17.5.2015, 13:13
![]() Администратор ![]() ![]() ![]() ![]() ![]() Группа: Root Admin Сообщений: 6 377 Регистрация: 7.1.2006 Из: Красноярск Пользователь №: 1 |
24.5.2015, 15:21
Ampex 210 Plus Very popular terminal, with monochrome display and RS-232 port, with software configuration (battery-backed), RTC, memory buffer "window mode" and many configuration options. It has a wide range of baud rates and is quite durable. Ampex terminals were used in industrial systems as well as in office ones, in Poland usually with PC machines as servers. The unit is built around Z80A CPU, it has dedicated 3515260 PLA chip and MC2672B4P CRT driver. Connection is made with AMI18828MHD serial driver chip, but it can be modified using installable module in a socket. Model 210 Plus Year: 1989 CPU: Z80 Memory: 8K Display: Monochrome green CRT Keyboard: Dedicated on 4-pin connector. Main port: Serial RS-232 Additional ports: Printer RS-232 ROM
Ampex_210_.zip ( 16.13 килобайт )
Кол-во скачиваний: 2858Manual
Ampex210man.djv ( 1.89 мегабайт )
Кол-во скачиваний: 4718-------------------- Живы будем - Не помрем !
| Текстовая версия | Сейчас: 17.5.2026, 14:04 |
