C3B @TSOP48 TE28F160B3T @TSOP48 TE28F160B3B @TSOP48 TE28F160C3T @TSOP48 TE28F160C3B @TSOP48 TE28F320B3T @TSOP48 TE28F320B3B @TSOP48 TE28F320C3T @TSOP48 TE28F320C3B @TSOP48 TE28F640B3T @TSOP48 TE28F640B3B @TSOP48 TE28F640C3T @TSOP48 TE28F640C3B @TSOP48 [ ISSI ] 230 PCS IS24C01 IS24C01 @MAP8 IS24C01 @SOIC8 IS24C01 @TSSOP8 IS24C01B IS24C01B @MAP8 IS24C01B @SOIC8 IS24C01B @TSSOP8 IS24C01C IS24C01C @MAP8 IS24C01C @SOIC8 IS24C01C @TSSOP8 IS24C02 IS24C02 @SOIC8 IS24C02 @TSSOP8 IS24C02A IS24C02A @SOIC8 IS24C02A @TSSOP8 IS24C02B IS24C02B @MAP8 IS24C02B @SOIC8 IS24C02B @TSSOP8 IS24C02C IS24C02C @SOIC8 IS24C02C @TSSOP8 IS24C02E IS24C02E @SOIC8 IS24C02E @TSSOP8 IS24C04 IS24C04 @MAP8 IS24C04 @SOIC8 IS24C04 @TSSOP8 IS24C04A IS24C04A @MAP8 IS24C04A @SOIC8 IS24C04A @TSSOP8 IS24C04B IS24C04B @MAP8 IS24C04B @SOIC8 IS24C04B @TSSOP8 IS24C08 IS24C08 @MAP8 IS24C08 @SOIC8 IS24C08 @TSSOP8 IS24C08A IS24C08A @MAP8 IS24C08A @SOIC8 IS24C08A @TSSOP8 IS24C08B IS24C08B @MAP8 IS24C08B @SOIC8 IS24C08B @TSSOP8 IS24C16 IS24C16 @SOIC8 IS24C16 @TSSOP8 IS24C16A IS24C16A @MAP8 IS24C16A @SOIC8 IS24C16A @TSSOP8 IS24C16B IS24C16B @MAP8 IS24C16B @SOIC8 IS24C16B @TSSOP8 IS24C32 IS24C32 @SOIC8 IS24C32 @TSSOP8 IS24C32A IS24C32A @MAP8 IS24C32A @SOIC8 IS24C32A @TSSOP8 IS24C32B IS24C32B @MAP8 IS24C32B @SOIC8 IS24C32B @TSSOP8 IS24C32C IS24C32C @SOIC8 IS24C32C @TSSOP8 IS24C64 IS24C64 @SOIC8 IS24C64 @TSSOP8 IS24C64A IS24C64A @MAP8 IS24C64A @SOIC8 IS24C64A @TSSOP8 IS24C64B IS24C64B @SOIC8 IS24C64B @TSSOP8 IS24C64C IS24C64C @MAP8 IS24C64C @SOIC8 IS24C64C @TSSOP8 IS24C128 IS24C128 @MAP8 IS24C128 @SOIC8 IS24C128 @TSSOP8 IS24C128B IS24C128B @MAP8 IS24C128B @SOIC8 IS24C128B @TSSOP8 IS24C256 IS24C256 @MAP8 IS24C256 @SOIC8 IS24C256 @TSSOP8 IS24C256A IS24C256A @MAP8 IS24C256A @SOIC8 IS24C256A @TSSOP8 IS24C256C IS24C256C @MAP8 IS24C256C @SOIC8 IS24C256C @TSSOP8 IS24L128 IS24L128 @SOIC8 IS24L128 @TSSOP8 IS24L256 IS24L256 @SOIC8 IS24L256 @TSSOP8 IS25C01 IS25C01 @SOIC8 IS25C01 @TSSOP8 IS25C02 IS25C02 @SOIC8 IS25C02 @TSSOP8 IS25C04 IS25C04 @SOIC8 IS25C04 @TSSOP8 IS25C08 IS25C08 @SOIC8 IS25C08 @TSSOP8 IS25C16 IS25C16 @SOIC8 IS25C16 @TSSOP8 IS25C32 IS25C32 @SOIC8 IS25C32 @TSSOP8 IS25C32A IS25C32A @SOIC8 IS25C32A @TSSOP8 IS25C64 IS25C64 @SOIC8 IS25C64 @TSSOP8 IS25C128 IS25C128 @SOIC8 IS25C128 @TSSOP8 IS25C256 IS25C256 @SOIC8 IS25C256 @TSSOP8 IS27C010 @DIP32 IS27C010 @PLCC32 IS27C010 @TSOP32 IS27C020 @DIP32 IS27C020 @PLCC32 IS27C020 @TSOP32 IS27C256 @DIP28 IS27C256 @PLCC32 IS27C512 @DIP28 IS27C512 @PLCC32 IS27HC010 @DIP32 IS27HC010 @PLCC32 IS27HC010 @TSOP32 IS27HC020 @DIP32 IS27HC020 @PLCC32 IS27HC020 @TSOP32 IS27HC256 @DIP28 IS27HC256 @PLCC32 IS27HC512 @DIP28 IS27HC512 @PLCC32 IS27LV010 @DIP32 IS27LV010 @PLCC32 IS27LV010 @TSOP32 IS27LV020 @DIP32 IS27LV020 @PLCC32 IS27LV020 @TSOP32 IS27LV256 @DIP28 IS27LV256 @PLCC32 IS27LV512 @DIP28 IS27LV512 @PLCC32 IS28F010 IS28F010 @PLCC32 IS28F010 @TSOP32 IS28F020 IS28F020 @PLCC32 IS28F020 @TSOP32 IS93C46(x8) IS93C46(x8) @SOIC8 IS93C46(x8) @TSOP8 IS93C46A(x8) IS93C46A(x8) @SOIC8 IS93C46A(x8) @TSOP8 IS93C46A(x16) IS93C46A(x16) @SOIC8 IS93C46A(x16) @TSOP8 IS93C46B IS93C46B @SOIC8 IS93C46B @TSOP8 IS93C46D(x8) IS93C46D(x8) @SOIC8 IS93C46D(x8) @TSOP8 IS93C46D(x16) IS93C46D(x16) @SOIC8 IS93C46D(x16) @TSOP8 IS93C56(x16) IS93C56(x16) @SOIC8 IS93C56A(x8) IS93C56A(x8) @SOIC8 IS93C56A(x8) @TSOP8 IS93C56A(x16) IS93C56A(x16) @SOIC8 IS93C56A(x16) @TSOP8 IS93C66(x16) IS93C66(x16) @SOIC8 IS93C66(x16) @TSOP8 IS93C66A(x8) IS93C66A(x8) @SOIC8 IS93C66A(x8) @TSOP8 IS93C66A(x16) IS93C66A(x16) @SOIC8 IS93C66A(x16) @TSOP8 IS93C76A(x8) IS93C76A(x8) @SOIC8 IS93C76A(x8) @TSOP8 IS93C76A(x16) IS93C76A(x16) @SOIC8 IS93C76A(x16) @TSOP8 IS93C86A(x8) IS93C86A(x8) @SOIC8 IS93C86A(x8) @TSOP8 IS93C86A(x16) IS93C86A(x16) @SOIC8 IS93C86A(x16) @TSOP8 [ KHIC ] 40 PCS KH25L1005 KH25L1005 @SON8 KH25L1005 @SOP8 KH25L1005A KH25L1005A @SON8 KH25L1005A @SOP8 KH25L2005 KH25L2005 @SON8 KH25L2005 @SOP8 KH25L4005 KH25L4005 @SON8 KH25L4005 @SOP8 KH25L4005A KH25L4005A @SON8 KH25L4005A @SOP8 KH25L512 KH25L512 @SON8 KH25L512 @SOP8 KH25L512A KH25L512A @SON8 KH25L512A @SOP8 KH25L8005 KH25L8005 @SON8 KH25L8005 @SOP8 KH25L8036D KH25L8036D @WSON8 KH25L8036D @SOP8 KH25L8036D @SOP16 KH29LV160CB @TSOP48 KH29LV160CT @TSOP48 KH29LV320DB @TSOP48 KH29LV320DT @TSOP48 KH29LV400CB @TSOP48 KH29LV400CB @SOP44 KH29LV400CT @TSOP48 KH29LV400CT @SOP44 KH29LV800CB @TSOP48 KH29LV800CB @SOP44 KH29LV800CT @TSOP48 KH29LV800CT @SOP44 [ KODENSHI ] 8 PCS KK24LC02B KK24LC02B @SOIC8 KK24LC04B KK24LC04B @SOIC8 KK24LC08B KK24LC08B @SOIC8 KK24LC16B KK24LC16B @SOIC8 [ LATTICE ] 23 PCS GAL16V8 GAL16V8 @SOIC20 GAL16V8A GAL16V8A @SOIC20 GAL16V8B GAL16V8B @SOIC20 GAL16V8C GAL16V8C @SOIC20 GAL16V8D GAL16V8D @SOIC20 GAL20V8 GAL20V8A GAL20V8B GAL20V8C GAL20V8D GAL22V10 GAL22V10 @SOIC24 GAL22V10B GAL22V10B @SOIC24 GAL22V10C GAL22V10C @SOIC24 GAL22V10D GAL22V10D @SOIC24 [ LINKAGE ] 6 PCS LG28C010 @DIP32 LG28C010 @PLCC32 LG28C020 @DIP32 LG28C020 @PLCC32 LG28C040 @DIP32 LG28C040 @PLCC32 [ LINKSMART ] 25 PCS L24C02 L24C02 @SOIC8 L24C02 @TSSOP8 L24C04 L24C04 @SOIC8 L24C04 @TSSOP8 L29S400F @TSOP48 L29S400F @SOP44 L29S400F-B @TSOP48 L29S400F-B @SOP44 L29S800F @TSOP48 L29S800F @SOP44 L29S800F-B @TSOP48 L29S800F-B @SOP44 L29S160F @TSOP48 L29S160F-B @TSOP48 LST28001 LST28001 @PLCC32 LST28001 @TSOP32 LST28002 LST28002 @PLCC32 LST28002 @TSOP32 LST28004 LST28004 @PLCC32 LST28004 @TSOP32 [ LITAO ] 5 PCS L24C01 L24C02 L24C04 L24C08 L24C16 [ LIZE ] 12 PCS L24C02 L24C02 @SOIC8 L24C02 @TSSOP8 L24C04 L24C04 @SOIC8 L24C04 @TSSOP8 L24C08 L24C08 @SOIC8 L24C08 @TSSOP8 L24C16 L24C16 @SOIC8 L24C16 @TSSOP8 [ LYONTEK ] 12 PCS LY24C02 LY24C02 @SOIC8 LY24C02 @TSSOP8 LY24C04 LY24C04 @SOIC8 LY24C04 @TSSOP8 LY24C08 LY24C08 @SOIC8 LY24C08 @TSSOP8 LY24C16 LY24C16 @SOIC8 LY24C16 @TSSOP8 [ MACRONIX ] 421 PCS KH25L1005 KH25L1005 @SON8 KH25L1005 @SOP8 KH25L1005A KH25L1005A @SON8 KH25L1005A @SOP8 KH25L2005 KH25L2005 @SON8 KH25L2005 @SOP8 KH25L4005 KH25L4005 @SON8 KH25L4005 @SOP8 KH25L4005A KH25L4005A @SON8 KH25L4005A @SOP8 KH25L512 KH25L512 @SON8 KH25L512 @SOP8 KH25L512A KH25L512A @SON8 KH25L512A @SOP8 KH25L8005 KH25L8005 @SON8 KH25L8005 @SOP8 KH25L8036D KH25L8036D @WSON8 KH25L8036D @SOP8 KH25L8036D @SOP16 KH29LV160CB @TSOP48 KH29LV160CT @TSOP48 KH29LV320DB @TSOP48 KH29LV320DT @TSOP48 KH29LV400CB @TSOP48 KH29LV400CB @SOP44 KH29LV400CT @TSOP48 KH29LV400CT @SOP44 KH29LV800CB @TSOP48 KH29LV800CB @SOP44 KH29LV800CT @TSOP48 KH29LV800CT @SOP44 MX25L1005 MX25L1005 @SON8 MX25L1005 @SOP8 MX25L1005 @USON8 MX25L1005A MX25L1005A @SON8 MX25L1005A @SOP8 MX25L1005C @SON8 MX25L1005C @SOP8 MX25L1006E @SOP8 MX25L1006E @USON8 MX25L1021E MX25L1021E @SOP8 MX25L1021E @SON8 MX25L1025C @SOP8 MX25L1026E @SOP8 MX25L12805D @SON8 MX25L12805D @WSON8 MX25L12805D @SOP16 MX25L12835E @WSON8 MX25L12835E @SOP16 MX25L12836E @SOP8 MX25L12836E @WSON8 MX25L12836E @SOP16 MX25L12845E @WSON8 MX25L12845E @SOP16 MX25L12865E @SOP8 MX25L12865E @WSON8 MX25L12865E @SOP16 MX25L1605 @SOP8 MX25L1605 @SOP16 MX25L1605A @SOP8 MX25L1605A @SOP16 MX25L1605D @SOP8 MX25L1605D @SOP16 MX25L1606E MX25L1606E @SOP8 MX25L1606E @USON8 MX25L1606E @WSON8 MX25L1606E @SOP16 MX25L1633E @SOP8 MX25L1633E @WSON8 MX25L1633E @SOP16 MX25L1635D @SOP8 MX25L1635D @USON8 MX25L1635D @WSON8 MX25L1635D @SOP16 MX25L1635E @SOP8 MX25L1636D @SOP8 MX25L1636D @WSON8 MX25L1636D @SOP16 MX25L1636E @SOP8 MX25L2005 MX25L2005 @SOP8 MX25L2005 @SON8 MX25L2005C @SOP8 MX25L2005C @USON8 MX25L2006E @SOP8 MX25L2006E @WSON8 MX25L2026C @SOP8 MX25L2026E @SOP8 MX25L2026E @WSON8 MX25L3205 @SOP8 MX25L3205 @SOP16 MX25L3205A @SOP8 MX25L3205A @SOP16 MX25L3205D @SOP8 MX25L3205D @SOP16 MX25L3206E MX25L3206E @SOP8 MX25L3206E @USON8 MX25L3206E @WSON8 MX25L3206E @SOP16 MX25L3225D @SOP8 MX25L3235D @SOP8 MX25L3235D @WSON8 MX25L3235D @SOP16 MX25L3236D @SOP8 MX25L3236D @WSON8 MX25L3236D @SOP16 MX25L3237D @WSON8 MX25L3237D @SOP16 MX25L4005 MX25L4005 @SOP8 MX25L4005 @SON8 MX25L4005 @USON8 MX25L4005A MX25L4005A @SOP8 MX25L4005A @SON8 MX25L4005A @USON8 MX25L4005C MX25L4005C @SOP8 MX25L4005C @TSOP8 MX25L4005C @USON8 MX25L4006E MX25L4006E @SOP8 MX25L4006E @WSON8 MX25L4026E @SOP8 MX25L512 MX25L512 @SOP8 MX25L512 @SON8 MX25L512A MX25L512A @SOP8 MX25L512A @SON8 MX25L512C MX25L512C @SOP8 MX25L512C @SON8 MX25L5121E MX25L5121E @SOP8 MX25L5121E @SON8 MX25L6405 MX25L6405 @16PIN MX25L6405D MX25L6405D @16PIN MX25L6406E @SOP8 MX25L6406E @WSON8 MX25L6406E @SOP16 MX25L6436E @SOP8 MX25L6436E @WSON8 MX25L6436E @SOP16 MX25L6445E @SOP8 MX25L6445E @WSON8 MX25L6445E @SOP16 MX25L6465E @SOP8 MX25L6465E @WSON8 MX25L6465E @SOP16 MX25L8005 MX25L8005 @SOP8 MX25L8005 @SON8 MX25L8005 @USON8 MX25L8006E MX25L8006E @SOP8 MX25L8006E @USON8 MX25L8006E @WSON8 MX25L8035E @SOP8 MX25L8036E @SOP8 MX25V512 MX25V512 @SOP8 MX25V512 @SOP8 MX25V4005 MX25V4005 @SOP8 MX25V4005 @WSON8 MX25V8005 MX25V8005 @SOP8 MX25V8005 @WSON8 MX26C1000 MX26C1000 @PLCC32 MX26C1000 @TSOP32 MX26C2000 MX26C2000 @PLCC32 MX26C2000 @TSOP32 MX26C4000 MX26C4000 @PLCC32 MX26C4000 @TSOP32 MX26LV004B @PLCC32 MX26LV004B @TSOP40 MX26LV004T @PLCC32 MX26LV004T @TSOP40 MX26LV008B @TSOP40 MX26LV008T @TSOP40 MX26LV040 MX26LV040 @PLCC32 MX26LV040 @TSOP32 MX26LV160B @TSOP48 MX26LV160T @TSOP48 MX26LV400B @TSOP48 MX26LV400T @TSOP48 MX26LV800B @TSOP48 MX26LV800T @TSOP48 MX27C1000 @DIP32 MX27C1000 @PLCC32 MX27C1000 @TSOP32 MX27C1000A @DIP32 MX27C1000A @PLCC32 MX27C1000A @TSOP32 MX27C1024 @DIP40 MX27C2000 @DIP32 MX27C2000 @PLCC32 MX27C2000 @TSOP32 MX27C2000A @DIP32 MX27C2000A @PLCC32 MX27C2000A @TSOP32 MX27C2048 @DIP40 MX27C256 @DIP28 MX27C256 @PLCC32 MX27C4000 @DIP32 MX27C4000 @PLCC32 MX27C4000 @TSOP32 MX27C4000A @DIP32 MX27C4000A @PLCC32 MX27C4000A @TSOP32 MX27C4096 @DIP40 MX27C512 @DIP28 MX27C512 @PLCC32 MX27C8000 @DIP32 MX27C8000 @PLCC32 MX27C8000 @TSOP32 MX27C8000A @DIP32 MX27C8000A @PLCC32 MX27C8000A @TSOP32 MX27L1000 @DIP32 MX27L1000 @PLCC32 MX27L1000 @TSOP32 MX27L2000 @DIP32 MX27L2000 @PLCC32 MX27L2000 @TSOP32 MX27L256 @DIP28 MX27L256 @PLCC32 MX27L4000 @DIP32 MX27L4000 @PLCC32 MX27L4000 @TSOP32 MX27L4096 @DIP40 MX27L512 @DIP28 MX27L512 @PLCC32 MX28F1000P MX28F1000P @PLCC32 MX28F1000P @TSOP32 MX28F160C3B @TSOP48 MX28F160C3T @TSOP48 MX28F2000P MX28F2000P @PLCC32 MX28F2000P @TSOP32 MX28F2000T MX28F2100B @TSOP48 MX28F640C3B @TSOP48 MX28F640C3T @TSOP48 MX29F001B @DIP32 MX29F001B @PLCC32 MX29F001B @TSOP32 MX29F001T @DIP32 MX29F001T @PLCC32 MX29F001T @TSOP32 MX29F002B @DIP32 MX29F002B @PLCC32 MX29F002B @TSOP32 MX29F002NB @DIP32 MX29F002NB @PLCC32 MX29F002NB @TSOP32 MX29F002NT @DIP32 MX29F002NT @PLCC32 MX29F002NT @TSOP32 MX29F002T @DIP32 MX29F002T @PLCC32 MX29F002T @TSOP32 MX29F004B @DIP32 MX29F004B @PLCC32 MX29F004B @TSOP32 MX29F004T @DIP32 MX29F004T @PLCC32 MX29F004T @TSOP32 MX29F022B @DIP32 MX29F022B @PLCC32 MX29F022B @TSOP32 MX29F022NB @DIP32 MX29F022NB @PLCC32 MX29F022NB @TSOP32 MX29F022NT @DIP32 MX29F022NT @PLCC32 MX29F022NT @TSOP32 MX29F022T @DIP32 MX29F022T @PLCC32 MX29F022T @TSOP32 MX29F040 @DIP32 MX29F040 @PLCC32 MX29F040 @TSOP32 MX29F040C @DIP32 MX29F040C @PLCC32 MX29F040C @TSOP32 MX29F080 @TSOP40 MX29F100B @TSOP48 MX29F100B @SOP44 MX29F100T @TSOP48 MX29F100T @SOP44 MX29F200B @TSOP48 MX29F200B @SOP44 MX29F200CB @TSOP48 MX29F200CB @SOP44 MX29F200CT @TSOP48 MX29F200CT @SOP44 MX29F200T @TSOP48 MX29F200T @SOP44 MX29F400B @TSOP48 MX29F400B @SOP44 MX29F400CB @TSOP48 MX29F400CB @SOP44 MX29F400CT @TSOP48 MX29F400CT @SOP44 MX29F400T @TSOP48 MX29F400T @SOP44 MX29F800B @TSOP48 MX29F800B @SOP44 MX29F800CB @TSOP48 MX29F800CB @SOP44 MX29F800CT @TSOP48 MX29F800CT @SOP44 MX29F800T @TSOP48 MX29F800T @SOP44 MX29LV002CB @PLCC32 MX29LV002CB @TSOP32 MX29LV002NCB @PLCC32 MX29LV002NCB @TSOP32 MX29LV002NCT @PLCC32 MX29LV002NCT @TSOP32 MX29LV002CT @PLCC32 MX29LV002CT @TSOP32 MX29LV004B @PLCC32 MX29LV004B @TSOP32 MX29LV004B @TSOP40 MX29LV004CB @TSOP40 MX29LV004CT @TSOP40 MX29LV004T @PLCC32 MX29LV004T @TSOP32 MX29LV004T @TSOP40 MX29LV008B @TSOP40 MX29LV008BB @TSOP40 MX29LV008BT @TSOP40 MX29LV008CB @TSOP40 MX29LV008CT @TSOP40 MX29LV008T @TSOP40 MX29LV017AT @TSOP40 MX29LV017BT @TSOP40 MX29LV040 @PLCC32 MX29LV040 @TSOP32 MX29LV040C @PLCC32 MX29LV040C @TSOP32 MX29LV160B @TSOP48 MX29LV160AB @TSOP48 MX29LV160AT @TSOP48 MX29LV160BB @TSOP48 MX29LV160BT @TSOP48 MX29LV160CB @TSOP48 MX29LV160CT @TSOP48 MX29LV160DB @TSOP48 MX29LV160DT @TSOP48 MX29LV160EB @TSOP48 MX29LV160ET @TSOP48 MX29LV160T @TSOP48 MX29LV320AB @TSOP48 MX29LV320AT @TSOP48 MX29LV320B @TSOP48 MX29LV320BB @TSOP48 MX29LV320BT @TSOP48 MX29LV320CB @TSOP48 MX29LV320CT @TSOP48 MX29LV320DB @TSOP48 MX29LV320DT @TSOP48 MX29LV320EB @TSOP48 MX29LV320ET @TSOP48 MX29LV320MB @TSOP48 MX29LV320MT @TSOP48 MX29LV320T @TSOP48 MX29LV400B @TSOP48 MX29LV400B @SOP44 MX29LV400BB @TSOP48 MX29LV400BB @SOP44 MX29LV400BT @TSOP48 MX29LV400BT @SOP44 MX29LV400CB @TSOP48 MX29LV400CB @SOP44 MX29LV400CT @TSOP48 MX29LV400CT @SOP44 MX29LV400T @TSOP48 MX29LV400T @SOP44 MX29LV640BB @TSOP48 MX29LV640BT @TSOP48 MX29LV640EB @TSOP48 MX29LV640ET @TSOP48 MX29LV640MB @TSOP48 MX29LV640MT @TSOP48 MX29LV800B @TSOP48 MX29LV800B @SOP44 MX29LV800BB @TSOP48 MX29LV800BB @SOP44 MX29LV800BT @TSOP48 MX29LV800BT @SOP44 MX29LV800CB @TSOP48 MX29LV800CB @SOP44 MX29LV800CT @TSOP48 MX29LV800CT @SOP44 MX29LV800T @TSOP48 MX29LV800T @SOP44 -------------------- Живы будем - Не помрем !
![]() Администратор ![]() ![]() ![]() ![]() ![]() Группа: Root Admin Сообщений: 6 344 Регистрация: 7.1.2006 Из: Красноярск Пользователь №: 1 ![]() |
[ MAXCOM ] 12 PCS
MAX24A02 MAX24A02 @SOIC8 MAX24A02 @TSSOP8 MAX24A04 MAX24A04 @SOIC8 MAX24A04 @TSSOP8 MAX24A08 MAX24A08 @SOIC8 MAX24A08 @TSSOP8 MAX24A16 MAX24A16 @SOIC8 MAX24A16 @TSSOP8 [ MAXWELL ] 12 PCS 28C010 28C010 @PLCC32 28C010 @TSOP32 28C010T 28C010T @PLCC32 28C010T @TSOP32 28C011 28C011 @PLCC32 28C011 @TSOP32 28C011T 28C011T @PLCC32 28C011T @TSOP32 [ MICROCHIP memory ] 784 PCS 24AA00 24AA00 @DFN8 24AA00 @SOIC8 24AA00 @TSSOP8 24AA01 24AA01 @DFN8 24AA01 @SOIC8 24AA01 @TSSOP8 24AA014 24AA014 @SOIC8 24AA014 @TSSOP8 24AA02 24AA02 @DFN8 24AA02 @SOIC8 24AA02 @TSSOP8 24AA024 24AA024 @DFN8 24AA024 @SOIC8 24AA024 @TSSOP8 24AA025 24AA025 @DFN8 24AA025 @SOIC8 24AA025 @TSSOP8 24AA04 24AA04 @DFN8 24AA04 @SOIC8 24AA04 @TSSOP8 24AA08 24AA08 @DFN8 24AA08 @SOIC8 24AA08 @TSSOP8 24AA128 24AA128 @DFN8 24AA128 @SOIC8 24AA128 @TSSOP8 24AA16 24AA16 @DFN8 24AA16 @SOIC8 24AA16 @TSSOP8 24AA256 24AA256 @DFN8 24AA256 @SOIC8 24AA256 @TSSOP8 24AA32 24AA32 @DFN8 24AA32 @SOIC8 24AA32 @TSSOP8 24AA32A 24AA32A @DFN8 24AA32A @SOIC8 24AA32A @TSSOP8 24AA512 24AA512 @DFN8 24AA512 @SOIC8 24AA512 @TSSOP8 24AA64 24AA64 @DFN8 24AA64 @SOIC8 24AA64 @TSSOP8 24AA65 24AA65 @DFN8 24AA65 @SOIC8 24AA65 @TSSOP8 24C00 24C00 @DFN8 24C00 @SOIC8 24C00 @TSSOP8 24C01 24C01A 24C01A @SOIC8 24C01C 24C01C @SOIC8 24C01C @TSOP8 24C02 24C02A 24C02A @SOIC8 24C02C 24C02C @SOIC8 24C02C @TSSOP8 24C04 24C04A 24C04A @SOIC8 24C04A @TSSOP8 24C08 24C08 @SOIC8 24C08B 24C08B @SOIC8 24C16 24C16 @SOIC8 24C16B 24C16B @SOIC8 24C32 24C32 @DFN8 24C32 @SOIC8 24C64 24C64 @SOIC8 24C64 @SOIC8 24C64 @TSSOP8 24C65 24C65 @SOIC8 24C65 @SOIC8 24FC128 24FC128 @DFN8 24FC128 @SOIC8 24FC128 @TSSOP8 24FC16 24FC16 @DFN8 24FC16 @SOIC8 24FC16 @TSSOP8 24FC256 24FC256 @DFN8 24FC256 @SOIC8 24FC256 @TSSOP8 24FC32 24FC32 @DFN8 24FC32 @SOIC8 24FC32 @TSSOP8 24FC512 24FC512 @DFN8 24FC512 @SOIC8 24FC512 @TSSOP8 24FC64 24FC64 @DFN8 24FC64 @SOIC8 24FC64 @TSSOP8 24FC65 24FC65 @DFN8 24FC65 @SOIC8 24FC65 @TSSOP8 24LC00 24LC00 @DFN8 24LC00 @SOIC8 24LC00 @TSSOP8 24LC014 24LC014 @SOIC8 24LC014 @TSSOP8 24LC01B 24LC01B @DFN8 24LC01B @SOIC8 24LC01B @TSSOP8 24LC024 24LC024 @DFN8 24LC024 @SOIC8 24LC024 @TSSOP8 24LC025 24LC025 @DFN8 24LC025 @SOIC8 24LC025 @TSSOP8 24LC02B 24LC02B @DFN8 24LC02B @SOIC8 24LC02B @TSSOP8 24LC04B 24LC04B @DFN8 24LC04B @SOIC8 24LC04B @TSSOP8 24LC08B 24LC08B @DFN8 24LC08B @SOIC8 24LC08B @TSSOP8 24LC128 24LC128 @DFN8 24LC128 @SOIC8 24LC128 @TSSOP8 24LC16B 24LC16B @DFN8 24LC16B @SOIC8 24LC16B @TSSOP8 24LC21 24LC21 @SOIC8 24LC21A 24LC21A @SOIC8 24LC256 24LC256 @DFN8 24LC256 @SOIC8 24LC256 @TSSOP8 24LC32 24LC32 @DFN8 24LC32 @SOIC8 24LC32 @TSSOP8 24LC32A 24LC32A @DFN8 24LC32A @SOIC8 24LC32A @TSSOP8 24LC512 24LC512 @DFN8 24LC512 @SOIC8 24LC512 @TSSOP8 24LC64 24LC64 @DFN8 24LC64 @SOIC8 24LC64 @TSSOP8 24LC65 24LC65 @DFN8 24LC65 @SOIC8 24LC65 @TSSOP8 24LCS21 24LCS21 @SOIC8 24LCS21A 24LCS21A @SOIC8 25AA010A 25AA010A @DFN8 25AA010A @MSOP8 25AA010A @SOIC8 25AA010A @TSSOP8 25AA020A 25AA020A @DFN8 25AA020A @MSOP8 25AA020A @SOIC8 25AA020A @TSSOP8 25AA040 25AA040 @SOIC8 25AA040 @TSSOP8 25AA040A 25AA040A @DFN8 25AA040A @MSOP8 25AA040A @SOIC8 25AA040A @TSSOP8 25AA080 25AA080 @SOIC8 25AA080A 25AA080A @MSOP8 25AA080A @SOIC8 25AA080A @TSSOP8 25AA080B 25AA080B @MSOP8 25AA080B @SOIC8 25AA080B @TSSOP8 25AA080C 25AA080C @MSOP8 25AA080C @SOIC8 25AA080C @TSSOP8 25AA080D 25AA080D @MSOP8 25AA080D @SOIC8 25AA080D @TSSOP8 25AA1024 25AA1024 @DFN8 25AA1024 @SOIC8 25AA128 25AA128 @DFN8 25AA128 @SOIC8 25AA128 @TSSOP8 25AA160 25AA160 @SOIC8 25AA160A 25AA160A @MSOP8 25AA160A @SOIC8 25AA160A @TSSOP8 25AA160B 25AA160B @MSOP8 25AA160B @SOIC8 25AA160B @TSSOP8 25AA256 25AA256 @DFN8 25AA256 @SOIC8 25AA256 @TSSOP8 25AA320 25AA320 @SOIC8 25AA320 @TSSOP8 25AA512 25AA512 @DFN8 25AA512 @SOIC8 25AA640 25AA640 @SOIC8 25AA640 @TSSOP8 25C040 25C040 @SOIC8 25C040 @TSSOP8 25C080 25C080 @SOIC8 25C160 25C160 @SOIC8 25C320 25C320 @SOIC8 25C320 @TSSOP8 25C640 25C640 @SOIC8 25C640 @TSSOP8 25LC010A 25LC010A @DFN8 25LC010A @MSOP8 25LC010A @SOIC8 25LC010A @TSSOP8 25LC020A 25LC020A @DFN8 25LC020A @MSOP8 25LC020A @SOIC8 25LC020A @TSSOP8 25LC040 25LC040 @SOIC8 25LC040 @TSSOP8 25LC040A 25LC040A @DFN8 25LC040A @MSOP8 25LC040A @SOIC8 25LC040A @TSSOP8 25LC080 25LC080 @SOIC8 25LC080A 25LC080A @MSOP8 25LC080A @SOIC8 25LC080A @TSSOP8 25LC080B 25LC080B @MSOP8 25LC080B @SOIC8 25LC080B @TSSOP8 25LC080C 25LC080C @MSOP8 25LC080C @SOIC8 25LC080C @TSSOP8 25LC080D 25LC080D @MSOP8 25LC080D @SOIC8 25LC080D @TSSOP8 25LC1024 25LC1024 @DFN8 25LC1024 @SOIC8 25LC128 25LC128 @DFN8 25LC128 @SOIC8 25LC128 @TSSOP8 25LC160 25LC160 @SOIC8 25LC160A 25LC160A @MSOP8 25LC160A @SOIC8 25LC160A @TSSOP8 25LC160B 25LC160B @MSOP8 25LC160B @SOIC8 25LC160B @TSSOP8 25LC256 25LC256 @DFN8 25LC256 @SOIC8 25LC256 @TSSOP8 25LC320 25LC320 @SOIC8 25LC320 @TSSOP8 25LC512 25LC512 @DFN8 25LC512 @SOIC8 25LC640 25LC640 @SOIC8 25LC640 @TSSOP8 27C128 @DIP28 27C128 @PLCC32 27C128 @SOIC28 27C256 @DIP28 27C256 @PLCC32 27C256 @SOIC28 27C32A @DIP24 27C512 @DIP28 27C512 @PLCC32 27C512A @DIP28 27C512A @PLCC32 27C512A @SOIC28 27C64 @DIP28 27C64 @PLCC32 27C64 @SOIC28 27HC256 @DIP28 27HC256 @PLCC32 27HC256 @SOIC28 27HC256L @DIP28 27HC256L @PLCC32 27HC256L @SOIC28 27HC64 @DIP28 27HC64 @PLCC32 27LV256 @DIP28 27LV256 @PLCC32 27LV256 @SOIC28 27LV64 @DIP28 27LV64 @PLCC32 27LV64 @SOIC28 2804 2816 2817 28C04A 28C04A @PLCC32 28C04A @SOIC24 28C04AF 28C04AF @PLCC32 28C04AF @SOIC24 28C16A 28C16A @PLCC32 28C16A @SOIC24 28C16AF 28C16AF @PLCC32 28C16AF @SOIC24 28C17A 28C17A @PLCC32 28C17A @SOIC28 28C17AF 28C17AF @PLCC32 28C17AF @SOIC28 28C256 28C256 @PLCC32 28C256F 28C256F @PLCC32 28C64A 28C64A @PLCC32 28C64A @SOIC28 28C64AF 28C64AF @PLCC32 28C64AF @SOIC28 28C64B 28C64B @PLCC32 28C64B @SOIC28 28LV64A 28LV64A @PLCC32 28LV64A @SOIC28 93AA46(x8) 93AA46(x8) @SOIC8 93AA46(x16) 93AA46(x16) @SOIC8 93AA46A(x8) 93AA46A(x8) @DFN8 93AA46A(x8) @MSOP8 93AA46A(x8) @SOIC8 93AA46A(x8) @TSOP8 93AA46B(x16) 93AA46B(x16) @DFN8 93AA46B(x16) @MSOP8 93AA46B(x16) @SOIC8 93AA46B(x16) @TSOP8 93AA46C(x8) 93AA46C(x8) @DFN8 93AA46C(x8) @MSOP8 93AA46C(x8) @SOIC8 93AA46C(x8) @TSOP8 93AA46C(x16) 93AA46C(x16) @DFN8 93AA46C(x16) @MSOP8 93AA46C(x16) @SOIC8 93AA46C(x16) @TSOP8 93AA56(x8) 93AA56(x8) @SOIC8 93AA56(x16) 93AA56(x16) @SOIC8 93AA56A(x8) 93AA56A(x8) @DFN8 93AA56A(x8) @MSOP8 93AA56A(x8) @SOIC8 93AA56A(x8) @TSOP8 93AA56B(x16) 93AA56B(x16) @DFN8 93AA56B(x16) @MSOP8 93AA56B(x16) @SOIC8 93AA56B(x16) @TSOP8 93AA56C(x8) 93AA56C(x8) @DFN8 93AA56C(x8) @MSOP8 93AA56C(x8) @SOIC8 93AA56C(x8) @TSOP8 93AA56C(x16) 93AA56C(x16) @DFN8 93AA56C(x16) @MSOP8 93AA56C(x16) @SOIC8 93AA56C(x16) @TSOP8 93AA66(x8) 93AA66(x8) @SOIC8 93AA66(x16) 93AA66(x16) @SOIC8 93AA66A(x8) 93AA66A(x8) @DFN8 93AA66A(x8) @MSOP8 93AA66A(x8) @SOIC8 93AA66A(x8) @TSOP8 93AA66B(x16) 93AA66B(x16) @DFN8 93AA66B(x16) @MSOP8 93AA66B(x16) @SOIC8 93AA66B(x16) @TSOP8 93AA66C(x8) 93AA66C(x8) @DFN8 93AA66C(x8) @MSOP8 93AA66C(x8) @SOIC8 93AA66C(x8) @TSOP8 93AA66C(x16) 93AA66C(x16) @DFN8 93AA66C(x16) @MSOP8 93AA66C(x16) @SOIC8 93AA66C(x16) @TSOP8 93AA76(x8) 93AA76(x8) @SOIC8 93AA76(x16) 93AA76(x16) @SOIC8 93AA76A(x8) 93AA76A(x8) @DFN8 93AA76A(x8) @MSOP8 93AA76A(x8) @SOIC8 93AA76A(x8) @TSOP8 93AA76B(x16) 93AA76B(x16) @DFN8 93AA76B(x16) @MSOP8 93AA76B(x16) @SOIC8 93AA76B(x16) @TSOP8 93AA76C(x8) 93AA76C(x8) @DFN8 93AA76C(x8) @MSOP8 93AA76C(x8) @SOIC8 93AA76C(x8) @TSOP8 93AA76C(x16) 93AA76C(x16) @DFN8 93AA76C(x16) @MSOP8 93AA76C(x16) @SOIC8 93AA76C(x16) @TSOP8 93AA86(x8) 93AA86(x8) @SOIC8 93AA86(x16) 93AA86(x16) @SOIC8 93AA86A(x8) 93AA86A(x8) @DFN8 93AA86A(x8) @MSOP8 93AA86A(x8) @SOIC8 93AA86A(x8) @TSOP8 93AA86B(x16) 93AA86B(x16) @DFN8 93AA86B(x16) @MSOP8 93AA86B(x16) @SOIC8 93AA86B(x16) @TSOP8 93AA86C(x8) 93AA86C(x8) @DFN8 93AA86C(x8) @MSOP8 93AA86C(x8) @SOIC8 93AA86C(x8) @TSOP8 93AA86C(x16) 93AA86C(x16) @DFN8 93AA86C(x16) @MSOP8 93AA86C(x16) @SOIC8 93AA86C(x16) @TSOP8 93C06(x16) 93C06(x16) @SOIC8 93C46(x8) 93C46(x8) @SOIC8 93C46(x16) 93C46(x16) @SOIC8 93C46X(x16) 93C46X(x16) @SOIC8 93C46A(x8) 93C46A(x8) @DFN8 93C46A(x8) @MSOP8 93C46A(x8) @SOIC8 93C46A(x8) @TSOP8 93C46B(x16) 93C46B(x16) @DFN8 93C46B(x16) @MSOP8 93C46B(x16) @SOIC8 93C46B(x16) @TSOP8 93C46C(x8) 93C46C(x8) @DFN8 93C46C(x8) @MSOP8 93C46C(x8) @SOIC8 93C46C(x8) @TSOP8 93C46C(x16) 93C46C(x16) @DFN8 93C46C(x16) @MSOP8 93C46C(x16) @SOIC8 93C46C(x16) @TSOP8 93C56(x8) 93C56(x8) @SOIC8 93C56(x16) 93C56(x16) @SOIC8 93C56A(x8) 93C56A(x8) @DFN8 93C56A(x8) @MSOP8 93C56A(x8) @SOIC8 93C56A(x8) @TSOP8 93C56B(x16) 93C56B(x16) @DFN8 93C56B(x16) @MSOP8 93C56B(x16) @SOIC8 93C56B(x16) @TSOP8 93C56C(x8) 93C56C(x8) @DFN8 93C56C(x8) @MSOP8 93C56C(x8) @SOIC8 93C56C(x8) @TSOP8 93C56C(x16) 93C56C(x16) @DFN8 93C56C(x16) @MSOP8 93C56C(x16) @SOIC8 93C56C(x16) @TSOP8 93C66(x8) 93C66(x8) @SOIC8 93C66(x16) 93C66(x16) @SOIC8 93C66A(x8) 93C66A(x8) @DFN8 93C66A(x8) @MSOP8 93C66A(x8) @SOIC8 93C66A(x8) @TSOP8 93C66B(x16) 93C66B(x16) @DFN8 93C66B(x16) @MSOP8 93C66B(x16) @SOIC8 93C66B(x16) @TSOP8 93C66C(x8) 93C66C(x8) @DFN8 93C66C(x8) @MSOP8 93C66C(x8) @SOIC8 93C66C(x8) @TSOP8 93C66C(x16) 93C66C(x16) @DFN8 93C66C(x16) @MSOP8 93C66C(x16) @SOIC8 93C66C(x16) @TSOP8 93C76(x8) 93C76(x8) @SOIC8 93C76(x16) 93C76(x16) @SOIC8 93C76A(x8) 93C76A(x8) @DFN8 93C76A(x8) @MSOP8 93C76A(x8) @SOIC8 93C76A(x8) @TSOP8 93C76B(x16) 93C76B(x16) @DFN8 93C76B(x16) @MSOP8 93C76B(x16) @SOIC8 93C76B(x16) @TSOP8 93C76C(x8) 93C76C(x8) @DFN8 93C76C(x8) @MSOP8 93C76C(x8) @SOIC8 93C76C(x8) @TSOP8 93C76C(x16) 93C76C(x16) @DFN8 93C76C(x16) @MSOP8 93C76C(x16) @SOIC8 93C76C(x16) @TSOP8 93C86(x8) 93C86(x8) @SOIC8 93C86(x16) 93C86(x16) @SOIC8 93C86A(x8) 93C86A(x8) @DFN8 93C86A(x8) @MSOP8 93C86A(x8) @SOIC8 93C86A(x8) @TSOP8 93C86B(x16) 93C86B(x16) @DFN8 93C86B(x16) @MSOP8 93C86B(x16) @SOIC8 93C86B(x16) @TSOP8 93C86C(x8) 93C86C(x8) @DFN8 93C86C(x8) @MSOP8 93C86C(x8) @SOIC8 93C86C(x8) @TSOP8 93C86C(x16) 93C86C(x16) @DFN8 93C86C(x16) @MSOP8 93C86C(x16) @SOIC8 93C86C(x16) @TSOP8 93LC46(x8) 93LC46(x8) @SOIC8 93LC46(x16) 93LC46(x16) @SOIC8 93LC46A(x8) 93LC46A(x8) @DFN8 93LC46A(x8) @MSOP8 93LC46A(x8) @SOIC8 93LC46A(x8) @TSOP8 93LC46B(x16) 93LC46B(x16) @DFN8 93LC46B(x16) @MSOP8 93LC46B(x16) @SOIC8 93LC46B(x16) @TSOP8 93LC46C(x8) 93LC46C(x8) @DFN8 93LC46C(x8) @MSOP8 93LC46C(x8) @SOIC8 93LC46C(x8) @TSOP8 93LC46C(x16) 93LC46C(x16) @DFN8 93LC46C(x16) @MSOP8 93LC46C(x16) @SOIC8 93LC46C(x16) @TSOP8 93LC56(x8) 93LC56(x8) @SOIC8 93LC56(x16) 93LC56(x16) @SOIC8 93LC56A(x8) 93LC56A(x8) @DFN8 93LC56A(x8) @MSOP8 93LC56A(x8) @SOIC8 93LC56A(x8) @TSOP8 93LC56B(x16) 93LC56B(x16) @DFN8 93LC56B(x16) @MSOP8 93LC56B(x16) @SOIC8 93LC56B(x16) @TSOP8 93LC56C(x8) 93LC56C(x8) @DFN8 93LC56C(x8) @MSOP8 93LC56C(x8) @SOIC8 93LC56C(x8) @TSOP8 93LC56C(x16) 93LC56C(x16) @DFN8 93LC56C(x16) @MSOP8 93LC56C(x16) @SOIC8 93LC56C(x16) @TSOP8 93LC66(x8) 93LC66(x8) @SOIC8 93LC66(x16) 93LC66(x16) @SOIC8 93LC66A(x8) 93LC66A(x8) @DFN8 93LC66A(x8) @MSOP8 93LC66A(x8) @SOIC8 93LC66A(x8) @TSOP8 93LC66B(x16) 93LC66B(x16) @DFN8 93LC66B(x16) @MSOP8 93LC66B(x16) @SOIC8 93LC66B(x16) @TSOP8 93LC66C(x8) 93LC66C(x8) @DFN8 93LC66C(x8) @MSOP8 93LC66C(x8) @SOIC8 93LC66C(x8) @TSOP8 93LC66C(x16) 93LC66C(x16) @DFN8 93LC66C(x16) @MSOP8 93LC66C(x16) @SOIC8 93LC66C(x16) @TSOP8 93LC76(x8) 93LC76(x8) @SOIC8 93LC76(x16) 93LC76(x16) @SOIC8 93LC76A(x8) 93LC76A(x8) @DFN8 93LC76A(x8) @MSOP8 93LC76A(x8) @SOIC8 93LC76A(x8) @TSOP8 93LC76B(x16) 93LC76B(x16) @DFN8 93LC76B(x16) @MSOP8 93LC76B(x16) @SOIC8 93LC76B(x16) @TSOP8 93LC76C(x8) 93LC76C(x8) @DFN8 93LC76C(x8) @MSOP8 93LC76C(x8) @SOIC8 93LC76C(x8) @TSOP8 93LC76C(x16) 93LC76C(x16) @DFN8 93LC76C(x16) @MSOP8 93LC76C(x16) @SOIC8 93LC76C(x16) @TSOP8 93LC86(x8) 93LC86(x8) @SOIC8 93LC86(x16) 93LC86(x16) @SOIC8 93LC86A(x8) 93LC86A(x8) @DFN8 93LC86A(x8) @MSOP8 93LC86A(x8) @SOIC8 93LC86A(x8) @TSOP8 93LC86B(x16) 93LC86B(x16) @DFN8 93LC86B(x16) @MSOP8 93LC86B(x16) @SOIC8 93LC86B(x16) @TSOP8 93LC86C(x8) 93LC86C(x8) @DFN8 93LC86C(x8) @MSOP8 93LC86C(x8) @SOIC8 93LC86C(x8) @TSOP8 93LC86C(x16) 93LC86C(x16) @DFN8 93LC86C(x16) @MSOP8 93LC86C(x16) @SOIC8 93LC86C(x16) @TSOP8 93LCS46 93LCS46 @SOIC8 93LCS46 @SOIC14 93LCS56 93LCS56 @SOIC8 93LCS56 @SOIC14 93LCS66 93LCS66 @SOIC8 93LCS66 @SOIC14 [ MICROCHIP MPU ] 909 PCS PIC10F200 PIC10F202 PIC10F204 PIC10F206 PIC10F220 PIC10F222 PIC12C508 PIC12C508 @SOIC8 PIC12C508A PIC12C508A @SOIC8 PIC12C509 PIC12C509 @SOIC8 PIC12C509A PIC12C509A @SOIC8 PIC12C671 PIC12C671 @DFN8 PIC12C671 @SOIC8 PIC12C672 PIC12C672 @DFN8 PIC12C672 @SOIC8 PIC12CE518 PIC12CE518 @SOIC8 PIC12CE519 PIC12CE519 @SOIC8 PIC12CE673 PIC12CE673 @SOIC8 PIC12CE674 PIC12CE674 @SOIC8 PIC12F508 PIC12F508 @MSOP8 PIC12F508 @SOIC8 PIC12F509 PIC12F509 @MSOP8 PIC12F509 @SOIC8 PIC12F510 PIC12F510 @MSOP8 PIC12F510 @SOIC8 PIC12F519 PIC12F519 @DFN8 PIC12F519 @MSOP8 PIC12F519 @SOIC8 PIC12F609 PIC12F609 @DFN8 PIC12F609 @MSOP8 PIC12F609 @SOIC8 PIC12F615 PIC12F615 @DFN8 PIC12F615 @MSOP8 PIC12F615 @SOIC8 PIC12F629 PIC12F629 @DFN8 PIC12F629 @MSOP8 PIC12F629 @SOIC8 PIC12F635 PIC12F635 @DFN8 PIC12F635 @MSOP8 PIC12F635 @SOIC8 PIC12F675 PIC12F675 @DFN8 PIC12F675 @SOIC8 PIC12F683 PIC12F683 @DFN8 PIC12F683 @SOIC8 PIC12HV609 PIC12HV609 @DFN8 PIC12HV609 @MSOP8 PIC12HV609 @SOIC8 PIC12HV615 PIC12HV615 @DFN8 PIC12HV615 @MSOP8 PIC12HV615 @SOIC8 PIC12LC508 PIC12LC508 @SOIC8 PIC12LC508A PIC12LC508A @SOIC8 PIC12LC509 PIC12LC509 @SOIC8 PIC12LC509A PIC12LC509A @SOIC8 PIC12LC671 PIC12LC671 @DFN8 PIC12LC671 @SOIC8 PIC12LC672 PIC12LC672 @DFN8 PIC12LC672 @SOIC8 PIC12LCE518 PIC12LCE518 @SOIC8 PIC12LCE519 PIC12LCE519 @SOIC8 PIC12LF508 PIC12LF508 @MSOP8 PIC12LF508 @SOIC8 PIC12LF509 PIC12LF509 @MSOP8 PIC12LF509 @SOIC8 PIC12LF519 PIC12LF519 @DFN8 PIC12LF519 @MSOP8 PIC12LF519 @SOIC8 PIC16C505 PIC16C505 @SOIC14 PIC16C54 PIC16C54 @SOIC18 PIC16C54A PIC16C54A @SOIC18 PIC16C54B PIC16C54B @SOIC18 PIC16C54C PIC16C54C @SOIC18 PIC16C55 PIC16C55 @SOIC28 PIC16C554 @DIP18 PIC16C554 @SOIC18 PIC16C558 @DIP18 PIC16C558 @SOIC18 PIC16C55A PIC16C55A @SOIC28 PIC16C56 PIC16C56 @SOIC18 PIC16C56A PIC16C56A @SOIC18 PIC16C57 PIC16C57 @SOIC28 PIC16C57C PIC16C57C @SOIC28 PIC16C58A PIC16C58A @SOIC18 PIC16C58B PIC16C58B @SOIC18 PIC16C61 PIC16C61 @SOIC18 PIC16C62 PIC16C62 @SOIC28 PIC16C620 PIC16C620 @SOIC18 PIC16C620A PIC16C620A @SOIC18 PIC16C621 PIC16C621 @SOIC18 PIC16C621A PIC16C621A @SOIC18 PIC16C622 PIC16C622 @SOIC18 PIC16C622A PIC16C622A @SOIC18 PIC16C62A PIC16C62A @SOIC28 PIC16C62B PIC16C62B @SOIC28 PIC16C63 PIC16C63 @SOIC28 PIC16C63A PIC16C63A @SOIC28 PIC16C64 PIC16C64A PIC16C65 PIC16C65A PIC16C65B PIC16C66 PIC16C66 @SOIC28 PIC16C67 PIC16C71 PIC16C71 @SOIC18 PIC16C710 PIC16C710 @SOIC18 PIC16C711 PIC16C711 @SOIC18 PIC16C712 @DIP18 PIC16C712 @SOIC18 PIC16C712 @SSOP20 PIC16C716 @DIP18 PIC16C716 @SOIC18 PIC16C716 @SSOP20 PIC16C717 @DIP18 PIC16C717 @SOIC18 PIC16C717 @SSOP20 PIC16C72 PIC16C72 @SOIC28 PIC16C72A PIC16C72A @SOIC28 PIC16C73 PIC16C73 @SOIC28 PIC16C73A PIC16C73A @SOIC28 PIC16C73B PIC16C73B @SOIC28 PIC16C74 PIC16C745 PIC16C745 @SOIC28 PIC16C74A PIC16C74B PIC16C76 PIC16C76 @SOIC28 PIC16C765 PIC16C77 PIC16C770 PIC16C770 @SOIC20 PIC16C771 PIC16C771 @SOIC20 PIC16C773 PIC16C773 @SOIC28 PIC16C774 PIC16C781 PIC16C781 @SOIC20 PIC16C782 PIC16C782 @SOIC20 PIC16CE623 PIC16CE623 @SOIC18 PIC16CE624 PIC16CE624 @SOIC18 PIC16CE625 PIC16CE625 @SOIC18 PIC16CR54A PIC16CR54A @SOIC18 PIC16CR54B PIC16CR54B @SOIC18 PIC16CR54C PIC16CR54C @SOIC18 PIC16CR56A PIC16CR56A @SOIC18 PIC16CR57B PIC16CR57B @SOIC28 PIC16CR57C PIC16CR57C @SOIC28 PIC16CR58A PIC16CR58A @SOIC18 PIC16CR58B PIC16CR58B @SOIC18 PIC16F505 PIC16F505 @SOIC14 PIC16F505 @TSOP14 PIC16F506 PIC16F506 @SOIC14 PIC16F506 @TSOP14 PIC16F526 PIC16F526 @SOIC14 PIC16F526 @TSOP14 PIC16F54 PIC16F54 @SOIC18 PIC16F57 PIC16F57 @SOIC28 PIC16F57 @TSOP28 PIC16F59 (ISCP) PIC16F610 PIC16F610 @SOIC14 PIC16F610 @TSOP14 PIC16F616 PIC16F616 @SOIC14 PIC16F616 @TSOP14 PIC16F627A PIC16F627A @SOIC18 PIC16F627A @SSOP20 PIC16F628A PIC16F628A @SOIC18 PIC16F628A @SSOP20 PIC16F630 PIC16F630 @SOIC14 PIC16F630 @TSOP14 PIC16F631 PIC16F631 @SOIC20 PIC16F631 @TSOP20 PIC16F636 PIC16F636 @SOIC14 PIC16F636 @TSOP14 PIC16F639 PIC16F639 @SOIC20 PIC16F639 @SSOP20 PIC16F648A PIC16F648A @SOIC18 PIC16F648A @SSOP20 PIC16F676 PIC16F676 @SOIC14 PIC16F676 @TSOP14 PIC16F677 PIC16F677 @SOIC20 PIC16F677 @TSOP20 PIC16F684 PIC16F684 @SOIC14 PIC16F684 @TSOP14 PIC16F685 PIC16F685 @SOIC20 PIC16F685 @TSOP20 PIC16F687 PIC16F687 @SOIC20 PIC16F687 @TSOP20 PIC16F688 PIC16F688 @SOIC14 PIC16F688 @TSOP14 PIC16F689 PIC16F689 @SOIC20 PIC16F689 @TSOP20 PIC16F690 PIC16F690 @SOIC20 PIC16F690 @TSOP20 PIC16F716 PIC16F716 @SOIC18 PIC16F716 @SSOP20 PIC16F72 PIC16F72 @SOIC28 PIC16F72 @SSOP28 PIC16F722 PIC16F722 @SOIC28 PIC16F722 @SSOP28 PIC16F722A PIC16F722A @SOIC28 PIC16F722A @SSOP28 PIC16F723 PIC16F723 @SOIC28 PIC16F723 @SSOP28 PIC16F723A PIC16F723A @SOIC28 PIC16F723A @SSOP28 PIC16F724 PIC16F726 PIC16F726 @SOIC28 PIC16F726 @SSOP28 PIC16F727 PIC16F73 PIC16F73 @SOIC28 PIC16F73 @SSOP28 PIC16F737 PIC16F737 @SOIC28 PIC16F737 @SSOP28 PIC16F74 PIC16F747 PIC16F76 PIC16F76 @SOIC28 PIC16F76 @SSOP28 PIC16F767 PIC16F767 @SOIC28 PIC16F767 @SSOP28 PIC16F77 PIC16F777 PIC16F785 PIC16F785 @SOIC20 PIC16F785 @TSOP20 PIC16F818 PIC16F818 @SOIC18 PIC16F819 PIC16F819 @SOIC18 PIC16F83 PIC16F83 @SOIC18 PIC16F84 PIC16F84 @SOIC18 PIC16F84A PIC16F84A @SOIC18 PIC16F84A @SSOP20 PIC16F87 PIC16F87 @SOIC18 PIC16F870 PIC16F870 @SOIC28 PIC16F870 @SSOP28 PIC16F871 PIC16F872 PIC16F872 @SOIC28 PIC16F872 @SSOP28 PIC16F873 PIC16F873 @SOIC28 PIC16F873 @SSOP28 PIC16F873A PIC16F873A @SOIC28 PIC16F873A @SSOP28 PIC16F874 PIC16F874A PIC16F876 PIC16F876 @SOIC28 PIC16F876 @SSOP28 PIC16F876A PIC16F876A @SOIC28 PIC16F876A @SSOP28 PIC16F877 PIC16F877A PIC16F88 PIC16F88 @SOIC18 PIC16F882 PIC16F882 @SOIC28 PIC16F882 @SSOP28 PIC16F883 PIC16F883 @SOIC28 PIC16F883 @SSOP28 PIC16F884 PIC16F886 PIC16F886 @SOIC28 PIC16F886 @SSOP28 PIC16F887 PIC16F913 PIC16F913 @SOIC28 PIC16F913 @SSOP28 PIC16F914 PIC16F916 PIC16F916 @SOIC28 PIC16F916 @SSOP28 PIC16F917 PIC16F946 (ISCP) PIC16HV610 PIC16HV610 @SOIC14 PIC16HV610 @TSOP14 PIC16HV616 PIC16HV616 @SOIC14 PIC16HV616 @TSOP14 PIC16HV785 PIC16HV785 @SOIC20 PIC16HV785 @TSOP20 PIC16LC505 PIC16LC505 @SOIC14 PIC16LC54 PIC16LC54 @SOIC18 PIC16LC54A PIC16LC54A @SOIC18 PIC16LC54C PIC16LC54C @SOIC18 PIC16LC55 PIC16LC55 @SOIC28 PIC16LC554 @DIP18 PIC16LC554 @SOIC18 PIC16LC558 @DIP18 PIC16LC558 @SOIC18 PIC16LC56A PIC16LC56A @SOIC18 PIC16LC58A PIC16LC58A @SOIC18 PIC16LC58B PIC16LC58B @SOIC18 PIC16LC620 PIC16LC620 @SOIC18 PIC16LC620A PIC16LC620A @SOIC18 PIC16LC621A PIC16LC621A @SOIC18 PIC16LC622 PIC16LC622 @SOIC18 PIC16LC622A PIC16LC622A @SOIC18 PIC16LC62A PIC16LC62A @SOIC28 PIC16LC62B PIC16LC62B @SOIC28 PIC16LC63 PIC16LC63 @SOIC28 PIC16LC63A PIC16LC63A @SOIC28 PIC16LC64A PIC16LC65A PIC16LC65B PIC16LC66 PIC16LC66 @SOIC28 PIC16LC67 PIC16LC71 PIC16LC71 @SOIC18 PIC16LC710 PIC16LC710 @SOIC18 PIC16LC711 PIC16LC711 @SOIC18 PIC16LC712 @DIP18 PIC16LC712 @SOIC18 PIC16LC712 @SSOP20 PIC16LC716 @DIP18 PIC16LC716 @SOIC18 PIC16LC716 @SSOP20 PIC16LC717 @DIP18 PIC16LC717 @SOIC18 PIC16LC717 @SSOP20 PIC16LC72 PIC16LC72 @SOIC28 PIC16LC72A PIC16LC72A @SOIC28 PIC16LC73A PIC16LC73A @SOIC28 PIC16LC73B PIC16LC73B @SOIC28 PIC16LC74 PIC16LC74A PIC16LC74B PIC16LC76 PIC16LC76 @SOIC28 PIC16LC77 PIC16LC773 PIC16LC773 @SOIC28 PIC16LC774 PIC16LC781 PIC16LC781 @SOIC20 PIC16LC782 PIC16LC782 @SOIC20 PIC16LCE623 PIC16LCE623 @SOIC18 PIC16LF505 PIC16LF505 @SOIC14 PIC16LF505 @TSOP14 PIC16LF506 PIC16LF506 @SOIC14 PIC16LF506 @TSOP14 PIC16LF526 PIC16LF526 @SOIC14 PIC16LF526 @TSOP14 PIC16LF54 PIC16LF54 @SOIC18 PIC16LF57 PIC16LF57 @SOIC28 PIC16LF57 @TSOP28 PIC16LF59 (ISCP) PIC16LF627A PIC16LF627A @SOIC18 PIC16LF627A @SSOP20 PIC16LF628A PIC16LF628A @SOIC18 PIC16LF628A @SSOP20 PIC16LF631 PIC16LF631 @SOIC20 PIC16LF631 @TSOP20 PIC16LF639 PIC16LF639 @SOIC20 PIC16LF639 @SSOP20 PIC16LF648A PIC16LF648A @SOIC18 PIC16LF648A @SSOP20 PIC16LF677 PIC16LF677 @SOIC20 PIC16LF677 @TSOP20 PIC16LF685 PIC16LF685 @SOIC20 PIC16LF685 @TSOP20 PIC16LF687 PIC16LF687 @SOIC20 PIC16LF687 @TSOP20 PIC16LF689 PIC16LF689 @SOIC20 PIC16LF689 @TSOP20 PIC16LF690 PIC16LF690 @SOIC20 PIC16LF690 @TSOP20 PIC16LF722 PIC16LF722 @SOIC28 PIC16LF722 @SSOP28 PIC16LF722A PIC16LF722A @SOIC28 PIC16LF722A @SSOP28 PIC16LF723 PIC16LF723 @SOIC28 PIC16LF723 @SSOP28 PIC16LF723A PIC16LF723A @SOIC28 PIC16LF723A @SSOP28 PIC16LF724 PIC16LF726 PIC16LF726 @SOIC28 PIC16LF726 @SSOP28 PIC16LF727 PIC16LF73 PIC16LF73 @SOIC28 PIC16LF73 @SSOP28 PIC16LF737 PIC16LF737 @SOIC28 PIC16LF737 @SSOP28 PIC16LF74 PIC16LF747 PIC16LF76 PIC16LF76 @SOIC28 PIC16LF76 @SSOP28 PIC16LF767 PIC16LF767 @SOIC28 PIC16LF767 @SSOP28 PIC16LF77 PIC16LF777 PIC16LF818 PIC16LF818 @SOIC18 PIC16LF819 PIC16LF819 @SOIC18 PIC16LF83 PIC16LF83 @SOIC18 PIC16LF84 PIC16LF84 @SOIC18 PIC16LF84A PIC16LF84A @SOIC18 PIC16LF84A @SSOP20 PIC16LF87 PIC16LF87 @SOIC18 PIC16LF870 PIC16LF870 @SOIC28 PIC16LF870 @SSOP28 PIC16LF871 PIC16LF872 PIC16LF872 @SOIC28 PIC16LF872 @SSOP28 PIC16LF873 PIC16LF873 @SOIC28 PIC16LF873 @SSOP28 PIC16LF873A PIC16LF873A @SOIC28 PIC16LF873A @SSOP28 PIC16LF874 PIC16LF874A PIC16LF876 PIC16LF876 @SOIC28 PIC16LF876 @SSOP28 PIC16LF876A PIC16LF876A @SOIC28 PIC16LF876A @SSOP28 PIC16LF877 PIC16LF877A PIC16LF88 PIC16LF88 @SOIC18 PIC16LF913 PIC16LF913 @SOIC28 PIC16LF913 @SSOP28 PIC16LF914 PIC16LF916 PIC16LF916 @SOIC28 PIC16LF916 @SSOP28 PIC16LF917 PIC16LF946 (ISCP) PIC18F2221 PIC18F2221 @SOIC28 PIC18F2221 @SSOP28 PIC18F2321 PIC18F2321 @SOIC28 PIC18F2321 @SSOP28 PIC18F2410 PIC18F2410 @SOIC28 PIC18F2410 @SSOP28 PIC18F242 PIC18F242 @SOIC28 PIC18F2420 PIC18F2420 @SOIC28 PIC18F2420 @SSOP28 PIC18F2423 PIC18F2423 @SOIC28 PIC18F2423 @SSOP28 PIC18F2450 PIC18F2450 @SOIC28 PIC18F2450 @SSOP28 PIC18F2455 PIC18F2455 @SOIC28 PIC18F2455 @SSOP28 PIC18F2458 PIC18F2458 @SOIC28 PIC18F2458 @SSOP28 PIC18F248 PIC18F248 @SOIC28 PIC18F2480 PIC18F2480 @SOIC28 PIC18F2480 @SSOP28 PIC18F24J10(ISP) PIC18F24J11(ISP) PIC18F24J50(ISP) PIC18F2510 PIC18F2510 @SOIC28 PIC18F2510 @SSOP28 PIC18F2515 PIC18F2515 @SOIC28 PIC18F2515 @SSOP28 PIC18F252 PIC18F252 @SOIC28 PIC18F2520 PIC18F2520 @SOIC28 PIC18F2520 @SSOP28 PIC18F2523 PIC18F2523 @SOIC28 PIC18F2523 @SSOP28 PIC18F2525 PIC18F2525 @SOIC28 PIC18F2525 @SSOP28 PIC18F2550 PIC18F2550 @SOIC28 PIC18F2550 @SSOP28 PIC18F2553 PIC18F2553 @SOIC28 PIC18F2553 @SSOP28 PIC18F258 PIC18F258 @SOIC28 PIC18F2580 PIC18F2580 @SOIC28 PIC18F2580 @SSOP28 PIC18F2585 PIC18F2585 @SOIC28 PIC18F2585 @SSOP28 PIC18F25J10(ISP) PIC18F25J11(ISP) PIC18F25J50(ISP) PIC18F2610 PIC18F2610 @SOIC28 PIC18F2610 @SSOP28 PIC18F2620 PIC18F2620 @SOIC28 PIC18F2620 @SSOP28 PIC18F2680 PIC18F2680 @SOIC28 PIC18F2680 @SSOP28 PIC18F2682 PIC18F2682 @SOIC28 PIC18F2682 @SSOP28 PIC18F2685 PIC18F2685 @SOIC28 PIC18F2685 @SSOP28 PIC18F26J11(ISP) PIC18F26J50(ISP) PIC18F4221 PIC18F4321 PIC18F4410 PIC18F442 PIC18F4420 PIC18F4423 PIC18F4450 PIC18F4455 PIC18F4458 PIC18F448 PIC18F4480 PIC18F44J10(ISP) PIC18F44J11(ISP) PIC18F44J50(ISP) PIC18F4510 PIC18F4515 PIC18F452 PIC18F4520 PIC18F4523 PIC18F4525 PIC18F4550 PIC18F4553 PIC18F458 PIC18F4580 PIC18F4585 PIC18F45J10(ISP) PIC18F45J11(ISP) PIC18F45J50(ISP) PIC18F4610 PIC18F4620 PIC18F4680 PIC18F4682 PIC18F4685 PIC18F46J11(ISP) PIC18F46J50(ISP) PIC18F63J11(ISP) PIC18F63J90(ISP) PIC18F64J11(ISP) PIC18F64J90(ISP) PIC18F65J10(ISP) PIC18F65J11(ISP) PIC18F65J15(ISP) PIC18F65J50(ISP) PIC18F65J90(ISP) PIC18F66J10(ISP) PIC18F66J11(ISP) PIC18F66J15(ISP) PIC18F66J16(ISP) PIC18F66J50(ISP) PIC18F66J55(ISP) PIC18F66J90(ISP) PIC18F66J93(ISP) PIC18F67J10(ISP) PIC18F67J11(ISP) PIC18F67J50(ISP) PIC18F67J90(ISP) PIC18F67J93(ISP) PIC18F83J11(ISP) PIC18F83J90(ISP) PIC18F84J11(ISP) PIC18F84J90(ISP) PIC18F85J10(ISP) PIC18F85J11(ISP) PIC18F85J15(ISP) PIC18F85J50(ISP) PIC18F85J90(ISP) PIC18F86J10(ISP) PIC18F86J11(ISP) PIC18F86J15(ISP) PIC18F86J16(ISP) PIC18F86J50(ISP) PIC18F86J55(ISP) PIC18F86J90(ISP) PIC18F86J93(ISP) PIC18F87J10(ISP) PIC18F87J11(ISP) PIC18F87J50(ISP) PIC18F87J90(ISP) PIC18F87J93(ISP) PIC18LF2221 PIC18LF2221 @SOIC28 PIC18LF2221 @SSOP28 PIC18LF2321 PIC18LF2321 @SOIC28 PIC18LF2321 @SSOP28 PIC18LF2410 PIC18LF2410 @SOIC28 PIC18LF2410 @SSOP28 PIC18LF242 PIC18LF242 @SOIC28 PIC18LF2420 PIC18LF2420 @SOIC28 PIC18LF2420 @SSOP28 PIC18LF2423 PIC18LF2423 @SOIC28 PIC18LF2423 @SSOP28 PIC18LF2450 PIC18LF2450 @SOIC28 PIC18LF2450 @SSOP28 PIC18LF2455 PIC18LF2455 @SOIC28 PIC18LF2455 @SSOP28 PIC18LF2458 PIC18LF2458 @SOIC28 PIC18LF2458 @SSOP28 PIC18LF248 PIC18LF248 @SOIC28 PIC18LF2480 PIC18LF2480 @SOIC28 PIC18LF2480 @SSOP28 PIC18LF24J10(ISP) PIC18LF24J11(ISP) PIC18LF24J50(ISP) PIC18LF2510 PIC18LF2510 @SOIC28 PIC18LF2510 @SSOP28 PIC18LF2515 PIC18LF2515 @SOIC28 PIC18LF2515 @SSOP28 PIC18LF252 PIC18LF252 @SOIC28 PIC18LF2520 PIC18LF2520 @SOIC28 PIC18LF2520 @SSOP28 PIC18LF2523 PIC18LF2523 @SOIC28 PIC18LF2523 @SSOP28 PIC18LF2525 PIC18LF2525 @SOIC28 PIC18LF2525 @SSOP28 PIC18LF2550 PIC18LF2550 @SOIC28 PIC18LF2550 @SSOP28 PIC18LF2553 PIC18LF2553 @SOIC28 PIC18LF2553 @SSOP28 PIC18LF258 PIC18LF258 @SOIC28 PIC18LF2580 PIC18LF2580 @SOIC28 PIC18LF2580 @SSOP28 PIC18LF2585 PIC18LF2585 @SOIC28 PIC18LF2585 @SSOP28 PIC18LF25J10(ISP) PIC18LF25J11(ISP) PIC18LF25J50(ISP) PIC18LF2610 PIC18LF2610 @SOIC28 PIC18LF2610 @SSOP28 PIC18LF2620 PIC18LF2620 @SOIC28 PIC18LF2620 @SSOP28 PIC18LF2680 PIC18LF2680 @SOIC28 PIC18LF2680 @SSOP28 PIC18LF2682 PIC18LF2682 @SOIC28 PIC18LF2682 @SSOP28 PIC18LF2685 PIC18LF2685 @SOIC28 PIC18LF2685 @SSOP28 PIC18LF26J11(ISP) PIC18LF26J50(ISP) PIC18LF4221 PIC18LF4321 PIC18LF4410 PIC18LF442 PIC18LF4420 PIC18LF4423 PIC18LF4450 PIC18LF4455 PIC18LF4458 PIC18LF448 PIC18LF4480 PIC18LF44J10(ISP) PIC18LF44J11(ISP) PIC18LF44J50(ISP) PIC18LF4510 PIC18LF4515 PIC18LF452 PIC18LF4520 PIC18LF4523 PIC18LF4525 PIC18LF4550 PIC18LF4553 PIC18LF458 PIC18LF4580 PIC18LF4585 PIC18LF45J10(ISP) PIC18LF45J11(ISP) PIC18LF45J50(ISP) PIC18LF4610 PIC18LF4620 PIC18LF4680 PIC18LF4682 PIC18LF4685 PIC18LF46J11(ISP) PIC18LF46J50(ISP) PIC18LF63J11(ISP) PIC18LF63J90(ISP) PIC18LF64J11(ISP) PIC18LF64J90(ISP) PIC18LF65J11(ISP) PIC18LF65J90(ISP) PIC18LF66J10(ISP) PIC18LF83J11(ISP) PIC18LF83J90(ISP) PIC18LF84J11(ISP) PIC18LF84J90(ISP) PIC18LF85J11(ISP) PIC18LF85J90(ISP) rfPIC12C509AG @SOIC18 rfPIC12C509AF @SSOP20 [ MICRON ] 39 PCS MT28F002B1 @TSOP40 MT28F002B3-T @TSOP40 MT28F002B3-B @TSOP40 MT28F002B5-T @TSOP40 MT28F002B5-B @TSOP40 MT28F004B3-T @TSOP40 MT28F004B3-B @TSOP40 MT28F004B5-T @TSOP40 MT28F004B5-B @TSOP40 MT28F008B3-T @TSOP40 MT28F008B3-B @TSOP40 MT28F008B5-T @TSOP40 MT28F008B5-B @TSOP40 MT28F016S3 @TSOP40 MT28F016S5 @TSOP40 MT28F200B3-T @TSOP48 MT28F200B3-T @SOP44 MT28F200B3-B @TSOP48 MT28F200B3-B @SOP44 MT28F200B5-T @TSOP48 MT28F200B5-T @SOP44 MT28F200B5-B @TSOP48 MT28F200B5-B @SOP44 MT28F400B3-T @TSOP48 MT28F400B3-T @SOP44 MT28F400B3-B @TSOP48 MT28F400B3-B @SOP44 MT28F400B5-T @TSOP48 MT28F400B5-T @SOP44 MT28F400B5-B @TSOP48 MT28F400B5-B @SOP44 MT28F800B3-T @TSOP48 MT28F800B3-T @SOP44 MT28F800B3-B @TSOP48 MT28F800B3-B @SOP44 MT28F800B5-T @TSOP48 MT28F800B5-T @SOP44 MT28F800B5-B @TSOP48 MT28F800B5-B @SOP44 [ MITSUBISHI ] 23 PCS M5M27C102K @DIP40 M5M27C128 @DIP28 M5M27C202K @DIP40 M5M27C202K @SOP40 M5M27C256K @DIP28 M5M28F101 @DIP32 M5M28F101 @PLCC32 M5M28F101 @SOIC32 M5M28F101 @TSOP32 M5M28F101A @DIP32 M5M28F101A @PLCC32 M5M28F101A @SOIC32 M5M28F101A @TSOP32 M5M29FB800 @TSOP48 M5M29FB800 @SOP44 M5M29FT800 @TSOP48 M5M29FT800 @SOP44 M5M29GB160 @TSOP48 M5M29GT160 @TSOP48 M5M29GB320 @TSOP48 M5M29GT320 @TSOP48 M5M29KB331 @TSOP48 M5M29KT331 @TSOP48 [ MOSEL VITELIC ] 45 PCS V29C31001B @DIP32 V29C31001B @PLCC32 V29C31001B @TSOP32 V29C31001T @DIP32 V29C31001T @PLCC32 V29C31001T @TSOP32 V29C31002B @DIP32 V29C31002B @PLCC32 V29C31002B @TSOP32 V29C31002T @DIP32 V29C31002T @PLCC32 V29C31002T @TSOP32 V29C31004B @DIP32 V29C31004B @PLCC32 V29C31004B @TSOP32 V29C31004T @DIP32 V29C31004T @PLCC32 V29C31004T @TSOP32 V29C51001B @DIP32 V29C51001B @PLCC32 V29C51001B @TSOP32 V29C51001T @DIP32 V29C51001T @PLCC32 V29C51001T @TSOP32 V29C51002B @DIP32 V29C51002B @PLCC32 V29C51002B @TSOP32 V29C51002T @DIP32 V29C51002T @PLCC32 V29C51002T @TSOP32 V29C51004B @DIP32 V29C51004B @PLCC32 V29C51004B @TSOP32 V29C51004T @DIP32 V29C51004T @PLCC32 V29C51004T @TSOP32 V29LC51000 @DIP32 V29LC51000 @PLCC32 V29LC51000 @TSOP32 V29LC51001 @DIP32 V29LC51001 @PLCC32 V29LC51001 @TSOP32 V29LC51002 @DIP32 V29LC51002 @PLCC32 V29LC51002 @TSOP32 [ MSHINE ] 21 PCS MS25X512 @DIP8 MS25X512 @SOP8 MS25X512 @TSOP8 MS25X10 @DIP8 MS25X10 @SOP8 MS25X10 @TSOP8 MS25X20 @DIP8 MS25X20 @SOP8 MS25X20 @TSOP8 MS25X40 @DIP8 MS25X40 @SOP8 MS25X40 @TSOP8 MS25X80 @DIP8 MS25X80 @SOP8 MS25X80 @TSOP8 MS25X16 @DIP8 MS25X16 @SOP8 MS25X16 @SOP16 MS25X32 @DIP8 MS25X32 @SOP8 MS25X32 @SOP16 [ MY-MS ] 23 PCS MM24C01-3 MM24C01-3 @SOIC8 MM24C02-3 MM24C02-3 @SOIC8 MM24C04-3 MM24C04-3 @SOIC8 MM24C08-2/3 MM24C08-2/3 @SOIC8 MM24C16-2/3 MM24C16-2/3 @SOIC8 MM24C32-2/3 MM24C32-2/3 @SOIC8 MM24C64-2/3 MM24C64-2/3 @SOIC8 MM93C46-3P MM93C46-3G @SOIC8 MM93C46-3GR @SOIC8 MM93C56-3P MM93C56-3G @SOIC8 MM93C56-3GR @SOIC8 MM93C66-3P MM93C66-3G @SOIC8 MM93C66-3GR @SOIC8 [ MYSON ] 16 PCS MTV24C02 MTV24C02 @SOIC8 MTV24C04 MTV24C04 @SOIC8 MTV24C08 MTV24C08 @SOIC8 MTV24C016 MTV24C016 @SOIC8 MTV24LC02 MTV24LC02 @SOIC8 MTV24LC04 MTV24LC04 @SOIC8 MTV24LC08 MTV24LC08 @SOIC8 MTV24LC016 MTV24LC016 @SOIC8 [ NANTRONICS ] 18 PCS N25S10 N25S10 @SOIC8 N25S10 @WSON8 N25S20 N25S20 @SOIC8 N25S20 @WSON8 N25S40 N25S40 @SOIC8 N25S40 @WSON8 N25S16 N25S16 @SOIC8 N25S16 @WSON8 N25S32 N25S32 @SOIC8 N25S32 @SOIC16 N25S80 N25S80 @SOIC8 N25S80 @WSON8 [ NEC ] 28 PCS UPD27128 @DIP28 UPD27256 @DIP28 UPD27512 @DIP28 UPD2764 @DIP28 UPD27C1001A @DIP32 UPD27C1001A @PLCC32 UPD27C1001A @TSOP32 UPD27C1024A @DIP40 UPD27C128 @DIP28 UPD27C128 @PLCC32 UPD27C2001 @DIP32 UPD27C2001 @PLCC32 UPD27C2001 @TSOP32 UPD27C256A @DIP28 UPD27C4001 @DIP32 UPD27C4001 @PLCC32 UPD27C4001 @TSOP32 UPD27C4096 @DIP40 UPD27C512 @DIP28 UPD27C512 @PLCC32 UPD27C8001 @DIP32 UPD27C8001 @PLCC32 UPD27C8001 @TSOP32 UPD28C04 @DIP24 UPD28C04 @SOIC24 UPD28C256 UPD28C64 UPD28C64 @SOIC28 [ NEXFLASH ] 17 PCS NX25P10 @MLP8 NX25P10 @SOIC8 NX25P16 @MLP8 NX25P16 @SOIC8 NX25P16 @SOP16 NX25P20 @MLP8 NX25P20 @SOIC8 NX25P32 @MLP8 NX25P32 @SOIC8 NX25P32 @SOP16 NX25P40 @MLP8 NX25P40 @SOIC8 NX25P80 @MLP8 NX25P80 @SOIC8 NX29F010 @DIP32 NX29F010 @PLCC32 NX29F010 @TSOP32 [ NSC ] 201 PCS NM24C02 NM24C02 @SOIC8 NM24C02 @TSSOP8 NM24C02L NM24C02L @SOIC8 NM24C02L @TSSOP8 NM24C03 NM24C03 @SOIC8 NM24C03 @TSSOP8 NM24C04 NM24C04 @SOIC8 NM24C04 @TSSOP8 NM24C05 NM24C05 @SOIC8 NM24C05 @TSSOP8 NM24C08 NM24C08 @SOIC8 NM24C08 @TSSOP8 NM24C09 NM24C09 @SOIC8 NM24C09 @TSSOP8 NM24C16 NM24C16 @SOIC8 NM24C16 @TSSOP8 NM24C17 NM24C17 @SOIC8 NM24C17 @TSSOP8 NM24C65 NM24C65 @SOIC8 NM24C65 @TSSOP8 NM27C010 @DIP32 NM27C010 @PLCC32 NM27C010 @TSOP32 NM27C020 @DIP32 NM27C020 @PLCC32 NM27C020 @TSOP32 NM27C040 @DIP32 NM27C040 @PLCC32 NM27C040 @TSOP32 NM27C64Q @DIP28 NM27C64Q @PLCC32 NM27C128 @DIP28 NM27C128 @PLCC32 NM27C210 @DIP40 NM27C240 @DIP40 NM27C256 @DIP28 NM27C256 @PLCC32 NM27C512 @DIP28 NM27C512 @PLCC32 NM27LC010 @DIP32 NM27LC010 @PLCC32 NM27LC010 @TSOP32 NM27LC64 @DIP28 NM27LC64 @PLCC32 NM27LC256 @DIP28 NM27LC256 @PLCC32 NM27LC512 @DIP28 NM27LC512 @PLCC32 NM27LV010 NM27LV010 @PLCC32 NM27LV010 @TSOP32 NM27LV020 @DIP32 NM27LV020 @PLCC32 NM27LV020 @TSOP32 NM27LV040 @DIP32 NM27LV040 @PLCC32 NM27LV040 @TSOP32 NM27LV210 @DIP40 NM27LV512 @DIP28 NM27LV512 @PLCC32 NM27P010 NM27P010 @PLCC32 NM27P010 @TSOP32 NM27P020 @DIP32 NM27P020 @PLCC32 NM27P020 @TSOP32 NM27P040 @DIP32 NM27P040 @PLCC32 NM27P040 @TSOP32 NM27P210 @DIP40 NM27P512 @DIP28 NM27P512 @PLCC32 NM93C06(x16) NM93C06(x16) @SOIC8 NM93C46 NM93C46 @SOIC8 NM93C46 @TSOP8 NM93C46A(x8) NM93C46A(x8) @SOIC8 NM93C46A(x8) @TSOP8 NM93C46A(x16) NM93C46A(x16) @SOIC8 NM93C46A(x16) @TSOP8 NM93C56 NM93C56 @SOIC8 NM93C56 @TSOP8 NM93C56A(x8) NM93C56A(x8) @SOIC8 NM93C56A(x8) @TSOP8 NM93C56A(x16) NM93C56A(x16) @SOIC8 NM93C56A(x16) @TSOP8 NM93C66 NM93C66 @SOIC8 NM93C66 @TSOP8 NM93C66A(x8) NM93C66A(x8) @SOIC8 NM93C66A(x8) @TSOP8 NM93C66A(x16) NM93C66A(x16) @SOIC8 NM93C66A(x16) @TSOP8 NM93C76 NM93C76 @SOIC8 NM93C76 @TSOP8 NM93C76A(x8) NM93C76A(x8) @SOIC8 NM93C76A(x8) @TSOP8 NM93C76A(x16) NM93C76A(x16) @SOIC8 NM93C76A(x16) @TSOP8 NM93C86 NM93C86 @SOIC8 NM93C86 @TSOP8 NM93C86A(x8) NM93C86A(x8) @SOIC8 NM93C86A(x8) @TSOP8 NM93C86A(x16) NM93C86A(x16) @SOIC8 NM93C86A(x16) @TSOP8 NM93CS06 NM93CS06 @SOIC8 NM93CS06 @TSOP8 NM93CS46 NM93CS46 @SOIC8 NM93CS46 @TSOP8 NM93CS56 NM93CS56 @SOIC8 NM93CS56 @TSOP8 NM93CS66 NM93CS66 @SOIC8 NM93CS66 @TSOP8 NMC2732 @DIP24 NMC27C010 @DIP32 NMC27C010 @PLCC32 NMC27C010 @TSOP32 NMC27C16 @DIP24 NMC27C16B @DIP24 NMC27C16Q @DIP24 NMC27C32B @DIP24 NMC27C64Q @DIP28 NMC27C64Q @PLCC32 NMC27C128B @DIP28 NMC27C128B @PLCC32 NMC27C128C @DIP28 NMC27C128C @PLCC32 NMC27C256B @DIP28 NMC27C256B @PLCC32 NMC27C256Q @DIP28 NMC27C256Q @PLCC32 NMC27C512A @DIP28 NMC27C512A @PLCC32 NMC27C512Q @DIP28 NMC27C512Q @PLCC32 NMC27C1024 @DIP40 NMC87C257Q @DIP28 NMC87C257Q @PLCC32 NMC87C257V @DIP28 NMC87C257V @PLCC32 NMC93C46 NMC93C46 @SOIC8 NMC93C46 @TSOP8 NMC93C46A NMC93C46A @SOIC8 NMC93C46A @TSOP8 NMC93C56 NMC93C56 @SOIC8 NMC93C56 @SOIC14 NMC93C56 @TSOP8 NMC93C66 NMC93C66 @SOIC8 NMC93C66 @SOIC14 NMC93C66 @TSOP8 NMC93C86A NMC93C86A @SOIC8 NMC93C86A @SOIC14 NMC93CS06 NMC93CS06 @SOIC8 NMC93CS06 @SOIC14 NMC93CS06 @TSOP8 NMC93CS46 NMC93CS46 @SOIC8 NMC93CS46 @SOIC14 NMC93CS46 @TSOP8 NMC93CS56 NMC93CS56 @SOIC8 NMC93CS56 @SOIC14 NMC93CS56 @TSOP8 NMC93CS66 NMC93CS66 @SOIC8 NMC93CS66 @SOIC14 NMC93CS66 @TSOP8 [ NUMONYX ] 91 PCS M25P05 M25P05 @SOIC8 M25P05A @SOIC8 M25P05A @TSSOP8 M25P10 M25P10 @SOIC8 M25P10A @QFN8 M25P10A @SOIC8 M25P20 @QFN8 M25P20 @SOIC8 M25P40 @QFN8 M25P40 @SOIC8 M25P80 @QFN8 M25P80 @SOIC8 M25P80 @SOP16 M25P16 @QFN8 M25P16 @SOIC8 M25P16 @SOP16 M25P32 @QFN8 M25P32 @SOIC8 M25P32 @SOP16 M25P64 @SOIC8 M25P64 @SOIC16 M25P128(ST25P28V6G) @FPN8 M25P128(ST25P28V6G) @SOP16 M25PE10 @QFN8 M25PE10 @SOIC8 M25PE16 @QFN8 M25PE16 @SOIC8 M25PE20 @QFN8 M25PE20 @SOIC8 M25PE40 @QFN8 M25PE40 @SOIC8 M25PE80 @QFN8 M25PE80 @SOIC8 M29F200FB @TSOP48 M29F200FB @SOP44 M29F200FT @TSOP48 M29F200FT @SOP44 M29F400FB @TSOP48 M29F400FB @SOP44 M29F400FT @TSOP48 M29F400FT @SOP44 M29F800FB @TSOP48 M29F800FB @SOP44 M29F800FT @TSOP48 M29F800FT @SOP44 M29F160FB @TSOP48 M29F160FT @TSOP48 M29W200BT @TSOP48 M29W200BT @SOP44 M29W200BB @TSOP48 M29W200BB @SOP44 M29W400T @TSOP48 M29W400T @SOP44 M29W400B @TSOP48 M29W400B @SOP44 M29W400BT @TSOP48 M29W400BT @SOP44 M29W400BB @TSOP48 M29W400BB @SOP44 M29W400DT @TSOP48 M29W400DT @SOP44 M29W400DB @TSOP48 M29W400DB @SOP44 M29W400FT @TSOP48 M29W400FB @TSOP48 M29W800AT @TSOP48 M29W800AT @SOP44 M29W800AB @TSOP48 M29W800AB @SOP44 M29W800DT @TSOP48 M29W800DT @SOP44 M29W800DB @TSOP48 M29W800DB @SOP44 M29W800FT @TSOP48 M29W800FB @TSOP48 M29W160BT @TSOP48 M29W160BB @TSOP48 M29W160DT @TSOP48 M29W160DB @TSOP48 M29W160ET @TSOP48 M29W160EB @TSOP48 M29W320DT @TSOP48 M29W320DB @TSOP48 M29W320ET @TSOP48 M29W320EB @TSOP48 M29W640DT @TSOP48 M29W640DB @TSOP48 M29W640FT @TSOP48 M29W640FB @TSOP48 [ NXP ] 24 PCS PCA24S08 @SOIC8 PCA24S08 @TSSOP8 P87C51FA P87C51FA @PLCC44 P87C51FB P87C51FB @PLCC44 P87C51FC P87C51FC @PLCC44 P87C51RA P87C51RA @PLCC44 P87C51RB P87C51RB @PLCC44 P87C51RC P87C51RC @PLCC44 P87C51RD P87C51RD @PLCC44 P87C51U P87C51U @PLCC44 P87C52U P87C52U @PLCC44 P87C54U P87C54U @PLCC44 P87C58U P87C58U @PLCC44 [ OKI ] 9 PCS MSM27C201 @DIP32 MSM27C201 @PLCC32 MSM27C201 @TSOP32 MSM27C401 @DIP32 MSM27C401 @PLCC32 MSM27C401 @TSOP32 MSM27C512 MSM27C512 @SOP28 MSM27C512 @PLCC32 [ ON SEMI. ] 89 PCS CAT24AA01 @SOIC8 CAT24AA02 @SOIC8 CAT24AA04 @SOIC8 CAT24AA08 @SOIC8 CAT24AA16 @SOIC8 CAT24C01 CAT24C01 @SOIC8 CAT24C01 @TSSOP8 CAT24C02 CAT24C02 @SOIC8 CAT24C02 @TSSOP8 CAT24C03 CAT24C03 @SOIC8 CAT24C03 @TSSOP8 CAT24C04 CAT24C04 @SOIC8 CAT24C04 @TSSOP8 CAT24C05 CAT24C05 @SOIC8 CAT24C05 @TSSOP8 CAT24C08 CAT24C08 @SOIC8 CAT24C08 @TSSOP8 CAT24C09 CAT24C09 @SOIC8 CAT24C09 @TSSOP8 CAT24C16 CAT24C16 @SOIC8 CAT24C16 @TSSOP8 CAT24C32 CAT24C32 @SOIC8 CAT24C32 @TSSOP8 CAT24C64 CAT24C64 @SOIC8 CAT24C64 @TSSOP8 CAT24C128 CAT24C128 @SOIC8 CAT24C128 @TSSOP8 CAT24C256 CAT24C256 @SOIC8 CAT24C256 @TSSOP8 CAT25010 CAT25010 @SOIC8 CAT25010 @TSSOP8 CAT25020 CAT25020 @SOIC8 CAT25020 @TSSOP8 CAT25040 CAT25040 @SOIC8 CAT25040 @TSSOP8 CAT25080 CAT25080 @SOIC8 CAT25080 @TSSOP8 CAT25160 CAT25160 @SOIC8 CAT25160 @TSSOP8 CAT25320 CAT25320 @SOIC8 CAT25320 @TSSOP8 CAT25640 CAT25640 @SOIC8 CAT25640 @TSSOP8 CAT25128 CAT25128 @SOIC8 CAT25128 @TSSOP8 CAT25256 CAT25256 @SOIC8 CAT25256 @TSSOP8 CAT93C46(x16) CAT93C46(x16) @SOIC8 CAT93C46(x16) @TSOP8 CAT93C46R(x16) CAT93C46R(x16) @SOIC8 CAT93C46R(x16) @TSOP8 CAT93C56(x16) CAT93C56(x16) @SOIC8 CAT93C56(x16) @TSOP8 CAT93C57(x16) CAT93C57(x16) @SOIC8 CAT93C57(x16) @TSOP8 CAT93C66(x16) CAT93C66(x16) @SOIC8 CAT93C66(x16) @TSOP8 CAT93C76(x16) CAT93C76(x16) @SOIC8 CAT93C76(x16) @TSOP8 CAT93C86(x16) CAT93C86(x16) @SOIC8 CAT93C86(x16) @TSOP8 [ PCT ] 9 PCS PCT25LF020A @SOIC8 PCT25VF010A @SOIC8 PCT25VF016B @SOIC8 PCT25VF020A @SOIC8 PCT25VF032B @SOIC8 PCT25VF040A @SOIC8 PCT25VF040B @SOIC8 PCT25VF080B @SOIC8 PCT25VF512A @SOIC8 [ PHILIPS ] 40 PCS 27C010 @DIP32 27C010 @PLCC32 27C010 @TSOP32 27C040 @DIP32 27C040 @PLCC32 27C040 @TSOP32 27C210 @DIP40 27C240 @DIP40 27C256 @DIP28 27C256 @PLCC32 27C512 @DIP28 27C512 @PLCC32 P87C51FA P87C51FA @PLCC44 P87C51FB P87C51FB @PLCC44 P87C51FC P87C51FC @PLCC44 P87C51RA P87C51RA @PLCC44 P87C51RB P87C51RB @PLCC44 P87C51RC P87C51RC @PLCC44 P87C51RD P87C51RD @PLCC44 P87C51U P87C51U @PLCC44 P87C52U P87C52U @PLCC44 P87C54U P87C54U @PLCC44 P87C58U P87C58U @PLCC44 PCF8582C PCF8582C @SOIC8 PCF8594C PCF8594C @SOIC8 PCF8598C PCF8598C @SOIC8 [ PMC ] 99 PCS PM25LD256C PM25LD256C @SOP8 PM25LD256C @WSON8 PM25LD256C @TSSOP8 PM25LD512 PM25LD512 @SOP8 PM25LD512 @WSON8 PM25LD512 @TSSOP8 PM25LD512C PM25LD512C @SOP8 PM25LD512C @WSON8 PM25LD512C @TSSOP8 PM25LD010 PM25LD010 @SOP8 PM25LD010 @WSON8 PM25LD010 @TSSOP8 PM25LD010C PM25LD010C @SOP8 PM25LD010C @WSON8 PM25LD010C @TSSOP8 PM25LD020 PM25LD020 @SOP8 PM25LD020 @WSON8 PM25LD020 @TSSOP8 PM25LD020C PM25LD020C @SOP8 PM25LD020C @WSON8 PM25LD020C @TSSOP8 PM25LD040 PM25LD040 @SOP8 PM25LD040 @WSON8 PM25LD040 @TSSOP8 PM25LD040C PM25LD040C @SOP8 PM25LD040C @WSON8 PM25LD040C @TSSOP8 PM25LV512 PM25LV512 @SOP8 PM25LV512 @WSON8 PM25LV512A PM25LV512A @SOP8 PM25LV512A @WSON8 PM25LV010 PM25LV010 @SOP8 PM25LV010 @WSON8 PM25LV010A PM25LV010A @SOP8 PM25LV010A @WSON8 PM25LV020 PM25LV020 @SOP8 PM25LV020 @WSON8 PM25LV040 PM25LV040 @SOP8 PM25LV040 @WSON8 PM25LV080B PM25LV080B @SOP8 PM25LV080B @WSON8 PM25LV016B PM25LV016B @SOP8 PM25LV016B @WSON8 PM25WD020 PM25WD020 @SOP8 PM25WD020 @WSON8 PM25WD040 PM25WD040 @SOP8 PM25WD040 @WSON8 PM29F002T @DIP32 PM29F002T @PLCC32 PM29F002B @DIP32 PM29F002B @PLCC32 PM29F004T @DIP32 PM29F004T @PLCC32 PM29F004B @DIP32 PM29F004B @PLCC32 PM39F010 @DIP32 PM39F010 @PLCC32 PM39F010 @TSOP32 PM39F020 @DIP32 PM39F020 @PLCC32 PM39F020 @TSOP32 PM39F040 @DIP32 PM39F040 @PLCC32 PM39F040 @TSOP32 PM39LV512 @PLCC32 PM39LV512 @TSOP32 PM39LV010 @PLCC32 PM39LV010 @TSOP32 PM39LV020 @PLCC32 PM39LV020 @TSOP32 PM39LV040 @PLCC32 PM39LV040 @TSOP32 PM49FL002T @PLCC32 PM49FL002T @TSOP32 PM49FL004T @PLCC32 PM49FL004T @TSOP32 PM49FL008T @PLCC32 PM49FL008T @TSOP32 PM49LP002T @PLCC32 PM49LP002T @TSOP32 [ PORTEK ] 8 PCS PTK24A02T PTK24A02T @SOIC8 PTK24A04T PTK24A04T @SOIC8 PTK24A08T PTK24A08T @SOIC8 PTK24A16T PTK24A16T @SOIC8 [ PTC ] 6 PCS PT28C010 PT28C010 @PLCC32 PT28C020 PT28C020 @PLCC32 PT28C040 PT28C040 @PLCC32 [ RAMTRON ] 35 PCS FM24C04A FM24C04A @SOIC8 FM24C08A FM24C08A @SOIC8 FM24C16 FM24C16 @SOIC8 FM24C16A FM24C16A @SOIC8 FM24C64A FM24C64A@SOIC8 FM24C256 FM24C256 @SOIC8 FM24CL04 FM24CL04 @SOIC8 FM24CL16 FM24CL16 @SOIC8 FM24CL64 FM25040 FM25040 @SOIC8 FM25C160 FM25C160 @SOIC8 FM25640 FM25640 @SOIC8 FM25CL04 FM25CL04 @SOIC8 FM25CL64 FM25CL64 @SOIC8 FM25L16 FM25L16 @SOIC8 FM25L256 FM25L256 @SOIC8 FM25L512 FM25L512 @SOIC8 FM25W256 FM25W256 @SOIC8 [ RATO ] 21 PCS RT24A02 RT24A02 @SOIC8 RT24A02 @TSSOP8 RT24A04 RT24A04 @SOIC8 RT24A04 @TSSOP8 RT24A08 RT24A08 @SOIC8 RT24A08 @TSSOP8 RT24A16 RT24A16 @SOIC8 RT24A16 @TSSOP8 RT93C46B(x16) RT93C46B(x16) @SOIC8 RT93C46B(x16) @TSOP8 RT93LC46(x8) RT93LC46(x8) @SOIC8 RT93LC46(x8) @TSOP8 RT93LC46(x16) RT93LC46(x16) @SOIC8 RT93LC46(x16) @TSOP8 [ RAYDIUM ] 6 PCS RM24C02 @SOIC8 RM24C04 @SOIC8 RM24C08 @SOIC8 RM24C16 @SOIC8 RM24C32 @SOIC8 RM24C64 @SOIC8 [ RENESAS ] 70 PCS HN58V24256 @SOIC8 HN58V24256 @TSSOP8 HN58V24512 @SOIC8 HN58V24512 @TSSOP8 HN58X2402 @SOIC8 HN58X2402 @TSSOP8 HN58X2404 @SOIC8 HN58X2404 @TSSOP8 HN58X2408 @SOIC8 HN58X2408 @TSSOP8 HN58X2416 @SOIC8 HN58X2416 @TSSOP8 HN58X2432 @SOIC8 HN58X2432 @TSSOP8 HN58X2464 @SOIC8 HN58X2464 @TSSOP8 HN58X24128 @SOIC8 HN58X24128 @TSSOP8 HN58X24256 @SOIC8 HN58X24256 @TSSOP8 HN58X24512 @SOIC8 HN58X24512 @TSSOP8 HN58X2502 @SOIC8 HN58X2502 @TSSOP8 HN58X2504 @SOIC8 HN58X2504 @TSSOP8 HN58X2508 @SOIC8 HN58X2508 @TSSOP8 HN58X25128 @SOIC8 HN58X2516 @SOIC8 HN58X2516 @TSSOP8 HN58X25256 @SOIC8 HN58X2532 @SOIC8 HN58X2532 @TSSOP8 HN58X2564 @SOIC8 HN58X2564 @TSSOP8 R1EX24002A @SOIC8 R1EX24002A @TSSOP8 R1EX24004A @SOIC8 R1EX24004A @TSSOP8 R1EX24008A @SOIC8 R1EX24008A @TSSOP8 R1EX24016A @SOIC8 R1EX24016A @TSSOP8 R1EX24032A @SOIC8 R1EX24032A @TSSOP8 R1EX24064A @SOIC8 R1EX24064A @TSSOP8 R1EX24128A @SOIC8 R1EX24128A @TSSOP8 R1EX24128B @SOIC8 R1EX24128B @TSSOP8 R1EX24256A @SOIC8 R1EX24256A @TSSOP8 R1EX24256B @SOIC8 R1EX24256B @TSSOP8 R1EX24512A @SOIC8 R1EX24512A @TSSOP8 R1EX25002A @SOIC8 R1EX25002A @TSSOP8 R1EX25004A @SOIC8 R1EX25004A @TSSOP8 R1EX25008A @SOIC8 R1EX25008A @TSSOP8 R1EX25016A @SOIC8 R1EX25016A @TSSOP8 R1EX25032A @SOIC8 R1EX25032A @TSSOP8 R1EX25064A @SOIC8 R1EX25064A @TSSOP8 [ ROHM ] 425 PCS BR24A01(F) @SOP8 BR24A01(FJ) @SOP-J8 BR24A01(FVM) @MSOP8 BR24A02(F) @SOP8 BR24A02(FJ) @SOP-J8 BR24A02(FVM) @MSOP8 BR24A04(F) @SOP8 BR24A04(FJ) @SOP-J8 BR24A04(FVM) @MSOP8 BR24A08(F) @SOP8 BR24A08(FJ) @SOP-J8 BR24A08(FVM) @MSOP8 BR24A16(F) @SOP8 BR24A16(FJ) @SOP-J8 BR24A16(FVM) @MSOP8 BR24A32(F) @SOP8 BR24A32(FJ) @SOP-J8 BR24A32(FVM) @MSOP8 BR24A64(F) @SOP8 BR24A64(FJ) @SOP-J8 BR24A64(FVM) @MSOP8 BR24C01A BR24C01A(F) @SOP8 BR24C01A(FJ) @SOP-J8 BR24C01A(FV) @MSOP8 BR24C02 BR24C02(F) @SOP8 BR24C02(FJ) @SOP-J8 BR24C02(FV) @MSOP8 BR24C04 BR24C04(F) @SOP8 BR24C04(FJ) @SOP-J8 BR24C04(FV) @MSOP8 BR24C08 BR24C08(F) @SOP8 BR24C08(FJ) @SOP-J8 BR24C08(FV) @MSOP8 BR24C16 BR24C16(F) @SOP8 BR24C16(FJ) @SOP-J8 BR24C16(FV) @MSOP8 BR24C21 BR24C21F BR24C21FJ BR24C21FV BR24C32 BR24C32(F) @SOP8 BR24C32(FJ) @SOP-J8 BR24C32(FV) @MSOP8 BR24C64 BR24C64(F) @SOP8 BR24C64(FJ) @SOP-J8 BR24C64(FV) @MSOP8 BR24E16 BR24E16(F) @SOP8 BR24E16(FJ) @SOP-J8 BR24E16(FV) @MSOP8 BR24G01 BR24G01(F) @SOP8 BR24G01(FJ) @SOP-J8 BR24G01(FV) @MSOP8 BR24G02 BR24G02(F) @SOP8 BR24G02(FJ) @SOP-J8 BR24G02(FV) @MSOP8 BR24G04 BR24G04(F) @SOP8 BR24G04(FJ) @SOP-J8 BR24G04(FV) @MSOP8 BR24G08 BR24G08(F) @SOP8 BR24G08(FJ) @SOP-J8 BR24G08(FV) @MSOP8 BR24G16 BR24G16(F) @SOP8 BR24G16(FJ) @SOP-J8 BR24G16(FV) @MSOP8 BR24G32 BR24G32(F) @SOP8 BR24G32(FJ) @SOP-J8 BR24G32(FV) @MSOP8 BR24G64 BR24G64(F) @SOP8 BR24G64(FJ) @SOP-J8 BR24G64(FV) @MSOP8 BR24G128 BR24G128(F) @SOP8 BR24G128(FJ) @SOP-J8 BR24G128(FV) @MSOP8 BR24G256 BR24G256(F) @SOP8 BR24G256(FJ) @SOP-J8 BR24G256(FV) @MSOP8 BR24G512 BR24G512(F) @SOP8 BR24G512(FJ) @SOP-J8 BR24G512(FV) @MSOP8 BR24G1M BR24G1M(F) @SOP8 BR24L01A BR24L01A(F) @SOP8 BR24L01A(FJ) @SOP-J8 BR24L01A(FV) @MSOP8 BR24L02 BR24L02(F) @SOP8 BR24L02(FJ) @SOP-J8 BR24L02(FV) @MSOP8 BR24L04 BR24L04(F) @SOP8 BR24L04(FJ) @SOP-J8 BR24L04(FV) @MSOP8 BR24L08 BR24L08(F) @SOP8 BR24L08(FJ) @SOP-J8 BR24L08(FV) @MSOP8 BR24L16 BR24L16(F) @SOP8 BR24L16(FJ) @SOP-J8 BR24L16(FV) @MSOP8 BR24L32 BR24L32(F) @SOP8 BR24L32(FJ) @SOP-J8 BR24L32(FV) @MSOP8 BR24L64 BR24L64(F) @SOP8 BR24L64(FJ) @SOP-J8 BR24L64(FV) @MSOP8 BR24S01 BR24S01(F) @SOP8 BR24S01(FJ) @SOP-J8 BR24S01(FV) @MSOP8 BR24S02 BR24S02(F) @SOP8 BR24S02(FJ) @SOP-J8 BR24S02(FV) @MSOP8 BR24S04 BR24S04(F) @SOP8 BR24S04(FJ) @SOP-J8 BR24S04(FV) @MSOP8 BR24S08 BR24S08(F) @SOP8 BR24S08(FJ) @SOP-J8 BR24S08(FV) @MSOP8 BR24S16 BR24S16(F) @SOP8 BR24S16(FJ) @SOP-J8 BR24S16(FV) @MSOP8 BR24S32 BR24S32(F) @SOP8 BR24S32(FJ) @SOP-J8 BR24S32(FV) @MSOP8 BR24S64 BR24S64(F) @SOP8 BR24S64(FJ) @SOP-J8 BR24S64(FV) @MSOP8 BR24S128 BR24S128(F) @SOP8 BR24S128(FJ) @SOP-J8 BR24S128(FV) @MSOP8 BR24S256 BR24S256(F) @SOP8 BR24S256(FJ) @SOP-J8 BR24S256(FV) @MSOP8 BR24T01 BR24T01(F) @SOP8 BR24T01(FJ) @SOP-J8 BR24T01(FV) @MSOP8 BR24T02 BR24T02(F) @SOP8 BR24T02(FJ) @SOP-J8 BR24T02(FV) @MSOP8 BR24T04 BR24T04(F) @SOP8 BR24T04(FJ) @SOP-J8 BR24T04(FV) @MSOP8 BR24T08 BR24T08(F) @SOP8 BR24T08(FJ) @SOP-J8 BR24T08(FV) @MSOP8 BR24T16 BR24T16(F) @SOP8 BR24T16(FJ) @SOP-J8 BR24T16(FV) @MSOP8 BR24T32 BR24T32(F) @SOP8 BR24T32(FJ) @SOP-J8 BR24T32(FV) @MSOP8 BR24T64 BR24T64(F) @SOP8 BR24T64(FJ) @SOP-J8 BR24T64(FV) @MSOP8 BR24T128 BR24T128(F) @SOP8 BR24T128(FJ) @SOP-J8 BR24T128(FV) @MSOP8 BR24T256 BR24T256(F) @SOP8 BR24T256(FJ) @SOP-J8 BR24T256(FV) @MSOP8 BR24T512 BR24T512(F) @SOP8 BR24T512(FJ) @SOP-J8 BR24T512(FV) @MSOP8 BR24T1M BR24T1M(F) @SOP8 BR25010 @SOIC8 BR25010 @TSSOP8 BR25020 @SOIC8 BR25020 @TSSOP8 BR25040 @SOIC8 BR25040 @TSSOP8 BR25080 @SOIC8 BR25080 @TSSOP8 BR25160 @SOIC8 BR25160 @TSSOP8 BR25320 @SOIC8 BR25320 @TSSOP8 BR25H010(F) @SOP8 BR25H010(FJ) @SOP-J8 BR25H020(F) @SOP8 BR25H020(FJ) @SOP-J8 BR25H040(F) @SOP8 BR25H040(FJ) @SOP-J8 BR25H080(F) @SOP8 BR25H080(FJ) @SOP-J8 BR25H080(FVT)@TSSOP8 BR25H160(F) @SOP8 BR25H160(FJ) @SOP-J8 BR25H160(FVT)@TSSOP8 BR25H320(F) @SOP8 BR25H320(FJ) @SOP-J8 BR25H320(FVT)@TSSOP8 BR25L010 BR25L010(F) @SOP8 BR25L010(FJ) @SOP-J8 BR25L010(FV) @MSOP8 BR25L020 BR25L020(F) @SOP8 BR25L020(FJ) @SOP-J8 BR25L020(FV) @MSOP8 BR25L040 BR25L040(F) @SOP8 BR25L040(FJ) @SOP-J8 BR25L040(FV) @MSOP8 BR25L080 BR25L080(F) @SOP8 BR25L080(FJ) @SOP-J8 BR25L080(FV) @MSOP8 BR25L160 BR25L160(F) @SOP8 BR25L160(FJ) @SOP-J8 BR25L160(FV) @MSOP8 BR25L320 BR25L320(F) @SOP8 BR25L320(FJ) @SOP-J8 BR25L320(FV) @MSOP8 BR25L640 BR25L640(F) @SOP8 BR25L640(FJ) @SOP-J8 BR25L640(FV) @MSOP8 BR25S320(F) @SOP8 BR25S320(FJ) @SOP-J8 BR25S320(FV) @MSOP8 BR25S640(F) @SOP8 BR25S640(FJ) @SOP-J8 BR25S640(FV) @MSOP8 BR25S128(F) @SOP8 BR25S128(FJ) @SOP-J8 BR25S256(F) @SOP8 BR25S256(FJ) @SOP-J8 BR9010 BR9010(F) @SOP8 BR9010(RFV) @SSOP8 BR9016 BR9016(F) @SOP8 BR9016(RFV) @SSOP8 BR9016A BR9016A(F) @SOP8 BR9016A(RFV) @SSOP8 BR9020 BR9020(F) @SOP8 BR9020(RFV) @SSOP8 BR9040 BR9040(F) @SOP8 BR9040(RFV) @SSOP8 BR9080 BR9080(F) @SOP8 BR9080(RFV) @SSOP8 BR9080A BR9080A(F) @SOP8 BR9080A(RFV) @SSOP8 BR93A46(F) BR93A46(FJ) BR93A46(RF) BR93A46(RFJ) BR93A56(F) BR93A56(FJ) BR93A56(RF) BR93A56(RFJ) BR93A66(F) BR93A66(FJ) BR93A66(RF) BR93A66(RFJ) BR93A76(F) BR93A76(FJ) BR93A76(RF) BR93A76(RFJ) BR93A86(F) BR93A86(FJ) BR93A86(RF) BR93A86(RFJ) BR93C46 BR93C46(F) BR93C46(FJ) BR93C46(FV) BR93C46(RF) BR93C46(RFJ) BR93C56 BR93C56(F) BR93C56(FJ) BR93C56(FV) BR93C56(RF) BR93C56(RFJ) BR93C66 BR93C66(F) BR93C66(FJ) BR93C66(FV) BR93C66(RF) BR93C66(RFJ) BR93C76 BR93C76(F) BR93C76(FJ) BR93C76(FV) BR93C76(RF) BR93C76(RFJ) BR93C86 BR93C86(F) BR93C86(FJ) BR93C86(FV) BR93C86(RF) BR93C86(RFJ) BR93CS46 BR93CS46F BR93H46(FJ) BR93H46(RF) BR93H46(RFJ) BR93H56(FJ) BR93H56(RF) BR93H56(RFJ) BR93H66(FJ) BR93H66(RF) BR93H66(RFJ) BR93H76(FJ) BR93H76(RF) BR93H76(RFJ) BR93H86(FJ) BR93H86(RF) BR93H86(RFJ) BR93L46 BR93L46(F) BR93L46(FJ) BR93L46(FV) BR93L46(RF) BR93L46(RFJ) BR93L56 BR93L56(F) BR93L56(FJ) BR93L56(FV) BR93L56(RF) BR93L56(RFJ) BR93L66 BR93L66(F) BR93L66(FJ) BR93L66(FV) BR93L66(RF) BR93L66(RFJ) BR93L76 BR93L76(F) BR93L76(FJ) BR93L76(FV) BR93L76(RF) BR93L76(RFJ) BR93L86 BR93L86(F) BR93L86(FJ) BR93L86(FV) BR93L86(RF) BR93L86(RFJ) BR93LC46 BR93LC46(F) BR93LC46(FV) BR93LC46(RF) BR93LC46(RFJ) BR93LC56 BR93LC56(F) BR93LC56(FV) BR93LC56(RF) BR93LC56(RFJ) BR93LC66 BR93LC66(F) BR93LC66(FV) BR93LC66(RF) BR93LC66(RFJ) BR93LC76 BR93LC76(F) BR93LC76(FV) BR93LC76(RF) BR93LC76(RFJ) BR93LC86 BR93LC86(F) BR93LC86(FV) BR93LC86(RF) BR93LC86(RFJ) BR93LL46(F) BR93LL46(FV) BR95010 @SOIC8 BR95010 @TSSOP8 BR95020 @SOIC8 BR95020 @TSSOP8 BR95040 @SOIC8 BR95040 @TSSOP8 BR95080 @SOIC8 BR95080 @TSSOP8 BR95160 @SOIC8 BR95160 @TSSOP8 [ SAIFUN ] 12 PCS SA24C1024 SA24C1024 @SOIC8 SA24C512 SA24C512 @SOIC8 SA25C1024H SA25C1024H @SOIC8 SA25C1024L SA25C1024L @SOIC8 SA25C512H SA25C512H @SOIC8 SA25C512L SA25C512L @SOIC8 [ SAMSUNG ] 112 PCS KM28C64A KM28C64A @PLCC32 KM28C65A KM28C65A @PLCC32 KM93C46 KM93C46G KM93C46GD KM93C46V KM93C46VG KM93C46VGD KM93C56V KM93C56VG KM93C56VGD KM93C66V KM93C66VG KM93C66VGD KS24C010 KS24C010 @SOIC8 KS24C010 @TSOP8 KS24C011 KS24C011 @SOIC8 KS24C011 @TSOP8 KS24C020 KS24C020 @SOIC8 KS24C020 @TSSOP8 KS24C021 KS24C021 @SOIC8 KS24C021 @TSSOP8 KS24C040 KS24C040 @SOIC8 KS24C040 @TSSOP8 KS24C041 KS24C041 @SOIC8 KS24C041 @TSSOP8 KS24C080 KS24C080 @SOIC8 KS24C080 @TSSOP8 KS24C081 KS24C081 @SOIC8 KS24C081 @TSSOP8 S524A40X10 S524A40X10 @SOIC8 S524A40X10 @TSOP8 S524A40X11 S524A40X11 @SOIC8 S524A40X11 @TSOP8 S524A40X20 S524A40X20 @SOIC8 S524A40X20 @TSSOP8 S524A40X21 S524A40X21 @SOIC8 S524A40X21 @TSSOP8 S524A40X40 S524A40X40 @SOIC8 S524A40X40 @TSSOP8 S524A40X41 S524A40X41 @SOIC8 S524A40X41 @TSSOP8 S524A60X51 S524A60X51 @SOIC8 S524A60X51 @TSSOP8 S524A60X81 S524A60X81 @SOIC8 S524A60X81 @TSSOP8 S524AB0X91 S524AB0X91 @SOIC8 S524AB0X91 @TSSOP8 S524AB0XB1 S524AB0XB1 @SOIC8 S524AB0XB1 @TSSOP8 S524AD0XD1 S524AD0XD1 @SOIC8 S524AD0XD1 @TSSOP8 S524AD0XF1 S524AD0XF1 @SOIC8 S524AD0XF1 @TSSOP8 S524C20D10 S524C20D10 @SOIC8 S524C20D10 @TSOP8 S524C20D11 S524C20D11 @SOIC8 S524C20D11 @TSOP8 S524C20D20 S524C20D20 @SOIC8 S524C20D20 @TSSOP8 S524C20D21 S524C20D21 @SOIC8 S524C20D21 @TSSOP8 S524C80D40 S524C80D40 @SOIC8 S524C80D40 @TSSOP8 S524C80D41 S524C80D41 @SOIC8 S524C80D41 @TSSOP8 S524C80D80 S524C80D80 @SOIC8 S524C80D80 @TSSOP8 S524C80D81 S524C80D81 @SOIC8 S524C80D81 @TSSOP8 S524L50D51 S524L50D51 @SOIC8 S524L50D51 @TSSOP8 S524L50X51 S524L50X51 @SOIC8 S524L50X51 @TSSOP8 S524LB0X91 S524LB0X91 @SOIC8 S524LB0X91 @TSSOP8 S524LB0XB1 S524LB0XB1 @SOIC8 S524LB0XB1 @TSSOP8 [ SANYO ] 44 PCS LE24C041 LE24C041 @MFP8 LE24C042 LE24C042 @MFP8 LE24C043 LE24C043 @MFP8 LE24C081 LE24C081 @MFP8 LE24C082 LE24C082 @MFP8 LE24C161 LE24C161 @MFP8 LE24C162 LE24C162 @MFP8 LE24C321 LE24C321 @MFP8 LE24C322 LE24C322 @MFP8 LE24C641 LE24C641 @MFP8 LE24C642 LE24C642 @MFP8 LE24L082 LE24L082 @MFP8 LE24L162 LE24L162 @MFP8 LE24LA322 LE24LA322 @MFP8 LE24LB642 LE24LB642 @MFP8 LE25FU106BMA @MFP8 LE25FU106BTT @MSOP8 LE25FU206MA @MFP8 LE25FU206TT @MSOP8 LE25FU406BMA @MFP8 LE25FU406BTT @MSOP8 LE25FW206M @SOP8 LE25FW206T @MSOP8 LE25FW406M @SOP8 LE25FW406T @MSOP8 LE25FW406AM @MFP8 LE25FW406AT @MSOP8 LE25FW806M @SOP8 LE25FW806T @MSOP8 [ SEIKO ] 184 PCS S-24C01A S-24C01A @SOIC8 S-24C01B S-24C01B @SOIC8 S-24C01C @SOIC8 S-24C01C @TSSOP8 S-24C02A S-24C02A @SOIC8 S-24C02B S-24C02B @SOIC8 S-24C02C @SOIC8 S-24C02C @TSSOP8 S-24C04A S-24C04A @SOIC8 S-24C04B S-24C04B @SOIC8 S-24C08A S-24C08A @SOIC8 S-24C08C @SOIC8 S-24C08C @TSSOP8 S-24C16A S-24C16A @SOIC8 S-24C16A @TSSOP8 S-24C32C @SOIC8 S-24C32C @TSSOP8 S-24C64C @SOIC8 S-24C64C @TSSOP8 S-24CS01A S-24CS01A @SOIC8 S-24CS01A @TSSOP8 S-24CS02A S-24CS02A @SOIC8 S-24CS02A @TSSOP8 S-24CS04A S-24CS04A @SOIC8 S-24CS04A @TSSOP8 S-24CS08A S-24CS08A @SOIC8 S-24CS08A @TSSOP8 S-24CS16A S-24CS16A @SOIC8 S-24CS16A @TSSOP8 S-24CS32A @SOIC8 S-24CS32A @TSSOP8 S-24CS64A @SOIC8 S-24CS64A @TSSOP8 S24H45 S24H45 @SOP8 S24S45 S24S45 @SOP8 S-25A010A @SOIC8 S-25A010A @TSSOP8 S-25A020A @SOIC8 S-25A020A @TSSOP8 S-25A040A @SOIC8 S-25A040A @TSSOP8 S-25A080A @SOIC8 S-25A080A @TSSOP8 S-25A160A @SOIC8 S-25A160A @TSSOP8 S-25A320A @SOIC8 S-25A320A @TSSOP8 S-25A640A @SOIC8 S-25A640A @TSSOP8 S-25C010A @SOIC8 S-25C010A @TSSOP8 S-25C020A @SOIC8 S-25C020A @TSSOP8 S-25C040A @SOIC8 S-25C040A @TSSOP8 S-25C080A @SOIC8 S-25C080A @TSSOP8 S-25C160A @SOIC8 S-25C160A @TSSOP8 S-25C320A @SOIC8 S-25C320A @TSSOP8 S-25C640A @SOIC8 S-25C640A @TSSOP8 S-29130A(DP) S-29130A(DFJA) @SOIC8 S-29130A(FJ) @SOIC8 S-29131A(DP) S-29131A(FJ) @SOIC8 S-29220A(DP) S-29220A(DFJA) @SOIC8 S-29220A(FJ) @SOIC8 S-29221A(DP) S-29221A(FJ) @SOIC8 S-29230A(DP) S-29230A(DFJA) @SOIC8 S-29230A(FJ) @SOIC8 S-29231A(DP) S-29231A(FJ) @SOIC8 S-29330A(DP) S-29330A(DFJA) @SOIC8 S-29330A(FJ) @SOIC8 S-29331A(DP) S-29331A(FJ) @SOIC8 S-29L130A(DFE) @SOIC8 S-29L130A(FE) @SOIC8 S-29L130A(FS) @SSOP8 S-29L131A(DFE) @SOIC8 S-29L131A(FE) @SOIC8 S-29L131A(FS) @SSOP8 S-29L220A(DFE) @SOIC8 S-29L220A(FE) @SOIC8 S-29L220A(FS) @SSOP8 S-29L221A(DFE) @SOIC8 S-29L221A(FE) @SOIC8 S-29L221A(FS) @SSOP8 S-29330A(DFE) @SOIC8 S-29330A(FE) @SOIC8 S-29330A(FS) @SSOP8 S-29331A(DFE) @SOIC8 S-29331A(FE) @SOIC8 S-29331A(FS) @SSOP8 S-29U130A(DFE) @SOIC8 S-29U130A(FE) @SOIC8 S-29U130A(FS) @SSOP8 S-29U131A(DFE) @SOIC8 S-29U131A(FE) @SOIC8 S-29U131A(FS) @SSOP8 S-29U220A(DFE) @SOIC8 S-29U220A(FE) @SOIC8 S-29U220A(FS) @SSOP8 S-29U221A(DFE) @SOIC8 S-29U221A(FE) @SOIC8 S-29U221A(FS) @SSOP8 S-29U330A(DFE) @SOIC8 S-29U330A(FE) @SOIC8 S-29U330A(FS) @SSOP8 S-29U331A(DFE) @SOIC8 S-29U331A(FE) @SOIC8 S-29U331A(FS) @SSOP8 S-29Z330A(DFJA) @SOIC8 S-29Z330A(FS) @SSOP8 S-29Z430A(DFJA) @SOIC8 S-29Z430A(FS) @SSOP8 S-93A46A @SOIC8 S-93A56A @SOIC8 S-93A66A @SOIC8 S-93A86A @SOIC8 S-93C46A(DP) S-93C46A(DFJ) @SOIC8 S-93C46A(FJ) @SOIC8 S-93C46A(FT) @TSOP8 S-93C46B(DP) S-93C46B(DFJ) @SOIC8 S-93C46B(FJ) @SOIC8 S-93C46B(FT) @TSOP8 S-93C56A(DP) S-93C56A(DFJ) @SOIC8 S-93C56A(FJ) @SOIC8 S-93C56A(FT) @TSOP8 S-93C56B(DP) S-93C56B(DFJ) @SOIC8 S-93C56B(FJ) @SOIC8 S-93C56B(FT) @TSOP8 S-93C66A(DP) S-93C66A(DFJ) @SOIC8 S-93C66A(FJ) @SOIC8 S-93C66A(FT) @TSOP8 S-93C66B(DP) S-93C66B(DFJ) @SOIC8 S-93C66B(FJ) @SOIC8 S-93C66B(FT) @TSOP8 S-93C76A(DP) S-93C76A(DFJ) @SOIC8 S-93C76A(FJ) @SOIC8 S-93C76A(FT) @TSOP8 S-93C86A(DP) S-93C86A(DFJ) @SOIC8 S-93C86A(FJ) @SOIC8 S-93C86A(FT) @TSOP8 S-93C86B @SOIC8 S-93C86B @TSOP8 S-93L46A(D0I) @SOIC8 S-93L46A(R0I) @SOIC8 S-93L56A(D0I) @SOIC8 S-93L56A(R0I) @SOIC8 S-93L66A(D0I) @SOIC8 S-93L66A(R0I) @SOIC8 S-93L76A(D0I) @SOIC8 S-93L76A(R0I) @SOIC8 [ SGS-THOMSON ] 298 PCS ETC2716 @DIP24 ETC2732 @DIP24 M24128 M24128 @SOIC8 M24256 M24256 @SOIC8 M24512 M24512 @SOIC8 M24C01 M24C01 @SOIC8 M24C02 M24C02 @SOIC8 M24C04 M24C04 @SOIC8 M24C08 M24C08 @SOIC8 M24C16 M24C16 @SOIC8 M24C32 M24C32 @SOIC8 M24C32 @SSOP8 M24C64 M24C64 @SOIC8 M24C64 @SSOP8 M27128A @DIP28 M2716 @DIP24 M27256 @DIP28 M2732A @DIP24 M27512 @DIP28 M2764A @DIP28 M27C1001 @DIP32 M27C1001 @PLCC32 M27C1001 @TSOP32 M27C1024 @DIP40 M27C2001 @DIP32 M27C2001 @PLCC32 M27C2001 @TSOP32 M27C202 @DIP40 M27C256B @DIP28 M27C256B @PLCC32 M27C4001 @DIP32 M27C4001 @PLCC32 M27C4001 @TSOP32 M27C4002 @DIP40 M27C512 @DIP28 M27C512 @PLCC32 M27C64A @DIP28 M27C64A @PLCC32 M27C801 M27C801 @PLCC32 M27C801 @TSOP32 M27V101 @DIP32 M27V101 @PLCC32 M27V101 @TSOP32 M27V201 @DIP32 M27V201 @PLCC32 M27V201 @TSOP32 M27V401 @DIP32 M27V401 @PLCC32 M27V401 @TSOP32 M27V512 @DIP28 M27V512 @PLCC32 M27W201 @DIP32 M27W201 @PLCC32 M27W201 @TSOP32 M28010 M28010 @PLCC32 M28010 @TSOP32 M28C64 M28C64 @PLCC32 M28C64 @SOIC28 M28C64A M28C64A @PLCC32 M28C64A @SOIC28 M28C64-xxW M28C64-xxW @PLCC32 M28C64-xxW @SOIC28 M28F101 M28F101 @PLCC32 M28F101 @TSOP32 M28F201 M28F201 @PLCC32 M28F201 @TSOP32 M28W800BT @TSOP48 M28W800BB @TSOP48 M28W800CT @TSOP48 M28W800CB @TSOP48 M28W160BT @TSOP48 M28W160BB @TSOP48 M28W160CT @TSOP48 M28W160CB @TSOP48 M28W320BT @TSOP48 M28W320BB @TSOP48 M28W320CT @TSOP48 M28W320CB @TSOP48 M28W640CT @TSOP48 M28W640CB @TSOP48 M28W640ECT @TSOP48 M28W640ECB @TSOP48 M29DW323DB @TSOP48 M29DW323DT @TSOP48 M29DW324DB @TSOP48 M29DW324DT @TSOP48 M29DW640D @TSOP48 M29DW640F @TSOP48 M29DW641F @TSOP48 M29F002B M29F002B @PLCC32 M29F002B @TSOP32 M29F002BB M29F002BB @PLCC32 M29F002BB @TSOP32 M29F002BT M29F002BT @PLCC32 M29F002BT @TSOP32 M29F002BNT M29F002BNT @PLCC32 M29F002BNT @TSOP32 M29F002BNB M29F002BNB @PLCC32 M29F002BNB @TSOP32 M29F002NT M29F002NT @PLCC32 M29F002NT @TSOP32 M29F002T M29F002T @PLCC32 M29F002T @TSOP32 M29F010B M29F010B @PLCC32 M29F010B @TSOP32 M29F016B @TSOP40 M29F016D @TSOP40 M29F040B M29F040B @PLCC32 M29F040B @TSOP32 M29F080A @TSOP40 M29F080D @TSOP40 M29F100B @TSOP48 M29F100B @SOP44 M29F100BB @TSOP48 M29F100BB @SOP44 M29F100BT @TSOP48 M29F100BT @SOP44 M29F100T @TSOP48 M29F100T @SOP44 M29F102BB @VSOP40 M29F160BB @TSOP48 M29F160BT @TSOP48 M29F200B @TSOP48 M29F200B @SOP44 M29F200T @TSOP48 M29F200T @SOP44 M29F400B @TSOP48 M29F400B @SOP44 M29F400BB @TSOP48 M29F400BB @SOP44 M29F400BT @TSOP48 M29F400BT @SOP44 M29F400T @TSOP48 M29F400T @SOP44 M29F512B M29F512B @PLCC32 M29F512B @TSOP32 M29F800AB @TSOP48 M29F800AB @SOP44 M29F800AT @TSOP48 M29F800AT @SOP44 M29F800DB @TSOP48 M29F800DB @SOP44 M29F800DT @TSOP48 M29F800DT @SOP44 M29W002BB @TSOP40 M29W002BT @TSOP40 M29W004B @TSOP40 M29W004T @TSOP40 M29W008AB @TSOP40 M29W008AT @TSOP40 M29W008B @TSOP40 M29W008T @TSOP40 M29W010B @PLCC32 M29W010B @TSOP32 M29W017D @TSOP40 M29W040B @PLCC32 M29W040B @TSOP32 M29W102BB @VSOP40 M29W102BT @VSOP40 M29W200BB @TSOP48 M29W200BB @SOP44 M29W200BT @TSOP48 M29W200BT @SOP44 M29W400B @TSOP48 M29W400B @SOP44 M29W400BB @TSOP48 M29W400BB @SOP44 M29W400BT @TSOP48 M29W400BT @SOP44 M29W400T @TSOP48 M29W400T @SOP44 M29W512B @PLCC32 M29W512B @TSOP32 M29W800AB @TSOP48 M29W800AB @SOP44 M29W800AT @TSOP48 M29W800AT @SOP44 M29W800DB @TSOP48 M29W800DB @SOP44 M29W800DT @TSOP48 M29W800DT @SOP44 M29W160BB @TSOP48 M29W160BT @TSOP48 M29W160DB @TSOP48 M29W160DT @TSOP48 M29W160EB @TSOP48 M29W160ET @TSOP48 M29W320DB @TSOP48 M29W320DT @TSOP48 M29W320EB @TSOP48 M29W320ET @TSOP48 M29W640DB @TSOP48 M29W640DT @TSOP48 M29W640Gx @TSOP48 M29W641DH @TSOP48 M29W641DL @TSOP48 M29W641DU @TSOP48 M50FLW040A @PLCC32 M50FLW040A @TSOP32 M50FLW040A @TSOP40 M50FLW040B @PLCC32 M50FLW040B @TSOP32 M50FLW040B @TSOP40 M50FLW080A @PLCC32 M50FLW080A @TSOP32 M50FLW080A @TSOP40 M50FLW080B @PLCC32 M50FLW080B @TSOP32 M50FLW080B @TSOP40 M50FW002 @PLCC32 M50FW040 M50FW040 @PLCC32 M50FW040 @TSOP32 M50FW040 @TSOP40 M50FW080 M50FW080 @PLCC32 M50FW080 @TSOP32 M50FW080 @TSOP40 M50FW016 @TSOP40 M50LPW002 @PLCC32 M50LPW040 @PLCC32 M50LPW040 @TSOP40 M50LPW041 @PLCC32 M50LPW041 @TSOP40 M50LPW080 @PLCC32 M50LPW080 @TSOP40 M50LPW116 @TSOP40 M87C257 @DIP28 M87C257 @PLCC32 M93C06(x8) M93C06(x8) @SOIC8 M93C06(x16) M93C06(x16) @SOIC8 M93S46 M93S46 @SOIC8 M93S46 @TSOP8 ST24C01 ST24C01 @SOIC8 ST24C02 ST24C02 @SOIC8 ST24C04 ST24C04 @SOIC8 ST24C08 ST24C08 @SOIC8 ST24C16 ST24C16 @SOIC8 ST24W01 ST24W01 @SOIC8 ST24W02 ST24W02 @SOIC8 ST24W04 ST24W04 @SOIC8 ST24W08 ST24W08 @SOIC8 ST24W16 ST24W16 @SOIC8 ST27128A @DIP28 ST27256 @DIP28 ST2764A @DIP28 ST27C256 @DIP28 ST27C256 @PLCC32 ST93C06(x8) ST93C06(x8) @SOIC8 ST93C06(x16) ST93C06(x16) @SOIC8 ST93CS46 ST93CS46 @SOIC8 ST93CS46 @TSOP8 TS27C256 @DIP28 TS27C64A @DIP28 TS27C64A @PLCC32 [ SHARP ] 25 PCS LH28F004SC @TSOP40 LH28F008SA @TSOP40 LH28F008SC @TSOP40 LH28F016SC @TSOP40 LH28F160BJE-B @TSOP48 LH28F160BJE-T @TSOP48 LH28F320BJE-PB @TSOP48 LH28F320BJE-PT @TSOP48 LH28F400SU @TSOP48 LH28F400SU @SOP44 LH28F400BVE @TSOP48 LH28F400BGE-B @TSOP48 LH28F400BGE-T @TSOP48 LH28F400BGHE-B @TSOP48 LH28F400BGHE-T @TSOP48 LH28F400BVHE-B @TSOP48 LH28F400BVHE-T @TSOP48 LH28F640BFHE-PB @TSOP48 LH28F640BFHE-PT @TSOP48 LH28F800BGE-B @TSOP48 LH28F800BGE-T @TSOP48 LH28F800BGHE-B @TSOP48 LH28F800BGHE-T @TSOP48 LH28F800BVHE-BTL @TSOP48 LH28F800BVHE-TTL @TSOP48 [ SIEMENS ] 52 PCS SLA24C01 SLA24C01 @SOIC8 SLA24C02 SLA24C02 @SOIC8 SLA24C04 SLA24C04 @SOIC8 SLA24C08 SLA24C08 @SOIC8 SLA24C16 SLA24C16 @SOIC8 SLA24C32 SLA24C32 @SOIC8 SLA24C64 SLA24C64 @SOIC8 SLA25010 SLA25010 @SOIC8 SLA25020 SLA25020 @SOIC8 SLA25040 SLA25040 @SOIC8 SLA25080 SLA25080 @SOIC8 SLA25160 SLA25160 @SOIC8 SLA25320 SLA25320 @SOIC8 SLE24C01 SLE24C01 @SOIC8 SLE24C02 SLE24C02 @SOIC8 SLE24C04 SLE24C04 @SOIC8 SLE24C08 SLE24C08 @SOIC8 SLE24C16 SLE24C16 @SOIC8 SLE24C32 SLE24C32 @SOIC8 SLE24C64 SLE24C64 @SOIC8 SLE25010 SLE25010 @SOIC8 SLE25020 SLE25020 @SOIC8 SLE25040 SLE25040 @SOIC8 SLE25080 SLE25080 @SOIC8 SLE25160 SLE25160 @SOIC8 SLE25320 SLE25320 @SOIC8 [ SPANSION ] 858 PCS AM29BL162CB @SOP56 AM29BL802CB @SOP56 AM29DL161DB @TSOP48 AM29DL161DT @TSOP48 AM29DL162DB @TSOP48 AM29DL162DT @TSOP48 AM29DL163DB @TSOP48 AM29DL163DT @TSOP48 AM29DL164DB @TSOP48 AM29DL164DT @TSOP48 AM29DL322DB @TSOP48 AM29DL322DT @TSOP48 AM29DL322GB @TSOP48 AM29DL322GT @TSOP48 AM29DL323DB @TSOP48 AM29DL323DT @TSOP48 AM29DL323GB @TSOP48 AM29DL323GT @TSOP48 AM29DL324DB @TSOP48 AM29DL324DT @TSOP48 AM29DL324GB @TSOP48 AM29DL324GT @TSOP48 AM29DL400BB @TSOP48 AM29DL400BB @SOP44 AM29DL400BT @TSOP48 AM29DL400BT @SOP44 AM29DL800BB @TSOP48 AM29DL800BB @SOP44 AM29DL800BT @TSOP48 AM29DL800BT @SOP44 AM29F002B @DIP32 AM29F002B @PLCC32 AM29F002B @TSOP32 AM29F002BB @DIP32 AM29F002BB @PLCC32 AM29F002BB @TSOP32 AM29F002BT @DIP32 AM29F002BT @PLCC32 AM29F002BT @TSOP32 AM29F002NB @DIP32 AM29F002NB @PLCC32 AM29F002NB @TSOP32 AM29F002NBB @DIP32 AM29F002NBB @PLCC32 AM29F002NBB @TSOP32 AM29F002NBT @DIP32 AM29F002NBT @PLCC32 AM29F002NBT @TSOP32 AM29F002NT @DIP32 AM29F002NT @PLCC32 AM29F002NT @TSOP32 AM29F002T @DIP32 AM29F002T @PLCC32 AM29F002T @TSOP32 AM29F010 @DIP32 AM29F010 @PLCC32 AM29F010 @TSOP32 AM29F010B @DIP32 AM29F010B @PLCC32 AM29F010B @TSOP32 AM29F016D @TSOP40 AM29F040 @DIP32 AM29F040 @PLCC32 AM29F040 @TSOP32 AM29F040B @DIP2 AM29F040B @PLCC32 AM29F040B @TSOP32 AM29F080 @TSOP40 AM29F080B @TSOP40 AM29F100AB @TSOP48 AM29F100AB @SOP44 AM29F100AT @TSOP48 AM29F100AT @SOP44 AM29F100B @TSOP48 AM29F100B @SOP44 AM29F100T @TSOP48 AM29F100T @SOP44 AM29F160DB @TSOP48 AM29F160DT @TSOP48 AM29F200AB @TSOP48 AM29F200AB @SOP44 AM29F200AT @TSOP48 AM29F200AT @SOP44 AM29F200BB @TSOP48 AM29F200BB @SOP44 AM29F200BT @TSOP48 AM29F200BT @SOP44 AM29F400AB @TSOP48 AM29F400AB @SOP44 AM29F400AT @TSOP48 AM29F400AT @SOP44 AM29F400BB @TSOP48 AM29F400BB @SOP44 AM29F400BT @TSOP48 AM29F400BT @SOP44 AM29F800AB @TSOP48 AM29F800AB @SOP44 AM29F800AT @TSOP48 AM29F800AT @SOP44 AM29F800B @TSOP48 AM29F800B @SOP44 AM29F800BB @TSOP48 AM29F800BB @SOP44 AM29F800BT @TSOP48 AM29F800BT @SOP44 AM29F800T @TSOP48 AM29F800T @SOP44 AM29LV001B @PLCC32 AM29LV001B @TSOP32 AM29LV001BB @PLCC32 AM29LV001BB @TSOP32 AM29LV001BT @PLCC32 AM29LV001BT @TSOP32 AM29LV001T @PLCC32 AM29LV001T @TSOP32 AM29LV002B @TSOP40 AM29LV002T @TSOP40 AM29LV004B @TSOP40 AM29LV004BB @TSOP40 AM29LV004BT @TSOP40 AM29LV004T @TSOP40 AM29LV008B @TSOP40 AM29LV008BB @TSOP40 AM29LV008BT @TSOP40 AM29LV008T @TSOP40 AM29LV010B @PLCC32 AM29LV010B @TSOP32 AM29LV017 @TSOP40 AM29LV020B @PLCC32 AM29LV020B @TSOP32 AM29LV033C @TSOP40 AM29LV033M @TSOP40 AM29LV040B @PLCC32 AM29LV040B @TSOP32 AM29LV081 @TSOP40 AM29LV160BB @TSOP48 AM29LV160BT @TSOP48 AM29LV160DB @TSOP48 AM29LV160DT @TSOP48 AM29LV200B @TSOP48 AM29LV200B @SOP44 AM29LV200BB @TSOP48 AM29LV200BB @SOP44 AM29LV200BT @TSOP48 AM29LV200BT @SOP44 AM29LV200T @SOP44 AM29LV200T @TSOP48 AM29LV320DB @TSOP48 AM29LV320DT @TSOP48 AM29LV320MB @TSOP48 AM29LV320MT @TSOP48 AM29LV400B @TSOP48 AM29LV400B @SOP44 AM29LV400BB @TSOP48 AM29LV400BB @SOP44 AM29LV400BT @TSOP48 AM29LV400BT @SOP44 AM29LV400T @TSOP48 AM29LV400T @SOP44 AM29LV641D @TSOP48 AM29LV800B @TSOP48 AM29LV800B @SOP44 AM29LV800BB @TSOP48 AM29LV800BB @SOP44 AM29LV800DB @TSOP48 AM29LV800DB @SOP44 AM29LV800BT @TSOP48 AM29LV800BT @SOP44 AM29LV800DT @TSOP48 AM29LV800DT @SOP44 AM29LV800T @TSOP48 AM29LV800T @SOP44 MBM29DL161BD @TSOP48 MBM29DL161BE @TSOP48 MBM29DL161TD @TSOP48 MBM29DL161TE @TSOP48 MBM29DL162BD @TSOP48 MBM29DL162BE @TSOP48 MBM29DL162TD @TSOP48 MBM29DL162TE @TSOP48 MBM29DL163BD @TSOP48 MBM29DL163BE @TSOP48 MBM29DL163TD @TSOP48 MBM29DL163TE @TSOP48 MBM29DL164BD @TSOP48 MBM29DL164BE @TSOP48 MBM29DL164TD @TSOP48 MBM29DL164TE @TSOP48 MBM29DL321BD @TSOP48 MBM29DL321BE @TSOP48 MBM29DL321TD @TSOP48 MBM29DL321TE @TSOP48 MBM29DL322BD @TSOP48 MBM29DL322BE @TSOP48 MBM29DL322TD @TSOP48 MBM29DL322TE @TSOP48 MBM29DL323BD @TSOP48 MBM29DL323BE @TSOP48 MBM29DL323BF @TSOP48 MBM29DL323TD @TSOP48 MBM29DL323TE @TSOP48 MBM29DL323TF @TSOP48 MBM29DL324BD @TSOP48 MBM29DL324BE @TSOP48 MBM29DL324TD @TSOP48 MBM29DL324TE @TSOP48 MBM29DL32BF @TSOP48 MBM29DL32TF @TSOP48 MBM29DL34BF @TSOP48 MBM29DL34TF @TSOP48 MBM29DL400BB @TSOP48 MBM29DL400BB @SOP44 MBM29DL400BC @TSOP48 MBM29DL400BC @SOP44 MBM29DL400BT @TSOP48 MBM29DL400BT @SOP44 MBM29DL400TC @TSOP48 MBM29DL400TC @SOP44 MBM29DL800B @TSOP48 MBM29DL800B @SOP44 MBM29DL800BA @TSOP48 MBM29DL800BA @SOP44 MBM29DL800BB @TSOP48 MBM29DL800BB @SOP44 MBM29DL800BT @TSOP48 MBM29DL800BT @SOP44 MBM29DL800T @TSOP48 MBM29DL800T @SOP44 MBM29DL800TA @TSOP48 MBM29DL800TA @SOP44 MBM29DL640E @TSOP48 MBM29DL640D @TSOP48 MBM29F002B MBM29F002B @PLCC32 MBM29F002B @TSOP32 MBM29F002T MBM29F002T @PLCC32 MBM29F002T @TSOP32 MBM29F002SB @TSOP40 MBM29F002ST @TSOP40 MBM29F033C @TSOP40 MBM29F040 MBM29F040 @PLCC32 MBM29F040 @TSOP32 MBM29F040A @PLCC32 MBM29F040A @TSOP32 MBM29F040C @PLCC32 MBM29F040C @TSOP32 MBM29F160TE @TSOP48 MBM29F160BE @TSOP48 MBM29F200AB @TSOP48 MBM29F200AB @SOP44 MBM29F200AT @TSOP48 MBM29F200AT @SOP44 MBM29F200B @TSOP48 MBM29F200B @SOP44 MBM29F200BC @TSOP48 MBM29F200BC @SOP44 MBM29F200T @TSOP48 MBM29F200T @SOP44 MBM29F200TC @TSOP48 MBM29F200TC @SOP44 MBM29F400AB @TSOP48 MBM29F400AB @SOP44 MBM29F400AT @TSOP48 MBM29F400AT @SOP44 MBM29F400B @TSOP48 MBM29F400B @SOP44 MBM29F400BC @TSOP48 MBM29F400BC @SOP44 MBM29F400T @TSOP48 MBM29F400T @SOP44 MBM29F400TC @TSOP48 MBM29F400TC @SOP44 MBM29F800B @TSOP48 MBM29F800B @SOP44 MBM29F800BA @TSOP48 MBM29F800BA @SOP44 MBM29F800BB @TSOP48 MBM29F800BB @SOP44 MBM29F800BT @TSOP48 MBM29F800BT @SOP44 MBM29F800T @TSOP48 MBM29F800T @SOP44 MBM29F800TA @TSOP48 MBM29F800TA @SOP44 MBM29LV001B @PLCC32 MBM29LV001B @TSOP32 MBM29LV001BB @PLCC32 MBM29LV001BB @TSOP32 MBM29LV001BC @PLCC32 MBM29LV001BC @TSOP32 MBM29LV001BT @PLCC32 MBM29LV001BT @TSOP32 MBM29LV001T @PLCC32 MBM29LV001T @TSOP32 MBM29LV001TC @PLCC32 MBM29LV001TC @TSOP32 MBM29LV002B @TSOP40 MBM29LV002BC @TSOP40 MBM29LV002T @TSOP40 MBM29LV002TC @TSOP40 MBM29LV004B @TSOP40 MBM29LV004BB @TSOP40 MBM29LV004BC @TSOP40 MBM29LV004BT @TSOP40 MBM29LV004T @TSOP40 MBM29LV004TC @TSOP40 MBM29LV008B @TSOP40 MBM29LV008BA @TSOP40 MBM29LV008BB @TSOP40 MBM29LV008BT @TSOP40 MBM29LV008T @TSOP40 MBM29LV008TA @TSOP40 MBM29LV016T @TSOP40 MBM29LV016B @TSOP40 MBM29LV017 @TSOP40 MBM29LV017B @TSOP40 MBM29LV017E @TSOP40 MBM29LV160B @TSOP48 MBM29LV160BE @TSOP48 MBM29LV160BM @TSOP48 MBM29LV160T @TSOP48 MBM29LV160TE @TSOP48 MBM29LV160TM @TSOP48 MBM29LV200B @TSOP48 MBM29LV200B @SOP44 MBM29LV200BB @TSOP48 MBM29LV200BB @SOP44 MBM29LV200BC @TSOP48 MBM29LV200BC @SOP44 MBM29LV200BT @TSOP48 MBM29LV200BT @SOP44 MBM29LV200T @TSOP48 MBM29LV200T @SOP44 MBM29LV200TC @TSOP48 MBM29LV200TC @SOP44 MBM29LV320T @TSOP48 MBM29LV320B @TSOP48 MBM29LV400B @TSOP48 MBM29LV400B @SOP44 MBM29LV400BB @TSOP48 MBM29LV400BB @SOP44 MBM29LV400BC @TSOP48 MBM29LV400BC @SOP44 MBM29LV400BT @TSOP48 MBM29LV400BT @SOP44 MBM29LV400T @TSOP48 MBM29LV400T @SOP44 MBM29LV400TC @TSOP48 MBM29LV400TC @SOP44 MBM29LV650UE @TSOP48 MBM29LV651UE @TSOP48 MBM29LV800B @TSOP48 MBM29LV800B @SOP44 MBM29LV800BA @TSOP48 MBM29LV800BA @SOP44 MBM29LV800BB @TSOP48 MBM29LV800BB @SOP44 MBM29LV800BE @TSOP48 MBM29LV800BE @SOP44 MBM29LV800T @TSOP48 MBM29LV800T @SOP44 MBM29LV800TA @TSOP48 MBM29LV800TA @SOP44 MBM29LV800TE @TSOP48 MBM29LV800TE @SOP44 S25FL001D @SOIC8 S25FL001D @WSON8 S25FL002D @SOIC8 S25FL002D @WSON8 S25FL004A @SOIC8 S25FL004A @WSON8 S25FL004D @SOIC8 S25FL004D @WSON8 S25FL004K @SOIC8 S25FL004K @WSON8 S25FL008A @SOIC8 S25FL008A @WSON8 S25FL008D @SOIC8 S25FL008D @WSON8 S25FL008K @SOIC8 S25FL008K @WSON8 S25FL016A @SOIC8 S25FL016A @SOIC16 S25FL016K @SOIC8 S25FL016K @SOIC16 S25FL032A @SOIC8 S25FL032A @SOIC16 S25FL032K @SOIC8 S25FL032K @SOIC16 S25FL032P @SOIC8 S25FL032P @SOIC16 S25FL040A @SOIC8 S25FL040A @WSON8 S25FL040A(BOT) @SOIC8 S25FL040A(BOT) @WSON8 S25FL040A(TOP) @SOIC8 S25FL040A(TOP) @WSON8 S25FL064A @SOIC8 S25FL064A @SOIC16 S25FL064K @SOIC8 S25FL064K @SOIC16 S25FL064P @SOIC8 S25FL064P @SOIC16 S25FL128K @SOIC8 S25FL128K @SOIC16 S25FL128P(64KB) @SOIC8 S25FL128P(64KB) @SOIC16 S25FL128P(256KB) @SOIC8 S25FL128P(256KB) @SOIC16 S25FL128S(256KB) @SOIC8 S25FL128S(256KB) @SOIC16 S25FL128S(512KB) @SOIC8 S25FL128S(512KB) @SOIC16 S29AL004D55MAI01 @SOP44 S29AL004D55MAI02 @SOP44 S29AL004D55MANR1 @SOP44 S29AL004D55MANR2 @SOP44 S29AL004D55MFI01 @SOP44 S29AL004D55MFI02 @SOP44 S29AL004D55MFNR1 @SOP44 S29AL004D55MFNR2 @SOP44 S29AL004D55TAI01 @TSOP48 S29AL004D55TAI02 @TSOP48 S29AL004D55TANR1 @TSOP48 S29AL004D55TANR2 @TSOP48 S29AL004D55TFI01 @TSOP48 S29AL004D55TFI02 @TSOP48 S29AL004D55TFNR1 @TSOP48 S29AL004D55TFNR2 @TSOP48 S29AL004D70MAI01 @SOP44 S29AL004D70MAI02 @SOP44 S29AL004D70MAN01 @SOP44 S29AL004D70MAN02 @SOP44 S29AL004D70MFI01 @SOP44 S29AL004D70MFI02 @SOP44 S29AL004D70MFN01 @SOP44 S29AL004D70MFN02 @SOP44 S29AL004D70TAI01 @TSOP48 S29AL004D70TAI02 @TSOP48 S29AL004D70TAN01 @TSOP48 S29AL004D70TAN02 @TSOP48 S29AL004D70TFI01 @TSOP48 S29AL004D70TFI02 @TSOP48 S29AL004D70TFN01 @TSOP48 S29AL004D70TFN02 @TSOP48 S29AL004D90MAI01 @SOP44 S29AL004D90MAI02 @SOP44 S29AL004D90MAN01 @SOP44 S29AL004D90MAN02 @SOP44 S29AL004D90MFI01 @SOP44 S29AL004D90MFI02 @SOP44 S29AL004D90MFN01 @SOP44 S29AL004D90MFN02 @SOP44 S29AL004D90TAI01 @TSOP48 S29AL004D90TAI02 @TSOP48 S29AL004D90TAN01 @TSOP48 S29AL004D90TAN02 @TSOP48 S29AL004D90TFI01 @TSOP48 S29AL004D90TFI02 @TSOP48 S29AL004D90TFN01 @TSOP48 S29AL004D90TFN02 @TSOP48 S29AL008D55MAIR1 @SOP44 S29AL008D55MAIR2 @SOP44 S29AL008D55MFIR1 @SOP44 S29AL008D55MFIR2 @SOP44 S29AL008D55TAIR1 @TSOP48 S29AL008D55TAIR2 @TSOP48 S29AL008D55TFIR1 @TSOP48 S29AL008D55TFIR2 @TSOP48 S29AL008D60MAI01 @SOP44 S29AL008D60MAI02 @SOP44 S29AL008D60MAN01 @SOP44 S29AL008D60MAN02 @SOP44 S29AL008D60MFI01 @SOP44 S29AL008D60MFI02 @SOP44 S29AL008D60MFN01 @SOP44 S29AL008D60MFN02 @SOP44 S29AL008D60TAI01 @TSOP48 S29AL008D60TAI02 @TSOP48 S29AL008D60TAN01 @TSOP48 S29AL008D60TAN02 @TSOP48 S29AL008D60TFI01 @TSOP48 S29AL008D60TFI02 @TSOP48 S29AL008D60TFN01 @TSOP48 S29AL008D60TFN02 @TSOP48 S29AL008D70MAI01 @SOP44 S29AL008D70MAI02 @SOP44 S29AL008D70MAN01 @SOP44 S29AL008D70MAN02 @SOP44 S29AL008D70MFI01 @SOP44 S29AL008D70MFI02 @SOP44 S29AL008D70MFN01 @SOP44 S29AL008D70MFN02 @SOP44 S29AL008D70TAI01 @TSOP48 S29AL008D70TAI02 @TSOP48 S29AL008D70TAN01 @TSOP48 S29AL008D70TAN02 @TSOP48 S29AL008D70TFI01 @TSOP48 S29AL008D70TFI02 @TSOP48 S29AL008D70TFN01 @TSOP48 S29AL008D70TFN02 @TSOP48 S29AL008D90MAI01 @SOP44 S29AL008D90MAI02 @SOP44 S29AL008D90MAN01 @SOP44 S29AL008D90MAN02 @SOP44 S29AL008D90MFI01 @SOP44 S29AL008D90MFI02 @SOP44 S29AL008D90MFN01 @SOP44 S29AL008D90MFN02 @SOP44 S29AL008D90TAI01 @TSOP48 S29AL008D90TAI02 @TSOP48 S29AL008D90TAN01 @TSOP48 S29AL008D90TAN02 @TSOP48 S29AL008D90TFI01 @TSOP48 S29AL008D90TFI02 @TSOP48 S29AL008D90TFN01 @TSOP48 S29AL008D90TFN02 @TSOP48 S29AL008J55TFIR1 @TSOP48 S29AL008J55TFIR2 @TSOP48 S29AL008J55TFNR1 @TSOP48 S29AL008J55TFNR2 @TSOP48 S29AL008J70TFI01 @TSOP48 S29AL008J70TFI02 @TSOP48 S29AL008J70TFI03 @TSOP48 S29AL008J70TFI04 @TSOP48 S29AL008J70TFN01 @TSOP48 S29AL008J70TFN02 @TSOP48 S29AL016D70TAI01 @TSOP48 S29AL016D70TAI02 @TSOP48 S29AL016D70TAN01 @TSOP48 S29AL016D70TAN02 @TSOP48 S29AL016D70TFI01 @TSOP48 S29AL016D70TFI02 @TSOP48 S29AL016D70TFN01 @TSOP48 S29AL016D70TFN02 @TSOP48 S29AL016D90TAI01 @TSOP48 S29AL016D90TAI02 @TSOP48 S29AL016D90TAN01 @TSOP48 S29AL016D90TAN02 @TSOP48 S29AL016D90TFI01 @TSOP48 S29AL016D90TFI02 @TSOP48 S29AL016D90TFN01 @TSOP48 S29AL016D90TFN02 @TSOP48 S29AL016J55TFIR1 @TSOP48 S29AL016J55TFIR2 @TSOP48 S29AL016J55TFNR1 @TSOP48 S29AL016J55TFNR2 @TSOP48 S29AL016J70TFI01 @TSOP48 S29AL016J70TFI02 @TSOP48 S29AL016J70TFI03 @TSOP48 S29AL016J70TFI04 @TSOP48 S29AL016J70TFN01 @TSOP48 S29AL016J70TFN02 @TSOP48 S29AL016M10TAI01 @TSOP48 S29AL016M10TAI02 @TSOP48 S29AL016M10TAIR1 @TSOP48 S29AL016M10TAIR2 @TSOP48 S29AL016M10TFI01 @TSOP48 S29AL016M10TFI02 @TSOP48 S29AL016M10TFIR1 @TSOP48 S29AL016M10TFIR2 @TSOP48 S29AL016M90TAI01 @TSOP48 S29AL016M90TAI02 @TSOP48 S29AL016M90TAIR1 @TSOP48 S29AL016M90TAIR2 @TSOP48 S29AL016M90TFI01 @TSOP48 S29AL016M90TFI02 @TSOP48 S29AL016M90TFIR1 @TSOP48 S29AL016M90TFIR2 @TSOP48 S29AL032D70TAI00 @TSOP40 S29AL032D70TAI03 @TSOP48 S29AL032D70TAI04 @TSOP48 S29AL032D70TFI00 @TSOP40 S29AL032D70TFI03 @TSOP48 S29AL032D70TFI04 @TSOP48 S29AL032D90TAI00 @TSOP40 S29AL032D90TAI03 @TSOP48 S29AL032D90TAI04 @TSOP48 S29AL032D90TAN00 @TSOP40 S29AL032D90TAN03 @TSOP48 S29AL032D90TAN04 @TSOP48 S29AL032D90TFI00 @TSOP40 S29AL032D90TFI03 @TSOP48 S29AL032D90TFI04 @TSOP48 S29AL032D90TFN00 @TSOP40 S29AL032D90TFN03 @TSOP48 S29AL032D90TFN04 @TSOP48 S29GL016A10TAI01 @TSOP48 S29GL016A10TAI02 @TSOP48 S29GL016A10TAIR1 @TSOP48 S29GL016A10TAIR2 @TSOP48 S29GL016A10TFI01 @TSOP48 S29GL016A10TFI02 @TSOP48 S29GL016A10TFIR1 @TSOP48 S29GL016A10TFIR2 @TSOP48 S29GL016A90TAIR1 @TSOP48 S29GL016A90TAIR2 @TSOP48 S29GL016A90TFIR1 @TSOP48 S29GL016A90TFIR2 @TSOP48 S29GL032A10TAIR3 @TSOP48 S29GL032A10TAIR4 @TSOP48 S29GL032A10TFIR3 @TSOP48 S29GL032A10TFIR4 @TSOP48 S29GL032A11TAIR3 @TSOP48 S29GL032A11TAIR4 @TSOP48 S29GL032A11TFIR3 @TSOP48 S29GL032A11TFIR4 @TSOP48 S29GL032A90TAIR3 @TSOP48 S29GL032A90TAIR4 @TSOP48 S29GL032A90TFIR3 @TSOP48 S29GL032A90TFIR4 @TSOP48 S29GL032M10TAIR0 @TSOP40 S29GL032M10TAIR3 @TSOP48 S29GL032M10TAIR4 @TSOP48 S29GL032M10TBIR3 @TSOP48 S29GL032M10TBIR4 @TSOP48 S29GL032M10TCIR3 @TSOP48 S29GL032M10TCIR4 @TSOP48 S29GL032M10TFIR0 @TSOP40 S29GL032M10TFIR3 @TSOP48 S29GL032M10TFIR4 @TSOP48 S29GL032M11TAIR0 @TSOP40 S29GL032M11TAIR3 @TSOP48 S29GL032M11TAIR4 @TSOP48 S29GL032M11TBIR3 @TSOP48 S29GL032M11TBIR4 @TSOP48 S29GL032M11TCIR3 @TSOP48 S29GL032M11TCIR4 @TSOP48 S29GL032M11TFIR0 @TSOP40 S29GL032M11TFIR3 @TSOP48 S29GL032M11TFIR4 @TSOP48 S29GL032M90TACR0 @TSOP40 S29GL032M90TACR3 @TSOP48 S29GL032M90TACR4 @TSOP48 S29GL032M90TAIR0 @TSOP40 S29GL032M90TAIR3 @TSOP48 S29GL032M90TAIR4 @TSOP48 S29GL032M90TBIR3 @TSOP48 S29GL032M90TBIR4 @TSOP48 S29GL032M90TCIR3 @TSOP48 S29GL032M90TCIR4 @TSOP48 S29GL032M90TFCR0 @TSOP40 S29GL032M90TFCR3 @TSOP48 S29GL032M90TFCR4 @TSOP48 S29GL032M90TFIR0 @TSOP40 S29GL032M90TFIR3 @TSOP48 S29GL032M90TFIR4 @TSOP48 S29GL032N70TAI03 @TSOP48 S29GL032N70TAI04 @TSOP48 S29GL032N70TAIR3 @TSOP48 S29GL032N70TAIR4 @TSOP48 S29GL032N70TFI03 @TSOP48 S29GL032N70TFI04 @TSOP48 S29GL032N70TFIR3 @TSOP48 S29GL032N70TFIR4 @TSOP48 S29GL032N90TAI03 @TSOP48 S29GL032N90TAI04 @TSOP48 S29GL032N90TAIR3 @TSOP48 S29GL032N90TAIR4 @TSOP48 S29GL032N90TFI03 @TSOP48 S29GL032N90TFI04 @TSOP48 S29GL032N90TFIR3 @TSOP48 S29GL032N90TFIR4 @TSOP48 S29GL064A10TAIR3 @TSOP48 S29GL064A10TAIR4 @TSOP48 S29GL064A10TAIR6 @TSOP48 S29GL064A10TAIR7 @TSOP48 S29GL064A10TAIR8 @TSOP48 S29GL064A10TAIR9 @TSOP48 S29GL064A10TFIR3 @TSOP48 S29GL064A10TFIR4 @TSOP48 S29GL064A10TFIR6 @TSOP48 S29GL064A10TFIR7 @TSOP48 S29GL064A10TFIR8 @TSOP48 S29GL064A10TFIR9 @TSOP48 S29GL064A11TAIR3 @TSOP48 S29GL064A11TAIR4 @TSOP48 S29GL064A11TAIR6 @TSOP48 S29GL064A11TAIR7 @TSOP48 S29GL064A11TAIR8 @TSOP48 S29GL064A11TAIR9 @TSOP48 S29GL064A11TFIR3 @TSOP48 S29GL064A11TFIR4 @TSOP48 S29GL064A11TFIR6 @TSOP48 S29GL064A11TFIR7 @TSOP48 S29GL064A11TFIR8 @TSOP48 S29GL064A11TFIR9 @TSOP48 S29GL064A90TAIR3 @TSOP48 S29GL064A90TAIR4 @TSOP48 S29GL064A90TAIR6 @TSOP48 S29GL064A90TAIR7 @TSOP48 S29GL064A90TAIR8 @TSOP48 S29GL064A90TAIR9 @TSOP48 S29GL064A90TFIR3 @TSOP48 S29GL064A90TFIR4 @TSOP48 S29GL064A90TFIR6 @TSOP48 S29GL064A90TFIR7 @TSOP48 S29GL064A90TFIR8 @TSOP48 S29GL064A90TFIR9 @TSOP48 S29GL064M10TAIR0 @TSOP48 S29GL064M10TAIR3 @TSOP48 S29GL064M10TAIR4 @TSOP48 S29GL064M10TAIR6 @TSOP48 S29GL064M10TAIR7 @TSOP48 S29GL064M10TBIR2 @TSOP48 S29GL064M10TBIR7 @TSOP48 S29GL064M10TCIR2 @TSOP48 S29GL064M10TCIR7 @TSOP48 S29GL064M10TFIR0 @TSOP48 S29GL064M10TFIR3 @TSOP48 S29GL064M10TFIR4 @TSOP48 S29GL064M10TFIR6 @TSOP48 S29GL064M10TFIR7 @TSOP48 S29GL064M11TAIR0 @TSOP48 S29GL064M11TAIR3 @TSOP48 S29GL064M11TAIR4 @TSOP48 S29GL064M11TAIR6 @TSOP48 S29GL064M11TAIR7 @TSOP48 S29GL064M11TBIR2 @TSOP48 S29GL064M11TBIR7 @TSOP48 S29GL064M11TCIR2 @TSOP48 S29GL064M11TCIR7 @TSOP48 S29GL064M11TFIR0 @TSOP48 S29GL064M11TFIR3 @TSOP48 S29GL064M11TFIR4 @TSOP48 S29GL064M11TFIR6 @TSOP48 S29GL064M11TFIR7 @TSOP48 S29GL064M90TAIR0 @TSOP48 S29GL064M90TAIR3 @TSOP48 S29GL064M90TAIR4 @TSOP48 S29GL064M90TAIR6 @TSOP48 S29GL064M90TAIR7 @TSOP48 S29GL064M90TBIR2 @TSOP48 S29GL064M90TBIR7 @TSOP48 S29GL064M90TCIR2 @TSOP48 S29GL064M90TCIR7 @TSOP48 S29GL064M90TFIR0 @TSOP48 S29GL064M90TFIR3 @TSOP48 S29GL064M90TFIR4 @TSOP48 S29GL064M90TFIR6 @TSOP48 S29GL064M90TFIR7 @TSOP48 S29GL064N11TAIV6 @TSOP48 S29GL064N11TAIV7 @TSOP48 S29GL064N11TFIV6 @TSOP48 S29GL064N11TFIV7 @TSOP48 S29GL064N70TAI03 @TSOP48 S29GL064N70TAI04 @TSOP48 S29GL064N70TAI06 @TSOP48 S29GL064N70TAI07 @TSOP48 S29GL064N70TAIR3 @TSOP48 S29GL064N70TAIR4 @TSOP48 S29GL064N70TAIR6 @TSOP48 S29GL064N70TAIR7 @TSOP48 S29GL064N70TFI03 @TSOP48 S29GL064N70TFI04 @TSOP48 S29GL064N70TFI06 @TSOP48 S29GL064N70TFI07 @TSOP48 S29GL064N70TFIR3 @TSOP48 S29GL064N70TFIR4 @TSOP48 S29GL064N70TFIR6 @TSOP48 S29GL064N70TFIR7 @TSOP48 S29GL064N90TAI03 @TSOP48 S29GL064N90TAI04 @TSOP48 S29GL064N90TAI06 @TSOP48 S29GL064N90TAI07 @TSOP48 S29GL064N90TAIR3 @TSOP48 S29GL064N90TAIR4 @TSOP48 S29GL064N90TAIR6 @TSOP48 S29GL064N90TAIR7 @TSOP48 S29GL064N90TAIV6 @TSOP48 S29GL064N90TAIV7 @TSOP48 S29GL064N90TFI03 @TSOP48 S29GL064N90TFI04 @TSOP48 S29GL064N90TFI06 @TSOP48 S29GL064N90TFI07 @TSOP48 S29GL064N90TFIR3 @TSOP48 S29GL064N90TFIR4 @TSOP48 S29GL064N90TFIR6 @TSOP48 S29GL064N90TFIR7 @TSOP48 S29GL064N90TFIV6 @TSOP48 S29GL064N90TFIV7 @TSOP48 S29JL032H60TAI01 @TSOP48 S29JL032H60TAI02 @TSOP48 S29JL032H60TAI21 @TSOP48 S29JL032H60TAI22 @TSOP48 S29JL032H60TAI31 @TSOP48 S29JL032H60TAI32 @TSOP48 S29JL032H60TAI41 @TSOP48 S29JL032H60TAI42 @TSOP48 S29JL032H60TFI01 @TSOP48 S29JL032H60TFI02 @TSOP48 S29JL032H60TFI21 @TSOP48 S29JL032H60TFI22 @TSOP48 S29JL032H60TFI31 @TSOP48 S29JL032H60TFI32 @TSOP48 S29JL032H60TFI41 @TSOP48 S29JL032H60TFI42 @TSOP48 S29JL032H70TAI01 @TSOP48 S29JL032H70TAI02 @TSOP48 S29JL032H70TAI21 @TSOP48 S29JL032H70TAI22 @TSOP48 S29JL032H70TAI31 @TSOP48 S29JL032H70TAI32 @TSOP48 S29JL032H70TAI41 @TSOP48 S29JL032H70TAI42 @TSOP48 S29JL032H70TFI01 @TSOP48 S29JL032H70TFI02 @TSOP48 S29JL032H70TFI21 @TSOP48 S29JL032H70TFI22 @TSOP48 S29JL032H70TFI31 @TSOP48 S29JL032H70TFI32 @TSOP48 S29JL032H70TFI41 @TSOP48 S29JL032H70TFI42 @TSOP48 S29JL032H90TAI01 @TSOP48 S29JL032H90TAI02 @TSOP48 S29JL032H90TAI21 @TSOP48 S29JL032H90TAI22 @TSOP48 S29JL032H90TAI31 @TSOP48 S29JL032H90TAI32 @TSOP48 S29JL032H90TAI41 @TSOP48 S29JL032H90TAI42 @TSOP48 S29JL032H90TFI01 @TSOP48 S29JL032H90TFI02 @TSOP48 S29JL032H90TFI21 @TSOP48 S29JL032H90TFI22 @TSOP48 S29JL032H90TFI31 @TSOP48 S29JL032H90TFI32 @TSOP48 S29JL032H90TFI41 @TSOP48 S29JL032H90TFI42 @TSOP48 S29JL032J60TFI01 @TSOP48 S29JL032J60TFI02 @TSOP48 S29JL032J60TFI21 @TSOP48 S29JL032J60TFI22 @TSOP48 S29JL032J60TFI31 @TSOP48 S29JL032J60TFI32 @TSOP48 S29JL032J60TFI41 @TSOP48 S29JL032J60TFI42 @TSOP48 S29JL032J70TFI01 @TSOP48 S29JL032J70TFI02 @TSOP48 S29JL032J70TFI21 @TSOP48 S29JL032J70TFI22 @TSOP48 S29JL032J70TFI31 @TSOP48 S29JL032J70TFI32 @TSOP48 S29JL032J70TFI41 @TSOP48 S29JL032J70TFI42 @TSOP48 S29JL064H55TAI00 @TSOP48 S29JL064H55TFI00 @TSOP48 S29JL064H60TAI00 @TSOP48 S29JL064H60TFI00 @TSOP48 S29JL064H70TAI00 @TSOP48 S29JL064H70TFI00 @TSOP48 S29JL064H90TAI00 @TSOP48 S29JL064H90TFI00 @TSOP48 S29JL064J55TFI00 @TSOP48 S29JL064J60TFI00 @TSOP48 S29JL064J70TFI00 @TSOP48 [ SST ] 320 PCS SST25LF020A SST25LF020A @SOIC8 SST25LF020A @WSON8 SST25LF040A SST25LF040A @SOIC8 SST25LF040A @WSON8 SST25LF080A SST25LF080A @SOIC8 SST25LF080A @WSON8 SST25VF010 SST25VF010 @SOIC8 SST25VF010 @WSON8 SST25VF010A SST25VF010A @SOIC8 SST25VF010A @WSON8 SST25VF016B SST25VF016B @SOIC8 SST25VF016B @WSON8 SST25VF020 SST25VF020 @SOIC8 SST25VF020 @WSON8 SST25VF020A SST25VF020A @SOIC8 SST25VF020A @WSON8 SST25VF020B SST25VF020B @SOIC8 SST25VF020B @WSON8 SST25VF032B SST25VF032B @SOIC8 SST25VF032B @WSON8 SST25VF040 SST25VF040 @SOIC8 SST25VF040 @WSON8 SST25VF040A SST25VF040A @SOIC8 SST25VF040A @WSON8 SST25VF040B SST25VF040B @SOIC8 SST25VF040B @WSON8 SST25VF080B SST25VF080B @SOIC8 SST25VF080B @WSON8 SST25VF512 SST25VF512 @SOIC8 SST25VF512 @WSON8 SST25VF512A SST25VF512A @SOIC8 SST25VF512A @WSON8 SST27SF010 @DIP32 SST27SF010 @PLCC32 SST27SF010 @TSOP32 SST27SF020 @DIP32 SST27SF020 @PLCC32 SST27SF020 @TSOP32 SST27SF256 @DIP28 SST27SF256 @PLCC32 SST27SF512 @DIP28 SST27SF512 @PLCC32 SST27VF010 @DIP32 SST27VF010 @PLCC32 SST27VF010 @TSOP32 SST27VF020 @DIP32 SST27VF020 @PLCC32 SST27VF020 @TSOP32 SST27VF256 @DIP28 SST27VF256 @PLCC32 SST27VF512 @DIP28 SST27VF512 @PLCC32 SST28LF040 SST28LF040 @PLCC32 SST28LF040 @TSOP32 SST28LF040A SST28LF040A @PLCC32 SST28LF040A @TSOP32 SST28SF040 SST28SF040 @PLCC32 SST28SF040 @TSOP32 SST28SF040A SST28SF040A @PLCC32 SST28SF040A @TSOP32 SST28VF040 SST28VF040 @PLCC32 SST28VF040 @TSOP32 SST28VF040A SST28VF040A @PLCC32 SST28VF040A @TSOP32 SST29EE010 SST29EE010 @PLCC32 SST29EE010 @TSOP32 SST29EE020 SST29EE020 @PLCC32 SST29EE020 @TSOP32 SST29EE512 SST29EE512 @PLCC32 SST29EE512 @TSOP32 SST29LE010 SST29LE010 @PLCC32 SST29LE010 @TSOP32 SST29LE020 SST29LE020 @PLCC32 SST29LE020 @TSOP32 SST29LE512 SST29LE512 @PLCC32 SST29LE512 @TSOP32 SST29SF010 SST29SF010 @PLCC32 SST29SF010 @TSOP32 SST29SF020 SST29SF020 @PLCC32 SST29SF020 @TSOP32 SST29SF040 SST29SF040 @PLCC32 SST29SF040 @TSOP32 SST29SF512 SST29SF512 @PLCC32 SST29SF512 @TSOP32 SST29VE010 SST29VE010 @PLCC32 SST29VE010 @TSOP32 SST29VE020 SST29VE020 @PLCC32 SST29VE020 @TSOP32 SST29VE512 SST29VE512 @PLCC32 SST29VE512 @TSOP32 SST29VF010 SST29VF010 @PLCC32 SST29VF010 @TSOP32 SST29VF020 SST29VF020 @PLCC32 SST29VF020 @TSOP32 SST29VF040 SST29VF040 @PLCC32 SST29VF040 @TSOP32 SST29VF512 SST29VF512 @PLCC32 SST29VF512 @TSOP32 SST36VF1601 @TSOP48 SST36VF1602 @TSOP48 SST36VF3203 @TSOP48 SST36VF3204 @TSOP48 SST37VF010 SST37VF010 @PLCC32 SST37VF010 @TSOP32 SST37VF020 SST37VF020 @PLCC32 SST37VF020 @TSOP32 SST37VF040 SST37VF040 @PLCC32 SST37VF040 @TSOP32 SST37VF512 SST37VF512 @PLCC32 SST37VF512 @TSOP32 SST39LF010 @PLCC32 SST39LF010 @TSOP32 SST39LF016 @TSOP40 SST39LF020 @PLCC32 SST39LF020 @TSOP32 SST39LF040 @PLCC32 SST39LF040 @TSOP32 SST39LF080 @TSOP40 SST39LF160 @TSOP48 SST39LF200A @TSOP48 SST39LF400A @TSOP48 SST39LF512 @PLCC32 SST39LF512 @TSOP32 SST39LF800A @TSOP48 SST39LH010 SST39LH010 @PLCC32 SST39LH010 @TSOP32 SST39LH020 SST39LH020 @PLCC32 SST39LH020 @TSOP32 SST39LH040 SST39LH040 @PLCC32 SST39LH040 @TSOP32 SST39LH512 SST39LH512 @PLCC32 SST39LH512 @TSOP32 SST39SF010 SST39SF010 @PLCC32 SST39SF010 @TSOP32 SST39SF010A SST39SF010A @PLCC32 SST39SF010A @TSOP32 SST39SF020 SST39SF020 @PLCC32 SST39SF020 @TSOP32 SST39SF020A SST39SF020A @PLCC32 SST39SF020A @TSOP32 SST39SF040 SST39SF040 @PLCC32 SST39SF040 @TSOP32 SST39SF512 SST39SF512 @PLCC32 SST39SF512 @TSOP32 SST39SF512A SST39SF512A @PLCC32 SST39SF512A @TSOP32 SST39VF010 SST39VF010 @PLCC32 SST39VF010 @TSOP32 SST39VF016 @TSOP40 SST39VF020 SST39VF020 @PLCC32 SST39VF020 @TSOP32 SST39VF040 SST39VF040 @PLCC32 SST39VF040 @TSOP32 SST39VF040A SST39VF040A @PLCC32 SST39VF040A @TSOP32 SST39VF080 @TSOP40 SST39VF088 @TSOP48 SST39VF160 @TSOP48 SST39VF1601 @TSOP48 SST39VF1602 @TSOP48 SST39VF200A @TSOP48 SST39VF320 @TSOP48 SST39VF3201 @TSOP48 SST39VF3202 @TSOP48 SST39VF400A @TSOP48 SST39VF512 SST39VF512 @PLCC32 SST39VF512 @TSOP32 SST39VF6401 @TSOP48 SST39VF6402 @TSOP48 SST39VF800A @TSOP48 SST49LF002A @PLCC32 SST49LF002A @TSOP32 SST49LF002B @PLCC32 SST49LF002B @TSOP32 SST49LF003A @PLCC32 SST49LF003A @TSOP32 SST49LF004 @PLCC32 SST49LF004 @TSOP32 SST49LF004A @PLCC32 SST49LF004A @TSOP32 SST49LF004B @PLCC32 SST49LF004B @TSOP40 SST49LF004C @PLCC32 SST49LF004C @TSOP40 SST49LF008A @PLCC32 SST49LF008A @TSOP32 SST49LF008A @TSOP40 SST49LF008C @PLCC32 SST49LF008C @TSOP40 SST49LF020 @PLCC32 SST49LF020 @TSOP32 SST49LF020A @PLCC32 SST49LF020A @TSOP32 SST49LF030A @PLCC32 SST49LF030A @TSOP32 SST49LF040 @PLCC32 SST49LF040 @TSOP32 SST49LF040A @PLCC32 SST49LF040A @TSOP32 SST49LF040B @PLCC32 SST49LF040B @TSOP32 SST49LF080 @PLCC32 SST49LF080 @TSOP32 SST49LF080A @PLCC32 SST49LF080A @TSOP32 SST89C54 SST89C54 @PLCC44 SST89C58 SST89C58 @PLCC44 SST89E516RD SST89E516RD @PLCC44 SST89E516RD2 SST89E516RD2 @PLCC44 SST89E52RD SST89E52RD @PLCC44 SST89E52RD2 SST89E52RD2 @PLCC44 SST89E54RD SST89E54RD @PLCC44 SST89E54RD2 SST89E54RD2 @PLCC44 SST89E554 SST89E554 @PLCC44 SST89E554RC SST89E554RC @PLCC44 SST89E564 SST89E564 @PLCC44 SST89E564RD SST89E564RD @PLCC44 SST89E58RD SST89E58RD @PLCC44 SST89E58RD2 SST89E58RD2 @PLCC44 SST89F54 SST89F54 @PLCC44 SST89F58 SST89F58 @PLCC44 SST89V516RD SST89V516RD @PLCC44 SST89V516RD2 SST89V516RD2 @PLCC44 SST89V52RD SST89V52RD @PLCC44 SST89V52RD2 SST89V52RD2 @PLCC44 SST89V54RD2 SST89V54RD2 @PLCC44 SST89V54RD SST89V54RD @PLCC44 SST89V554 SST89V554 @PLCC44 SST89V554RC SST89V554RC @PLCC44 SST89V564 SST89V56 @PLCC44 SST89V564RD SST89V564RD @PLCC44 SST89V58RD SST89V58RD @PLCC44 SST89V58RD2 SST89V58RD2 @PLCC44 [ ST ] 787 PCS ETC2716 @DIP24 ETC2732 @DIP24 M24128 M24128 @SOIC8 M24128 @TSOP8 M24256 M24256 @SOIC8 M24256 @TSOP8 M24256BF M24256BF @SOIC8 M24256BF @TSOP8 M24256BR M24256BR @SOIC8 M24256BR @TSOP8 M24256BW M24256BW @SOIC8 M24256BW @TSOP8 M24512 M24512 @SOIC8 M24512 @TSOP8 M24C01 M24C01 @SOIC8 M24C01 @TSOP8 M24C01R M24C01R @SOIC8 M24C01R @TSOP8 M24C01W M24C01W @SOIC8 M24C01W @TSOP8 M24C02 M24C02 @SOIC8 M24C02 @TSOP8 M24C02R M24C02R @SOIC8 M24C02R @TSOP8 M24C02W M24C02W @SOIC8 M24C02W @TSOP8 M24C04 M24C04 @SOIC8 M24C04 @TSOP8 M24C04R M24C04R @SOIC8 M24C04R @TSOP8 M24C04W M24C04W @SOIC8 M24C04W @TSOP8 M24C08 M24C08 @SOIC8 M24C08 @TSOP8 M24C08R M24C08R @SOIC8 M24C08R @TSOP8 M24C08W M24C08W @SOIC8 M24C08W @TSOP8 M24C128 M24C128 @SOIC8 M24C128 @TSOP8 M24C128B M24C128B @SOIC8 M24C128B @TSOP8 M24C16 M24C16 @SOIC8 M24C16 @SOIC8 M24C16R M24C16R @SOIC8 M24C16R @SOIC8 M24C16W M24C16W @SOIC8 M24C16W @SOIC8 M24C256 M24C256 @SOIC8 M24C256 @TSSOP8 M24C256A M24C256A @SOIC8 M24C256A @TSSOP8 M24C256B M24C256B @SOIC8 M24C256B @TSSOP8 M24C256W M24C256W @SOIC8 M24C256W @TSSOP8 M24C32 M24C32 @SOIC8 M24C32 @SSOP8 M24C32W M24C32W @SOIC8 M24C32W @SSOP8 M24C64 M24C64 @SOIC8 M24C64 @SSOP8 M24C64W M24C64W @SOIC8 M24C64W @SSOP8 M24M01-HR @SOIC8 M24M01-R @SOIC8 M24M01-S @SOIC8 M24M01-V @SOIC8 M24M01-W @SOIC8 M24W01 M24W01 @SOIC8 M24W02 M24W02 @SOIC8 M24W04 M24W04 @SOIC8 M24W08 M24W08 @SOIC8 M24W16 M24W16 @SOIC8 M25C01 M25C02 M25C04 M25C08 M25C16 M25P05 M25P05 @SOIC8 M25P05A @SOIC8 M25P05A @TSOP8 M25P10 M25P10 @SOIC8 M25P10A M25P10A @SOIC8 M25P16 @SOIC8 M25P16 @SOIC16 M25P20 M25P20 @SOIC8 M25P32 @SOIC8 M25P32 @SOIC16 M25P40 M25P40 @SOIC8 M25P64 @SOIC8 M25P64 @SOIC16 M25P80 @SOIC8 M25P80 @SOIC16 M25PE10 M25PE10 @SOIC8 M25PE16 M25PE16 @SOIC8 M25PE20 M25PE20 @SOIC8 M25PE40 M25PE40 @SOIC8 M25PE80 M25PE80 @SOIC8 M25PX16 @SOIC8 M25PX16 @SOIC16 M25PX32 @SOIC8 M25PX32 @SOIC16 M25PX64 @SOIC8 M25PX64 @SOIC16 M25PX80 M25PX80 @SOIC8 M25W01 M25W02 M25W04 M25W08 M25W16 M35080-3 M35080-3 @SOIC8 M35080-6 M35080-6 @SOIC8 M35080V6 M35080V6 @SOIC8 M35080VP M35080VP @SOIC8 M27128A @DIP28 M2716 @DIP24 M27256 @DIP28 M2732A @DIP24 M27512 @DIP28 M2764A @DIP28 M27C1001 @DIP32 M27C1001 @PLCC32 M27C1001 @TSOP32 M27C1024 @DIP40 M27C2001 @DIP32 M27C2001 @PLCC32 M27C2001 @TSOP32 M27C202 @DIP40 M27C256B @DIP28 M27C256B @PLCC32 M27C4001 @DIP32 M27C4001 @PLCC32 M27C4001 @TSOP32 M27C4002 @DIP40 M27C512 @DIP28 M27C512 @PLCC32 M27C64A @DIP28 M27C64A @PLCC32 M27C801 M27C801 @PLCC32 M27C801 @TSOP32 M27V101 @DIP32 M27V101 @PLCC32 M27V101 @TSOP32 M27V201 @DIP32 M27V201 @PLCC32 M27V201 @TSOP32 M27V401 @DIP32 M27V401 @PLCC32 M27V401 @TSOP32 M27V512 @DIP28 M27V512 @PLCC32 M27W101 @DIP32 M27W101 @PLCC32 M27W101 @TSOP32 M27W201 @DIP32 M27W201 @PLCC32 M27W201 @TSOP32 M27W401 @DIP32 M27W401 @PLCC32 M27W401 @TSOP32 M27W512 @DIP28 M27W512 @PLCC32 M28010 M28010 @PLCC32 M28010 @TSOP32 M28C64 M28C64 @PLCC32 M28C64 @SOIC28 M28C64A M28C64A @PLCC32 M28C64A @SOIC28 M28C64-xxW M28C64-xxW @PLCC32 M28C64-xxW @SOIC28 M28F101 M28F101 @PLCC32 M28F101 @TSOP32 M28F201 M28F201 @PLCC32 M28F201 @TSOP32 M28LV64 M28LV64 @PLCC32 M28LV64 @SOIC28 M28W160BB @TSOP48 M28W160BT @TSOP48 M28W160CB @TSOP48 M28W160CT @TSOP48 M28W320BB @TSOP48 M28W320BT @TSOP48 M28W320CB @TSOP48 M28W320CT @TSOP48 M28W640CB @TSOP48 M28W640CT @TSOP48 M28W640ECB @TSOP48 M28W640ECT @TSOP48 M28W800BB @TSOP48 M28W800BT @TSOP48 M28W800CB @TSOP48 M28W800CT @TSOP48 M29DW323DB @TSOP48 M29DW323DT @TSOP48 M29DW324DB @TSOP48 M29DW324DT @TSOP48 M29DW640D @TSOP48 M29DW640F @TSOP48 M29DW641F @TSOP48 M29F002B M29F002B @PLCC32 M29F002B @TSOP32 M29F002BB M29F002BB @PLCC32 M29F002BB @TSOP32 M29F002BT M29F002BT @PLCC32 M29F002BT @TSOP32 M29F002BNT M29F002BNT @PLCC32 M29F002BNT @TSOP32 M29F002BNB M29F002BNB @PLCC32 M29F002BNB @TSOP32 M29F002NT M29F002NT @PLCC32 M29F002NT @TSOP32 M29F002T M29F002T @PLCC32 M29F002T @TSOP32 M29F010B M29F010B @PLCC32 M29F010B @TSOP32 M29F016B @TSOP40 M29F016D @TSOP40 M29F040B M29F040B @PLCC32 M29F040B @TSOP32 M29F080A @TSOP40 M29F080D @TSOP40 M29F100B @TSOP48 M29F100B @SOP44 M29F100BB @TSOP48 M29F100BB @SOP44 M29F100BT @TSOP48 M29F100BT @SOP44 M29F100T @TSOP48 M29F100T @SOP44 M29F102BB @VSOP40 M29F160BB @TSOP48 M29F160BT @TSOP48 M29F200B @TSOP48 M29F200B @SOP44 M29F200T @TSOP48 M29F200T @SOP44 M29F400B @TSOP48 M29F400B @SOP44 M29F400BB @TSOP48 M29F400BB @SOP44 M29F400BT @TSOP48 M29F400BT @SOP44 M29F400T @TSOP48 M29F400T @SOP44 M29F512B M29F512B @PLCC32 M29F512B @TSOP32 M29F800AB @TSOP48 M29F800AB @SOP44 M29F800AT @TSOP48 M29F800AT @SOP44 M29F800DB @TSOP48 M29F800DB @SOP44 M29F800DT @TSOP48 M29F800DT @SOP44 M29W002BB @TSOP40 M29W002BT @TSOP40 M29W004B @TSOP40 M29W004T @TSOP40 M29W008AB @TSOP40 M29W008AT @TSOP40 M29W008B @TSOP40 M29W008T @TSOP40 M29W010B @PLCC32 M29W010B @TSOP32 M29W017D @TSOP40 M29W040B @PLCC32 M29W040B @TSOP32 M29W102BB @VSOP40 M29W102BT @VSOP40 M29W160BB @TSOP48 M29W160BT @TSOP48 M29W160DB @TSOP48 M29W160DT @TSOP48 M29W160EB @TSOP48 M29W160ET @TSOP48 M29W200BB @TSOP48 M29W200BB @SOP44 M29W200BT @TSOP48 M29W200BT @SOP44 M29W320DB @TSOP48 M29W320DT @TSOP48 M29W320EB @TSOP48 M29W320ET @TSOP48 M29W400B @TSOP48 M29W400B @SOP44 M29W400BB @TSOP48 M29W400BB @SOP44 M29W400BT @TSOP48 M29W400BT @SOP44 M29W400T @TSOP48 M29W400T @SOP44 M29W512B @PLCC32 M29W512B @TSOP32 M29W640DB @TSOP48 M29W640DT @TSOP48 M29W640FB @TSOP48 M29W640FT @TSOP48 M29W640Gx @TSOP48 M29W641DH @TSOP48 M29W641DL @TSOP48 M29W641DU @TSOP48 M29W800AB @TSOP48 M29W800AB @SOP44 M29W800AT @TSOP48 M29W800AT @SOP44 M29W800DB @TSOP48 M29W800DB @SOP44 M29W800DT @TSOP48 M29W800DT @SOP44 M50FLW040A @PLCC32 M50FLW040A @TSOP32 M50FLW040A @TSOP40 M50FLW040B @PLCC32 M50FLW040B @TSOP32 M50FLW040B @TSOP40 M50FLW080A @PLCC32 M50FLW080A @TSOP32 M50FLW080A @TSOP40 M50FLW080B @PLCC32 M50FLW080B @TSOP32 M50FLW080B @TSOP40 M50FW002 @PLCC32 M50FW040 M50FW040 @PLCC32 M50FW040 @TSOP32 M50FW040 @TSOP40 M50FW080 M50FW080 @PLCC32 M50FW080 @TSOP32 M50FW080 @TSOP40 M50FW016 @TSOP40 M50LPW002 @PLCC32 M50LPW040 @PLCC32 M50LPW040 @TSOP40 M50LPW041 @PLCC32 M50LPW041 @TSOP40 M50LPW080 @PLCC32 M50LPW080 @TSOP40 M50LPW116 @TSOP40 M87C257 @DIP28 M87C257 @PLCC32 M93C06(x8) M93C06(x8) @SOIC8 M93C06(x16) M93C06(x16) @SOIC8 M93C46(x8) M93C46(x8) @MSOP8 M93C46(x8) @SOIC8 M93C46(x8) @TSOP8 M93C46(x16) M93C46(x16) @MSOP8 M93C46(x16) @SOIC8 M93C46(x16) @TSOP8 M93C46R(x8) M93C46R(x8) @MSOP8 M93C46R(x8) @SOIC8 M93C46R(x8) @TSOP8 M93C46R(x16) M93C46R(x16) @MSOP8 M93C46R(x16) @SOIC8 M93C46R(x16) @TSOP8 M93C46W(x8) M93C46W(x8) @MSOP8 M93C46W(x8) @SOIC8 M93C46W(x8) @TSOP8 M93C46W(x16) M93C46W(x16) @MSOP8 M93C46W(x16) @SOIC8 M93C46W(x16) @TSOP8 M93C56(x8) M93C56(x8) @MSOP8 M93C56(x8) @SOIC8 M93C56(x8) @TSOP8 M93C56(x16) M93C56(x16) @MSOP8 M93C56(x16) @SOIC8 M93C56(x16) @TSOP8 M93C56R(x8) M93C56R(x8) @MSOP8 M93C56R(x8) @SOIC8 M93C56R(x8) @TSOP8 M93C56R(x16) M93C56R(x16) @MSOP8 M93C56R(x16) @SOIC8 M93C56R(x16) @TSOP8 M93C56W(x8) M93C56W(x8) @MSOP8 M93C56W(x8) @SOIC8 M93C56W(x8) @TSOP8 M93C56W(x16) M93C56W(x16) @MSOP8 M93C56W(x16) @SOIC8 M93C56W(x16) @TSOP8 M93C66(x8) M93C66(x8) @MSOP8 M93C66(x8) @SOIC8 M93C66(x8) @TSOP8 M93C66(x16) M93C66(x16) @MSOP8 M93C66(x16) @SOIC8 M93C66(x16) @TSOP8 M93C66R(x8) M93C66R(x8) @MSOP8 M93C66R(x8) @SOIC8 M93C66R(x8) @TSOP8 M93C66R(x16) M93C66R(x16) @MSOP8 M93C66R(x16) @SOIC8 M93C66R(x16) @TSOP8 M93C66W(x8) M93C66W(x8) @MSOP8 M93C66W(x8) @SOIC8 M93C66W(x8) @TSOP8 M93C66W(x16) M93C66W(x16) @MSOP8 M93C66W(x16) @SOIC8 M93C66W(x16) @TSOP8 M93C76(x8) M93C76(x8) @MSOP8 M93C76(x8) @SOIC8 M93C76(x8) @TSOP8 M93C76(x16) M93C76(x16) @MSOP8 M93C76(x16) @SOIC8 M93C76(x16) @TSOP8 M93C76R(x8) M93C76R(x8) @MSOP8 M93C76R(x8) @SOIC8 M93C76R(x8) @TSOP8 M93C76R(x16) M93C76R(x16) @MSOP8 M93C76R(x16) @SOIC8 M93C76R(x16) @TSOP8 M93C76W(x8) M93C76W(x8) @MSOP8 M93C76W(x8) @SOIC8 M93C76W(x8) @TSOP8 M93C76W(x16) M93C76W(x16) @MSOP8 M93C76W(x16) @SOIC8 M93C76W(x16) @TSOP8 M93C86(x8) M93C86(x8) @MSOP8 M93C86(x8) @SOIC8 M93C86(x8) @TSOP8 M93C86(x16) M93C86(x16) @MSOP8 M93C86(x16) @SOIC8 M93C86(x16) @TSOP8 M93C86R(x8) M93C86R(x8) @MSOP8 M93C86R(x8) @SOIC8 M93C86R(x8) @TSOP8 M93C86R(x16) M93C86R(x16) @MSOP8 M93C86R(x16) @SOIC8 M93C86R(x16) @TSOP8 M93C86W(x8) M93C86W(x8) @MSOP8 M93C86W(x8) @SOIC8 M93C86W(x8) @TSOP8 M93C86W(x16) M93C86W(x16) @MSOP8 M93C86W(x16) @SOIC8 M93C86W(x16) @TSOP8 M93S46 M93S46 @SOIC8 M93S46 @TSOP8 M93S46R M93S46R @SOIC8 M93S46R @TSOP8 M93S46W M93S46W @SOIC8 M93S46W @TSOP8 M93S56 M93S56 @SOIC8 M93S56 @TSOP8 M93S56R M93S56R @SOIC8 M93S56R @TSOP8 M93S56W M93S56W @SOIC8 M93S56W @TSOP8 M93S66 M93S66 @SOIC8 M93S66 @TSOP8 M93S66R M93S66R @SOIC8 M93S66R @TSOP8 M93S66W M93S66W @SOIC8 M93S66W @TSOP8 M95010 M95010 @SOIC8 M95010 @TSOP8 M95010R M95010R @SOIC8 M95010R @TSOP8 M95010W M95010W @SOIC8 M95010W @TSOP8 M95020 M95020 @SOIC8 M95020 @TSOP8 M95020R M95020R @SOIC8 M95020R @TSOP8 M95020W M95020W @SOIC8 M95020W @TSOP8 M95040 M95040 @SOIC8 M95040 @TSOP8 M95040R M95040R @SOIC8 M95040R @TSOP8 M95040W M95040W @SOIC8 M95040W @TSOP8 M95080 M95080 @SOIC8 M95080 @TSOP8 M95080R M95080R @SOIC8 M95080R @TSOP8 M95080W M95080W @SOIC8 M95080W @TSOP8 M95128 M95128 @SOIC8 M95128 @TSOP8 M95128R M95128R @SOIC8 M95128R @TSOP8 M95128W M95128W @SOIC8 M95128W @TSOP8 M95160 M95160 @SOIC8 M95160 @TSOP8 M95160R M95160R @SOIC8 M95160R @TSOP8 M95160W M95160W @SOIC8 M95160W @TSOP8 M95256 M95256 @SOIC8 M95256 @TSOP8 M95256R M95256R @SOIC8 M95256R @TSOP8 M95256W M95256W @SOIC8 M95256W @TSOP8 M95320 M95320 @SOIC8 M95320 @TSOP8 M95320R M95320R @SOIC8 M95320R @TSOP8 M95320W M95320W @SOIC8 M95320W @TSOP8 M95512R @SOIC8 M95512R @TSOP8 M95512W @SOIC8 M95512W @TSOP8 M95640 M95640 @SOIC8 M95640 @TSOP8 M95640R M95640R @SOIC8 M95640R @TSOP8 M95640W M95640W @SOIC8 M95640W @TSOP8 M95M01R @SOIC8 M95M01R @TSOP8 M95M01W @SOIC8 M95M01W @TSOP8 ST24C01 ST24C01 @SOIC8 ST24C02 ST24C02 @SOIC8 ST24C04 ST24C04 @SOIC8 ST24C08 ST24C08 @SOIC8 ST24C16 ST24C16 @SOIC8 ST24FC21 ST24FC21 @SOIC8 ST24LC21B ST24LC21B @SOIC8 ST24W01 ST24W01 @SOIC8 ST24W02 ST24W02 @SOIC8 ST24W04 ST24W04 @SOIC8 ST24W08 ST24W08 @SOIC8 ST24W16 ST24W16 @SOIC8 ST25C01 ST25C02 ST25C04 ST25C08 ST25C16 ST25P05 ST25P05 @SOIC8 ST25P05A @SOIC8 ST25P05A @TSOP8 ST25P10 ST25P10 @SOIC8 ST25P10A ST25P10A @SOIC8 ST25P16 @SOIC8 ST25P16 @SOIC16 ST25P20 ST25P20 @SOIC8 ST25P32 @SOIC8 ST25P32 @SOIC16 ST25P40 ST25P40 @SOIC8 ST25P64 @SOIC8 ST25P64 @SOIC16 ST25P80 @SOIC8 ST25P80 @SOIC16 ST25W01 ST25W02 ST25W04 ST25W08 ST25W16 ST27128A @DIP28 ST27256 @DIP28 ST2764A @DIP28 ST27C256 @DIP28 ST27C256 @PLCC32 ST93C06(x8) ST93C06(x8) @SOIC8 ST93C06(x16) ST93C06(x16) @SOIC8 ST93C46(x8) ST93C46(x8) @SOIC8 ST93C46(x16) ST93C46(x16) @SOIC8 ST93C46A(x8) ST93C46A(x8) @SOIC8 ST93C46A(x16) ST93C46A(x16) @SOIC8 ST93C46C(x8) ST93C46C(x8) @SOIC8 ST93C46C(x16) ST93C46C(x16) @SOIC8 ST93C46T(x8) ST93C46T(x8) @SOIC8 ST93C46T(x16) ST93C46T(x16) @SOIC8 ST93C47C(x8) ST93C47C(x8) @SOIC8 ST93C47C(x16) ST93C47C(x16) @SOIC8 ST93C47T(x8) ST93C47T(x8) @SOIC8 ST93C47T(x16) ST93C47T(x16) @SOIC8 ST93C56(x8) ST93C56(x8) @SOIC8 ST93C56(x16) ST93C56(x16) @SOIC8 ST93C56B(x8) ST93C56B(x8) @SOIC8 ST93C56B(x16) ST93C56B(x16) @SOIC8 ST93C56C(x8) ST93C56C(x8) @SOIC8 ST93C56C(x16) ST93C56C(x16) @SOIC8 ST93C57C(x8) ST93C57C(x8) @SOIC8 ST93C57C(x16) ST93C57C(x16) @SOIC8 ST93C66(x8) ST93C66(x8) @SOIC8 ST93C66(x16) ST93C66(x16) @SOIC8 ST93C67(x8) ST93C67(x8) @SOIC8 ST93C67(x16) ST93C67(x16) @SOIC8 ST93C76(x8) ST93C76(x8) @SOIC8 ST93C76(x16) ST93C76(x16) @SOIC8 ST93C86(x8) ST93C86(x8) @SOIC8 ST93C86(x16) ST93C86(x16) @SOIC8 ST93CS46 ST93CS46 @SOIC8 ST93CS47 ST93CS47 @SOIC8 ST93CS56 ST93CS56 @SOIC8 ST93CS57 ST93CS57 @SOIC8 ST93CS66 ST93CS66 @SOIC8 ST93CS66 @SOIC14 ST93CS67 ST93CS67 @SOIC8 ST93CS67 @SOIC14 TS27C256 @DIP28 TS27C64A @DIP28 TS27C64A @PLCC32 [ SUMMIT ] 32 PCS S24VP02P S24VP02S @SOIC8 S24VP04P S24VP04S @SOIC8 S24VP08P S24VP08S @SOIC8 S24VP16P S24VP16S @SOIC8 S93462 S93462 @SOIC8 S93463 S93463 @SOIC8 S93662 S93662 @SOIC8 S93663 S93664 @SOIC8 S93VP462 S93VP462 @SOIC8 S93VP463 S93VP463 @SOIC8 S93VP662 S93VP662 @SOIC8 S93VP663 S93VP664 @SOIC8 S93WD462 S93WD462 @SOIC8 S93WD463 S93WD463 @SOIC8 S93WD662 S93WD662 @SOIC8 S93WD663 S93WD664 @SOIC8 [ SUNMOON ] 8 PCS SM24C02 SM24C02 @SOIC8 SM24C04 SM24C04 @SOIC8 SM24C08 SM24C08 @SOIC8 SM24C16 SM24C16 @SOIC8 [ SYNCMOS ] 182 PCS F29C31004B @DIP32 F29C31004B @PLCC32 F29C31004B @TSOP32 F29C31004T @DIP32 F29C31004T @PLCC32 F29C31004T @TSOP32 F29C51001B @DIP32 F29C51001B @PLCC32 F29C51001B @TSOP32 F29C51001T @DIP32 F29C51001T @PLCC32 F29C51001T @TSOP32 F29C51002B @DIP32 F29C51002B @PLCC32 F29C51002B @TSOP32 F29C51002T @DIP32 F29C51002T @PLCC32 F29C51002T @TSOP32 F29C51004B @DIP32 F29C51004B @PLCC32 F29C51004B @TSOP32 F29C51004T @DIP32 F29C51004T @PLCC32 F29C51004T @TSOP32 F29LC51000 @DIP32 F29LC51000 @PLCC32 F29LC51000 @TSOP32 F29LC51001 @DIP32 F29LC51001 @PLCC32 F29LC51001 @TSOP32 F29LC51002 @DIP32 F29LC51002 @PLCC32 F29LC51002 @TSOP32 S29C31001B @DIP32 S29C31001B @PLCC32 S29C31001B @TSOP32 S29C31001T @DIP32 S29C31001T @PLCC32 S29C31001T @TSOP32 S29C31002B @DIP32 S29C31002B @PLCC32 S29C31002B @TSOP32 S29C31002T @DIP32 S29C31002T @PLCC32 S29C31002T @TSOP32 S29C31004B @DIP32 S29C31004B @PLCC32 S29C31004B @TSOP32 S29C31004T @DIP32 S29C31004T @PLCC32 S29C31004T @TSOP32 S29C51001B @DIP32 S29C51001B @PLCC32 S29C51001B @TSOP32 S29C51001T @DIP32 S29C51001T @PLCC32 S29C51001T @TSOP32 S29C51002B @DIP32 S29C51002B @PLCC32 S29C51002B @TSOP32 S29C51002T @DIP32 S29C51002T @PLCC32 S29C51002T @TSOP32 S29C51004B @DIP32 S29C51004B @PLCC32 S29C51004B @TSOP32 S29C51004T @DIP32 S29C51004T @PLCC32 S29C51004T @TSOP32 SM39R08A2 @ICP only SM39R12A2 @ICP only SM39R16A2 @ICP only SM39R2051 @ICP only SM39R4051 @ICP only SM59128C SM59128C @PLCC44 SM59264C SM59264C @PLCC44 SM5964AC SM5964AC @PLCC44 SM5964AL SM5964AL @PLCC44 SM5964C SM5964C @PLCC44 SM59D03G2C SM59D03G2C @PLCC44 SM59D03G2L SM59D03G2L @PLCC44 SM59D04G2C SM59D04G2C @PLCC44 SM59D04G2L SM59D04G2L @PLCC44 SM59R02A1C SM59R02A1C @PLCC44 SM59R02A1L SM59R02A1L @PLCC44 SM59R02A2C SM59R02A2C @PLCC44 SM59R02A2L SM59R02A2L @PLCC44 SM59R03A1C SM59R03A1C @PLCC44 SM59R03A1L SM59R03A1L @PLCC44 SM59R03A2C SM59R03A2C @PLCC44 SM59R03A2L SM59R03A2L @PLCC44 SM59R04A1C SM59R04A1C @PLCC44 SM59R04A1L SM59R04A1L @PLCC44 SM59R04A2C SM59R04A2C @PLCC44 SM59R04A2L SM59R04A2L @PLCC44 SM59R05A3C SM59R05A3C @PLCC44 SM59R05A3L SM59R05A3L @PLCC44 SM59R05A5C SM59R05A5C @PLCC44 SM59R05A5L SM59R05A5L @PLCC44 SM59R05G6 SM59R05G6 @PLCC44 SM59R09A3C SM59R09A3C @PLCC44 SM59R09A3L SM59R09A3L @PLCC44 SM59R09A5C SM59R09A5C @PLCC44 SM59R09A5L SM59R09A5L @PLCC44 SM59R09G6 SM59R09G6 @PLCC44 SM59R16A3C SM59R16A3C @PLCC44 SM59R16A3L SM59R16A3L @PLCC44 SM59R16A5C SM59R16A5C @PLCC44 SM59R16A5L SM59R16A5L @PLCC44 SM59R16G6 SM59R16G6 @PLCC44 SM79108C SM79108C @PLCC44 SM79108L SM79108L @PLCC44 SM79164C SM79164C @PLCC44 SM79164L SM79164L @PLCC44 SM894051C SM894051C @SOIC20 SM894051L SM894051L @SOIC20 SM89516AC SM89516AC @PLCC44 SM89516AL SM89516AL @PLCC44 SM8951AC SM8951AC @PLCC44 SM8951AL SM8951AL @PLCC44 SM8951BC SM8951BC @PLCC44 SM8951BL SM8951BL @PLCC44 SM8952AC SM8952AC @PLCC44 SM8952AL SM8952AL @PLCC44 SM8954AC SM8954AC @PLCC44 SM8954AL SM8954A @PLCC44 SM8958AC SM8958AC @PLCC44 SM8958AL SM8958AL @PLCC44 [ TI ] 122 PCS SMJ27C128 @DIP28 SMJ27C128 @PLCC32 SMJ27C256 @DIP28 SMJ27C256 @PLCC32 SMJ27C512 @DIP28 SMJ27C512 @PLCC32 TMS2716 @DIP24 TMS2732A @DIP24 TMS2764 @DIP28 TMS27C010 @DIP32 TMS27C010 @PLCC32 TMS27C010 @TSOP32 TMS27C010A @DIP32 TMS27C010A @PLCC32 TMS27C010A @TSOP32 TMS27C020 @DIP32 TMS27C020 @PLCC32 TMS27C020 @TSOP32 TMS27C040 @DIP32 TMS27C040 @PLCC32 TMS27C040 @TSOP32 TMS27C128 @DIP28 TMS27C128 @PLCC32 TMS27C210A @DIP40 TMS27C240 @DIP40 TMS27C256 @DIP28 TMS27C256 @PLCC32 TMS27C512 @DIP28 TMS27C512 @PLCC32 TMS27PC010A @DIP32 TMS27PC010A @PLCC32 TMS27PC010A @TSOP32 TMS27PC020 @DIP32 TMS27PC020 @PLCC32 TMS27PC020 @TSOP32 TMS27PC040 @DIP32 TMS27PC040 @PLCC32 TMS27PC040 @TSOP32 TMS27PC128 @DIP28 TMS27PC128 @PLCC32 TMS27PC210A @DIP40 TMS27PC240 @DIP40 TMS27PC256 @DIP28 TMS27PC256 @PLCC32 TMS27PC512 @DIP28 TMS27PC512 @PLCC32 TMS28F002Axx-T @TSOP40 TMS28F002Axx-B @TSOP40 TMS28F004Axx-T @TSOP40 TMS28F004Axx-B @TSOP40 TMS28F008Axx-T @TSOP40 TMS28F008Axx-B @TSOP40 TMS28F010 TMS28F010 @PLCC32 TMS28F010 @TSOP32 TMS28F010A TMS28F010A @PLCC32 TMS28F010A @TSOP32 TMS28F010B TMS28F010B @PLCC32 TMS28F010B @TSOP32 TMS28F020 TMS28F020 @PLCC32 TMS28F020 @TSOP32 TMS28F200AF-B @TSOP48 TMS28F200AF-B @SOP44 TMS28F200AF-T @TSOP48 TMS28F200AF-T @SOP44 TMS28F200BZ-B @SOP44 TMS28F200BZ-T @SOP44 TMS28F400AE-B @TSOP48 TMS28F400AE-B @SOP44 TMS28F400AE-T @TSOP48 TMS28F400AE-T @SOP44 TMS28F400AF-B @TSOP48 TMS28F400AF-B @SOP44 TMS28F400AF-T @TSOP48 TMS28F400AF-T @SOP44 TMS28F400AM-B @TSOP48 TMS28F400AM-B @SOP44 TMS28F400AM-T @TSOP48 TMS28F400AM-T @SOP44 TMS28F400AS-B @TSOP48 TMS28F400AS-B @SOP44 TMS28F400AS-T @TSOP48 TMS28F400AS-T @SOP44 TMS28F400AZ-B @TSOP48 TMS28F400AZ-B @SOP44 TMS28F400AZ-T @TSOP48 TMS28F400AZ-T @SOP44 TMS28F400BZB @SOP44 TMS28F400BZT @SOP44 TMS28F800AE-B @TSOP48 TMS28F800AE-B @SOP44 TMS28F800AE-T @TSOP48 TMS28F800AE-T @SOP44 TMS28F800AL-B @TSOP48 TMS28F800AL-B @SOP44 TMS28F800AL-T @TSOP48 TMS28F800AL-T @SOP44 TMS28F800AS-B @TSOP48 TMS28F800AS-B @SOP44 TMS28F800AS-T @TSOP48 TMS28F800AS-T @SOP44 TMS28F800AV-B @TSOP48 TMS28F800AV-B @SOP44 TMS28F800AV-T @TSOP48 TMS28F800AV-T @SOP44 TMS28F800AZ-B @TSOP48 TMS28F800AZ-B @SOP44 TMS28F800AZ-T @TSOP48 TMS28F800AZ-T @SOP44 TMS28F1600B @TSOP48 TMS28F1600T @TSOP48 TMS29F002RT @PLCC32 TMS29F002RB @PLCC32 TMS29F010 @PLCC32 TMS29F040 @PLCC32 TMS29LF040 @PLCC32 TMS29VF040 @PLCC32 TMS87C257 @DIP28 TMS87C257 @PLCC32 [ TMC ] 65 PCS TMC24A01 TMC24A01 @SOIC8 TMC24A01 @TSSOP8 TMC24A02 TMC24A02 @SOIC8 TMC24A02 @TSSOP8 TMC24A04 TMC24A04 @SOIC8 TMC24A04 @TSSOP8 TMC24A08 TMC24A08 @SOIC8 TMC24A08 @TSSOP8 TMC24A16 TMC24A16 @SOIC8 TMC24A16 @TSSOP8 TMC93LC46(x8) TMC93LC46(x8)(J,W) @SOIC8 TMC93LC46(x8)(K,X) @SOIC8 TMC93LC46(x8)(S,V) @SOIC8 TMC93LC46(x8)(U,Y) @TSOP8 TMC93LC46(x16) TMC93LC46(x16)(J,W) @SOIC8 TMC93LC46(x16)(K,X) @SOIC8 TMC93LC46(x16)(S,V) @SOIC8 TMC93LC46(x16)(U,Y) @TSOP8 TMC93LC56(x8) TMC93LC56(x8)(J,W) @SOIC8 TMC93LC56(x8)(K,X) @SOIC8 TMC93LC56(x8)(S,V) @SOIC8 TMC93LC56(x8)(U,Y) @TSOP8 TMC93LC56(x16) TMC93LC56(x16)(J,W) @SOIC8 TMC93LC56(x16)(K,X) @SOIC8 TMC93LC56(x16)(S,V) @SOIC8 TMC93LC56(x16)(U,Y) @TSOP8 TMC93LC57(x8) TMC93LC57(x8)(J,W) @SOIC8 TMC93LC57(x8)(K,X) @SOIC8 TMC93LC57(x8)(S,V) @SOIC8 TMC93LC57(x8)(U,Y) @TSOP8 TMC93LC57(x16) TMC93LC57(x16)(J,W) @SOIC8 TMC93LC57(x16)(K,X) @SOIC8 TMC93LC57(x16)(S,V) @SOIC8 TMC93LC57(x16)(U,Y) @TSOP8 TMC93LC66(x8) TMC93LC66(x8)(J,W) @SOIC8 TMC93LC66(x8)(K,X) @SOIC8 TMC93LC66(x8)(S,V) @SOIC8 TMC93LC66(x8)(U,Y) @TSOP8 TMC93LC66(x16) TMC93LC66(x16)(J,W) @SOIC8 TMC93LC66(x16)(K,X) @SOIC8 TMC93LC66(x16)(S,V) @SOIC8 TMC93LC66(x16)(U,Y) @TSOP8 TMC93LC86(x8) TMC93LC86(x8)(J,W) @SOIC8 TMC93LC86(x8)(K,X) @SOIC8 TMC93LC86(x8)(S,V) @SOIC8 TMC93LC86(x8)(U,Y) @TSOP8 TMC93LC86(x16) TMC93LC86(x16)(J,W) @SOIC8 TMC93LC86(x16)(K,X) @SOIC8 TMC93LC86(x16)(S,V) @SOIC8 TMC93LC86(x16)(U,Y) @TSOP8 [ TOSHIBA ] 33 PCS TC54256AF @DIP28 TC54256AF @SOIC28 TC54256AP @DIP28 TC54256AP @SOIC28 TC57256D @DIP28 TC57512AD @DIP28 TC57512AD @PLCC32 TC58FVB004 @TSOP40 TC58FVB008 @TSOP40 TC58FVB016 @TSOP40 TC58FVB160 @TSOP48 TC58FVB321 @TSOP48 TC58FVB400 @TSOP48 TC58FVB400 @SOP44 TC58FVB641 @TSOP48 TC58FVB800 @TSOP48 TC58FVB800 @SOP44 TC58FVM5B2A @TSOP48 TC58FVM5T2A @TSOP48 TC58FVM5B3A @TSOP48 TC58FVM5T3A @TSOP48 TC58FVM6B2A @TSOP48 TC58FVM6T2A @TSOP48 TC58FVT004 @TSOP40 TC58FVT008 @TSOP40 TC58FVT016 @TSOP40 TC58FVT160 @TSOP48 TC58FVT321 @TSOP48 TC58FVT400 @TSOP48 TC58FVT400 @SOP44 TC58FVT641 @TSOP48 TC58FVT800 @TSOP48 TC58FVT800 @SOP44 [ TURBO IC ] 33 PCS TU24C01 TU24C01 @SOIC8 TU24C01 @TSSOP8 TU24C02 TU24C02 @SOIC8 TU24C02 @TSSOP8 TU24C04 TU24C04 @SOIC8 TU24C04 @TSSOP8 TU24C08 TU24C08 @SOIC8 TU24C08 @TSSOP8 TU24C16 TU24C16 @SOIC8 TU24C16 @TSSOP8 TU24C32 TU24C32 @SOIC8 TU24C32 @TSSOP8 TU24C64 TU24C64 @SOIC8 TU24C64 @TSSOP8 TU93C46(x8) TU93C46(x8) @SOIC8 TU93C46(x16) TU93C46(x16) @SOIC8 TU93C56(x8) TU93C56(x8) @SOIC8 TU93C56(x16) TU93C56(x16) @SOIC8 TU93C66(x8) TU93C66(x8) @SOIC8 TU93C66(x16) TU93C66(x16) @SOIC8 [ UNIGEN ] 39 PCS UG24C01 UG24C01 @SOIC8 UG24C01 @TSSOP8 UG24C02 UG24C02 @SOIC8 UG24C02 @TSSOP8 UG24C04 UG24C04 @SOIC8 UG24C04 @TSSOP8 UG24C08 UG24C08 @SOIC8 UG24C08 @TSSOP8 UG24C16 UG24C16 @SOIC8 UG24C16 @TSSOP8 UG24C32 UG24C32 @SOIC8 UG24C32 @TSSOP8 UG24C64 UG24C64 @SOIC8 UG24C64 @TSSOP8 UG93C46-A(x8) UG93C46-A(x8) @SOIC8 UG93C46-A(x16) UG93C46-A(x16) @SOIC8 UG93C46-B(x8) @SOIC8 UG93C46-B(x16) @SOIC8 UG93C56-A(x8) UG93C56-A(x8) @SOIC8 UG93C56-A(x16) UG93C56-A(x16) @SOIC8 UG93C56-B(x8) @SOIC8 UG93C56-B(x16) @SOIC8 UG93C66-A(x8) UG93C66-A(x8) @SOIC8 UG93C66-A(x16) UG93C66-A(x16) @SOIC8 UG93C66-B(x8) @SOIC8 UG93C66-B(x16) @SOIC8 [ WAVE SYSTEM ] 24 PCS W93C46(x8) W93C46(x8) @SOIC8 W93C46(x8) @TSOP8 W93C46(x16) W93C46(x16) @SOIC8 W93C46(x16) @TSOP8 W93C56(x8) W93C56(x8) @SOIC8 W93C56(x8) @TSOP8 W93C56(x16) W93C56(x16) @SOIC8 W93C56(x16) @TSOP8 W93C66(x8) W93C66(x8) @SOIC8 W93C66(x8) @TSOP8 W93C66(x16) W93C66(x16) @SOIC8 W93C66(x16) @TSOP8 W93C86(x8) W93C86(x8) @SOIC8 W93C86(x8) @TSOP8 W93C86(x16) W93C86(x16) @SOIC8 W93C86(x16) @TSOP8 [ WED ] 6 PCS WE128K8 WE256K8 WE512K8 WME128K8 WME128K8 @CSOJ32 WME128K8 @PLCC32 [ WINBOND ] 360 PCS W24010 W24020 W24040 W24256 W24257A W24512 W2464 W2465 W25P10 @MLP8 W25P10 @SOIC8 W25P16 @MLP8 W25P16 @SOIC8 W25P16 @SOIC16 W25P20 @MLP8 W25P20 @SOIC8 W25P32 @MLP8 W25P32 @SOIC8 W25P32 @SOIC16 W25P40 @MLP8 W25P40 @SOIC8 W25P64 @MLP8 W25P64 @SOIC16 W25P80 @MLP8 W25P80 @SOIC8 W25Q128BV @SOIC8 W25Q128BV @SOIC16 W25Q16 @MLP8 W25Q16 @SOIC8 W25Q16 @SOIC16 W25Q16BV W25Q16BV @WSON8 W25Q16BV @SOIC8 W25Q16BV @SOIC16 W25Q16CL W25Q16CL @WSON8 W25Q16CL @SOIC8 W25Q16CL @SOIC16 W25Q16CV W25Q16CV @WSON8 W25Q16CV @SOIC8 W25Q16CV @SOIC16 W25Q16V @WSON8 W25Q16V @SOIC8 W25Q16V @SOIC16 W25Q32 @MLP8 W25Q32 @SOIC16 W25Q32BV W25Q32BV @WSON8 W25Q32BV @SOIC8 W25Q32BV @SOIC16 W25Q32V @MLP8 W25Q32V @SOIC16 W25Q40BL W25Q40BL @WSON8 W25Q40BL @SOIC8 W25Q40BV W25Q40BV @WSON8 W25Q40BV @SOIC8 W25Q64BV W25Q64BV @WSON8 W25Q64BV @SOIC8 W25Q64BV @SOIC16 W25Q64CV W25Q64CV @WSON8 W25Q64CV @SOIC8 W25Q64CV @SOIC16 W25Q64FV W25Q64FV @WSON8 W25Q64FV @SOIC8 W25Q64FV @SOIC16 W25Q80BL W25Q80BL @WSON8 W25Q80BL @SOIC8 W25Q80BL @SOIC16 W25Q80BL W25Q80BV @WSON8 W25Q80BV @SOIC8 W25Q80BV @SOIC16 W25X05 W25X05 @WSON8 W25X05 @SOIC8 W25X05CL W25X05CL @WSON8 W25X05CL @SOIC8 W25X10AV W25X10AV @WSON8 W25X10AV @SOIC8 W25X10BL W25X10BL @WSON8 W25X10BL @SOIC8 W25X10BV W25X10BV @WSON8 W25X10BV @SOIC8 W25X10CL W25X10CL @WSON8 W25X10CL @SOIC8 W25X10L W25X10L @WSON8 W25X10L @SOIC8 W25X10V W25X10V @WSON8 W25X10V @SOIC8 W25X16 W25X16 @SOIC8 W25X16 @SOIC16 W25X16AL W25X16AL @SOIC8 W25X16AL @SOIC16 W25X16AV W25X16AV @SOIC8 W25X16AV @SOIC16 W25X16BV W25X16BV @SOIC8 W25X16BV @SOIC16 W25X16V W25X16V @SOIC8 W25X16V @SOIC16 W25X20AL W25X20AL @WSON8 W25X20AL @SOIC8 W25X20AV W25X20AV @WSON8 W25X20AV @SOIC8 W25X20BL W25X20BL @WSON8 W25X20BL @SOIC8 W25X20BV W25X20BV @WSON8 W25X20BV @SOIC8 W25X20CL W25X20CL @WSON8 W25X20CL @SOIC8 W25X20L W25X20L @WSON8 W25X20L @SOIC8 W25X20V W25X20V @WSON8 W25X20V @SOIC8 W25X32 W25X32 @SOIC8 W25X32 @SOIC16 W25X32AV W25X32AV @SOIC8 W25X32AV @SOIC16 W25X32BV W25X32BV @SOIC8 W25X32BV @SOIC16 W25X32V W25X32V @SOIC8 W25X32V @SOIC16 W25X40AL W25X40AL @WSON8 W25X40AL @SOIC8 W25X40AV W25X40AV @WSON8 W25X40AV @SOIC8 W25X40BL W25X40BL @WSON8 W25X40BL @SOIC8 W25X40BV W25X40BV @WSON8 W25X40BV @SOIC8 W25X40CL W25X40CL @WSON8 W25X40CL @SOIC8 W25X40L W25X40L @WSON8 W25X40L @SOIC8 W25X40V W25X40V @WSON8 W25X40V @SOIC8 W25X64 @SOIC8 W25X64 @SOIC16 W25X64BV @SOIC8 W25X64BV @SOIC16 W25X64V @SOIC8 W25X64V @SOIC16 W25X80AL W25X80AL @WSON8 W25X80AL @SOIC8 W25X80AV W25X80AV @WSON8 W25X80AV @SOIC8 W25X80BV W25X80BV @WSON8 W25X80BV @SOIC8 W25X80L W25X80L @WSON8 W25X80L @SOIC8 W25X80V W25X80V @WSON8 W25X80V @SOIC8 W27C01 W27C01 @PLCC32 W27C01 @TSOP32 W27C010 W27C010 @PLCC32 W27C010 @TSOP32 W27C02 W27C02 @PLCC32 W27C02 @TSOP32 W27C020 W27C020 @PLCC32 W27C020 @TSOP32 W27C04 W27C04 @PLCC32 W27C04 @TSOP32 W27C040 W27C040 @PLCC32 W27C040 @TSOP32 W27C257 @DIP28 W27C257 @PLCC32 W27C512 @DIP28 W27C512 @PLCC32 W27E01 W27E01 @PLCC32 W27E01 @TSOP32 W27E010 W27E010 @PLCC32 W27E010 @TSOP32 W27E02 W27E02 @PLCC32 W27E02 @TSOP32 W27E020 W27E020 @PLCC32 W27E020 @TSOP32 W27E040 W27E040 @PLCC32 W27E040 @TSOP32 W27E257 @DIP28 W27E257 @PLCC32 W27E512 @DIP28 W27E512 @PLCC32 W27L01 W27L01 @PLCC32 W27L01 @TSOP32 W27L010 W27L010 @PLCC32 W27L010 @TSOP32 W27L02 W27L02 @PLCC32 W27L02 @TSOP32 W29C010 W29C010 @PLCC32 W29C010 @TSOP32 W29C011 W29C011 @PLCC32 W29C011 @TSOP32 W29C020 W29C020 @PLCC32 W29C020 @TSOP32 W29C020C W29C020C @PLCC32 W29C020C @TSOP32 W29C022 W29C022 @PLCC32 W29C022 @TSOP32 W29C040 W29C040 @PLCC32 W29C040 @TSOP32 W29C042 W29C042 @PLCC32 W29C042 @TSOP32 W29C512 W29C512 @PLCC32 W29C512 @TSOP32 W29EE010 W29EE010 @PLCC32 W29EE010 @TSOP32 W29EE011 W29EE011 @PLCC32 W29EE011 @TSOP32 W29EE012 W29EE012 @PLCC32 W29EE012 @TSOP32 W29EE512 W29EE512 @PLCC32 W29EE512 @TSOP32 W39F010 W39F010 @PLCC32 W39F010 @TSOP32 W39L010 @PLCC32 W39L010 @TSOP32 W39L020 @PLCC32 W39L020 @TSOP32 W39L040 @PLCC32 W39L040 @TSOP32 W39L040A W39L040AP @PLCC32 W39L040AT @TSOP32 W39L040AQ @VSOP32 W39L512 @PLCC32 W39L512 @TSOP32 W39V040A @PLCC32 W39V040A @TSOP32 W39V040B @PLCC32 W39V040B @TSOP32 W39V040C @PLCC32 W39V040C @TSOP32 W39V040FA @PLCC32 W39V040FA @TSOP32 W39V040FB @PLCC32 W39V040FB @TSOP32 W39V040FC @PLCC32 W39V040FC @TSOP32 W39V080A @PLCC32 W39V080A @TSOP32 W39V080A @TSOP40 W39V080FA @PLCC32 W39V080FA @TSOP32 W39V080FA @TSOP40 W49F002 W49F002 @PLCC32 W49F002 @TSOP32 W49F002A W49F002A @PLCC32 W49F002A @TSOP32 W49F002B W49F002B @PLCC32 W49F002B @TSOP32 W49F002U W49F002U @PLCC32 W49F002U @TSOP32 W49F020 W49F020 @PLCC32 W49F020 @TSOP32 W49F102Q @VSOP40 W49F201T @TSOP48 W49F201S @SOP44 W49L102Q @VSOP40 W49L201T @TSOP48 W49L201S @SOP44 W49V002 @PLCC32 W49V002 @TSOP32 W49V002A @PLCC32 W49V002A @TSOP32 W49V002F @PLCC32 W49V002F @TSOP32 W49V002FA @PLCC32 W49V002FA @TSOP32 W78E51 W78E51 @PLCC44 W78E51B W78E51B @PLCC44 W78E51C W78E51C @PLCC44 W78E52 W78E52 @PLCC44 W78E52B W78E52B @PLCC44 W78E52C W78E52C @PLCC44 W78E54 W78E54 @PLCC44 W78E54B W78E54B @PLCC44 W78E54C W78E54C @PLCC44 W78E58 W78E58 @PLCC44 [ WINGSHING ] 14 PCS WS24C02 WS24C02 @SOIC8 WS24C04 WS24C04 @SOIC8 WS24C08 WS24C08 @SOIC8 WS24C16 WS24C16 @SOIC8 WS24W04 WS24W04 @SOIC8 WS24W08 WS24W08 @SOIC8 WS24W16 WS24W16 @SOIC8 [ WSI ] 19 PCS WS27C010F @DIP32 WS27C010F @PLCC32 WS27C010L @DIP32 WS27C010L @PLCC32 WS27C010L @TSOP32 WS27C128F @DIP28 WS27C128F @PLCC32 WS27C256L @DIP28 WS27C256L @PLCC32 WS27C512F @DIP28 WS27C512F @PLCC32 WS27C512L @DIP28 WS27C512L @PLCC32 WS27C64 @DIP28 WS27C64 @PLCC32 WS57C128FB @DIP28 WS57C128FB @PLCC32 WS57C256F @DIP28 WS57C256F @PLCC32 [ XICOR ] 94 PCS X2402 X2402 @SOIC8 X2444 X2444 @SOIC8 X2444I X2444I @SOIC8 X24C01 X24C01 @SOIC8 X24C01A X24C01A @SOIC8 X24C02 X24C02 @SOIC8 X24C04 X24C04 @SOIC8 X24C04I X24C04I @SOIC8 X24C08 X24C08 @SOIC8 X24C08I X24C08I @SOIC8 X24C16 X24C16 @SOIC8 X24C16I X24C16I @SOIC8 X24C44 X24C44 @SOIC8 X24C44I X24C44I @SOIC8 X24C45 X24C45 @SOIC8 X24C45I X24C45I @SOIC8 X25010 X25010 @SOIC8 X25020 X25020 @SOIC8 X25040 X25040 @SOIC8 X25041 X25041 @SOIC8 X25043 X25043 @SOIC8 X25045 X25045 @SOIC8 X25080 X25080 @SOIC8 X25128 X25128 @SOIC8 X25160 X25160 @SOIC8 X25170 X25170 @SOIC8 X25320 X25320 @SOIC8 X25330 X25330 @SOIC8 X25640 X25640 @SOIC8 X25642 X25642 @SOIC8 X25650 X25650 @SOIC8 X25F008-5 X25F008-5 @SOIC8 X25F008(1.8v) X25F008(1.8v) @SOIC8 X25F016-5 X25F016-5 @SOIC8 X25F016(1.8v) X25F016(1.8v) @SOIC8 X25F032-5 X25F032-5 @SOIC8 X25F032(1.8v) X25F032(1.8v) @SOIC8 X25F064-5 X25F064-5 @SOIC8 X25F064(1.8v) X25F064(1.8v) @SOIC8 X2804A X2804AI X2816A X2816B X2816C X28256 X2864AP X28C010 X28C010 @PLCC32 X28C010 @TSOP32 X28C64 X28C256 X5043 X5043 @SOIC8 X5045 X5045 @SOIC8 [ YMC ] 30 PCS Y24LC02 Y24LC02 @SOIC8 Y24LC02 @TSSOP8 Y24LC04 Y24LC04 @SOIC8 Y24LC04 @TSSOP8 Y24LC08 Y24LC08 @SOIC8 Y24LC08 @TSSOP8 Y24LC16 Y24LC16 @SOIC8 Y24LC16 @TSSOP8 Y93LC46(x8) Y93LC46(x8) @SOIC8 Y93LC46(x8) @TSOP8 Y93LC46(x16) Y93LC46(x16) @SOIC8 Y93LC46(x16) @TSOP8 Y93LC66(x8) Y93LC66(x8) @SOIC8 Y93LC66(x8) @TSOP8 Y93LC66(x16) Y93LC66(x16) @SOIC8 Y93LC66(x16) @TSOP8 Y93LC86(x8) Y93LC86(x8) @SOIC8 Y93LC86(x8) @TSOP8 Y93LC86(x16) Y93LC86(x16) @SOIC8 Y93LC86(x16) @TSOP8 [ ZEMPRO Elec ] 12 PCS TS25L512A TS25L512A @SOP8 TS25L010A TS25L010A @SOP8 TS25L020A TS25L020A @SOP8 TS25L16AP TS25L16AP @SOP8 TS25L16BP TS25L16BP @SOP8 TS25L16P TS25L16P @SOP8 [ ZHENGXIN ] 8 PCS LX24C02 LX24C02 @SOIC8 LX24C04 LX24C04 @SOIC8 LX24C08 LX24C08 @SOIC8 LX24C16 LX24C16 @SOIC8 [ Standard SRAM ] 10 PCS 6116 6164 61256 61512 6264 62256 62512 628128 628256 628512 [ Logic Ic ] 166 PCS 14001 14011 14012 14013 14014 14015 14017 14018 14021 14023 14025 14049 14050 14051 14052 14053 14069 14070 14071 14073 14075 14077 14081 14093 14160 14161 14162 14163 14174 14175 4001 4011 4012 4013 4014 4015 4017 4018 4019 4021 4023 4025 4030 4049 4050 4051 4052 4053 4069 4070 4071 4073 4075 4077 4081 4093 40160 40161 40162 40163 40174 40175 40192 40193 74HC(LS)00 74HC(LS)01 74HC(LS)02 74HC(LS)03 74HC(LS)04 74HC(LS)05 74HC(LS)06 74HC(LS)07 74HC(LS)08 74HC(LS)09 74HC(LS)10 74HC(LS)11 74HC(LS)12 74HC(LS)13 74HC(LS)14 74HC(LS)15 74HC(LS)16 74HC(LS)17 74HC(LS)18 74HC(LS)19 74HC(LS)20 74HC(LS)21 74HC(LS)22 74HC(LS)24 74HC(LS)26 74HC(LS)27 74HC(LS)28 74HC(LS)30 74HC(LS)32 74HC(LS)33 74HC(LS)34 74HC(LS)35 74HC(LS)36 74HC(LS)37 74HC(LS)38 74HC(LS)39 74HC(LS)40 74HC(LS)42 74HC(LS)43 74HC(LS)45 74HC(LS)74 74HC(LS)86 74HC(LS)93 74HC(LS)112 74HC(LS)122 74HC(LS)123 74HC(LS)125 74HC(LS)126 74HC(LS)128 74HC(LS)132 74HC(LS)133 74HC(LS)134 74HC(LS)136 74HC(LS)138 74HC(LS)139 74HC(LS)140 74HC(LS)145 74HC(LS)153 74HC(LS)155 74HC(LS)156 74HC(LS)157 74HC(LS)158 74HC(LS)160 74HC(LS)161 74HC(LS)162 74HC(LS)163 74HC(LS)164 74HC(LS)165 74HC(LS)166 74HC(LS)174 74HC(LS)175 74HC(LS)192 74HC(LS)193 74HC(LS)240 74HC(LS)241 74HC(LS)244 74HC(LS)245 74HC(LS)257 74HC(LS)258 74HC(LS)266 74HC(LS)268 74HC(LS)273 74HC(LS)367 74HC(LS)373 74HC(LS)374 74HC(LS)377 74HC(LS)378 74HC(LS)386 74HC(LS)390 74HC(LS)393 74HC(LS)563 74HC(LS)564 74HC(LS)573 74HC(LS)574 74HC(LS)576 74HC(LS)580 74HC(LS)640 74HC(LS)641 74HC(LS)642 74HC(LS)643 74HC(LS)644 74HC(LS)645 Total: 13137 PCS -------------------- Живы будем - Не помрем !
Текстовая версия | Сейчас: 30.7.2025, 22:18 |
