18.10.2015, 18:20
System Restrictions
Primary graphics head must be installed in PCI Bus 0. Support of Maximum 16 SCSI devices per Bus requires: o Minimum OpenVMS v7.1 o WindowsNT o Minimum Tru64 UNIX v5.0 o SCSI Controller counts as 1 device Support of Maximum 8 SCSI devices per Bus requires: o OpenVMS o WindowsNT o Tru64 UNIX o SCSI Controller counts as 1 device Note: No UltraSCSI support for internally embedded UltraSCSI drives prior to 54-25436-01 backplane at revision A01. Chassis (30-47994-01) revision with this backplane is minimum revision F02(chassis revision label located on bottom of system).
18.10.2015, 21:36
Digital AlphaStation 400 Series
Upgrade Information Order Number: EK–AVAXP–UP. A01
Digital_AlphaStation_400_Upgrade_Information_EK_AVAXP_UP_A01_avaxpupa.pdf ( 1.93 мегабайт )
Кол-во скачиваний: 1465Upgrade Information Order Number: EK–ALPH4–UP. A01
Digital_AlphaServer_400_Upgrade_Information_EK_ALPH4_UP_A01_ek_alph4_up_a01.pdf ( 42.11 килобайт )
Кол-во скачиваний: 1516CPU Module Information Order Number: EK-PCDSA-CI. A01
Digital_AlphaStation_400_CPU_Module_Information_EK_PCDSA_CI_A01_pcdsacia.pdf ( 254.87 килобайт )
Кол-во скачиваний: 1531User Information Order Number: EK-PCSVA-UI. A01
Digital_AlphaServer_400_Series_User_Information_EK_PCSVA_UI_A01_ek_pcsva_ui_a01.pdf ( 1.13 мегабайт )
Кол-во скачиваний: 4338User Information Order Number: EK-PCDSA-UI. B01
Digital_AlphaStation_400_User_Information_EK_PCDSA_UI_B01_ek_pcdsa_ui_b01.pdf ( 904.03 килобайт )
Кол-во скачиваний: 2338Digital AlphaStation 200/400 Series Technical Information Part Number: EK-PCDSA-TI. A01
Digital_AlphaStation_200_400_Technical_Information_EK_PCDSA_TI_A01_ek_pcdsa_ti.pdf ( 868.86 килобайт )
Кол-во скачиваний: 1973Firmware Update Procedures
DIGITAL_AlphaStation_200_400_Firmware_Update_Procedures_alpha200_v70_fw_relnote.pdf ( 69.09 килобайт )
Кол-во скачиваний: 2693ALPHASERVER™ 400 SERIES INSTALLATION INFORMATION
ALPHASERVER_400_SERIES_INSTALLATION_INFORMATION_ek_pcsva_ii_a01.pdf ( 398.55 килобайт )
Кол-во скачиваний: 1869-------------------- Живы будем - Не помрем !
18.10.2015, 21:44
Alpha SRM Console for Alpha Microprocessor Motherboards
User's Guide Order Number: EC–QK8DF–TE Обзор рабочих станций Workstation Models
Digital_Workstation_Models_Digital_Memorys.pdf ( 269.84 килобайт )
Кол-во скачиваний: 1829Прикрепленные файлы
Alpha_SRM_Console_for_Alpha_Microprocessor_Motherboards_Users_Guide_EC_QK8DF_TE_srmcons.pdf ( 451.7 килобайт )
Кол-во скачиваний: 12366-------------------- Живы будем - Не помрем !
18.10.2015, 22:00
| Текстовая версия | Сейчас: 12.11.2026, 2:17 |
