23.8.2016, 11:40
Осенью 2014ого я поставил SSD PNY Prevail Elite SSD9SC240GEDA-PB 240 Гб
модель SSD2SC240G0LC726B104-297 на сервер базы данных (на котором крутится и этот форум в том числе) Сейчас, те почти через 2 года я решил оценить остаточный ресурс данных SSD (они стоят у меня в программном зеркале MD ) Для начала я решил достать техподдержку PNY ибо уж производитель должен знать как проверить их железку Цитата Good day, support! I have 2 in the SSD of your production Please help assess their residual resource SMART printing an attachment ---------------- Dear Mr Could you please explain what do you need to know from those SSD? Sincerely. ---------------- Good day, tech-sup. > Dear Mr > Could you please explain what do you need to know from those SSD? > Sincerely. I use your SSD in the server database. I want to evaluate the residual SSD resource for planning new purchases. In an attachment listing S.M.A.R.T. these discs Please help ---------------- Dear Mr Im not sure to understand what do you need, could you please clarify. Do you need to check if we have this SSD model on stock? Sincerely. ---------------- Dear Mr Thank you for clarifying the query. The information regarding the maximum number of supported write cycles should be stored in the firmware, with no access for the S.M.A.R.T. ability. I don't see how that technology would know how to compute the number of remaining write cycles before the SSD go to the read-only status. It would only read for how long the device has run, how many bytes have been read or written. It is possible to get some data from S.M.A.R.T. reports such as those files you sent us. A big part of it is quite meaningless for the common mortal. The other part is relevant, provided the viewing utility can clearly show it. Maybe you could use one such as CrystalDiskInfo? You will get for instance the number of total GBytes that have been written on a specific SSD. That number, divided by the capacity of the device, should provide the number of write cycles that have already been used. Does this help? -------------------- Живы будем - Не помрем !
23.8.2016, 12:06
И так, техподдержка хоть и не в курсе какие данные отдаются через S.M.A.R.T
но однозначно подтвердила гипотезу об оценке ресурса через количество записанной информации итак у меня заявлен ресурс: Код Ресурс SSD 2.29 петабайт (иначе говоря 2290ТБ) Ресурс SSD (циклов стирания/записи) 10K циклов стирания/записи остается понять сколько записано начнем Код #uptime 11:43:51 up 120 days, 25 min, 4 users, load average: 0.58, 0.40, 0.35 # iostat avg-cpu: %user %nice %system %iowait %steal %idle 5,34 0,49 0,87 1,28 0,00 92,01 Device: tps Blk_read/s Blk_wrtn/s Blk_read Blk_wrtn sda 269,73 2153,73 2286,57 22333246582 23710756484 sdb 259,43 0,02 2286,57 251024 23710756484 * обратите внимание что чтение идет практически только с SDA, нам потом это пригодится нас интересует оценка количества записанной информации ГБ в сутки если исходить из Blk_wrtn/s то в сутки набегает ~94GB если исходить из Blk_wrtn то 11306GB/120=~94GB значит в год ~34ТБ всего прошло c 7.09.2014 по 23.08.2016 365+366-15=716дней те записано должно быть примерно 67ТБ теперь посмотрим S.M.A.R.T. sda Код 231 Temperature_Celsius 0x0013 097 097 010 Pre-fail Always - 0 233 Media_Wearout_Indicator 0x0032 000 000 000 Old_age Always - 54497 234 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 57879 241 Total_LBAs_Written 0x0032 000 000 000 Old_age Always - 57879 242 Total_LBAs_Read 0x0032 000 000 000 Old_age Always - 77960 sdb Код 231 Temperature_Celsius 0x0013 098 098 010 Pre-fail Always - 0 233 Media_Wearout_Indicator 0x0032 000 000 000 Old_age Always - 55559 234 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 57879 241 Total_LBAs_Written 0x0032 000 000 000 Old_age Always - 57879 242 Total_LBAs_Read 0x0032 000 000 000 Old_age Always - 15 по информации из сети параметр 231 означает остаточный ресурс SSD в % если всего SSD рассчитана на 2290ТБ а у меня записано ~67ТБ что примерно 2.9% соответственно эту информацию можно считать правдоподобной теперь посмотрим на параметры, которые явно говорят о связи с количеством записанного и считанного - это 241 Total_LBAs_Written и 242 Total_LBAs_Read на основании данных iostat мы помним что чтение было почти только с SDA и тут мы видим подтверждение этого - 242 Total_LBAs_Read у sdb мал! соответственно у нас есть все основания считать, что информация в параметрах 241 и 242 имеет отношение к делу, остается проверить размерность. и судя по всему это гигабайты, просто нагрузка за 2 года возрасла и мы получили большую цифру в 67ТБ против 57ТБ остаются параметры 233 Media_Wearout_Indicator 234 Unknown_Attribute судя по числам они тоже имеют какое-то отношение к остаточному ресурсу, однако для нас это уже малопринципиально - с оценкой ресурса уже стало понятно в текущем режиме, ресурс расходуется со скоростью ~1.5% в год, те SSD проживут дольше чем будут заменены из-за морального устаревания -------------------- Живы будем - Не помрем !
2.10.2019, 11:41
На дворе 2019й близится к концу
посмотрим ресурс: sda Код 231 Temperature_Celsius 0x0013 086 086 010 Pre-fail Always - 0 233 Media_Wearout_Indicator 0x0032 000 000 000 Old_age Always - 165950 234 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 286811 241 Total_LBAs_Written 0x0032 000 000 000 Old_age Always - 286811 242 Total_LBAs_Read 0x0032 000 000 000 Old_age Always - 241350 sdb Код 231 Temperature_Celsius 0x0013 086 086 010 Pre-fail Always - 0 233 Media_Wearout_Indicator 0x0032 000 000 000 Old_age Always - 167384 234 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 286811 241 Total_LBAs_Written 0x0032 000 000 000 Old_age Always - 286811 242 Total_LBAs_Read 0x0032 000 000 000 Old_age Always - 19 осталось ~86% ресурса SSD средний расход ~2.8% ресурса в год вообще расход вырос и можно прогнозировать срок службы как минимум еще 10лет при расходе 7% и запасе в 10% -------------------- Живы будем - Не помрем !
11.2.2020, 14:33
Обратил внимание на
Код ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 9 Power_On_Hours 0x0032 084 084 000 Old_age Always - 14312 (218 110 0) походу счетчик Power_On_Hours всего 15bit тк должно быть 47080 часов ps: и хорошо что у меня не HP тк у них это проблема https://support.hpe.com/hpesc/public/docDis...-a00092491en_us -------------------- Живы будем - Не помрем !
27.9.2021, 21:10
срез на сегодня
sda Код 231 Temperature_Celsius 0x0013 079 079 010 Pre-fail Always - 0 233 Media_Wearout_Indicator 0x0032 000 000 000 Old_age Always - 232841 234 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 429700 241 Total_LBAs_Written 0x0032 000 000 000 Old_age Always - 429700 242 Total_LBAs_Read 0x0032 000 000 000 Old_age Always - 486172 sdb Код 231 Temperature_Celsius 0x0013 079 079 010 Pre-fail Always - 0 233 Media_Wearout_Indicator 0x0032 000 000 000 Old_age Always - 235117 234 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 429700 241 Total_LBAs_Written 0x0032 000 000 000 Old_age Always - 429700 242 Total_LBAs_Read 0x0032 000 000 000 Old_age Always - 21 те осталось 79% -------------------- Живы будем - Не помрем !
14.11.2022, 23:27
Весной этого года было принято решении о миграции на более толстые SSD тк 240GB стало не хватать под данные. Соответственно сервер с данными SSD был выведен из эксплуатации и работал как тестовый сервер.
И вот сегодня я обнаружил, что одна из SSD 240GB перестала отвечать осталась вторая у которой Код ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x0033 095 095 050 Pre-fail Always - 10807210 5 Reallocated_Sector_Ct 0x0033 100 100 003 Pre-fail Always - 0 9 Power_On_Hours 0x0032 076 076 000 Old_age Always - 21297 (181 32 0) 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 79 171 Unknown_Attribute 0x000a 000 000 000 Old_age Always - 0 172 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 0 174 Unknown_Attribute 0x0030 000 000 000 Old_age Offline - 18 177 Wear_Leveling_Count 0x0000 000 000 000 Old_age Offline - 26 181 Program_Fail_Cnt_Total 0x000a 000 000 000 Old_age Always - 0 182 Erase_Fail_Count_Total 0x0032 000 000 000 Old_age Always - 0 187 Reported_Uncorrect 0x0012 100 100 000 Old_age Always - 0 194 Temperature_Celsius 0x0022 029 048 000 Old_age Always - 29 (Min/Max 13/48) 195 Hardware_ECC_Recovered 0x001c 120 120 000 Old_age Offline - 10807210 196 Reallocated_Event_Count 0x0033 100 100 003 Pre-fail Always - 0 201 Soft_Read_Error_Rate 0x001c 120 120 000 Old_age Offline - 10807210 204 Soft_ECC_Correction 0x001c 120 120 000 Old_age Offline - 10807210 230 Head_Amplitude 0x0013 100 100 000 Pre-fail Always - 100 231 Temperature_Celsius 0x0013 075 075 010 Pre-fail Always - 0 233 Media_Wearout_Indicator 0x0032 000 000 000 Old_age Always - 276376 234 Unknown_Attribute 0x0032 000 000 000 Old_age Always - 486015 241 Total_LBAs_Written 0x0032 000 000 000 Old_age Always - 486015 242 Total_LBAs_Read 0x0032 000 000 000 Old_age Always - 57 те та которая была основной в зеркале - те и читала и писала, вышла из строя. в принципе 8лет это хороший срок для SSD. Однако, ресурс по SMART не дает информации о скорой смерти SSD - те до выхода из строя у нее оставался еще огромный ресурс. -------------------- Живы будем - Не помрем !
18.12.2023, 14:06
Сдохла и вторая SSD
вообще за это время я поменял уже несколько SSD и сформировал мнение об этом Резюме: - SSD хорошо, но бекапы лучше хранить на физических жестких дисках - предсказать смерть SSD крайне сложно, SMART не показатель - для длительного хранения информации без изменения SSD не годятся -------------------- Живы будем - Не помрем !
18.6.2024, 11:03
Стоит добавить еще одну ложку дегдя
для нового рабочего компа в марте 2023 я приобрел SSD - NVME SSD SKC3000D2048G и в ноябре 2023 заметил некоторые затупы в работе компа, и тут решил проверить он под систему и софт, ну пару игр валяется. иначе говоря эксплуатируется достаточно слабо - все рабочие данные на DFS. запустил тест викторией и офигел занято на ней примерно половина и эта половина в начале диска пройдясь FARом и покопировав в NUL некоторые директории, подтвердил, что к примеру недавно(сентябрь) скопированный BG3 читается на скорости 3-5GB/c а chatgpt локальный который был скопирован на SSD в апреле этого года, откровенно тупит - средня скоростть в районе 100MB/c а местами вообще 16-30МБ/c более подробно про SSD эту SSDшку я успешно обменял по-гарантии, но конечно, уже не доверяя производителю KINGSTON я взял SSD SAMSUNG MZQL21T9HCJR-00A07 с U.2. и положил туда копию рабочего SSD в ноябре 2023его дабы понять - кто будет прокисать а кто нет и вот в мае 2024ого я увидел что KINGSTON прокисает! иначе говоря данные SSD имеют врожденный дефект - они не могут хранить данные более 3х месяцев и далее начинается деградация скорости ! а вот как читается самсунг пруф - SMART до сканирования: и после те видно что впервые с нее были считаны эти 2TB еще в одном домашнем компе где кроме браузера ничего не запускается сдохла мелкая 120GB SSD - отработала чуть больше гарантийного срока (до нее 60GB AMD - была заменена по-гарантии) и есть свежая SSD Patriot P220 2048GB начала прокисать после 500 часов работы (!) при минимальной нагрузке - туда писались арчивлоги Код 241 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 7612 242 Total_LBAs_Read 0x0032 100 100 000 Old_age Always - 5203 Сейчас я смотрю на приобретение не новых SSD а на старые SAS-диски они-то де-факто почти вечные ну банально - сейчас в моих серверах работают диски 2007ого года выпуска - им уже 17 лет ну вот к примеру лог Код Errors Corrected by Total Correction Gigabytes Total ECC rereads/ errors algorithm processed uncorrected fast | delayed rewrites corrected invocations [10^9 bytes] errors read: 0 0 0 0 0 1666664.522 0 write: 0 0 0 0 0 41825.410 0 перевожу на понятный - с этого диска уже считано 1,5 ПБ (!) и записан 41TB и для SSD такой ресурс в принципе недостижим или вот этот бытовой - пашет у меня 8,5 лет (на самом деле у меня их куча - больше 60шт - просто MSA20 не отдает SMART и посмотреть могу только по одному, в сервере бекапа) Код Model Family: Seagate Barracuda 7200.14 (AF) Device Model: ST2000DM001-1CH164 Serial Number: Z1E6NXYG Код 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 73752h+23m+21.004s -------------------- Живы будем - Не помрем !
27.6.2024, 13:07
Подробнее про SSD Patriot P220 2048GB
отработала 508 часов и начала тормозить сделал скан в виктории поменял на деньги поставлю SAS винты -------------------- Живы будем - Не помрем !
| Текстовая версия | Сейчас: 16.8.2026, 7:06 |
