X-ufo дорабоки |
X-ufo дорабоки |
3.10.2010, 10:30
Подключение к PC
X-UFO is a very sweet toy, so due to the high price it would be too much to be regretted to let gravity win against our lovely UFO right at the first fly. Beginner aliens can easily hit the ground, and unfortunately the manufacturer hadn't provided for the optional interface between the remote control and a UFO simulator software what one could get the routine of flying by to avoid the mass destruction in the garden, or even the living room. There is a 3.5mm jack connector on the remote unit, but it is designed only for an other remote especially for traning reasons. If we push trainer button, there is only a logical "0" sign on the output. It means that for training we need a remote unit working on exactly the same frequency as the beginners one, and the output -I mentioned above- is only for switching between two remotes. For this reason I had to make some changes to make it able to be attached to the FMS simulator. If you want to practice using simulator, grasp your favourite screwdriver and after removing all the batteries take the remote to pieces! After removing every screws, two side of the box must be slightly pushed to release small fastenings. At the bottom of the box there is a pcb. At its left corner, there is a point signed P65, located at the left of the XTAL. Here you can find a small piece of undressed wire. This is the point where the PPM signal runs into the transmitter unit. Use a thin twin-cable. In this example solder the brown wire to P65, this is the sign, and the grey wire to the negative part of the battery, this is the ground. Bind the wire forward near SW9 parallel with its cables, and let it out through the small hole next to the holder and put the box together. (If you can't find the orphan small wire coming out of the P65 on the pcb, than you should lift the board up, and solder the wire to the tared all-around-feeted processor-brains P65 point.) You can put a connector to the external end of the wire, whatever you want, for example a clipped one, simple mother jack, or RCA. For the other side, you should create the printer port cable as well. The parallel port joystick driver, and the FMS simulator is available at http://www.spmodell.hu/repletoltesek.htm There is an X-UFO modell file for FMS, or a similar four propellered terrible one. Эскизы прикрепленных изображений Прикрепленные файлы DfVti.zip ( 531.46 килобайт ) Кол-во скачиваний: 703 x_ufo.zip ( 742.06 килобайт ) Кол-во скачиваний: 725 -------------------- Живы будем - Не помрем !
3.10.2010, 11:02
комплектацию можно заказать из германии
отсюда Цитата Привет всем! Я сам долго мучелся с улутшением этого аппарата. В итоге заказал из германии 3d гироскоп http://www.xufo-shop.de/shop/article_17188...d%3D17188126%26 . И эта хрень полетела как надо. Этот чудо гироскоп ехал в Питер 2 месяца. В ожидании чуда (пока он ехал) я набрел в инете на валкеровский аналог уфошки http://www.rc-fever.com/walkera-x-ufo-7ch-...ufo-p-1968.html . В итоге приобрел и его,(дошла за две недели) привлекло то что там стоял не механический, а пьезо 3d гироскоп. А по приходу валкеровской уфошки стало ясно что совместно с гирой там стоит (не знаю как по научному называется) датчик горизонта. Тоесть бросаешь ручки на пульте и она возвращается в горизонтальное положение (как с мех гирой).И вот чудо случилось, посылка из германии пришла. Установив немецкий гироскоп на Silverlit эфект превзашел все ожидания. Silverlit висел по курсу колом и ветер это уже была не проблема для него. С легкой липолькой (400mah) можно было легко делать мертвую петлю, правда на высоте около 10м так как не хватало тяги при выходе из петли и нужен был запас высоты. (валкара делает тоже самое только в стандартном исполнении и не чего наворачивать не надо). И еще на немецкой гире нет датчика горизонта. Это отдельный модуль за который немцы просят почти 100 евро !!! В итоге я получил два одинаковых аппарата, но за совершенно разные деньги. Итог UFO Silverlit (в питере) стоит 8000р+гироскоп 8500р (доставкой из германии)+липолька 1000р=17500р!!! Валкеровская уфошка обошлась в 8300р с доставкой из китая (там даже ли-по в комплекте) Мой вам совет. вот тут http://www.rc-fever.com/walkera-dragonfly-...ver-p-2064.html или тут http://www.funrctoys.com/ufo-4-z-16-p-2187...0da56922b6ad753 можно купить отдельно плату от валкеровской уфошки с доставкой обойдется что-то около 1500-2500р а может и меньше, на ней уже есть все и регулятор и приемник и гироскоп и датчик горизонта. Поставил её на раму от Silverlit и в путь. А я в итоге заказал у немцев остольные комплектующие для бк моторов http://www.xufo-shop.de/shop/category_7/00...am=cid%3D104%26 . Взал все кроме рамы (правда весь аппарат встал около 1000 евро) Но зато теперь летаю с камерой весом 150г стабильно бесшумно и аккуратно. К стати к этой валкеровской плате мудрят бк моторы только регуляторы нужны с минимальным временем отклика. для большей стабилизации полета. Нашол это здесь. http://www.rcgroups.com/forums/attachment....hmentid=1905920 -------------------- Живы будем - Не помрем !
3.10.2010, 11:30
отсюда
Цитата Поэтому если хочется более стабильного и динамичного полета, скорее всего необходимо абгрейдить оборудование - перейти на бесколекторники - поставить 3 D гироскопы - поставить АСС акселерометр как сделать есть на сайте и в этом топике у меня где то была 3 D плата гироскопов, могу поискать больше эту систему расширить сложно, поэтому я перешел на http://multicopter.ru/ поглядите может заинтересует если подробнее что пишите dmitri_info@bk.ru C уважением, Дима -------------------- Живы будем - Не помрем !
Текстовая версия | Сейчас: 28.4.2024, 17:26 |
