Распайки разъемов Msx, разводка # pinout |
30.1.2015, 23:48
Разъем слота картриджа
Код 1:/CS1 2:/CS2 3:/CS12 4:/SLTSL 5: RSV(N.C) 6:/RFSH 7:/WAIT 8:/INT 9:/M1 10:/BUSDIR 11:/IORQ 12:/MERQ 13:/WR 14:/RD 15:/RESET 16: RSV(N.C) 17: A 9 18: A15 19: A11 20: A10 21: A 7 22: A 6 23: A12 24: A 8 25: A14 26: A13 27: A 1 28: A 0 29: A 3 30: A 2 31: A 5 32: A 4 33: D 1 34: D 0 35: D 3 36: D 2 37: D 5 38: D 4 39: D 7 40: D 6 41: GND 42: CLOCK 43: GND 44: SW1 45: +5V 46: SW2 47: +5V 48: +12V 49: SOUNDIN 50: -12V Код 1 ROM addresses 4000-7FFF select signal 2 ROM addresses 8000-BFFF select signal 3 ROM addresses 4000-BFFF select signal (for 256k ROM) 4 Slot select signal 5 Reserved signal line - use inhibited 6 Refresh cycle signal 7 CPU's WAIT request signal 8 Interrupt request signal to CPU 9 Signal expressing CPU fetch cycle 10 This signal controls direction of external databus buffer Cartridges are selected and L level is output from each cartridge at data transmission time 11 I/O request signal 12 Memory request signal 13 Write timing signal 14 Read timing signal 15 System reset signal 16 Reserved signal line - use inhibited 17-32 Address bus signals 33-40 Data bus signals 41 Signal ground 42 CPU clock 3.579545MHz 43 Signal ground 44,46 For insertion/removal protect 45,47 +5V power source 48 +12V power source 49 Sound input signal (-5bdm) 50 -12V power source -------------------- Живы будем - Не помрем !
30.1.2015, 23:53
Joystick connector
(Giovanni R. Nunes) DB 9 pins (male) Код 1 2 3 4 5 1 FWD I 5 +5V 6 7 8 9 2 BACK I 6 TRG 1 I/O 3 LEFT I 7 TRG 2 I/O 4 RIGHT I 8 OUT O 9 GND If a mouse is connected to a joystick-port, the pins are used as follows: (Laurens Holst and Giovanni R. Nunes) Код 1 data b0 (in) 2 data b1 (in) 3 data b2 (in) 4 data b3 (in) 5 +5V (out) 6 trigger 1 (in) 7 trigger 2 (in) 8 strobe (out) 9 ground The system works as follows: The MSX Mouse sends 2 signed bytes to the computer, X and Y. This byte must be added to the current X and Y location, so it is a relative movement. So X=0 means X is the same, X=1 means X=+1 and X=255 means X=-1. This is very easy to implement, however it poorly supports mouse speed control, because it's a digital signal. Well, anyways, those 2 bytes are transferred in 4 parts. The computer reads pins 1-4 four times, afterwards signalling the mouse to ready the next 4 bits by complementing pin 8. -------------------- Живы будем - Не помрем !
Текстовая версия | Сейчас: 25.4.2024, 13:33 |
