> Crowdfunding: assembly Cartridges Carnivore 2, display current status
сообщение 12.5.2020, 13:42
Sufficient number of orders collected
and ordering components for the assembly of cartridges
Most components are currently in delivery.
However they are already starting to arrive- currently delivered:
1. cartridge cases
2. M93C46
2 Страницы V < 1 2
Тема закрытаОткрыть новую тему
Ответов(20 - 34)
сообщение 30.6.2020, 11:51
Сообщение #21
To vote, you must enter the forum with your credentials
Unfortunately, the forum interface is Russian, and I will make tips so that no one gets lost.
To enter, click here, this is Login
then enter your login and password in these fields
it should look like
then press the button below
after entering, go to the voting page and vote
for example, select the sticker option
and click the button below
if you have any difficulties - ask questions by email
сообщение 2.7.2020, 23:23
Сообщение #22
to summarize
all cases are prepared - holes are cut out
boards assembled 51pcs
47pcs workers, the rest will bring later
40 pinned by founders
losses
- 3 cases ruined when cutting
- 12pcs dead CY62167DV30
- 14pcs dead M29W640GB
- 3pcs dead FPGAs EP2C5Q208C8
if it weren't for dead chips, it would be much easier
the winner picture is clear - №8 - this is the work of the Perm artist (bear outline) and my wife's collages
photo is used as background - Aurora Over The Trees Of Churchill Manitoba by David Marx
use agreed with the author and the sticker itself
I highly recommend visiting the site of the author of the photo and his instagram
https://www.davidmarx.com/
https://www.instagram.com/davidmarxphoto/
Now I'm waiting from Wierzbowsky a new version of the firmware is expected - in order to fill it already
accordingly, I'll have to repeat the tests, but I think that next week we'll start sending out cartridges.
sending out will be carried out in the strict manner of receiving payment.
if you have not previously paid for delivery - get ready to pay promptly!
сообщение 5.7.2020, 13:54
Сообщение #23
a little bit about cartridge assembly
сообщение 5.7.2020, 13:55
Сообщение #24
Soldering cartridge carnivore2
This is the first experiment to record video. the focus of the camera does not match the focus of the microscope eyepieces very well.
сообщение 11.7.2020, 17:12
Сообщение #25
tentatively next week shipping begins
after sending you will receive a package tracking number
important!
I ask you to track the parcel regularly and if it gets stuck somewhere for more than 7 days, inform me, I will make an application for the search for the parcel.
This is a kind of hack of the postal service - after the application for the search, the parcels are immediately accelerated.
сообщение 17.7.2020, 12:01
Сообщение #26
Hello!
finally got the perfect sticker!
initially we tried to make a paper sticker with lamination, however, tests of the sticker showed that the paper base is still sensitive to moisture and the result does not correspond to our desire to make quality.
Then they made a sticker on OraJet plastic film - the result is excellent, but I had to do a lot of iterations with adjusting the dimensions, especially for the CF slot.
All is ready! we start distribution according to the order of receipt of funds!
сообщение 17.7.2020, 19:48
Сообщение #27
Photo of a printed circuit board assembly
i think it would be correct to make some clarifications
1.As you can see, the audio connector has been moved to the other side of the PCB to reduce the complexity of milling the cartridge case.
2. I'm sure you will notice that almost all tantalum capacitors have been replaced with ceramic capacitors.
reasons for replacing two
- in the sound circuit, correctly place non-polar capacitors . 4 pieces of tantalum 4.7μF 25V are replaced with ceramic non-polar SAMSUNG 4μF 50V.
- in power circuits, ceramic capacitors are preferable, since they have a lower internal resistance. in fact, in ordinary life, tantalum capacitors or other oxide capacitors are blocked by ceramic to reduce resistance at high frequency. I have the opportunity to supply ceramic capacitors right away - I develop other boards and order ceramic capacitors in bulk and such a replacement is not expensive.
All these replacements are made with only one goal - to achieve maximum product quality!
сообщение 17.7.2020, 23:28
Сообщение #28
Ready to pack for send
сообщение 24.7.2020, 10:29
Сообщение #29
Hello!
Sending orders in progress, by the end of next week we will finish for sure
Half of the packages have already been sent.
I repeat:
Reminder for everyone - important links
Carnivore2 User Guide English version
Инструкция по эксплуатации Carnivore2 Русская версия
сообщение 27.7.2020, 11:29
Сообщение #30
Status of July 25, 2020
сообщение 30.7.2020, 12:29
Сообщение #31
I think you will be interested in how the cartridges are packed
packaging technology:
first it is packed in a branded bag
then some bubble wrap + strong box
to understand the size of the package, I put another cartridge on top
here is another cartridge next to it, too, to understand the thickness of the package
Carnivore2 cartridge weighing only 80 grams
with packaging, it weighs 170 grams - those 90 grams of packaging material
then it goes into the mail package
сообщение 9.8.2020, 14:00
Сообщение #32
Status of August 9, 2020
сообщение 26.8.2020, 1:29
Сообщение #33
Status of August 26, 2020
сообщение 31.8.2020, 22:11
Сообщение #34
Status of August 31, 2020
сообщение 13.1.2023, 18:56
Сообщение #35
Orders and Shipping
We accept paypal payment
The cost of a Carnivore2 by MAXIOL cartridge is $110 if paid as a friend.
when paid as a product $120
(cost not includes delivery)
To order, write a letter to radioshop@maxiol.com
The letter must indicate
- cartridge body number - the first message contains numbering.
- number of cartridges Carnivore2 by MAXIOL
- full mailing address for shipment
will come in response
- estimated shipping date
- payment method
reply is sent within 1 day, if you have not received a reply - check your spam folder.
If you have any questions, you can ask them by writing us a letter to radioshop@maxiol.com
2 Страницы V < 1 2
Текстовая версия Сейчас: 23.11.2026, 6:14
