![]() Администратор ![]() ![]() ![]() ![]() ![]() Группа: Root Admin Сообщений: 6 343 Регистрация: 7.1.2006 Из: Красноярск Пользователь №: 1 ![]() |
Софт
1. Development board introduction 2, CPLD development board V22 instructions 3. Development board schematic: EPM7128A1_sch.pdf 5. serial debugging assistant V2.1.exe 6. experimental VHDL source program, the development board provides 18 routines. 1. light: the light-emitting two tubes flashing. 2. shift: The LED is shifted to light. 3. ledwater: to achieve a water lamp. 4. PWM: Realize pulses with different duty cycles. . 5. dpyloop: digital loop display 0 ~ F. 6. traffic: implement a traffic light. 7. plus: the pulse count generated by SW1. 8. clock: implement a clock. 9. buzz: buzzer. 10. RS232: Serial port transmission/reception program. With the "serial debugging assistant", receive/send experiments. 11. AD_DA: AD / DA conversion program, I2C program. 13. KS1838T: infrared receiving program, single bus program. . 14. DS1302: calendar clock program, SPI program. 15. LCD1602: 1602 character LCD display program. 16. LCD12864: 12864 graphic LCD display program. 17. CONV: Test procedure for conversion of integers and semaphores. 18. StepCtrol: to achieve a four-phase eight-beat stepper motor speed control program. ![]() -------------------- Живы будем - Не помрем !
Технические параметры
![]() Серия max 7000s Тип программирования isp Количество блоков логических массивов 8 Количество макроячеек 128 Количество вентилей 2500 Количество входов/выходов 68 Напряжение питания, В 4.75:5.25 Рабочая температура,°C 0:+70 Корпус plcc-84(29.31x29.31) Даташиты: ![]() ![]() DevBoard - какие были в природе: https://habr.com/post/277947/ http://www.chatzones.co.uk/discus/messages...html?1294003072 https://web.archive.org/web/20021213042311/...v/unv-kits.html http://plaza.ufl.edu/maxk/8535.htm https://www.kora.hu/index.php?m=16352&FIX_catid=700 Информация по платам разработки http://www.pyroelectro.com/tutorials/up2/hardware.html http://hamblen.ece.gatech.edu/ALTERA/altera.htm http://www.pyroelectro.com/tutorials/up2/ Документация на русском Лабораторная плата UP1 Altera СПетербург 2002 ![]() DevBoard - какие можно купить https://ru.aliexpress.com/af/EPM7128--devel...ewCP=y&jump=afs https://www.ebay.com/sch/i.html?_from=R40&_...lrs=spell_check Ссылки по теме: https://habr.com/post/277947/ Где купить EPM7128SLC84-15N https://www.ebay.com/itm/10PCS-Programmable...bn7oB:rk:1:pf:0 https://www.ebay.com/itm/10PCS-Programmable...bn7oB:rk:2:pf:0 https://ru.aliexpress.com/af/epm7128slc84-1...810&needQuery=n Софт ![]() ![]() ![]() -------------------- Живы будем - Не помрем !
whiterabbit |
![]() Новичок ![]() Группа: Участники Сообщений: 1 Регистрация: 16.2.2023 Из: Петербург/Лондон Пользователь №: 35 953 ![]() |
Потрясающе функциональная плата. Я бы с удовольствием себе такую приобрел.
SuperMax поделись как такую добыть? |
Текстовая версия | Сейчас: 16.7.2025, 11:45 |
