Консольный клиент DavUtils
Команды: Код Usage: dav command [options] arguments... Commands: list [-altdepcR] [-u <date>] <url> get [-pcRK] [-o <file>] [-u <date>] [-V <version>] <url> put [-pcR] [-k <key>] [-L <lock>] <url> <file...> mkdir [-pc] [-k <key>] [-L <lock>] <url> [file...] remove [-pc] [-L <lock>] <url> [file...] copy [-pcO] [-L <lock>] <url> <url> move [-pcO] [-L <lock>] <url> <url> rename [-pcO] [-L <lock>] <url> <name> export [-pc] [-o <file>] [-u <date>] <url> import [-pc] [-k <key>] [-L <lock>] <url> <file> get-property [-pcx] [-V <version>] [-n <uri>] <url> <property> set-property [-pcx] [-L <lock>] [-n <uri>] <url> <property> [value] remove-property [-pc] [-n <uri>] <url> <property> lock [-pc] [-T timeout] <url> unlock [-pc] [-L <lock>] <url> info [-pc] [-V <version>] <url> date [url] Options: -k <key> Key to use for encryption -p Don't encrypt or decrypt files -c Enable full encryption -R Recursively do the operation for all children -K Keep already present files -o <file> Write output to file (use '-' for stdout) -u <date> Get resources which are modified since the specified date -V <version> Download a specific version of a resource -a show all files -l print resources in long list format -t print content type -d order by last modified date -e show extended flags -O override resources -L <lock> specificy lock token -T <sec> timeout in seconds -n <uri> specify namespace uri -x xml property content -N disable authentication prompt (all commands) -i disable cert verification (all commands) -v verbose output (all commands) Advanced commands: versioncontrol list-versions checkout checkin uncheckout Config commands: add-repository remove-repository list-repositories repository-url add-user remove-user edit-user list-users check-config Instead of an url you can pass a repository name with an optional path: <repository>/path/ Примеры использования получить каталог Код dav list http://192.168.0.170/test/FORTR.DSK.F11 скачать файл Код dav get http://192.168.0.164/test/10.td0 передать файл Код dav put http://192.168.0.164/ 10.td0 Скачать клиент ![]() -------------------- Живы будем - Не помрем !
Поддержка WEBDAV в Linux
Установка Код # yum install davfs2 Код # mount -t davfs http://192.168.0.164/ /mnt/testdav/ Код # umount -t davfs /mnt/testdav/ Данный клиент пока не поддерживается и может только читать файлы на самом деле это странно тк используется таже библиотека Neon которая в NetBOX в FAR и где все летает. -------------------- Живы будем - Не помрем !
Настройка WEBDAV в FAR3
ALT+F1 Идем в NETBOX ![]() ждем Shift+F4 ![]() создаем подключение по типу ![]() можно указывать и DNS-имя и IP адрес нашего AZ-контроллера далее сохраняем ![]() и работаем ![]() ![]() -------------------- Живы будем - Не помрем !
Для подключения с телефона (Андроид)
ставим CX-проводник создаем новое подключение ![]() выбираем webdav ![]() имя-пароль любые ![]() готово: ![]() -------------------- Живы будем - Не помрем !
Текстовая версия | Сейчас: 6.7.2025, 10:12 |
