> VAX 4000-600A: 2. Работа с ошибками, бутовая консоль
сообщение 23.5.2015, 18:19
Итак, ревизия сервера проведена - включаем
KA691-A V2.3, VMB 2.14
Performing normal system tests.
70..69..68..67..66..65..64..63..62..61..60..59..58..57..56..55..
54..53..52..51..50..49..48..47..46..45..44..43..42..41..40..39..
38..37..36..35..34..33..32..31..30..29..28..27..26..25..24..23..
? Test_Subtest_40_06  Loop_Subtest=00  Err_Type=FF   DE_Memory_count_pages.lis
Vec=0000  Prev_Errs=0000   P1=00000001   P2=00000001   P3=7FFFFFFF  P4=00000000
P5=00004000  P6=00040000   P7=00004000   P8=00000000   P9=00000000 P10=00000000
r0=00000002  r1=00000001   r2=00000000   r3=FFFFFFFF   r4=000000A0  r5=00000000
r6=00000000  r7=00000000   r8=00000000   r9=20140758  r10=00000000 r11=2014044B
dser=0000 cesr=00000000 icsr=01 pcsts=F800 pcctl=FC13 cctl=00000021
bcetsts=0000 bcedsts=0000 cefsts=00000200 nests=00 mmcdsr=01111000
mesr=00085000
Normal operation not possible.
осмотримся в загрузочной консоли
вспоминаем RT-11 и набираем
>>>help
Following is a brief summary of all the commands supported by the console:
        UPPERCASE  denotes a keyword that you must type in
        |          denotes an OR condition
        []         denotes optional parameters
        <>         denotes a field specifying a syntactically correct value
        ..         denotes one of an inclusive range of integers
        ...        denotes that the previous item may be repeated
Valid qualifiers:
    /B /W /L /Q /INSTRUCTION
    /G /I /V /P /M
    /STEP: /N: /NOT
    /WRONG /U
Valid commands:
    BOOT [[/R5:]<boot_flags>] [<boot_device>]
    CONFIGURE
    CONTINUE
    DEPOSIT [<qualifiers>] <address> <datum> [<datum>...]
    EXAMINE [<qualifiers>] [<address>]
    FIND [/MEMORY | /RPB]
    HALT
    HELP
    INITIALIZE
    LOGIN
    MOVE [<qualifiers>] <address> <address>
    NEXT [<count>]
    REPEAT <command>
    SEARCH [<qualifiers>] <address> <pattern> [<mask>]
    SET BFLG <boot_flags>
    SET BOOT <boot_device>
    SET CONTROLP <0..1 | DISABLED | ENABLED>
    SET DSSI_ID <bus_number> <id>    ! Type F for ID to use BUS ID plugs
    SET HALT <0..4 | DEFAULT | RESTART | REBOOT | HALT | RESTART_REBOOT>
    SET HOST/DUP/DSSI/BUS:<0..3> <node_number> [<task>]
    SET HOST/DUP/UQSSP </DISK | /TAPE> <controller_number> [<task>]
    SET HOST/DUP/UQSSP <physical_CSR_address> [<task>]
    SET HOST/MAINTENANCE/UQSSP/SERVICE <controller_number>
    SET HOST/MAINTENANCE/UQSSP <physical_CSR_address>
    SET LANGUAGE <1..15>
    SET PSE <0..1 | DISABLED | ENABLED>
    SET PSWD
    SET RECALL <0..1 | DISABLED | ENABLED>
    SHOW BFLG
    SHOW BOOT
    SHOW CONFIG
    SHOW CONTROLP
    SHOW DEVICE
    SHOW DSSI [0..3]
    SHOW DSSI_ID
    SHOW ERRORS
    SHOW ETHERNET
    SHOW HALT
    SHOW LANGUAGE
    SHOW MEMORY [/FULL]
    SHOW PSE
    SHOW QBUS
    SHOW RECALL
    SHOW RLV12
    SHOW SAVED_STATE
    SHOW SCSI
    SHOW TESTS
    SHOW TRANSLATION <physical_address>
    SHOW UQSSP
    SHOW VERSION
    START <address>
    TEST <test_code> [<parameters>]
    UNJAM
    X <address> <count>
отлично!
Осмотримся:
>>>SHOW VERSION
>>>SHOW DEVICE
DSSI Bus 0 Node 0 (SYSTEM)
-DIA0 (RF36)
DSSI Bus 0 Node 1 (USER)
-DIA1 (RF36)
DSSI Bus 0 Node 2 (TROLL2)
-DIA2 (RF36)
DSSI Bus 0 Node 3 (TROLL3)
-DIA3 (RF36)
DSSI Bus 0 Node 4 (TROLL4)
-DIA4 (RF36)
DSSI Bus 0 Node 6 (T88ZQ0)
-MIA6 (TF85)
DSSI Bus 0 Node 7 (*)
DSSI Bus 1 Node 7 (*)
SCSI Adapter 0 (761400), SCSI ID 7
Ethernet Adapter
-EZA0 (08-00-2B-3E-98-E9)
посмотрим что у нас на шине
>>>SHOW QBUS
Scan of Qbus I/O Space
-20000120 (760440) = 1F80 DHQ11/DHV11/CXA16/CXB16/CXY08
-20000122 (760442) = F081
-20000124 (760444) = DD18
-20000126 (760446) = 0000
-20000128 (760450) = 0000
-2000012A (760452) = 0000
-2000012C (760454) = 8000
-2000012E (760456) = 0000
-20000130 (760460) = 1F80 DHQ11/DHV11/CXA16/CXB16/CXY08
-20000132 (760462) = F081
-20000134 (760464) = DD18
-20000136 (760466) = 0000
-20000138 (760470) = 0000
-2000013A (760472) = 0000
-2000013C (760474) = 8000
-2000013E (760476) = 0000
-200001E0 (760740) = 0002 DSV11
-200001E2 (760742) = 0005
-200001E4 (760744) = AAAA
-200001E6 (760746) = 0000
-200001E8 (760750) = 0002 DSV11
-200001EA (760752) = 0005
-200001EC (760754) = AAAA
-200001EE (760756) = 0000
-20000300 (761400) = 0000 KZQSA
-20000302 (761402) = 0000
-20000304 (761404) = 0000
-20000306 (761406) = 0000
-20000308 (761410) = 0007
-2000030A (761412) = 0000
-2000030C (761414) = 0000
-2000030E (761416) = 0000
-20000310 (761420) = 0000
-20000312 (761422) = 0000
-20000314 (761424) = 0000
-20000316 (761426) = 0000
-20000318 (761430) = 0000
-2000031A (761432) = 0000
-2000031C (761434) = 0000
-2000031E (761436) = 0000
-20000320 (761440) = 0000
-20000322 (761442) = 0000
-20000324 (761444) = 0400
-20000326 (761446) = 1004
-20000328 (761450) = 0000
-2000032A (761452) = 0000
-2000032C (761454) = 0000
-2000032E (761456) = 5049
-20000330 (761460) = 8420
-20000332 (761462) = 0000
-20000334 (761464) = 0100
-20000336 (761466) = 0080
-20000338 (761470) = 1E00
-2000033A (761472) = FFFF
-2000033C (761474) = 0000
-2000033E (761476) = 14C0
-20000380 (761600) = 0000 DEFQA
-20000382 (761602) = 0000
-20000384 (761604) = 0000
-20000386 (761606) = 0000
-20000388 (761610) = 0000
-2000038A (761612) = 0000
-2000038C (761614) = 0000
-2000038E (761616) = 0000
-20000390 (761620) = 0000
-20000392 (761622) = 0000
-20000394 (761624) = 0200
-20000396 (761626) = 0000
-20000398 (761630) = 00D2
-2000039A (761632) = 0000
-2000039C (761634) = 0000
-2000039E (761636) = 0000
-200003A0 (761640) = 0000
-200003A2 (761642) = 0000
-200003A4 (761644) = 0000
-200003A6 (761646) = 0000
-200003A8 (761650) = 0000
-200003AA (761652) = 0000
-200003AC (761654) = 0000
-200003AE (761656) = 0000
-200003B0 (761660) = 0000
-200003B2 (761662) = 0000
-200003B4 (761664) = 0000
-200003B6 (761666) = 0000
-200003B8 (761670) = 0000
-200003BA (761672) = 0000
-200003BC (761674) = 0000
-200003BE (761676) = 0000
-20001F40 (777500) = 0020 IPCR
Scan of Qbus Memory Space
-30040000 to 3005FFFF (01000000 to 01377777)
>>>SHOW PSE
Disabled
Конфигурация железа нам понятна
Надо что-то сделать с ошибками
для начала посмотрим какие вообще тесты есть:
>>>show test
Test
#   Address   Name               Parameters
___________________________________________________________________________
    20051600  SCB
    20054C3C  De_executive
30  20069924  Memory_Init_Bitmap *** mark_Hard_SBEs ******
31  20069F1C  Memory_Setup_CSRs  *********
32  2005C530  NMC_registers      **********
33  2005C70C  NMC_powerup        **
34  2005DAC0  SSC_ROM            ***
35  2005EF78  B_Cache_diag_mode  bypass_test_mask *********
37  20060978  Cache_w_Memory     bypass_test_mask *********
3F  2006B954  Mem_FDM_Addr_shorts *** cont_on_err ******
40  2006A9DC  Memory_count_pages First_board Last_bd Soft_errs_allowed *******
41  200680D4  Board_Reset        *
42  20060C68  Chk_for_Interrupts **********
46  200604AC  P_Cache_diag_mode  bypass_test_mask *********
47  2006A0EC  Memory_Refresh     start_a end incr cont_on_err time_seconds *****
48  2006A410  Memory_Addr_shorts start_add end_add * cont_on_err pat2 pat3 ****
49  2006B2E0  Memory_FDM         *** cont_on_err ******
4A  20069624  Memory_ECC_SBEs    start_add end_add add_incr cont_on_err ******
4B  200687F4  Memory_Byte_Errors start_add end_add add_incr cont_on_err ******
4C  20068F88  Memory_ECC_Logic   start_add end_add add_incr cont_on_err ******
4D  200683D0  Memory_Address     start_add end_add add_incr cont_on_err ******
4E  20068570  Memory_Byte        start_add end_add add_incr cont_on_err ******
4F  2006ABFC  Memory_Data        start_add end_add add_incr cont_on_err ******
51  20057424  FPA                **********
52  20057918  SSC_Prog_timers    which_timer wait_time_us ***
53  20057C00  SSC_TOY_Clock      repeat_test_250ms_ea Tolerance ***
54  20057000  Virtual_Mode       ********
55  20058254  Interval_Timer     *****
56  20064464  SHAC_LPBCK         From_bus To_bus passes *******
58  2006510C  SHAC_RESET         dssi_bus port_number time_secs not_pres *
59  20061B60  SGEC_LPBCK_ASSIST  time_secs **
5C  200620F8  SHAC               SHAC_number *********
5F  20060DA0  SGEC               loopback_type no_ram_tests ******
60  2006D928  SSC_Console_SLU    start_BAUD end_BAUD *******
62  20057F04  console_QDSS       mark_not_present selftest_r0 selftest_r1 *****
63  2005808C  QDSS_any           input_csr selftest_r0 selftest_r1 ******
80  2005C7A8  CQBIC_memory       bypass_test_mask *********
81  20058AB4  Qbus_MSCP          IP_csr ******
82  20058C94  Qbus_DELQA         device_num_addr ****
83  20059C44  QZA_Intlpbck1      controller_number ********
84  2005B304  QZA_Intlpbck2      controller_number *********
85  20058E84  QZA_memory         incr test_pattern controller_number *******
86  2005932C  QZA_DMA            Controller_number main_mem_buf ********
90  2005787C  CQBIC_registers    *
91  200577F8  CQBIC_powerup      **
99  2005D034  Flush_Ena_Caches   dis_flush_VIC dis_flush_BC dis_flush_PC
9A  20063398  INTERACTION        pass_count disable_device *******
9B  20068230  Init_memory        **
9C  20065704  List_CPU_registers *
9D  2006C280  Utility            Flags *********
9E  20058424  List_diagnostics   script_number *
9F  200675B4  Create_A0_Script   **********
C1  20056C70  SSC_RAM_Data       *
C2  20056E60  SSC_RAM_Data_Addr  *
C5  20057DD0  SSC_registers      *
D0  20060058  V_Cache_diag_mode  bypass_test_mask *********
D2  2005D278  O_Bit_diag_mode    bypass_test_mask *********
DA  20060784  PB_Flush_Cache     **********
DB  2005DC38  Speed              print_speed *********
DC  2006C208  NO_Memory_present  ********
DD  2005E4C4  B_Cache_Data_debug start_add end_add add_incr *******
DE  2005E04C  B_Cache_Tag_Debug  start_add end_add add_incr *******
DF  2005D690  O_BIT_DEBUG        start_add end_add add_incr seg_incr ******
Scripts
#   Description
A0  User defined scripts
A1  Powerup tests, Functional Verify, continue on error, numeric countdown
A3  Functional Verify, stop on error, test # announcements
A4  Loop on A3 Functional Verify
A6  Memory tests, mark only multiple bit errors
A7  Memory tests
A8  Memory acceptance tests, mark single and multi-bit errors, call A7
A9  Memory tests, stop on error
B5  Extended tests, then loop
Load & start system exerciser
100 Customer mode, 2 passes
101 CSSE mode, 2 passes
102 CSSE mode, continous until ^C
103 Manuf mode, continous until ^C
104 Manuf TINA mode, continous until ^C
105 Manuf mode, 2 passes
106 CSSE mode, select tests, continous until ^C
107 Manuf mode, select tests, continous until ^C
просто огромный список!
но мы сложностей не боимся и прогоняем все тесты и.... ошибка памяти уходит
/на самом деле надо было начать с команды UNJAM и INITIALIZE , но об этом я прочитал позднее/
>>>SHOW MEMORY /fill/llif/full
Memory board 0: 00000000 to 07FFFFFF, 128MB, 262144 good pages, 0 bad pages
Total of 128MB, 262144 good pages, 0 bad pages, 160 reserved pages
Memory Bitmap
-07FEC000 to 07FF3FFF, 64 pages
Console Scratch Area
-07FF4000 to 07FF7FFF, 32 pages
Qbus Map
-07FF8000 to 07FFFFFF, 64 pages
Scan of Bad Pages
посмотрим с какого диска грузился этот сервер
>>>show boot
DIA5:
жаль, но этот винт мертв
настроим загрузку с винта с операционной системой из поставки
>>>SET BOOT dia0
>>>show boot
DIA0:
Ответов(1 - 1)
сообщение 24.5.2015, 21:20
На самом деле с ошибкой все оказалось сложнее - те после RESETa она появилась снова
mesr=00085000
Пробуем инициализацию
>>>init
>>>unjam
>>>test a7
9D..49..4F..4E..4D..4C..4B..4A..3F..3F..48..48..48..48..48..48..
48..48..48..48..48..47..40..
Vec=0000  Prev_Errs=0001   P1=00000001   P2=00000001   P3=00000001  P4=00000000
mesr=00085000
однако.....
тогда начнем с самого подозрительного теста
что же реально он делает пока установить не получилось
в документации лишь упоминания о возможности передать этому тесту какие-либо параметры
>>>test 30
>>>test a6 1
Vec=0000  Prev_Errs=0001   P1=00000001   P2=00000001   P3=7FFFFFFF  P4=00000000
mesr=00085000
>>>test 30
>>>test a6
9D..30..49..4F..4E..4B..4A..4C..3F..3F..48..48..48..48..48..48..
48..48..48..4D..47..40..40..80..
>>>test a7
>>>test a1
22..21..20..19..18..17..16..15..14..13..12..11..10..09..08..07..
06..05..04..03..
помогло!
итого память
>>>sh mem /full
Memory Bitmap
Qbus Map
Scan of Bad Pages
дальнейшие раскопки показали что появляются ошибки на тестах
>>>test 37
? Test_Subtest_37_07  Loop_Subtest=00  Err_Type=FF   DE_Cache_w_Memory.lis
Vec=0000  Prev_Errs=0006   P1=00000000   P2=00000000   P3=00000000  P4=00488020
P5=00000021  P6=00000000   P7=00000000   P8=00000000   P9=FFFFF800 P10=00000000
r0=00000002  r1=00000000   r2=201405E6   r3=00000037   r4=20060978  r5=20090000
r6=2005D6A6  r7=00000000   r8=FFFFFFF6   r9=20140758  r10=13000002 r11=2014044B
bcetsts=0000 bcedsts=0000 cefsts=00000200 nests=00 mmcdsr=0110EE00
mesr=00085000
>>>test 47 8
? Test_Subtest_48_11  Loop_Subtest=00  Err_Type=FF   DE_Memory_Addr_shorts.lis
Vec=0054  Prev_Errs=0008   P1=00000000   P2=08000000   P3=00000301  P4=00001000
P5=AAAAAAAA  P6=00000000   P7=09D1D000   P8=80085400   P9=00000000 P10=2006A88D
r0=00000002  r1=010080C0   r2=21018044   r3=00001BFA   r4=02000000  r5=AAAAAAAA
r6=AAAAAAAA  r7=00000000   r8=00000000   r9=20140758  r10=00000000 r11=2014044B
EPC=2006A85D Lis_Add=044D dser=0000 cesr=00000000 icsr=01 pcsts=F800
pcctl=FC13 cctl=00000021 bcetsts=0000 bcedsts=0000 cefsts=00000200 nests=00
mmcdsr=09D1D000 mesr=80085400 mear=10402037__Add=010080DC Mem_SBE=D45
которые уходят после прогона тестов
UPD 2016
после заказа новых модулей памяти ошибки ушли, видимо родной модуль был неисправен
Текстовая версия Сейчас: 13.11.2026, 11:08
