7.6.2020, 1:40
![]() Администратор ![]() ![]() ![]() ![]() ![]() Группа: Root Admin Сообщений: 6 373 Регистрация: 7.1.2006 Из: Красноярск Пользователь №: 1 |
Консолидирую всю информацию по SCSI и PDP-11
Контроллеры SCSI для QBUS Код M5976-AA KZQSA Q Qbus to SCSI adapter M5976-SA KZQSA-SA Q Qbus to SCSI adapter (for BA200/400 enclosures) M5976-SA with S-box handle M5977-AA RQZX1 Q Qbus to SCSI disk (MSCP) and tape (TMSCP) adapter MQ759 Q Dilog disk/tape adapter. Emulates MSCP & TMSCP. SA450 port, RX33/50 compatible, 7 x SCSI devices + 2 SA450 floppy drives SCDC-11 Q Andromeda SCSI controller. Emulates MSCP. SQ3703A Q Dilog SCSI tape adapter. Emulates TMSCP. BA4000. Replaced by SQ3709 SQ3706A Q Dilog SCSI disk adapter. Emulates MSCP. BA4000. Replaced by SQ3709 SQ3709 Q Dilog SCSI disk/tape adapter. Emulates MSCP and TMSCP. 7 x SCSI devices, BA4000. Replaces SQ3703A & SQ3706A SQ3723A Q Dilog SCSI differential tape adapter. BA4000. Emulates TMSCP. BA4000 SQ3726A Q Dilog SCSI differential disk adapter. Emulates MSCP. SQ703A Q Dilog SCSI tape adapter. Emulates TMSCP Replaced by SQ739 SQ706A Q Dilog SCSI disk adapter. Emulates MSCP. Replaced by SQ739 SQ713A Q Dilog SCSI differential tape adapter. Emulates TMSCP SQ706 Q Dilog SCSI disk controller for Ramstor 5150 SQ739 Q Dilog disk/tape adapter. Emulates MSCP & TMSCP. 7 x SCSI devices. Replaces SQ703A and SQ706A SU723A U Dilog SCSI tape adapter. Emulates TMSCP. 7 drives SU726A U Dilog SCSI disk adapter. Emulates MSCP. 7 drives UC01/LX Q Emulex SCSI bus adaptor. Emulates 1-4 RL01/RL02. 22-bit. Includes BDV11-compatible line-time clock and sockets for bootstrap ROMs and bus terminators. UC02 Q Emulex SCSI bus (ANSI X3T9.2) adaptor. Emulates MSCP controller for 1-4 disks. 22-bit. UC03 Q Emulex SCSI bus adaptor. Emulates MSCP controller UC04 Q Emulex SCSI bus adaptor. Emulates MSCP controller UC06D Q Emulex SCSI bus adaptor. UC07D Q Emulex single SCSI bus adaptor. UC08-2 Q Emulex dual SCSI bus adaptor. UC12 U Emulex SCSI bus adaptor. Emulates MSCP controller UC13 U Emulex SCSI bus adaptor. Emulates MSCP controller UC14 U Emulex SCSI bus adaptor. Emulates MSCP controller QTO Q TD Systems SCSI TMSCP tape controller, LSI-11 & VAX config and diagnostic programmes in ROM, NVRAM config settings. Q22. Ссылки по теме http://web.frainresearch.org:8080/projects.../3pdiskcntl.php Сравнение контроллеров по скорости Цитата I did (and published) some benchmarks of SCSI MSCP-emulating controllers probably a decade ago. And indeed the CMD CQD 440 was the winner. But they all beat the pants off a RQDX3! Here are the peak data rates measured for read and write 64 blocks-at-a-time: Read Write ---------- ---------- Andromeda SCDC 2.298 MB/s 1.131 MB/s CMD CQD440 2.397 MB/s 1.525 MB/s CMD CQD220 1.418 MB/s 0.882 MB/s CMD CQD220A 2.088 MB/s 1.409 MB/s DEC RQZX1 1.379 MB/s 1.097 MB/s Viking QDT 0.846 MB/s 0.704 MB/s DEC RQDX3 0.164 MB/s 0.161 MB/s The benchmarks were done under RT11FB 5.7 doing 1, 2, 4, 8, 16, 32, and 64 block-at-a-time READW's and WRITW's to 16384-block data files. A KDJ11B (PDP-11/73) CPU with 2 Megabytes of Clearpoint non-PMI memory was used for the bencharmks. With the SCSI controllers a Barracuda 7200 RPM ST15230N drive was used; with the RQDX3 a RD52 drive was used. отсюда https://vmsnet.pdp-11.narkive.com/kfYv0Qt6/...-scsi-interface -------------------- Живы будем - Не помрем !
7.6.2020, 15:54
Полноценная поддержка SCSI появилась в RT11 5.7
New Hardware Support
Ссылки по теме http://www.classiccmp.org/pipermail/cctalk...ber/035345.html -------------------- Живы будем - Не помрем !
| Текстовая версия | Сейчас: 15.3.2026, 20:56 |
